Gniazdko Neo Coolcam z pomiarem energii
elmaya
czw lis 19, 2020 11:57 am
lukfud pisze:
czw lis 19, 2020 8:14 am
elmaya pisze:
wt lis 10, 2020 3:24 pm
#define HJL01_CURRENT_RATIO             25740
#define HJL01_VOLTAGE_RATIO             313400
#define HJL01_POWER_RATIO               3414290
Why these values? Where did you get them?
They are only an initial reference to be able to show something even without doing the calibration.
lukfud
czw lis 19, 2020 12:07 pm
elmaya pisze:
lukfud pisze:
elmaya pisze:
Ok, thanks :)
One more question, will this piece be needed if I use the storage class from the library?
  if(millis() > mem_energy_milis){
    if ((float(hjl01.getEnergy()) + mem_energy > _mem_energy) && (digitalRead(relay_pin) == HIGH)){
     Serial.println("save energy");
      _mem_energy = (float)hjl01.getEnergy() + mem_energy;
      EEPROM.put(460, _mem_energy);
      EEPROM.commit();
     mem_energy_milis = millis() + 600000 ;
Maniek913
pn lis 23, 2020 8:17 pm
elmaya pisze:
for Gosund SP111
#include "LittleFS.h" // LittleFS is declared
#include <SuplaDevice.h>
#include <supla/sensor/one_phase_electricity_meter.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- V6 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Ticker.h>      //for LED status
#include <ESP8266TrueRandom.h>
#include <HLW8012.h>
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
#define SEL_PIN    12
#define CF1_PIN    14
#define CF_PIN     5
#define status_led 0
int wificonfig_pin = 13;
int relay_pin = 15;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;                      // config delay 10 seconds
int C_W_state2 = HIGH;
long C_W_delay2 = 100;
unsigned long eep_milis = 10000;
bool recover = true;
char Supla_server[81]=("Set server address");
char Email[81]=("set email address");
char Supla_name[51];
char Supla_status[51];
char Volt[8];
char Wats[8];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int s = 0;
bool starting = true;
bool Tik = true;
unsigned long  mem_energy_milis = 3000000;
float mem_energy = 0;
float _mem_energy = 0;
int customFieldLength = 40;
WiFiManagerParameter custom_field; // global param ( for non blocking w params )
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
static const char custom_radio_str[] PROGMEM = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>Counter mem</label><input type='radio' name='customfieldid' value='0' checked>keep Storage<input type='radio' name='customfieldid' value='1'>clear Storage</div>";
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
Ticker ticker;
Supla::ESPWifi wifi("", "");  //------ Do not change----wifimanager takes care------
Supla::Control::Relay *relay1 = nullptr;
#define CURRENT_MODE                    LOW
HLW8012 hjl01;
class Hj101 : public Supla::Sensor::OnePhaseElectricityMeter {
    public:
        Hj101()  {
        void onInit() {
            readValuesFromDevice();
            updateChannelValues();
        virtual void readValuesFromDevice() {
            unsigned int _reactive =  0;
            double _pf = 0;
            double _current = hjl01.getCurrent();
            unsigned int _voltage = hjl01.getVoltage();
            unsigned int _active = hjl01.getActivePower();
            unsigned int _apparent = _voltage * _current;
            if (_apparent > _active) {_reactive = sqrt(_apparent * _apparent - _active * _active); } else {_reactive =  0;}
            if (_active > _apparent){ _pf = 1;} if (_apparent == 0){ _pf = 0;}else{ _pf = (double) _active / _apparent;}
            // voltage in 0.01 V
            setVoltage(0,_voltage * 100);
            // current in 0.001 A
            setCurrent(0, _current * 1000);
            // power in 0.00001 kW
            setPowerActive(0, _active * 100000);
            // energy in 0.00001 kWh
            setFwdActEnergy(0, ((float)hjl01.getEnergy() + mem_energy) / 6 / 6 );
            // power in 0.00001 kVA
            setPowerApparent(0, _apparent * 100000);
            // power in 0.00001 kvar
            setPowerReactive(0, _reactive * 100000);
            // power in 0.001
