It's Pull Up so it connects to ground.
thermostat with Oled display
This is not about a specific soft but generally about the possibility of using the GPIO10 port on the WeMos D1 mini board.
Change two lines.
if (tr> = trt) { to if (tr <= trt) {
if (tr <= trs) { to if (tr> = trs) {
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <math.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h> // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <OneWire.h>
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
//#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
//SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled ---
#include "SH1106Wire.h" //----- 1.3 Oled ---
SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled ---
#define ONE_WIRE_BUS 13 //D7 --------------------oneWire Dallas Temperature --------requires 4k7 resistance
int relay_1 = 15; //D8 ------------------- thermometer Auto/Man Led ----- active high
int relay_2 = 12; //D6 ------------------- relay output ----- active high
int relay_3 = 120; // --------------------- thermostat temperature setting +/- 0.5º no Gpio -----
int relay_4 = 122; // --------------------- no Gpio -----
int button_1 = 14; //D5 ------------------- automatic / manual thermostat change ---- WiFi config 10 seconds --------
int button_2 = 16; //D0 ------------------- manual on / off ----requires 10k pullup resistance due to lack of internal
int button_3 = 5; //D1 ------------------- thermostat temperature setting - 0.5º----
int button_4 = 4; //D2 ------------------- thermostat temperature setting + 0.5º----
#define BTN_COUNT 4
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress tempDeviceAddress;
int resolution = 12;
bool pr_wifi = true;
bool start = true;
bool eep = LOW;
int epr = 0;
int s;
int Term_Temp ;
int Term_Hist ;
double tr = -275;
double trs ;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long tr_milis;
unsigned long ds_milis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds ---------- opóźnienie konfiguracji 10 sekund
bool tikOn = false;
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
char term_temp[5];
char term_hist[5];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
bool dimm = false;
unsigned long dimm_milis ;
int timeout = 180; // seconds to run the wifi config
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00,0x00,0x00,0x00,0xC0,0x1F,0x00,0x00,0xE0,0x7F,0x00,0x00,
0xF0,0x70,0x00,0x00,0x30,0xE0,0x00,0x00,0x38,0xC0,0x00,0x00,
0x18,0xC0,0x01,0x00,0x18,0xC0,0x01,0x00,0x38,0xC0,0x00,0x00,
0x38,0xE0,0x01,0x00,0x70,0xF0,0x07,0x00,0xE0,0x7F,0x0E,0x00,
0xC0,0x3F,0x38,0x00,0x00,0x1F,0xE0,0x0F,0x00,0x18,0xC0,0x1F,
0x00,0x18,0xC0,0x30,0x00,0x18,0xC0,0x30,0x00,0x30,0xC0,0x30,
0x00,0x30,0x80,0x1F,0x00,0x30,0xC0,0x0F,0x00,0x20,0x60,0x00,
0x00,0x60,0x20,0x00,0x00,0x60,0x30,0x00,0x00,0x40,0x18,0x00,
0x00,0xC0,0x0D,0x00,0x00,0xC0,0x07,0x00,0x00,0x60,0x04,0x00,
0x00,0x20,0x0C,0x00,0x00,0x20,0x0C,0x00,0x00,0x60,0x06,0x00,
0x00,0xC0,0x03,0x00,0x00,0x00,0x00,0x00
const uint8_t logo16_wifi_bmp[] PROGMEM = //logo wifi 16
0x00,0x00,0x00,0x00,0xE0,0x07,0x38,0x1C,0xC4,0x23,0x72,0x4E,
0x08,0x10,0xE4,0x27,0x10,0x0C,0x90,0x09,0x40,0x02,0x60,0x06,
0x40,0x02,0x80,0x01,0x00,0x00,0x00,0x00
const uint8_t logo16_supla_bmp[] PROGMEM = //logo supla 16
0x30,0x00,0x7C,0x00,0xC4,0x00,0x86,0x00,0x84,0x00,0xDC,0x03,
0x78,0x36,0x60,0x78,0x40,0x48,0x40,0x38,0x40,0x04,0x80,0x06,
0x80,0x03,0x40,0x02,0xC0,0x03,0x00,0x01
const uint8_t logo_Power_off[] PROGMEM = //Power off
0xe0, 0xff, 0xff, 0xff, 0x03, 0x38, 0xfc, 0xff, 0xff, 0x0f, 0x0c, 0xf0,
