Page 1 of 2
Arduino - Supla
Posted: Tue Mar 27, 2018 4:16 pm
by vuhazu
I used Arduino and NodeMCU
if connect to svr3.supla.org, it ok
but my local server, it Not connected
I followed this tutorial
can someone help me?
thanks.
Re: Arduino - Supla
Posted: Tue Mar 27, 2018 5:00 pm
by pzygmunt
Use docker
Re: Arduino - Supla
Posted: Tue Mar 27, 2018 5:25 pm
by vuhazu
docker is ok
But there are some problems, for example install php myadmin or create account
Is there any remedy for my local server?
Re: Arduino - Supla
Posted: Tue Mar 27, 2018 5:46 pm
by pzygmunt
LD_LIBRARY_PATH=/usr/lib/supla-server
export LD_LIBRARY_PATH
Re: Arduino - Supla
Posted: Tue Mar 27, 2018 6:20 pm
by vuhazu
this is the directory
and the device is not connected
Re: Arduino - Supla
Posted: Wed Mar 28, 2018 7:02 am
by pzygmunt
Check logs
Re: Arduino - Supla
Posted: Wed Mar 28, 2018 11:03 am
by vuhazu
connect to my local server , It stands here
Re: Arduino - Supla
Posted: Wed Mar 28, 2018 11:07 am
by pzygmunt
Check server log
Re: Arduino - Supla
Posted: Wed Mar 28, 2018 11:40 am
by vuhazu
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.113-sun8i (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: dma_declare_contiguous(266): ION reserve size should be 4m align! adjust size to 128MBytes
[    0.000000] cma: CMA: reserved 128 MiB at 58000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 131072
[    0.000000] free_area_init_node: node 0, pgdat c09914c0, node_mem_map c0aca000
[    0.000000]   Normal zone: 1152 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 129920 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0f5c000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: root=UUID=28c1cfce-318b-4f95-bf76-92472adc14bf rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=7 ubootpart=a90cd46f-01 ubootsource=mmc   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 371692k/371692k available, 152596k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08d0a9c   (8995 kB)
[    0.000000]       .init : 0xc08d1000 - 0xc0924ec0   ( 336 kB)
[    0.000000]       .data : 0xc0926000 - 0xc0995d30   ( 448 kB)
[    0.000000]        .bss : 0xc09964e4 - 0xc0ac97c8   (1229 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.002330] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.002471] pid_max: default: 32768 minimum: 301
[    0.002843] Security Framework initialized
[    0.002930] AppArmor: AppArmor disabled by boot time parameter
[    0.003354] Mount-cache hash table entries: 512
[    0.005380] Initializing cgroup subsys cpuacct
[    0.005458] Initializing cgroup subsys memory
[    0.005590] Initializing cgroup subsys devices
[    0.005654] Initializing cgroup subsys freezer
[    0.005715] Initializing cgroup subsys blkio
[    0.005798] Initializing cgroup subsys perf_event
[    0.006008] CPU: Testing write buffer coherency: ok
[    0.006151] ftrace: allocating 24851 entries in 73 pages
[    0.060573] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060660] [sunxi_smp_prepare_cpus] enter
[    0.060755] Setting up static identity map for 0x4061fbf8 - 0x4061fc50
[    0.062679] CPU1: Booted secondary processor
[    0.062679] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.070775] CPU2: Booted secondary processor
[    0.070775] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.070937] CPU3: Booted secondary processor
[    0.070937] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.080352] Brought up 4 CPUs
[    0.080509] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.081961] devtmpfs: initialized
[    0.096716] wakeup src cnt is : 2.
