fracz wrote: ↑Sat Feb 16, 2019 6:03 pm
Czy komuś jeszcze coś nie działa?
pi@raspberrypi:~ $ docker logs --tail=50 supla-server
INFO[1550356193.426449] Server version 2.3.1 [Protocol v10]
INFO[1550356193.426789] Started at Sat Feb 16 22:29:53 2019
INFO[1550356193.584536] SSL version: OpenSSL 1.0.1t 3 May 2016
2019-02-16 22:29:54,588 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-16 22:29:54,759 INFO success: supla-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-16 22:40:35,100 WARN received SIGTERM indicating exit request
2019-02-16 22:40:35,101 INFO waiting for supla-scheduler, supla-server to die
INFO[1550356835.101386] Shutting down...
ERR[1550356835.102073] IPC connection accept error 9
ERR[1550356835.104818] Connection accept error 9
ERR[1550356835.105431] Connection accept error 9
INFO[1550356835.114768] Stopped at Sat Feb 16 22:40:35 2019
2019-02-16 22:40:35,118 INFO stopped: supla-server (exit status 0)
INFO[1550356835.120054] Shutting down...
INFO[1550356835.121015] Stopped at Sat Feb 16 22:40:35 2019
2019-02-16 22:40:35,124 INFO stopped: supla-scheduler (exit status 0)
2019-02-16 22:41:05,170 CRIT Supervisor running as root (no user in config file)
2019-02-16 22:41:05,185 INFO supervisord started with pid 1
2019-02-16 22:41:06,192 INFO spawned: 'supla-scheduler' with pid 9
2019-02-16 22:41:06,200 INFO spawned: 'supla-server' with pid 10
INFO[1550356866.253053] Server version 2.3.1 [Protocol v10]
INFO[1550356866.255206] Scheduler version 2.3.1
INFO[1550356866.253712] Started at Sat Feb 16 22:41:06 2019
INFO[1550356866.255720] Started at Sat Feb 16 22:41:06 2019
INFO[1550356866.301550] SSL version: OpenSSL 1.0.1t 3 May 2016
2019-02-16 22:41:07,305 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-16 22:41:07,306 INFO success: supla-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-16 22:43:07,515 CRIT Supervisor running as root (no user in config file)
2019-02-16 22:43:07,539 INFO supervisord started with pid 1
2019-02-16 22:43:08,546 INFO spawned: 'supla-scheduler' with pid 10
2019-02-16 22:43:08,554 INFO spawned: 'supla-server' with pid 11
INFO[1550356988.735516] Scheduler version 2.3.1
INFO[1550356988.735985] Started at Sat Feb 16 22:43:08 2019
INFO[1550356988.745935] Server version 2.3.1 [Protocol v10]
INFO[1550356988.746286] Started at Sat Feb 16 22:43:08 2019
INFO[1550356989.25953] SSL version: OpenSSL 1.0.1t 3 May 2016
2019-02-16 22:43:10,029 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-16 22:43:10,059 INFO success: supla-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
INFO[1550419994.373186] Connection accepted: 193.188.22.75:1733 ClientSD: 10 Secure: 1
2019-02-17 17:26:20,690 CRIT Supervisor running as root (no user in config file)
2019-02-17 17:26:20,713 INFO supervisord started with pid 1
2019-02-17 17:26:21,720 INFO spawned: 'supla-scheduler' with pid 9
2019-02-17 17:26:21,730 INFO spawned: 'supla-server' with pid 10
INFO[1550424381.881747] Scheduler version 2.3.1
INFO[1550424381.882158] Started at Sun Feb 17 17:26:21 2019
INFO[1550424381.894599] Server version 2.3.1 [Protocol v10]
INFO[1550424381.894933] Started at Sun Feb 17 17:26:21 2019
INFO[1550424382.52896] SSL version: OpenSSL 1.0.1t 3 May 2016
2019-02-17 17:26:23,056 INFO success: supla-scheduler entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2019-02-17 17:26:23,056 INFO success: supla-server entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
pi@raspberrypi:~ $ docker logs --tail=50 supla-cloud
supla:clean:obsolete-oauth-tokens: NOT NOW
supla:clean:orphaned-measurement-logs: NOT NOW
supla:clean:disable-broken-schedules: NOT NOW
supla:clean:disable-demo-client-apps: RUN:
Clients to disable: 0
supla:generate-schedules-executions: NOT NOW
supla:clean:passed-io-client-registration-dates: RUN:
Client registration expiration date - cleared: 0
I/O Device registration expiration date - cleared: 0
supla:clean:broker-clouds-cache: NOT NOW
supla:clean:not-confirmed-users: NOT NOW
Raspberry 2B
Instalacja na czystej karcie (kilkanascie razy)
Nie pomaga:
-restart
-git pull
./supla.sh upgrade
-docker-compose pull
Wszystkie komendy oczywiście działają, wszystko idzie, pięknie się instaluje, logowanie przez https:// port 445 i
http://85 na wszelki wypadek żeby z czymś nie kolidowało i nic.
Wojtku, piszę do Was z wielką nieśmiałością, ponieważ nie jestem w stanie pomóc jak ścisła czołówka testerów z forum.
W którymś miejscu na forum piszesz, żeby dać Ci dostęp do rpi aby rozwiązać problem.
Mogę dać na priv wszystko (nr visa), żebym tylko wiedział jak.
Na tem moment wysyłam na priv to co potrafię.