0xff, 0xff, 0x3f, 0x06, 0xe0, 0xff, 0xff, 0x3f, 0x02, 0xc0, 0xcf, 0x43,
0x78, 0x03, 0xc0, 0x33, 0x43, 0x78, 0x01, 0xc0, 0x7b, 0x7b, 0xff, 0x01,
0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0xfd, 0x42, 0xf8, 0x01, 0x80, 0x7b,
0x7b, 0xff, 0x03, 0xc0, 0x33, 0x7b, 0xff, 0x02, 0xc0, 0xcf, 0x7b, 0x7f,
0x06, 0xe0, 0xff, 0xff, 0x7f, 0x0c, 0xf0, 0xff, 0xff, 0x3f, 0x18, 0xfc,
0xff, 0xff, 0x1f, 0xf0, 0xff, 0xff, 0xff, 0x07,
const uint8_t logo_Power_on[] PROGMEM = //Power on
0xe0, 0xff, 0xff, 0xff, 0x07, 0x38, 0x00, 0x00, 0x30, 0x0c, 0x0c, 0x00,
0x00, 0x18, 0x18, 0x06, 0x00, 0x00, 0x0c, 0x30, 0x02, 0x0e, 0x00, 0x06,
0x60, 0x03, 0x9f, 0x19, 0x02, 0x40, 0x81, 0xb1, 0x1b, 0x03, 0xc0, 0x81,
0xa0, 0x1a, 0x01, 0x80, 0x81, 0xa0, 0x1e, 0x01, 0x80, 0x81, 0xb1, 0x1c,
0x01, 0xc0, 0x03, 0x9b, 0x18, 0x03, 0x40, 0x02, 0x8e, 0x18, 0x02, 0x60,
0x06, 0x00, 0x00, 0x06, 0x20, 0x0c, 0x00, 0x00, 0x0c, 0x38, 0x38, 0x00,
0x00, 0x18, 0x0c, 0xe0, 0xff, 0xff, 0xff, 0x07,
void saveConfigCallback () { //callback notifying us of the need to save config
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
display.clear();
display.setContrast(100, 241, 64);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "Supla_Termostat");
display.display();
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_up_host("up_host", "xxxx (DHCP name)", up_host, 21,"required");
WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
WiFiManagerParameter custom_term_temp("Termostat", "Temp x 10", term_temp, 5,"required");
WiFiManagerParameter custom_term_hist("Histerisis", "Histerisis x 10", term_hist, 5,"required");
WiFiManager wifiManager;
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_up_host);
wifiManager.addParameter(&custom_update_username);
wifiManager.addParameter(&custom_update_password);
wifiManager.addParameter(&custom_term_temp);
wifiManager.addParameter(&custom_term_hist);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("Supla_Termostat")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
//read updated parameters
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(up_host, custom_up_host.getValue());
strcpy(update_username, custom_update_username.getValue());
strcpy(update_password, custom_update_password.getValue());
strcpy(term_temp, custom_term_temp.getValue());
strcpy(term_hist, custom_term_hist.getValue());
WiFi.softAPdisconnect(true); // close AP
typedef struct { //------------------------------------------- BTN ----------------------------------------------------
int pin;
int relay_pin;
int channel;
char last_val;
int ms;
unsigned long last_time;
bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
void TH_Overlay() {
display.clear();
if (tr > -100){
display.setFont(ArialMT_Plain_24);
display.drawString(64, 20, String(tr, 2) + "ºC");
if (tr < -100){
display.drawString(64, 20, "ERROR");
if ((btn[0].mem) == 1){
display.drawString(64, 48, "Auto Set " + String(trs, 1) + "ºC");
if ((btn[0].mem) == 0){
display.drawString(64, 48, "Manual mode");
if (pr_wifi == false){
display.drawXbm(2, 0, 16, 16, logo16_wifi_bmp);// -------------------------------------------------- oled wifi ok --------
if (s == 17){
display.drawXbm(24, 0, 16, 16, logo16_supla_bmp);// ------------------------------------------------ oled supla ok --------
}else{
display.setTextAlignment(TEXT_ALIGN_LEFT);
display.drawString(24, 0, "E " + String(s));
if ((btn[1].mem) == 0){
display.drawXbm(74, 0, 40, 16, logo_Power_off);// ------------------------------------------------- Relay off --------
