czw sty 07, 2021 6:24 am
tak zrobiłem, dodałem usera do dockera, zmieniłem obraz poleceniem plik wygląda tak:
/home/serwer/supla-docker/docker-compose.yml
version: '3.4'
services:
supla-cloud:
container_name: ${COMPOSE_PROJECT_NAME}-cloud
restart: unless-stopped
build:
context: ./cloud
target: supla_cloud_prod
env_file:
- .env.default
- .env
volumes:
- ./ssl/cloud:/etc/apache2/ssl:z
- ${VOLUME_DATA}/cloud-local:/var/www/cloud/var/local
- ${VOLUME_DATA}/cloud-logs:/var/www/cloud/var/logs
- supla-server-socket:/supla-server:z
logging:
options:
max-size: 50m
links:
- supla-db
depends_on:
- supla-db
supla-db:
container_name: ${COMPOSE_PROJECT_NAME}-db
image: i386/mariadb:5.5
env_file:
- .env.default
- .env
environment:
MYSQL_ROOT_PASSWORD: ${DB_PASSWORD}
MYSQL_DATABASE: supla
MYSQL_USER: supla
MYSQL_PASSWORD: ${DB_PASSWORD}
volumes:
- ${VOLUME_DATA}/mysql:/var/lib/mysql:z
- ./db:/etc/mysql/conf.d
logging:
options:
max-size: 50m
supla-server:
container_name: ${COMPOSE_PROJECT_NAME}-server
build: ./server
env_file:
- .env.default
- .env
volumes:
- ./ssl/server:/etc/supla-server/ssl:z
- supla-server-socket:/var/run/supla:z
ports:
Nadal wyskakuje błąd:
serwer@linux:~$ sudo ./supla-docker/supla.sh start
Starting SUPLA containers
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.7/http/client.py", line 1244, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1290, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1239, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.7/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/lib/python3.7/http/client.py", line 966, in send
self.connect()
File "/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py", line 43, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionRefusedError(111, 'Connection refused'))
File "/usr/local/lib/python3.7/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/docker/api/client.py", line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionRefusedError(111, 'Connection refused'))
File "/usr/local/bin/docker-compose", line 10, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 67, in main
command()
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 123, in perform_command
project = project_from_options('.', options)
File "/usr/local/lib/python3.7/dist-packages/compose/cli/command.py", line 69, in project_from_options
environment_file=environment_file
File "/usr/local/lib/python3.7/dist-packages/compose/cli/command.py", line 132, in get_project
verbose=verbose, version=api_version, context=context, environment=environment
File "/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py", line 43, in get_client
environment=environment, tls_version=get_tls_version(environment)
File "/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py", line 170, in docker_client
client = APIClient(**kwargs)
File "/usr/local/lib/python3.7/dist-packages/docker/api/client.py", line 197, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.7/dist-packages/docker/api/client.py", line 222, in _retrieve_server_version
'Error while fetching server API version: {0}'.format(e)
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', ConnectionRefusedError(111, 'Connection refused'))
serwer@linux:~$
