Zamieszczony kod , dokonuje pomiaru temperatury, narazie
* Supla.org NodeMCU WiFi minimal example
* Author: Programistyk - Kamil Kaminski <kamil@programistyk.pl>
* This example shows how to configure SuplaDevice for building for NodeMCU within Arduino IDE
#include <srpc.h>
#include <log.h>
#include <eh.h>
#include <proto.h>
#include <IEEE754tools.h>
// We define our own ethernet layer
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <lck.h>
#include <WiFiClient.h>
#include <ESP8266WiFiType.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiServer.h>
#include <ESP8266WiFiGeneric.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiSTA.h>
#include <WiFiUdp.h>
#include <Wire.h>
#include <OneWire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 0
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO32_GLCD_HEIGHT 32
#define LOGO32_GLCD_WIDTH 32
static const unsigned char PROGMEM temp_glcd_bmp[] =
0x00, 0x03, 0xc0, 0x00, 0x00, 0x07, 0xe0, 0x00, 0x00, 0x0e, 0x30, 0x00, 0x00, 0x18, 0x18, 0x00,
0x00, 0x30, 0x0c, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0xc3, 0xc3, 0x00, 0x01, 0x87, 0xe1, 0x80,
0x03, 0x0e, 0x70, 0xc0, 0x06, 0x0d, 0xb0, 0x60, 0x0c, 0x0d, 0xb0, 0x30, 0x18, 0x0d, 0xb0, 0x18,
0x30, 0x0d, 0xb0, 0x0c, 0x30, 0x0d, 0xb0, 0x0c, 0x30, 0x0d, 0xb0, 0x0c, 0x38, 0x0d, 0xb0, 0x1c,
0x1c, 0x0d, 0xb0, 0x38, 0x0c, 0x0d, 0xb0, 0x30, 0x0c, 0x0d, 0xb0, 0x30, 0x0c, 0x0d, 0xb0, 0x30,
0x0c, 0x1d, 0xb8, 0x30, 0x0c, 0x19, 0x98, 0x30, 0x0c, 0x19, 0x98, 0x30, 0x0c, 0x19, 0x98, 0x30,
0x0c, 0x18, 0x18, 0x30, 0x0c, 0x1c, 0x38, 0x30, 0x0c, 0x0f, 0xf0, 0x30, 0x0c, 0x07, 0xe0, 0x30,
0x0c, 0x00, 0x00, 0x30, 0x0e, 0x00, 0x00, 0x70, 0x07, 0xff, 0xff, 0xe0, 0x03, 0xff, 0xff, 0xc0, };
static const unsigned char PROGMEM logo32_glcd_bmp[] =
// 'logo'
0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x03, 0xf8, 0x00, 0x00, 0x07, 0xfc, 0x00, 0x00,
0x0e, 0x0e, 0x00, 0x00, 0x0c, 0x06, 0x00, 0x00, 0x1c, 0x03, 0x00, 0x00, 0x1c, 0x03, 0x00, 0x00,
0x1c, 0x03, 0x00, 0x00, 0x0c, 0x07, 0x00, 0x00, 0x0e, 0x0f, 0x80, 0x00, 0x07, 0xfc, 0xe0, 0x00,
0x03, 0xf8, 0x30, 0x00, 0x00, 0xf0, 0x0d, 0xe0, 0x00, 0x10, 0x07, 0x30, 0x00, 0x18, 0x02, 0x10,
0x00, 0x18, 0x06, 0x18, 0x00, 0x08, 0x02, 0x10, 0x00, 0x08, 0x03, 0xf0, 0x00, 0x0c, 0x07, 0xc0,
0x00, 0x04, 0x0c, 0x00, 0x00, 0x04, 0x08, 0x00, 0x00, 0x04, 0x10, 0x00, 0x00, 0x00, 0x20, 0x00,
0x00, 0x03, 0xc0, 0x00, 0x00, 0x04, 0x40, 0x00, 0x00, 0x0c, 0x20, 0x00, 0x00, 0x0c, 0x20, 0x00,
0x00, 0x04, 0x40, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,};
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
WiFiClient client;
// Setup Supla connection
const char* ssid = "XXXX ";
const char* password = "XXXX";
// Setup a oneWire instance
OneWire oneWire(2); // - Pin number
// Pass oneWire reference to Dallas Temperature
// DS18B20 Sensor read implementation
double t = -275;
if ( sensors.getDeviceCount() > 0 )
switch(channelNumber)
case 0:
t = sensors.getTempCByIndex(0);
display.clearDisplay();
display.setTextSize(2);
display.setTextColor(WHITE);
display.setRotation(2);
display.setCursor(45,30);
display.print(t,1);
display.print((char)247);
display.println("C");
drawbitmap(temp_glcd_bmp, LOGO32_GLCD_HEIGHT, LOGO32_GLCD_WIDTH);
display.display();
break;
Serial.println(t);
return t;
void setup() {
// Init Serial port
Serial.begin(115200);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x64)
// init done
// Show image buffer on the display hardware.
// Since the buffer is intialized with an Adafruit splashscreen
// internally, this will display the splashscreen.
//display.display();
// Clear the buffer.
// text display tests
display.setTextSize(3);
display.setCursor(30,25);
display.print("SUPLA");
drawbitmap(logo32_glcd_bmp, LOGO32_GLCD_HEIGHT, LOGO32_GLCD_WIDTH);
display.display();
// Init DS18B20 library
sensors.begin();
// Replace the falowing GUID
char GUID[SUPLA_GUID_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
// Ethernet MAC address
uint8_t mac[6] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
// CHANNEL0 - RELAY
mac, // Ethernet MAC address
"svr1.supla.org", // SUPLA server address
0, // Location ID
""); // Location Password
void loop() {
SuplaDevice.iterate();
void drawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
uint8_t icons[NUMFLAKES][3];
display.drawBitmap(0,0, bitmap, w, h, WHITE);
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
// Serial.println("WiFi init");
WiFi.begin(ssid, password);
delay(500);
// Serial.print(".");
//Serial.print("\nlocalIP: ");
//Serial.println(WiFi.localIP());
//Serial.print("subnetMask: ");
//Serial.println(WiFi.subnetMask());
//Serial.print("gatewayIP: ");
//Serial.println(WiFi.gatewayIP());
SuplaDeviceCallbacks cb;
cb.get_temperature = &get_temperature;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
