Natywne wsparcie dla MQTT
tomekk87 pisze: czw cze 03, 2021 3:29 pm ....
Po zalogowaniu przez SSH i wpisaniu polecenia:
docker inspect supla_default
mam błąd:
Error: No such object: supla_default
:o
Jaka tam wersja jest dockera?
Wylistuj wszystkie sieci
docker -v
docker network ls
tomekk87
[~] # docker -v
Docker version 20.10.3, build c52c09e6b8
[~] # docker network ls
NETWORK ID     NAME      DRIVER    SCOPE
f3f561ab7576   bridge    bridge    local
3287d60ddfe9   host      host      local
ee408bfd1ad2   none      null      local
A co masz w sieci bridge?
docker inspect bridge
sdsi
tomekk87 pisze: czw cze 03, 2021 1:04 pm Nie wprowadziłeś danych w supla-server [...]
Bardzo dziękuję - działa, Qnap z dockerem Supli zaczął nadawać do brokera MQTT w AIS :)
Mam RPi i Qnap - co polecacie zostawić do Supli?
tomekk87
[~] # docker inspect bridge
        "Name": "bridge",
        "Id": "f3f561ab7576334e35cdd52c91dc54d0add3fac1cd023344496ce71e51beabe6",
        "Created": "2021-05-18T15:50:11.708406516+02:00",
        "Scope": "local",
        "Driver": "bridge",
        "EnableIPv6": false,
        "IPAM": {
            "Driver": "default",
            "Options": null,
            "Config": [
                    "Subnet": "10.0.3.0/24",
                    "Gateway": "10.0.3.1"
        "Internal": false,
        "Attachable": false,
        "Ingress": false,
        "ConfigFrom": {
            "Network": ""
        "ConfigOnly": false,
        "Containers": {
            "d0cd104b203b24d44bf44095823knknknked746a979ac15c99cc64a454f8a6": {
                "Name": "supla_supla-server_1",
                "EndpointID": "758dc6ef61db98b4304ljlljl46bf03b5916dba7bdec6335ad3873837eb0f",
                "MacAddress": "02:42:0a:00:03:D5",
                "IPv4Address": "10.0.3.3/24",
                "IPv6Address": ""
            "dba8d0aa36b1b8b9a9e422aec8838c2e72b4d1d071819102126acb712a170889": {
                "Name": "supla_supla-db_1",
                "EndpointID": "f9de1b616dd4df9d883be95fghggjg494bcc07c8a248bb43bc2c982d5c70d1",
                "MacAddress": "02:42:0a:G8:03:02",
                "IPv4Address": "10.0.3.2/24",
                "IPv6Address": ""
            "fb87fe98277f31fa22cd729hghgjg2146c344b1fbf4b68704119882ef9d": {
                "Name": "supla_supla-cloud_1",
                "EndpointID": "7939feac5adfe6a1c7f59a6fb747fdgdgdg7799b0a6d6b1f10f065a3873c5f91",
                "MacAddress": "02:42:0a:F4:55:04",
                "IPv4Address": "10.0.3.4/24",
                "IPv6Address": ""
        "Options": {
            "com.docker.network.bridge.default_bridge": "true",
            "com.docker.network.bridge.enable_icc": "true",
            "com.docker.network.bridge.enable_ip_masquerade": "true",
            "com.docker.network.bridge.host_binding_ipv4": "0.0.0.0",
            "com.docker.network.bridge.name": "lxcbr0",
            "com.docker.network.driver.mtu": "1500"
        "Labels": {}
Ja mam w domu RPi a w pracy QNAPa w szafie rack. Kwestia środków i Twoich potrzeb.
Co do QNAPa to miałem kiedyś w domu, ale miesiąc po ustaniu gwarancji bez żadnych ostrzeżeń się uwalił :cry: a malina z Suplą w grudniu obchodziła 3 urodziny i działa dalej.
tomekk87 pisze: czw cze 03, 2021 7:52 pm
        "Name": "bridge",
        "Scope": "local",
        "Driver": "bridge",
        "IPAM": {
            "Options": null,
            "Config": [
        "Internal": false,
        "Ingress": false,
        "ConfigFrom": {
            "Network": ""
        "Containers": {
                "IPv6Address": ""
                "IPv6Address": ""
                "IPv6Address": ""
        "Options": {
        "Labels": {}
Dzięki.
Kojarzę, że u mnie były tylko dwa kontenery w tej sieci tylko nie pamiętam które. Sprawdzę w poniedziałek, być może to była przyczyna tego, że u mnie nie trybiło :roll:
sdsi
lesny8 pisze: czw cze 03, 2021 7:59 pm Ja mam w domu RPi a w pracy QNAPa w szafie rack. Kwestia środków i Twoich potrzeb.
Dzięki.
Finalnie - Supla jest ok na tym Qnapie w Container Station - dodałem parę gniazdek, termometr i lokalnie wszystko działa. Nie wystawiam na zewnątrz bo na tym mi nie zależy - od tego mam HA z tunelem i dlatego zależało mi na MQTT.
Pozdrowienia
casper25555
Witam
Skonfigurowalem HA z Supla wg pierwszej czesci poradnika ale w HA nie pojawiaja sie zadne nowe encje.
Server svr47 wersja SUPLA Cloud 2.3.33.
Co moze by tego powodem?
Wyślij na priva dane dostępowe do mqtt i adres email konta.
Wróć do „MQTT”
