Amazon Alexa
Możesz sprawdzić co masz w logach?
Chodzi o logi z serwera??
pi@raspberrypi:~ $ docker logs --tail=50 supla-server
INFO[1582286669.827389] Connection accepted: 192.168.1.81:50702 ClientSD: 25 Secure: 1
INFO[1582286669.890010] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 71
INFO[1582286669.892157] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 25
ERR[1582286686.698023] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286686.698120] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286686.699520] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286706.834507] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286706.836897] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286706.836963] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286726.937150] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286726.941936] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286726.942003] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286747.22980] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286747.43656] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286747.43760] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286767.115820] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286767.116603] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286767.127360] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286787.262406] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286787.262493] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286787.266205] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
INFO[1582286802.939755] Connection accepted: 192.168.1.81:51104 ClientSD: 59 Secure: 1
INFO[1582286802.941389] Connection accepted: 192.168.1.81:51106 ClientSD: 25 Secure: 1
INFO[1582286802.979528] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 59
INFO[1582286802.980611] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 25
ERR[1582286807.403041] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286807.403142] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286807.413472] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286827.528324] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286827.528916] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286827.528961] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286847.610953] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286847.618308] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286847.619563] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286867.697095] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286867.697645] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286867.697685] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286887.782714] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286887.782801] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286887.786725] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286907.871420] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286907.871522] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
ERR[1582286907.872906] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286927.957944] Http request - No data was received. Method: POST, resource: /default/amazonRefreshTokenBridge
ERR[1582286927.958314] Http request - No data was received. Method: POST, resource: /v3/events
ERR[1582286927.958347] Alexa event gateway client error (UserID: 1, httpCode: 0, Result: -300): REQUEST_ERROR
INFO[1582286936.78338] Connection accepted: 192.168.1.81:51512 ClientSD: 62 Secure: 1
INFO[1582286936.78889] Connection accepted: 192.168.1.81:51516 ClientSD: 25 Secure: 1
INFO[1582286936.154622] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 62
INFO[1582286936.166330] Cipher: ECDHE-RSA-AES256-GCM-SHA384, ClientSD: 25
Logi z web/var/logs
sprawdź też co pokazuje https://twoja_domena/api/server-status
No to coś leży. Zrestartuj kontenery.
resetowałem
pi@raspberrypi:~/docker-compose-letsencrypt-nginx-proxy-companion $ docker-compose stop
Stopping nginx-web ... done
Stopping nginx-letsencrypt ... done
Stopping nginx-gen ... done
pi@raspberrypi:~/docker-compose-letsencrypt-nginx-proxy-companion $ docker-compose up --build -d
Starting nginx-gen ... done
Starting nginx-letsencrypt ... done
Starting nginx-web ... done
o ja nie mądry
niestety dalej to samo
pi@raspberrypi:~/supla-docker $ ./supla.sh restart
Stopping SUPLA containers
Stopping supla-server ... done
Stopping supla-cloud ... done
Stopping supla-db ... done
SUPLA containers has been stopped.
Starting SUPLA containers
Starting supla-db ... done
Starting supla-cloud ... done
Starting supla-server ... done
SUPLA containers has been started.
Nadal status serwera jest "DOWN" ?
