Suggestion on System requirements for Supla
Post Reply
aruneshdutta
Post by aruneshdutta » Thu Jan 18, 2018 1:59 pm
Hello
I wanted to deploy Supla using Linux on VPS,wanted to know the suggestion on system requirements for the same.Thanks
Contact:
Re: Suggestion on System requirements for Supla
Post by pzygmunt » Thu Jan 18, 2018 2:21 pm
https://www.ovh.co.uk/order/vps/#/legacy/vps/options?vps=~(category~'ssd~product~'vps_ssd_model1_2017v3~os~'linux~datacenter~'uk1)
aruneshdutta
Post by aruneshdutta » Fri Jan 19, 2018 12:32 am
Thanks,so is this the ideal requirements as shown in ? was planning to use in Ubuntu 16.04
fracz
Post by fracz » Fri Jan 19, 2018 9:59 am
If you plan to use Docker installation: viewtopic.php?f=12&p=16088 I would suggest Debian rather than Ubuntu.
aruneshdutta
Post by aruneshdutta » Fri Jan 26, 2018 6:35 am
Thanks I'll go in with debian&docker.What's the minimum hw requirements of the server or any estimates that will help me know same for deployment
LyleSo
Post by LyleSo » Sat Feb 03, 2018 4:56 pm
Does it not work at all on Ubuntu or does it simply work better on Debian? I'm also considering Linux.
fracz
Post by fracz » Mon Feb 05, 2018 8:46 am
It should work on Ubuntu, too. Just considering debian as more "stable" for server environments. Personal opinion, that's all.
Post Reply