[    0.096768] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.096792] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.096814] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.096838] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.096860] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.096882] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.096905] sunxi pm init
[    0.097217] pinctrl core: initialized pinctrl subsystem
[    0.107733] NET: Registered protocol family 16
[    0.113058] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.113268] script_sysfs_init success
[    0.113355] sunxi_dump_init success
[    0.115168] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.117590] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.117590] plat: add bmp085 device
[    0.117590] plat: add pcf8591 device
[    0.117590] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.117590] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.117590] script config pll_video to 297 Mhz
[    0.117590] script config pll_de to 864 Mhz
[    0.117590] script config pll_ve to 402 Mhz
[    0.117590] sunxi_default_clk_init
[    0.117590] try to set pll6ahb1 to 200000000
[    0.117590] try to set ahb clk source to pll6ahb1
[    0.117590] set ahb clk source to pll6ahb1
[    0.117590] try to set ahb1 to 200000000
[    0.117590] try to set apb1 to 100000000
[    0.130479] bio: create slab <bio-0> at 0
[    0.130672] [ARISC] :sunxi-arisc driver v1.04
[    0.148914] [ARISC] :arisc version: [v0.1.58]
[    0.257870] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.261148] SCSI subsystem initialized
[    0.261347] usbcore: registered new interface driver usbfs
[    0.261550] usbcore: registered new interface driver hub
[    0.270095] usbcore: registered new device driver usb
[    0.270357] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.270416] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.270470] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.271981] Linux video capture interface: v2.00
[    0.272507] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.274061] cfg80211: Calling CRDA to update world regulatory domain
[    0.274218] NetLabel: Initializing
[    0.274218] NetLabel:  domain hash size = 128
[    0.274218] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.274218] NetLabel:  unlabeled traffic allowed by default
[    0.274218] Switching to clocksource arch_sys_counter
[    0.297172] FS-Cache: Loaded
[    0.297774] CacheFiles: Loaded
[    0.321600] NET: Registered protocol family 2
[    0.345166] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.346346] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.346914] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.347527] TCP: Hash tables configured (established 16384 bind 16384)
[    0.347583] TCP: reno registered
[    0.347627] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.347711] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.348415] NET: Registered protocol family 1
[    0.349266] RPC: Registered named UNIX socket transport module.
[    0.349330] RPC: Registered udp transport module.
[    0.349374] RPC: Registered tcp transport module.
[    0.349418] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.349849] Trying to unpack rootfs image as initramfs...
[    0.849031] Freeing initrd memory: 3724K
[    0.850443] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.850738] sunxi_reg_init enter
[    0.852594] audit: initializing netlink socket (disabled)
[    0.852735] type=2000 audit(0.850:1): initialized
[    0.856645] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.857057] misc fatfs initialized
[    0.857502] NFS: Registering the id_resolver key type
[    0.858328] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.858401] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.859975] NTFS driver 2.1.30 [Flags: R/W].
[    0.860758] fuse init (API version 7.18)
[    0.861635] msgmni has been set to 989
[    0.864661] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.864749] io scheduler noop registered
[    0.864791] io scheduler deadline registered
[    0.864947] io scheduler cfq registered (default)
[    0.865795] [DISP]disp_module_init
[    0.866452] cmdline,init_disp=
[    0.866539] cmdline,disp=
[    0.875423] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.891595] Console: switching to colour frame buffer device 90x36
[    0.910290] [DISP]disp_module_init finish
[    0.910994] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.911412] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.911816] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.913133] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.921219] sw_uart_pm()890 - uart0 clk is already enable
[    0.929191] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    1.050586] console [ttyS0] enabled
[    2.702450] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    2.718177] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    2.734322] sunxi_cmatest_init enter
[    2.734410] sunxi_cmatest_init success
[    2.743074] brd: module loaded
[    2.763301] loop: module loaded
[    2.775648] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    2.791228] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    2.807891] spi spi0: master is unqueued, this is deprecated
[    2.823658] spi spi1: master is unqueued, this is deprecated
[    2.838398] tun: Universal TUN/TAP device driver, 1.6
[    2.851904] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.868498] PPP generic driver version 2.4.2
[    2.881564] PPP BSD Compression module registered
[    2.894669] PPP Deflate Compression module registered
[    2.913352] PPP MPPE Compression module registered
[    2.926504] NET: Registered protocol family 24
