Page 1 of 8
Supla Button 4 direct links
Posted: Wed Dec 26, 2018 11:11 pm
by elmaya
modemcu to send 4 direct links with 4 buttons
button on D5 = link 1
button on D6 = link 2
button on D1 = link 3
button on D2 = link 4
D3 = configuration
#include <FS.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <Ticker.h>      //for LED status
Ticker ticker;
const char* host = "svr.supla.org";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char Supla_server[20];
char D_Link_1[40];
char D_Link_2[40];
char D_Link_3[40];
char D_Link_4[40];
byte mac[6];
String url = "/direct/xx/xxxxxxxxx/read";
//flag for saving data
bool initialConfig = false;
#define onboard_led D4
#define TRIGGER_PIN D3    // wifi config
#define Link_1_PIN D5     // triger Link 1
#define Link_2_PIN D6     // triger Link 2
#define Link_3_PIN D1     // triger Link 3
#define Link_4_PIN D2     // triger Link 4
int timeout           = 120; // seconds to run for
void tick()
  //toggle state
  int state = digitalRead(onboard_led);  // get the current state of D4 pin
  digitalWrite(onboard_led, !state);     // set pin to the opposite state
//callback notifying us of the need to save config
void saveConfigCallback () {
  shouldSaveConfig = true;
  ticker.attach(0.2, tick);
// The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 20);
  WiFiManagerParameter custom_D_Link_1("Link 1", "D_Link_1", D_Link_1, 40);
  WiFiManagerParameter custom_D_Link_2("Link 2", "D_Link_2", D_Link_2, 40);
  WiFiManagerParameter custom_D_Link_3("Link 3", "D_Link_3", D_Link_3, 40);
  WiFiManagerParameter custom_D_Link_4("Link 4", "D_Link_4", D_Link_4, 40);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  //add all your parameters here
  wifiManager.addParameter(&custom_D_Link_1);
  wifiManager.addParameter(&custom_D_Link_2);
  wifiManager.addParameter(&custom_D_Link_3);
  wifiManager.addParameter(&custom_D_Link_4);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wifiManager.setMinimumSignalQuality();
  // set configportal timeout
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("DirectLink4")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      delay(5000);
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
    //read updated parameters
    strcpy(D_Link_1, custom_D_Link_1.getValue());
    strcpy(D_Link_2, custom_D_Link_2.getValue());
    strcpy(D_Link_3, custom_D_Link_3.getValue());
    strcpy(D_Link_4, custom_D_Link_4.getValue());
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  Serial.begin(115200);
  //sensors.begin();
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  pinMode(Link_1_PIN, INPUT_PULLUP);
  pinMode(Link_2_PIN, INPUT_PULLUP);
  pinMode(Link_3_PIN, INPUT_PULLUP);
  pinMode(Link_4_PIN, INPUT_PULLUP);
  pinMode(onboard_led, OUTPUT);
  // start ticker with 0.6
  ticker.attach(0.6, tick);
  if (WiFi.SSID()==""){
    initialConfig = true;
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        // Allocate a buffer to store contents of the file.
        DynamicJsonBuffer jsonBuffer;
        Serial.println(jsonBuffer.size());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(D_Link_1, json["D_Link_1"]);
          strcpy(D_Link_2, json["D_Link_2"]);
          strcpy(D_Link_3, json["D_Link_3"]);
          strcpy(D_Link_4, json["D_Link_4"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  host = Supla_server;
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
void loop() {
 if ( digitalRead(Link_1_PIN) == LOW )  {
    url = D_Link_1;
    direct_Link() ;
   if ( digitalRead(Link_2_PIN) == LOW)  {
    url = D_Link_2;
    direct_Link() ;
  if ( digitalRead(Link_3_PIN) == LOW )  {
    url = D_Link_3;
    direct_Link() ;
   if ( digitalRead(Link_4_PIN) == LOW)  {
    url = D_Link_4;
    direct_Link() ;
    // is configuration portal requested?