if ((btn[1].mem) == 1){
display.drawXbm(74, 0, 40, 16, logo_Power_on);// -------------------------------------------------- Relay on ---------
display.display();
yield();
double t = -275;
switch(channelNumber)
case 3:
yield();
t = sensors.getTempCByIndex(0);
if (t < -55){t = -275;}
break;
case 4:
double trd = (Term_Temp) ;
trd = (trd / 10) ;
t = (trd);
break;
return t;
void itrate_Term() {
if (tr<-55){
if ( digitalRead(btn[1].relay_pin-1) == 1){
(btn[1].mem) = 0 ;
Serial.println(" Relay off temp to low");
SuplaDevice.relayOff(1);
return ;
double trt = (Term_Temp + Term_Hist) ;
trt = (trt / 10);
Serial.print("tr ");
Serial.println(tr);
if (tr <= trt) {
if ( digitalRead(btn[1].relay_pin-1) == 1) {
(btn[1].mem) = 0 ;
Serial.println(" Relay off ");
double trs = (Term_Temp - Term_Hist) ;
trs = (trs / 10) ;
if(tr >= trs) {
if ( digitalRead(btn[1].relay_pin-1) == 0) {
(btn[1].mem) = 1 ;
Serial.println(" Relay on ");
SuplaDevice.relayOn(1, 0);
void iterate_btn() {
char v;
unsigned long now = millis();
for(int a=0;a<4;a++)
if (btn[a].pin > 0) {
v = digitalRead(btn[a].pin-1);
if (v != btn[a].last_val && now - btn[a].last_time ) {
btn[a].last_val = v;
btn[a].last_time = now;
delay(75);
if (v==0)
if (dimm == true){
dimm_milis = millis() + 15000 ;
display.setContrast(100, 230, 60);
dimm = false;
TH_Overlay();
return;
}else{
if ((btn[a].channel)== 2){
Serial.print("Temp - ");
Term_Temp = Term_Temp - 5 ;
Serial.println(Term_Temp);
tr_milis = millis() + 5000 ;
trs = (Term_Temp) ;
trs = (trs / 10) ;
SuplaDevice.channelDoubleValueChanged(4,trs);
TH_Overlay();
return;
if ((btn[a].channel)== 3){
Serial.print("Temp + ");
Term_Temp = Term_Temp + 5 ;
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
return;
if ( (btn[a].mem) == 1 ) {
SuplaDevice.relayOff(btn[a].channel);
Serial.print("BTN Switsh off relay ");
Serial.println(btn[a].relay_pin-1);
btn[a].mem = 0;
return;
} else {
SuplaDevice.relayOn(btn[a].channel, 0);
Serial.print("BTN Switsh on relay ");
btn[a].mem = 1;
return;
void supla_btn_init() {
for(int a=0;a<BTN_COUNT;a++)
pinMode(btn[a].pin-1, INPUT_PULLUP);
btn[a].last_val = digitalRead(btn[a].pin-1);
btn[a].last_time = millis();
pinMode(btn[a].relay_pin-1,OUTPUT);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
return btn[channelNumber].mem;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
btn[channelNumber].mem =val;
case 0:
if ( (btn[channelNumber].mem) == 0 ) {
Serial.print("Manual Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, LOW);
eep_milis = millis() + 2000 ;
Serial.println(" Relay off Manual Mode");
}else {
Serial.print("Auto Mode ");
digitalWrite(btn[channelNumber].relay_pin-1, HIGH);
TH_Overlay();
break;
case 1:
Serial.print("Switsh off relay ");
Serial.println(btn[channelNumber].relay_pin-1);
}else {
Serial.print("Switsh on relay ");
TH_Overlay();
break;
case 2:
}else {
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
break;
return;
void Eeprom_save() { //----------EEPROM write ---------------------- EEprom
if (start){
return;
if ( (btn[0].mem) == 0 ) {
for(int e=0;e<2;e++) {
if ( btn[e].ms > 0 ) {
continue;
} else {
eep = (btn[e].mem); // --- read relay state
if (eep != EEPROM.read(e)){ // --- compare relay state with memorized state
EEPROM.write(e,eep); // --- if different write memory
Serial.print("EEPROM.");
Serial.print(e);
Serial.print(" write.");
Serial.print((eep));
Serial.print(" channel ");
Serial.println((btn[e].channel));
EEPROM.commit();
if ( (btn[0].mem) == 1 ) {
eep = (btn[0].mem); // --- read relay state
