Domoticz 0.1.0
isom
wt lip 09, 2019 8:49 am
Dzięki @magx2 , jak rozumiem po naprawieniu błędu wystarczy pobrać i podmienić plugin.py ?
superprzemo
wt lip 09, 2019 6:19 pm
Połączyłem się z Suplą, ale nie widzi urządzenia "SOCKET-ESP01-DHT22"
isom
wt lip 09, 2019 7:08 pm
@ magx2 powiem tak plugin ruszył co zresztą widać poniżej
2019-07-09 20:48:27.064 Status: User: Admin initiated a switch command (84/Supla - salon góra/Off)
2019-07-09 20:48:28.024 (Supla) Changing channel 1318679/LIGHTSWITCH to state 0
2019-07-09 20:48:32.560 (Supla) onHeartbeat called
2019-07-09 20:48:34.115 (Supla) onCommand called for Unit 2: Parameter 'On', Level: 1
2019-07-09 20:48:34.115 (Supla) api> patch(https://svr1.supla.org/api/v2.3.0/channels/1318679, {'action': 'TURN_ON'})
2019-07-09 20:48:34.633 (Supla) api> get(https://svr1.supla.org/api/v2.3.0/channels/1318679, includes=[connected, state])
2019-07-09 20:48:34.112 Status: User: Admin initiated a switch command (84/Supla - salon góra/On)
2019-07-09 20:48:35.096 (Supla) Changing channel 1318679/LIGHTSWITCH to state 1
2019-07-09 20:48:41.780 (Supla) onCommand called for Unit 2: Parameter 'Off', Level: 1
2019-07-09 20:48:41.780 (Supla) api> patch(https://svr1.supla.org/api/v2.3.0/channels/1318679, {'action': 'TURN_OFF'})
2019-07-09 20:48:41.729 Status: User: Admin initiated a switch command (84/Supla - salon góra/Off)
2019-07-09 20:48:42.284 (Supla) api> get(https://svr1.supla.org/api/v2.3.0/channels/1318679, includes=[connected, state])
2019-07-09 20:48:42.778 (Supla) Changing channel 1318679/LIGHTSWITCH to state 0
2019-07-09 20:48:43.797 (Supla) onHeartbeat called
2019-07-09 20:48:45.753 (Supla) onCommand called for Unit 2: Parameter 'Off', Level: 1
2019-07-09 20:48:45.753 (Supla) api> patch(https://svr1.supla.org/api/v2.3.0/channels/1318679, {'action': 'TURN_OFF'})
2019-07-09 20:48:45.734 Status: User: Admin initiated a switch command (84/Supla - salon góra/Off)
Ale
Całą instalację wtyczki musiałem zrobić z poziomu root-a, bo z poziomu usera "pi" git pull wywalał błąd, instalacja wszystkiego od nowa z poziomu pi nie pozwalała na załadowanie certów , jak same certy poszły z root-a to plugin walił błędami
Jeżeli chcesz to mam wszystkie błędy i logi skopiowane i mogę je udostępnić .
Dla tych którym wtyczka ruszy to nowych urządzeń szukać w zakładce "Urządzenia" i trzeba je dodać ręcznie.
Tak po za tym to wielkie dzięki kolego @magx2 za Twoją pracę
magx2
wt lip 09, 2019 9:07 pm
superprzemo pisze:
W tej chwili wspieramy tylko żarówki. Co robi twoje urządzenie?
@isom masz suple cloud na RPi czy laczysz się do tej oryginalnej?
superprzemo
śr lip 10, 2019 5:16 am
Odczyt temperatury i wilgotności + sterowanie przekaźnikiem, taka funkcja termostatu.
Tak przy okazji, czy domoticz podłączyć się do supli bez certyfikatu SSL?
magx2
śr lip 10, 2019 5:53 am
superprzemo pisze:
Nie. Domoticz łączy się po https
superprzemo
śr lip 10, 2019 6:17 am
Ok, sam przekaźnik jest widziany jako Light/Switch.
Wróć do „Domoticz”