  if ( digitalRead(TRIGGER_PIN) == LOW|| (initialConfig))  {
    ondemandwifiCallback () ;
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    json["D_Link_1"] = D_Link_1;
    json["D_Link_2"] = D_Link_2;
    json["D_Link_3"] = D_Link_3;
    json["D_Link_4"] = D_Link_4;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    //end save
    ticker.detach();
    digitalWrite(onboard_led, HIGH);
  if (WiFi.status() != WL_CONNECTED)
    WiFi_up();
void WiFi_up()
  WiFi.begin();
  for (int x = 60; x > 0; x--)
    if (WiFi.status() == WL_CONNECTED)
      break;
    else
      Serial.print(".");
      delay(500);
    ticker.detach();
    Serial.println("");
    Serial.println("Connected");
    Serial.println("Adres IP: ");
    Serial.print(WiFi.localIP());
    Serial.print(" / ");
    Serial.print(WiFi.subnetMask());
    long rssi = WiFi.RSSI();
    Serial.print("(RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
  else
    Serial.println("");
    Serial.println("connection failed");
void direct_Link() {
  // Use WiFiClientSecure class to create TLS connection
  WiFiClientSecure client;
  Serial.print("connecting to ");
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    return;
  Serial.print("requesting URL: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: BuildFailureDetectorESP8266\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("request sent");
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("headers received");
      break;
  String line = client.readStringUntil('}');
  line = line + "}";
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println(line);
  Serial.println("closing connection");
D_Link_wifiManager_x4.nodemcu.rar
compiled Firmware
(265.83 KiB) Downloaded 160 times
EDIT: added 100 milliseconds debounce to improve stability
config = link1 5 seconds
Initial parameters for "ESP Falsh Download Tool":
CreystalFreq 26M
SPI SPEED 40 MHz
SPI MODE DOUT
BAUDRATE 11520
FLASH SIZE 32Mbit (4MByte)
D_Link_Config_5_s_x4.rar
new firmware
(385.58 KiB) Downloaded 87 times
Re: Supla Button 4 direct links
Posted: Thu Dec 27, 2018 12:21 am
by dawidd
Super!
Posted: Thu Dec 27, 2018 6:51 pm
by elmaya
for 6 direct links
with 6 buttons, one for each link
status led D4
Slow flashing 0.8 s " No wifi connection
Fast flashing 0.2 s " config
two flashes after pressing a button = send link ok
pinout:
D1 = Link 1
D2 = Link 2
D3 = Link 3
D4 = Status Led
D5 = Link 4
D6 = Link 5
D7 = Link 6
to enter configuration hold down (Link 1 = D1) 5 seconds
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <WiFiManager.h>     //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h>     //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
Ticker ticker;
char D_Link_1[40];
char D_Link_2[40];
char D_Link_3[40];
char D_Link_4[40];
char D_Link_5[40];
char D_Link_6[40];
byte mac[6];
#define Link_1_PIN D1     // triger Link 1
#define Link_2_PIN D2     // triger Link 2
#define Link_3_PIN D3     // triger Link 3
#define Link_4_PIN D5     // triger Link 4
#define Link_5_PIN D6     // triger Link 5
#define Link_6_PIN D7     // triger Link 6
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 5000;               // config delay 5 seconds  ------------ opóźnienie konfiguracji 5 sekund
void tick()
  //toggle state
  WiFiManagerParameter custom_D_Link_5("Link 5", "D_Link_5", D_Link_5, 40);
  WiFiManagerParameter custom_D_Link_6("Link 6", "D_Link_6", D_Link_6, 40);