            setPowerFactor(0, _pf * 1000);
void tick() {
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void ICACHE_RAM_ATTR hjl01_cf1_interrupt() {
    hjl01.cf1_interrupt();
void ICACHE_RAM_ATTR hjl01_cf_interrupt() {
    hjl01.cf_interrupt();
void calibrate_hj101() {
   int ex_volt = atoi(Volt);
   int ex_pow = atoi(Wats);
   double ex_amps = ((float)ex_pow / (float)ex_volt);
   Serial.print("volt:"); Serial.println(ex_volt);
   Serial.print("wats:"); Serial.println(ex_pow);
   Serial.print("amps:"); Serial.println(ex_amps);
   digitalWrite(relay_pin,HIGH);
   Serial.println("Relay On:");
    unsigned long timeout1 = millis();
    while ((millis() - timeout1) < 10000) { delay(10);}
    hjl01.expectedActivePower(ex_pow);
    hjl01.expectedVoltage(ex_volt);
    hjl01.expectedCurrent(ex_amps);
    unsigned long timeout2 = millis();
    while ((millis() - timeout2) < 2000) {delay(10);}
    double current_multi = hjl01.getCurrentMultiplier();
    double voltage_multi = hjl01.getVoltageMultiplier();
    double power_multi = hjl01.getPowerMultiplier();
    Serial.print("[HLW] New current multiplier : "); Serial.println(current_multi);
    Serial.print("[HLW] New voltage multiplier : "); Serial.println(voltage_multi);
    Serial.print("[HLW] New power multiplier   : "); Serial.println(power_multi);
    EEPROM.put(400, current_multi);
    EEPROM.put(410, voltage_multi);
    EEPROM.put(420, power_multi);
    EEPROM.write(430, 60);
  EEPROM.commit();
  yield();
void get_hj101_config(){
  if (EEPROM.read(430) == 60){
      Serial.println("get eep multiplier ");
       double p_m;double v_m;double c_m;
        EEPROM.get(400,c_m);
         EEPROM.get(410,v_m);
          EEPROM.get(420,p_m);
           hjl01.setCurrentMultiplier(c_m);
            hjl01.setVoltageMultiplier(v_m);
             hjl01.setPowerMultiplier(p_m);
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
   ticker.attach(1.5, tick);
   WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
   WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
   WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
   WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
   WiFiManagerParameter custom_Volt("Volt", "expectedVoltage", Volt, 8);
   WiFiManagerParameter custom_Wats("Wats", "expectedActivePower", Wats, 8);
   new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input
   wifiManager.setBreakAfterConfig(true);
   wifiManager.setSaveConfigCallback(saveConfigCallback);
   wifiManager.setSaveParamsCallback(saveParamCallback);
   wifiManager.addParameter(&custom_Supla_server);
   wifiManager.addParameter(&custom_Email);
   wifiManager.addParameter(&custom_Supla_name);
   wifiManager.addParameter(&custom_Supla_status);
   wifiManager.addParameter(&custom_Volt);
   wifiManager.addParameter(&custom_Wats);
   wifiManager.addParameter(&custom_field);
   wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
   wifiManager.setMinimumSignalQuality(8);
   //wifiManager.setShowStaticFields(true); // force show static ip fields
   //wifiManager.setShowDnsFields(true);    // force show dns field always
   wifiManager.setConfigPortalTimeout(180);
   if (!wifiManager.startConfigPortal("Gosund_SP111")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Email, custom_Email.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(Volt, custom_Volt.getValue());
    strcpy(Wats, custom_Wats.getValue());
    if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
      Serial.println("new guid & authkey.");
      EEPROM.write(300, 0);
      EEPROM.commit();
      ESP.reset();
    if ((strlen(Volt) != 0) && (strlen(Wats) != 0)){
      calibrate_hj101();
    WiFi.softAPdisconnect(true);   //  close AP
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status){
    s = status;
      if (s != 10){
        strcpy(Supla_status, msg);
          Serial.print("Status: ");Serial.print(s);Serial.print(" ");Serial.println(Supla_status);
String getParam(String name){
  String value;
  if(wifiManager.server->hasArg(name)) {
    value = wifiManager.server->arg(name);
