Controlling SUPLA receivers with no Internet connection
Post Reply
piolin49
Wed Oct 09, 2019 10:57 am
Hi:
I've got a Supla SWR 01 to control a roller.
The system works ok when Internet connection is available. But, when Internet connection is not available, althoug internal Wifi Network is ok, I can't control the roller from my mobile.
Any way to control the system from mobile (Supla Application) without Internet connection but Wifi Network ok, with receivers an mobile connected?
Any way to got It althoug a trick?
Regards
Contact:
Wed Oct 09, 2019 11:12 am
You can install your own server locally at home without cloud.supla.org. For this you can use e.g. raspberry Pi.
piolin49
Wed Oct 09, 2019 11:47 am
Thank you for your reply:
May you show me a guide for implementing a easy way to install and configure this server inside my Network?
On the other hand, I guess Supla Team could consider implement an option to connect Supla receivers and mobile (App) in the same wifi network.
Thank you in advance.
Regards
piolin49
Wed Oct 09, 2019 1:00 pm
Ok. Thank you.
Can you say me what ports (in / out) use Supla for connecting to server and vice-versa. I guess if router has UPNP active, automatic configuration got.
Regards
Contact:
Wed Oct 09, 2019 1:39 pm
TCP 2016,2015,443
Post Reply