if (eep != EEPROM.read(0)){ // --- compare relay state with memorized state
EEPROM.write(0,eep); // --- if different write memory
Serial.print(0);
Serial.println((btn[0].channel));
EEPROM.commit();
void Eepron_read() { //----------EEPROM read ---------------------- EEprom
if ( btn[epr].ms > 0 ) {
return;
} else {
eep = EEPROM.read(epr); // ---read relay state
Serial.print(epr);
Serial.print(" read.");
Serial.println((btn[epr].channel));
if (eep == HIGH){ // --- if 1 send relay on
(btn[epr].mem) = 1 ;
SuplaDevice.relayOn(epr, 0); // --- only one channel on each pass
if (eep == 1) {
bool stat = digitalRead(btn[1].relay_pin-1);
if (stat) SuplaDevice.relayOn(1, 0);
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
void setup() { //------------------------------------------------ Setup ----------------------------------------------
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200);
delay(200);
EEPROM.begin(512);
sensors.begin();
sensors.getAddress(tempDeviceAddress, 0);
sensors.setResolution(tempDeviceAddress, resolution);
sensors.setWaitForConversion(false);
display.init();
display.flipScreenVertically();
display.clear();
display.drawString(33, 40, "SUPLA");
display.drawXbm(0, 16, 32, 32,logo32_glcd_bmp );
display.display();
delay(2000);
if (WiFi.SSID()==""){
initialConfig = true;
Serial.println("mounting FS...");
WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
SuplaDevice.addRelay(101, false);
SuplaDevice.addRelay(102, false);
SuplaDevice.addRelay(103, false);
memset(btn, 0, sizeof(btn));
btn[0].pin =button_1 +1; // pin gpio buton +1
btn[0].relay_pin =relay_1 +1; // pin gpio Relay +1
btn[0].channel =0; // channel
btn[0].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[0].mem =0;
btn[1].pin =button_2 +1; // pin gpio buton +1
btn[1].relay_pin =relay_2 +1; // pin gpio Relay +1
btn[1].channel =1; // channel
btn[1].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[1].mem =0;
btn[2].pin =button_3 +1; // pin gpio buton +1
btn[2].relay_pin =relay_3 +1; // pin gpio Relay +1
btn[2].channel =2; // channel
btn[2].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[2].mem =0;
btn[3].pin =button_4 +1; // pin gpio buton +1
btn[3].relay_pin =relay_4 +1; // pin gpio Relay +1
btn[3].channel =3; // channel
btn[3].ms =0; // if = 0 Bistable -- if > 0 Monostable for X ms
btn[3].mem =0;
supla_btn_init();
//read configuration from FS json
display.clear();
display.drawString(64, 0, "mounting FS...");
display.display();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Supla_server, json["Supla_server"]);
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
strcpy(up_host, json["up_host"]);
strcpy(update_username, json["update_username"]);
strcpy(update_password, json["update_password"]);
strcpy(term_temp, json["term_temp"]);
Term_Temp = (String(term_temp).toInt());
strcpy(term_hist, json["term_hist"]);
Term_Hist = (String(term_hist).toInt());
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
wifi_station_set_hostname(up_host); //nazwa w sieci lokalnej @cino111
SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead); // ------Send Value to server -------
SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite); // ------- Read Value from server -------
SuplaDevice.setStatusFuncImpl(&status_func); // ----------------------------- Status -----------------------------
SuplaDevice.setName(Supla_name);
int LocationID = atoi(Location_id);
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
dimm_milis = millis() + 15000;
void loop() {
if (start == true){
