Supla + BME280
Jak chcesz - daj na priv namiary na sieć i serwer to zrobię ci .bin-a
My łączymy teorię z praktyką czyli nic nie działa i nikt nie wie dlaczego
Mój problem
In file included from C:\Documents and Settings\RK\Ustawienia lokalne\Dane aplikacji\Arduino15\packages\esp8266\hardware\esp8266\2.3.0-rc2\cores\esp8266\abi.cpp:23:0:
c:\documents and settings\rk\ustawienia lokalne\dane aplikacji\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\cxxabi.h:50:32: fatal error: bits/cxxabi_tweaks.h: No such file or directory
 #include <bits/cxxabi_tweaks.h>
z kompilowaniem rozwiązał wątek: https://www.instructables.com/id/Portab ... E-v165-fo/
Na kompie mam Win XP :) jeszcze :)
Potem zobaczę na Win 8 na laptopie
Aczkolwiek mam jeszcze takie komunikaty:
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice/SuplaDevice.h:108:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice/SuplaDevice.h:116:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice/SuplaDevice.h:124:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice/SuplaDevice.h:156:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\dl\supla_esp_oled_bme_v21\supla_esp_oled_bme_v21.ino:136:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
In file included from K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp:21:0:
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.h:108:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.h:116:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.h:124:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.h:156:1: warning: 'typedef' was ignored in this declaration [enabled by default]
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp: In member function 'bool SuplaDeviceClass::begin(IPAddress*, char*, uint8_t*, const char*, int, const char*)':
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp:282:39: warning: NULL used in arithmetic [-Wpointer-arith]
  if ( Params.reg_dev.ServerName[0] == NULL ) {
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp: In function 'void float2DoublePacked(float, byte*, int)':
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp:76:29: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations]
             bar[i] = dbl.b[i];
K:\SUPLA_PRJ\arduino\arduino\arduino180\libraries\SuplaDevice\SuplaDevice.cpp:74:9: note: containing loop
         for (int i=0; i<8; i++)
slawek pisze: czw lis 01, 2018 1:58 pm Jak chcesz - daj na priv namiary na sieć i serwer to zrobię ci .bin-a
Bardzo dziękuję koledze ale nie ma co iść na łatwiznę - lepsza satysfakcja będzie jak zrobię to sam.
Przy okazji się nauczę. Nie miałem wcześniej do czynienia z programowaniem Arduino , dziś pierwszy raz odpaliłem to środowisko. Wcześniej tylko gotowe binarki wrzucałem.
QLQ pisze: czw lis 01, 2018 3:32 pm dziś pierwszy raz odpaliłem to środowisko. Wcześniej tylko gotowe binarki wrzucałem.
Ja też od niedawna "raczkuję" - skusił mnie oled i kolega @shimano73 - Supla mobilizuje do nauki... ;)
Jeszcze pytanie:
 uint8_t mac[6] = {0x20, 0x00, 0x00, 0x00, 0x00, 0x00};
- tu wpisuję mac ESP to wiem
ale
                    mac,             // Ethernet MAC address
                    "svr5.supla.org",  // SUPLA server address
                    0,                 // Location ID
                    "haslo_serwera_np svr1.supla.org");               // Location Password
pole mac - nie zmieniamy ? program przepisuje ją z unit8_t ? czy tu mam wpisać mac esp?
reszta pól wiadomo
Ma być tak:
                    0,          // Location ID - np. 123 odczytane ze strony clouda
                    "haslo_serwera_np svr1.supla.org");      //    np "a234" - odczytane ze strony clouda
MAC jest mało istotny, nic nie pisz, ważny jest GUID - albo wygeneruj z linka, albo użyj sposobu generowania na podstawie MAC (ale to tylko dla ESP, bo arduino nie posiada fabrycznie adresu MAC)
slawek pisze: czw lis 01, 2018 6:54 pm Ma być tak:
jakiś soft do tego?
Program ma być właśnie w WeMos lub ESP-07
Może inaczej - funkcja SuplaDevice.begin wczytuje wygenerowany i zdefiniowany wcześniej MAC i GUID, i podane przez ciebie dane dot. twego konta na serwerze - wpisujesz tu tylko 3 ostatnie dane dot. serwera
O to chodzi?
  // Replace the falowing GUID
  uint8_t mac[WL_MAC_ADDR_LENGTH];
  WiFi.macAddress(mac);
  char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6],
                                mac[WL_MAC_ADDR_LENGTH - 5],
                                mac[WL_MAC_ADDR_LENGTH - 4],
                                mac[WL_MAC_ADDR_LENGTH - 3],
                                mac[WL_MAC_ADDR_LENGTH - 2],
                                mac[WL_MAC_ADDR_LENGTH - 1]
Funkcja WiFi.macAddress(mac); odczytuje MAC z modułu i zostaje on dodatkowo "wykorzystany" do wygenerowania GUID, który ma być niepowtarzalny (czyli coś jak MAC)
Teraz mroczność stała się jasna. Dziękuję
Wróć do „Ogólna dyskusja”
