Problem z aktualizacją Raspberry v2.3.18
PioKar
sob sty 25, 2020 2:08 pm
Może ktoś zerknąć co poszło nie tak podczas upgrade do 2.3.18?
Na szczęście to malina testowa ale z 2.316 na 17 poszło bez problemu.
2020-01-25 14:01:40,320 WARN received SIGTERM indicating exit request
2020-01-25 14:01:40,329 INFO waiting for supla-scheduler to die
INFO[1579960902.50227] Shutting down...
INFO[1579960902.51352] Stopped at Sat Jan 25 14:01:42 2020
2020-01-25 14:01:42,060 INFO stopped: supla-scheduler (exit status 0)
2020-01-25 14:02:08,019 CRIT Supervisor running as root (no user in config file)
2020-01-25 14:02:08,030 INFO supervisord started with pid 1
2020-01-25 14:02:09,035 INFO spawned: 'supla-scheduler' with pid 11
2020-01-25 14:02:09,041 INFO spawned: 'supla-server' with pid 12
INFO[1579960929.95199] Scheduler version 2.3.6
INFO[1579960929.95510] Started at Sat Jan 25 14:02:09 2020
INFO[1579960929.105517] Server version 2.3.19 [Protocol v10]
INFO[1579960929.105748] Started at Sat Jan 25 14:02:09 2020
ERR[1579960929.130990] Incorrect database version!
2020-01-25 14:02:09,137 INFO exited: supla-server (exit status 1; not expected)
2020-01-25 14:02:10,140 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-01-25 14:02:10,144 INFO spawned: 'supla-server' with pid 14
INFO[1579960930.175520] Server version 2.3.19 [Protocol v10]
INFO[1579960930.175748] Started at Sat Jan 25 14:02:10 2020
ERR[1579960930.186502] Incorrect database version!
2020-01-25 14:02:10,191 INFO exited: supla-server (exit status 1; not expected)
2020-01-25 14:02:12,200 INFO spawned: 'supla-server' with pid 15
INFO[1579960932.245027] Server version 2.3.19 [Protocol v10]
INFO[1579960932.246783] Started at Sat Jan 25 14:02:12 2020
ERR[1579960932.259916] Incorrect database version!
2020-01-25 14:02:12,265 INFO exited: supla-server (exit status 1; not expected)
2020-01-25 14:02:15,275 INFO spawned: 'supla-server' with pid 16
INFO[1579960935.306915] Server version 2.3.19 [Protocol v10]
INFO[1579960935.307158] Started at Sat Jan 25 14:02:15 2020
ERR[1579960935.317559] Incorrect database version!
2020-01-25 14:02:15,320 INFO exited: supla-server (exit status 1; not expected)
2020-01-25 14:02:16,322 INFO gave up: supla-server entered FATAL state, too many start retries too quickly
fracz
sob sty 25, 2020 4:15 pm
Hm. Zrestartuj?
PioKar
sob sty 25, 2020 4:21 pm
fracz pisze:
Hm. Zrestartuj?
Restartuję od godziny.
Update zrobiłem ponownie i to samo.
Czytam teraz forum może coś wyczytam.
PioKar
sob sty 25, 2020 4:33 pm
Ja nic z portami nie robiłem.
Jak to naprawić?
pi@raspberrypi:~ $ ./supla-docker/supla.sh start
Starting SUPLA containers
supla-db is up-to-date
supla-cloud is up-to-date
Starting supla-server ... error
ERROR: for supla-server Cannot start service supla-server: driver failed programming external connectivity on endpoint supla-server (c8b7c578d775f51267cfd9315722765e39eb104a2b6b1b3ecbd59ef054b84085): Bind for 0.0.0.0:2016 failed: port is already allocated
ERROR: Encountered errors while bringing up the project.
pi@raspberrypi:~ $
fracz
sob sty 25, 2020 4:57 pm
Stara wersja się nie zatrzymała z jakiegoś powodu. Spróbuj:
docker-compose rm -fs
./supła.sh start
PioKar
sob sty 25, 2020 5:16 pm
fracz pisze:
./supła.sh start
pi@raspberrypi:~ $
pi@raspberrypi:~ $ docker-compose rm -fs
ERROR:
Can't find a suitable configuration file in this directory or any
parent. Are you in the right directory?
Supported filenames: docker-compose.yml, docker-compose.yaml
pi@raspberrypi:~ $
pi@raspberrypi:~ $ ./supła.sh start
bash: ./supła.sh: Nie ma takiego pliku ani katalogu
pi@raspberrypi:~ $
PioKar
sob sty 25, 2020 5:19 pm
A tu pokazuje ok.
pi@raspberrypi:~/supla-docker $ ./supla.sh upgrade
Making database backup
Database backup saved to ./var/backups/supla01252020181750.sql.gz
Stopping SUPLA containers
Stopping supla-server ... done
Stopping supla-cloud ... done
Stopping supla-db ... done
SUPLA containers has been stopped.
Pulling supla-db ... done
Pulling supla-cloud ... done
Pulling supla-server ... done
Starting supla-db ... done
Starting supla-cloud ... done
Starting supla-server ... done
SUPLA containers has been started.
fracz
sob sty 25, 2020 5:40 pm
No i działa?
PioKar
sob sty 25, 2020 5:44 pm
fracz pisze:
No i działa?
nie działa
serwer is down
dobrze że to malina testowa
pewnie będzie stawianie od początku...
ale ja chciałbym się nauczyć :)
sorki że wam śmiecę
fracz
sob sty 25, 2020 6:33 pm
Nie będzie.
Zrestartuj i pokaż logi.
docker-compose logs --tail=100 supla-cloud