  wifiManager.addParameter(&custom_D_Link_5);
  wifiManager.addParameter(&custom_D_Link_6);
  wifiManager.setMinimumSignalQuality(10);
    if (!wifiManager.startConfigPortal("DirectLink6")) {
      delay(3000);
      ESP.restart();
      delay(5000);
    strcpy(D_Link_5, custom_D_Link_5.getValue());
    strcpy(D_Link_6, custom_D_Link_6.getValue());
  pinMode(Link_5_PIN, INPUT_PULLUP);
  pinMode(Link_6_PIN, INPUT_PULLUP);
  ticker.attach(0.8, tick);
      if (configFile) {
          strcpy(D_Link_5, json["D_Link_5"]);
          strcpy(D_Link_6, json["D_Link_6"]);
        } else {
  } else {
void loop() {
    url = D_Link_1;
    direct_Link() ;
    url = D_Link_2;
    direct_Link() ;
    url = D_Link_3;
    direct_Link() ;
    url = D_Link_4;
    direct_Link() ;
  if ( digitalRead(Link_5_PIN) == LOW )  {
    url = D_Link_5;
    direct_Link() ;
   if ( digitalRead(Link_6_PIN) == LOW)  {
    url = D_Link_6;
    direct_Link() ;
  if  (initialConfig)  {
   int C_W_read = digitalRead(Link_1_PIN);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       Serial.println("Triger sate changed");
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
   last_C_W_state = C_W_read;
    json["D_Link_5"] = D_Link_5;
    json["D_Link_6"] = D_Link_6;
    if (!configFile) {
    configFile.close();
    ticker.detach();
    WiFi_up();
void WiFi_up()
  WiFi.begin();
      break;
    else
      Serial.print(".");
      delay(500);
    ticker.detach();
    Serial.println("");
    Serial.print(rssi);
  else
    Serial.println("");
    return;
    if (line == "\r") {
      break;
  line = line + "}";
  if (line.indexOf("true") >0) {
    digitalWrite(onboard_led, LOW);
    delay(200);
    delay(200);
    delay(200);
    Serial.println("successfull!");
  } else {
    Serial.println("failed");
D_Link_Config_5_s_x6.rar
compiled firmware
(385.76 KiB) Downloaded 77 times
Posted: Thu Dec 27, 2018 8:59 pm
by dawidd
Podziwiam kolegę :) Moze gdybyś to wrzucał tez na Polskie forum było, by większe zainteresowanie bo robisz naprawdę super przydatne softy
Posted: Tue Jan 08, 2019 11:31 pm
by elmaya
Supla Button 8 Direct Links
for 8 direct links using "A0" input
status led D4
Slow flashing 0.8 s " connecting wifi "
Fast flashing 0.2 s "configuration " -WiFiManager on-
led off "connected and ready"
two flashes after pressing a button = link sent successfully
to enter configuration hold down ( D3) 5 seconds
extern "C"
#include "user_interface.h"
Ticker ticker;
const char* host = "org";
char D_Link_1[40];
char D_Link_2[40];
char D_Link_3[40];
char D_Link_4[40];
char D_Link_5[40];
char D_Link_6[40];
char D_Link_7[40];
char D_Link_8[40];
byte mac[6];
String url = "/direct";
bool shouldSendLink = false;
#define Config_PIN D3     // triger config
int buttonValue; //Stores analog value when button is pressed
void tick(){
  //toggle state
  WiFiManagerParameter custom_D_Link_7("Link 7", "D_Link_7", D_Link_8, 40);
  WiFiManagerParameter custom_D_Link_8("Link 8", "D_Link_8", D_Link_7, 40);
  wifiManager.addParameter(&custom_D_Link_7);
  wifiManager.addParameter(&custom_D_Link_8);
    if (!wifiManager.startConfigPortal("DirectLink8")) {
      delay(3000);
      ESP.restart();
      delay(5000);
    strcpy(D_Link_7, custom_D_Link_7.getValue());
    strcpy(D_Link_8, custom_D_Link_8.getValue());
  wifi_set_sleep_type(NONE_SLEEP_T);
  pinMode(Config_PIN, INPUT);
      if (configFile) {
          strcpy(D_Link_7, json["D_Link_7"]);
