Supla Button 4 direct links
wsosniak
Wed Feb 20, 2019 1:09 pm
i can confirm the same like PuteR -> the newest ver for 6 links works without self executing.
i did :
- i loaded your newest bin (6 links 60 chars) into my ESP12
- i moved ESP12 in the place where i had problem with self execution of links
- i cant see any problem now
thx a lot !!
elmaya
Wed Feb 20, 2019 4:17 pm
Thanks for the help.
updated on page 1.
If you like my work please support it by buying me a cup of coffee :)
www.paypal.me/elmayasevilla
PuteR
Wed Feb 20, 2019 6:48 pm
We thank you :D
PuteR
Tue Apr 02, 2019 6:43 am
elamya What is the mistake from
<html>
<head><title>400 Bad Request</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<hr><center>nginx/1.15.8</center>
</body>
</html>
in D_Link_Config_5_s_x6, everything worked fine, and there was a problem yesterday. Link does not perform when the module I have on the wall, unless I hold the button longer it will be done.
After connecting to a computer, a serial monitor throws out the above error. After re-uploading the software on the computer, it works ok, as I will give the wall the same again.
I would add that I did not have any pull ups made, but until now everything worked correctly, but is pull up required ??
elmaya
Tue Apr 02, 2019 9:00 am
<html>
<body>
</body>
</html>
Check power supply
PuteR
Wed Apr 03, 2019 8:38 pm
I actually changed the power source and the problem stopped 😀. Thanks a lot
Post Reply