// read_initial_relay_state
for(int i=0;i<2;i++){ // ---check relay except der have delay (staircase)
if ( (btn[i].ms) > 0 ) {
digitalWrite(btn[i].relay_pin-1, LOW);
continue;
} else {
eep = EEPROM.read(i);
if (eep >= 2 ){
EEPROM.write(i,0);
Serial.println("epp correct");
EEPROM.commit();
Serial.print("Recover.");
Serial.print(i);
Serial.println((btn[i].channel));
btn[i].mem =eep;
Serial.print((btn[i].relay_pin) -1);
Serial.print(" set ");
Serial.println(eep);
start = false;
if (initialConfig == true){
EEPROM.write(i, 0);
EEPROM.commit();
Serial.println("initial config triger");
ondemandwifiCallback () ;
if (shouldSaveConfig == true) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["Supla_server"] = Supla_server;
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
json["up_host"] = up_host;
json["update_username"] = update_username;
json["update_password"] = update_password;
json["term_temp"] = term_temp;
json["term_hist"] = term_hist;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
Serial.println("config saved");
display.clear();
display.drawString(64, 0, "config saved");
display.display();
delay(5000);
ESP.restart();
if (millis() > ds_milis){ // ------------------------------Termp update -----------------------------
ds_milis = millis() + 5000 ;
if (WiFi.status() != WL_CONNECTED) {
if (millis() > wifimilis) {
WiFi.begin();
pr_wifi = true;
tikOn = false;
Serial.println("CONNECTING WIFI");
wifimilis = (millis() + wifi_checkDelay) ;
if (millis() > eep_milis){
Eeprom_save() ; // ------------------------------Eepron save callback -----------------------------
eep_milis = millis() + 5000 ;
yield();
if (millis() > dimm_milis){
if (dimm == false){
display.setContrast(50, 50, 30);
display.display();
dimm = true ;
if (s != 17) if (tikOn == true)tikOn = false;
switch (s) { // ------------------------------------------------ Status ------------------------------------
case 17: // ----- STATUS_REGISTERED_AND_READY
if (epr<2){
Eepron_read() ; // ------------------------------- Eeprom read callback -------------------------------
epr = epr+1;// -------- 1 loop for each output ----------
if (tikOn == false)tikOn = true;
break;
case 10: // --------------------- REGISTER_IN_PROGRESS ----------------------
epr = 0 ;
break;
int C_W_read = digitalRead(btn[0].pin-1);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
last_C_W_state = C_W_read;
iterate_btn();
if (WiFi.status() == WL_CONNECTED){
SuplaDevice.iterate();
if (pr_wifi == true){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
httpUpdater.setup(&httpServer, update_path, update_username, update_password);
httpServer.begin();
delay(100);
httpServer.handleClient();
if (millis() > tr_milis){ // ------------------------------Termostat callback -----------------------------
yield();
tr = sensors.getTempCByIndex(0);
trs = (Term_Temp) ;
trs = (trs / 10) ;
TH_Overlay();
if ((btn[0].mem) == true) itrate_Term();
if ((String(term_temp).toInt()) != Term_Temp){
display.invertDisplay();// ------------------- oled imvert ---------------------------------------------------
Serial.println(term_temp);
Serial.println("save Temp_Term");
itoa(Term_Temp ,term_temp ,10) ;
if (!configFile) {
configFile.close();
delay(100);
display.normalDisplay();//---------------------- oled normal ---------------------------------------------------
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
//WiFi_up();
SuplaDeviceCallbacks cb;
cb.get_temperature = &get_temperature;
//cb.get_temperature = NULL;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