          strcpy(D_Link_8, json["D_Link_8"]);
        } else {
  } else {
void loop() {
    analog_switch();   // ------------------------
   int C_W_read = digitalRead(Config_PIN);{
    json["D_Link_7"] = D_Link_7;
    json["D_Link_8"] = D_Link_8;
    if (!configFile) {
    configFile.close();
    ticker.detach();
    ESP.restart();
      delay(5000);
    WiFi_up();
void WiFi_up()
  WiFi.begin();
      break;
    else
      Serial.print(".");
      delay(500);
    ticker.detach();
    Serial.println("");
    Serial.print(rssi);
  else
    Serial.println("");
    return;
               "User-Agent: ESP8266\r\n" +
    if (line == "\r") {
      break;
  line = line + "}";
    delay(200);
    delay(200);
    delay(200);
  } else {
 void analog_switch(){
  buttonValue = analogRead(A0); //Read analog value from A0 pin
  //For no button:
  if (buttonValue<=50){
  delay (100);
  return;
  //For 1st button:
  else if (buttonValue>=113 && buttonValue<=153){
    Serial.println("read: 1 ");
    url = D_Link_1;
    direct_Link() ;
    return;
  //For 2nd button:
  else if (buttonValue>=256 && buttonValue<=296){
    Serial.println("read: 2 ");
    url = D_Link_2;
    direct_Link() ;
    return;
  //For 3rd button:
  else if (buttonValue>=389  && buttonValue<=429){
    Serial.println("read: 3 ");
    url = D_Link_3;
    direct_Link() ;
    return;
  //For 4th button:
  else if (buttonValue>=525  && buttonValue<=565){
    Serial.println("read: 4 ");
    url = D_Link_4;
    direct_Link() ;
    return;
  //For 5rd button:
  else if (buttonValue>=654  && buttonValue<=694){
    Serial.println("read: 5 ");
    url = D_Link_5;
    direct_Link() ;
    return;
  //For 6th button:
  else if (buttonValue>=796  && buttonValue<=836){
    Serial.println("read: 6 ");
    url = D_Link_6;
    direct_Link() ;
    return;
  //For 7rd button:
  else if (buttonValue>=930  && buttonValue<=970){
    Serial.println("read: 7 ");
    url = D_Link_7;
    direct_Link() ;
    return;
  //For 8th button:
  else if (buttonValue>=1000 ){
    Serial.println("read: 8 ");
    url = D_Link_8;
    direct_Link() ;
    return;
D_Link_x8.nodemcu.rar
compiled firmware
(266.37 KiB) Downloaded 87 times
Posted: Sun Jan 13, 2019 6:29 pm
by bulek68
Dobrze to łapie że przy użyciu tego softu i linków bezpośrednich mogę np przyciskami na ścianie sterować grupą rolet?
Posted: Sun Jan 13, 2019 7:01 pm
by wojtas567
nie tylko roletami
Posted: Sun Jan 13, 2019 8:44 pm
by Robert Błaszczak
Dokładnie tak. Pod przycisk możesz sobie podłożyć dowolny link wygenerowany w Supla Cloud. Po naciśnięciu zostanie wykonana zadana w linku akcja.
Testuje to rozwiązanie na Wemos D1 mini Pro i u mnie bardzo stabilnie działa wersja D_Link_x6 (6 przycisków).
Posted: Sun Jan 13, 2019 9:56 pm
by bulek68
Thanks for your answer. I'll try to send it to YUNSHAN module and do some tests. I'll see What happen. I've been waiting for this solution. I'll try it to control shuttets. In the future I want to use it to control the group of shutters and connect it with the SOMFY remote control of the gate.
( Dzięki za odpowiedź, spróbuję to wrzucić na Yunshan potestuje i zobaczymy co z tego wyjdzie.
Na takie rozwiązanie czekałem.
Raz ze zastosuje to przy drzwiach wejściowych a dwa że wykorzystam aby móc pilotem od napędu bramy somfy otwierać i zamykać wszytkie rolety w domu.)
Posted: Sun Jan 13, 2019 10:48 pm
by pzygmunt
English please
