sonoff 4ch r2
Posted: Fri Oct 26, 2018 5:43 pm
hi, i just wanna share something about the sonoff 4ch r2, i did flashed it with the firmware multiboard and as you said we cannot relay on it when used in gate control because the relay commute every 68 secondes when loses connection with the server.that why you advise us to use it only for socket or light viewtopic.php?t=3170 .and even the RF remote doesn't work.i was trying to fix it to work with remote and it did work and i didn't notice that even the problem of relays (that keep comutate every 68s )when offline is fixed.