      if (value == "1"){
        float cler = 0.0;
         EEPROM.put(460, cler);
          EEPROM.commit();
           Serial.println("clearStorage");
  return value;
void saveParamCallback(){
  Serial.println("[CALLBACK] saveParamCallback fired");
  Serial.println("PARAM customfieldid = " + getParam("customfieldid"));
void Eeprom_save(){
  if (digitalRead(relay_pin)!= EEPROM.read(431)){
    _mem_energy = (double)hjl01.getEnergy() + mem_energy;
    EEPROM.write(431,digitalRead(relay_pin));
    EEPROM.commit();
    Serial.println("mem relay + energy");
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    float cler = 0.0;
    EEPROM.write(300, 60);
    EEPROM.commit();
  read_guid();
  read_authkey();
  Serial.print("GUID : ");Serial.println(read_guid());
  Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  Serial.println();
  EEPROM.begin(1024);
  pinMode(wificonfig_pin, INPUT_PULLUP);
  pinMode(status_led,OUTPUT);
  digitalWrite(relay_pin, EEPROM.read(431));
  guid_authkey();
  ticker.attach(0.5, tick);
  if (WiFi.SSID()==""){ initialConfig = true;}
  if (LittleFS.begin()) {  // ------------------------- wificonfig read -----------------
    Serial.println("mounted file system");
    if (LittleFS.exists("/config.json")) {
      Serial.println("reading config file");
       File configFile = LittleFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
         size_t size = configFile.size();
         std::unique_ptr<char[]> buf(new char[size]);
         configFile.readBytes(buf.get(), size);
        DynamicJsonDocument json(1024);
        DeserializationError deserializeError = deserializeJson(json, buf.get());
        serializeJsonPretty(json, Serial);
        if (!deserializeError) {Serial.println("\nparsed json");
          if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
          if (json.containsKey("Email")) strcpy(Email, json["Email"]);
          if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
        } else {
          Serial.println("failed to load json config");
        configFile.close();
   } else {
    Serial.println("failed to mount FS");
   wifi_station_set_hostname(Supla_name);
     hjl01.setCurrentMultiplier(HJL01_CURRENT_RATIO);
     hjl01.setVoltageMultiplier(HJL01_VOLTAGE_RATIO);
     hjl01.setPowerMultiplier(HJL01_POWER_RATIO);
    // void begin(unsigned char cf_pin, unsigned char cf1_pin, unsigned char sel_pin, unsigned char currentWhen = HIGH, bool use_interrupts = false, unsigned long pulse_timeout = PULSE_TIMEOUT);
    hjl01.begin(CF_PIN, CF1_PIN, SEL_PIN, CURRENT_MODE, true);
    get_hj101_config();
    attachInterrupt(CF1_PIN, hjl01_cf1_interrupt, FALLING);
    attachInterrupt(CF_PIN, hjl01_cf_interrupt, FALLING);
    EEPROM.get(460, mem_energy);
    _mem_energy = mem_energy;
    Serial.print("mem energy: ");
    Serial.println(mem_energy);
    relay1 = new Supla::Control::Relay(relay_pin);
    new Hj101();
    SuplaDevice.setName(Supla_name);
    SuplaDevice.setStatusFuncImpl(&status_func);
    wifi.enableSSL(false);
    SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
char buffer[50];
void loop() {
  if (initialConfig == true){ondemandwifiCallback();EEPROM.write(431, 0); EEPROM.commit();}
   int C_W_read = digitalRead(wificonfig_pin);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay2) {
     if (C_W_read != C_W_state2) {
       C_W_state2 = C_W_read;
       if (C_W_state2 == LOW) {
        Serial.println("short press");
         if (!relay1->isOn()) {
          relay1->turnOn();
          yield();
          Serial.println("relayOn");
          Eeprom_save() ;
       }else{
         relay1->turnOff();
         yield();
         Serial.println("relayOff");
         Eeprom_save() ;
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       Serial.println("long press");
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        ondemandwifiCallback () ;
   last_C_W_state = C_W_read;
  if (shouldSaveConfig == true) { // ------------------------ wificonfig save --------------
    Serial.println(" config...");
