Page 1 of 2
how to add auto add device setup wizard
Posted: Fri Feb 16, 2018 7:26 pm
by hirdeshsaxena112
hi i have uploaded the firmware but when i use this new feature that add io device from app it says this is not compatible something can u let me know how to achieve this
Re: how to add auto add device setup wizard
Posted: Fri Feb 16, 2018 11:34 pm
by fracz
You need to have firmware 2.5+ in order to use the simplified devices registration.
Posted: Sun Feb 18, 2018 9:57 am
by hirdeshsaxena112
thankyou francz
Posted: Thu Apr 12, 2018 7:26 am
by dovico
hi @fracz
i used firmware 2.6 build form supla-espressif IOT SDK
and log
ENTER CFG MODE
state: 5 -> 0 (0)
rm 0
pm close 7
del if0
usl
mode : softAP(b6:e6:2d:03:43:d7)
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
If i used firmware 2.53 of zybi, it ok
do you know why?
Posted: Thu Apr 12, 2018 7:40 am
by fracz
@pzygmunt?
Posted: Thu Apr 12, 2018 7:54 am
by pzygmunt
Which board?
Posted: Thu Apr 12, 2018 9:28 am
by dovico
Which board?
Board wifisocket
Posted: Thu Apr 12, 2018 9:34 am
by pzygmunt
Should work :/
Posted: Thu Apr 12, 2018 9:48 am
by dovico
wifisocket.c
#define B_RELAY1_PORT      12
	#define B_RELAY2_PORT      13
	#define B_RELAY3_PORT      14
	#define B_CFG_PORT         0
	#define B_BTN2_PORT        4
	#define B_BTN3_PORT        5
void supla_esp_board_set_device_name(char *buffer, uint8 buffer_size) {
	ets_snprintf(buffer, buffer_size, "supla-Light switch");
void ICACHE_FLASH_ATTR supla_esp_board_gpio_init(void) {
		supla_input_cfg[0].type = INPUT_TYPE_BTN_MONOSTABLE;
		supla_input_cfg[0].gpio_id = B_CFG_PORT;
		supla_input_cfg[0].flags = INPUT_FLAG_PULLUP | INPUT_FLAG_CFG_BTN;
		supla_input_cfg[0].relay_gpio_id = B_RELAY1_PORT;
		supla_input_cfg[0].channel = 0;
		supla_input_cfg[1].type = INPUT_TYPE_BTN_MONOSTABLE;
		supla_input_cfg[1].gpio_id = B_BTN2_PORT;
		supla_input_cfg[1].flags = INPUT_FLAG_PULLUP;
		supla_input_cfg[1].relay_gpio_id = B_RELAY2_PORT;
		supla_input_cfg[1].channel = 1;
		supla_input_cfg[2].type = supla_esp_cfg.CfgButtonType == BTN_TYPE_BISTABLE ? INPUT_TYPE_BTN_BISTABLE : INPUT_TYPE_BTN_MONOSTABLE;
		supla_input_cfg[2].gpio_id = B_BTN3_PORT;
		supla_input_cfg[2].flags = INPUT_FLAG_PULLUP;
		supla_input_cfg[2].relay_gpio_id = B_RELAY3_PORT;
		supla_input_cfg[2].channel = 2;
		supla_relay_cfg[0].gpio_id = B_RELAY1_PORT;
		supla_relay_cfg[0].flags = RELAY_FLAG_RESTORE_FORCE;
		supla_relay_cfg[0].channel = 0;
		supla_relay_cfg[1].gpio_id = B_RELAY2_PORT;
		supla_relay_cfg[1].flags = RELAY_FLAG_RESTORE_FORCE;
		supla_relay_cfg[1].channel = 1;
		supla_relay_cfg[2].gpio_id = B_RELAY3_PORT;
		supla_relay_cfg[2].flags = RELAY_FLAG_RESTORE_FORCE;
		supla_relay_cfg[2].channel = 2;
void ICACHE_FLASH_ATTR supla_esp_board_set_channels(TDS_SuplaDeviceChannel_B *channels, unsigned char *channel_count) {
		*channel_count = 3;
		channels[0].Number = 0;
		channels[0].Type = SUPLA_CHANNELTYPE_RELAY;
		channels[0].FuncList = SUPLA_BIT_RELAYFUNC_POWERSWITCH \
								| SUPLA_BIT_RELAYFUNC_LIGHTSWITCH;
		channels[0].Default = SUPLA_CHANNELFNC_LIGHTSWITCH;
		channels[0].value[0] = supla_esp_gpio_relay_on(B_RELAY1_PORT);
		channels[1].Number = 1;
		channels[1].Type = channels[0].Type;
		channels[1].FuncList = channels[0].FuncList;
		channels[1].Default = channels[0].Default;
		channels[1].value[0] = supla_esp_gpio_relay_on(B_RELAY2_PORT);
		channels[2].Number = 2;
		channels[2].Type = channels[0].Type;
		channels[2].FuncList = channels[0].FuncList;
		channels[2].Default = channels[0].Default;
		channels[2].value[0] = supla_esp_gpio_relay_on(B_RELAY3_PORT);
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc) {
	supla_esp_channel_value_changed(0, supla_esp_gpio_relay_on(B_RELAY1_PORT));
	supla_esp_channel_value_changed(1, supla_esp_gpio_relay_on(B_RELAY2_PORT));
	supla_esp_channel_value_changed(2, supla_esp_gpio_relay_on(B_RELAY3_PORT));
wifisocket.h
#ifndef WIFISOCKET_H_
#define WIFISOCKET_H_
#define CFGBTN_TYPE_SELECTION
	#define LED_RED_PORT    15
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc);
#endif
Posted: Thu Apr 12, 2018 9:57 am
by pzygmunt
Open list of the wifi networks and check that your device is visible. The name of the network should match the rules that you can find in this function:
https://github.com/SUPLA/supla-android/ ... .java#L820
