New version of CLOUD server
astonix
Thu Sep 01, 2016 11:02 am
pzygmunt wrote:New version of CLOUD server will be released today.
It supports:
- Dimmer
- RGB Controller
- DHT11, DHT22, AM2302 sensors
Hi, Great job!
Anyway, i see Dimmer firmware on the github repo that there is only *.bin file available: https://github.com/SUPLA/ESP8266/tree/master/Dimmer
Could you provide the source code for it?
I planned to combine these function into socket-firmware.
Thanks.
astonix
Fri Sep 02, 2016 7:55 am
Hi, thanks for the link.
I see on the folder ESP8266_IOT there are "user" folder that contains many codes for microcontroller.
In my opinion, the source code for Dimmer has name "supla_esp_pwm.c" & "supla_esp_pwm.h", because it uses PWM.
Am I right?
VehuiahZer
Mon Sep 24, 2018 3:41 pm
No Rich. This will allow you to run reports from the cloud, not the program itself.
Post Reply