    json["Supla_server"] = Supla_server;
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    File configFile = LittleFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
        serializeJson(json, configFile);
    configFile.close();
    Serial.println("Config written successfully");
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
  if (s == 17){
    if ((Tik == true) && (WiFi.status() == WL_CONNECTED)){ticker.detach();Tik = false;}
    if(millis() > eep_milis){
     Eeprom_save() ;
     eep_milis = millis() + 3000 ;
    if (recover){
     Serial.println("ticker off");
      if (EEPROM.read(431) == true){
       relay1->turnOn();
        yield();
       recover = false;
  if ((s != 17) && (Tik == false)) { ticker.attach(0.5, tick);Tik = true;Serial.println("ticker on  no 17"); }
  //if ((WiFi.status() != WL_CONNECTED) && (Tik == false)){ticker.attach(0.5, tick);Tik = true;Serial.println("ticker on no wifi"); }
  if (s == 10){recover = true;}
   SuplaDevice.iterate();
   delay(50);
   if (WiFi.status() == WL_CONNECTED){
    if (starting){
      httpUpdater.setup(&httpServer, "/update", "admin", "pass");
      httpServer.begin();
      starting = false;
    httpServer.handleClient();
    if ((digitalRead(relay_pin) == digitalRead(status_led)) && (s ==17)){
    digitalWrite(status_led,!digitalRead(relay_pin));
      EEPROM.commit();
To access the Wi-Fi configuration, press button for at least 10 seconds, Led winks in wificonfig.
in the configuration page enter the data for "suplaServer, Email and Supla Device Name (name with which it will be seen in the cloud and DHCP)"
expectedVoltage = for calibration.
expectedActivePower = for calibration.
clear Storage = reset counter.
calibration process:
connect a resistive load with a known consumption, for example a 60W bulb.
access wificonfig (button pressed 10 seconds)
in the "expectedVoltage" field set the voltage of your line for example 227.
in the "expectedActivePower" field, set the consumption of the connected load, for example 60.
press save.
The procedure takes about 15 seconds, then the device restarts and the readings will be correct.
the calibration is only executed if there are data in both fields "expectedVoltage" and "expectedActivePower"
This allows for example to change the Wi-Fi network without recalibrating.
Gosund_SP111_DOUT_8Mbit.rar
Thanks a lot for your work
I put this soft into a similar socket -BliTZWOIF BW-SPH6 15A 3450W. Everything works, it measures energy, but apart from power in "W" and consumption in "kWh", it does not show other parameters in the application - voltage, current, etc.
This is correct? however, are these sockets different?
elmaya
pn lis 23, 2020 10:01 pm
Maniek913 pisze:
that model has CF1 connected to Gpio4 and not to Gpio14
try with this ;)
BlizWolf_BW-SHP6_15A_LittleFS_DOUT_8Mbit.rar
compiled firmware
(379.07 KiB) Pobrany 6 razy
Maniek913
wt lis 24, 2020 10:14 am
elmaya pisze:
Maniek913 pisze:
try with this ;)
Thank you very much. Works great :)
Screenshots before and after replacing the software:
It's just interesting why with an ordinary light bulb it shows a power factor different from 1?
elmaya
wt lis 24, 2020 11:51 am
have you done the calibration with pure resistive load?
don't expect exact results from HLW8012 it is not a precision device. ;)
Maniek913
wt lis 24, 2020 3:37 pm
elmaya pisze:
Yes, the load is an ordinary light bulb.
The power factor fluctuates around "1" but the measurement precision is sufficient
Thanks again
elmaya
wt lis 24, 2020 3:54 pm
Maniek913 pisze:
elmaya pisze:
Thanks again
try to calibrate with a toaster or a heater, something between 500 and 1000w of consumption.
In any case, the reading of voltage, watts and kWh will be quite accurate.
Nowy11
wt lis 24, 2020 7:00 pm
elmaya pisze:
Maniek913 pisze:
try with this ;)
Witam czy ten soft moge wgrac do gosund sp111????
Hello, can I upload this soft to gosund sp111 ???
elmaya
wt lis 24, 2020 8:01 pm
Nowy11 pisze:
elmaya pisze:
Maniek913 pisze:
try with this ;)
viewtopic.php?p=80073#p80073
Wróć do „Ogólna dyskusja”