[    2.939196] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.974646] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.991690] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    3.009335] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    3.040073] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    3.055674] hub 1-0:1.0: USB hub found
[    3.067651] hub 1-0:1.0: 1 port detected
[    3.100567] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.117697] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    3.135180] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    3.170102] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    3.185972] hub 2-0:1.0: USB hub found
[    3.198125] hub 2-0:1.0: 1 port detected
[    3.231089] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.248193] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    3.266014] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    3.300080] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    3.301231] hub 3-0:1.0: USB hub found
[    3.301266] hub 3-0:1.0: 1 port detected
[    3.322162] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.322220] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    3.373770] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    3.400098] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    3.415960] hub 4-0:1.0: USB hub found
[    3.428220] hub 4-0:1.0: 1 port detected
[    3.441314] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.476583] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    3.493575] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    3.510672] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    3.585175] hub 5-0:1.0: USB hub found
[    3.597741] hub 5-0:1.0: 1 port detected
[    3.631072] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    3.648247] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    3.665343] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    3.745194] hub 6-0:1.0: USB hub found
[    3.757845] hub 6-0:1.0: 1 port detected
[    3.791238] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    3.808307] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    3.825251] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    3.905104] hub 7-0:1.0: USB hub found
[    3.917649] hub 7-0:1.0: 1 port detected
[    3.950884] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    3.968122] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    3.985135] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    4.065087] hub 8-0:1.0: USB hub found
[    4.077637] hub 8-0:1.0: 1 port detected
[    4.091019] Initializing USB Mass Storage driver...
[    4.105208] usbcore: registered new interface driver usb-storage
[    4.120443] USB Mass Storage support registered.
[    4.134024] usbcore: registered new interface driver ums-alauda
[    4.149162] usbcore: registered new interface driver ums-cypress
[    4.164247] usbcore: registered new interface driver ums-datafab
[    4.179240] usbcore: registered new interface driver ums_eneub6250
[    4.194345] usbcore: registered new interface driver ums-freecom
[    4.209149] usbcore: registered new interface driver ums-isd200
[    4.223561] usbcore: registered new interface driver ums-jumpshot
[    4.238004] usbcore: registered new interface driver ums-karma
[    4.251995] usbcore: registered new interface driver ums-onetouch
[    4.266231] usbcore: registered new interface driver ums-realtek
[    4.280180] usbcore: registered new interface driver ums-sddr09
[    4.293992] usbcore: registered new interface driver ums-sddr55
[    4.307551] usbcore: registered new interface driver ums-usbat
[    4.321107]  uinput result 0 , vmouse_init
[    4.322375] mousedev: PS/2 mouse device common for all mice
[    4.335715] sunxikbd_init failed.
[    4.345972] sunxikbd_init failed.
[    4.345999] ls_fetch_sysconfig_para: ls_unused.
[    4.357600] ltr_init: ls_fetch_sysconfig_para err.
[    4.358243] [RTC] WARNING: Rtc time will be wrong!!
[    4.370289] [RTC] WARNING: use *internal OSC* as clock source
[    4.383699] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    4.397762] i2c /dev entries driver
[    4.408959] sunxi cedar version 0.1
[    4.409047] [cedar]: install start!!!
[    4.409443] [cedar]: install end!!!
[    4.409816] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    4.432760] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    4.456135] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    4.480111] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    4.504826] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    4.530087] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    4.556028] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    4.582765] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    4.610003] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    4.638360] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    4.667987] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    4.698869] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    4.731020] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    4.764443] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    4.799195] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    4.834689] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    4.870919] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    4.907851] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    4.944917] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    4.966250] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    4.991825] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    5.026760] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    5.046909] timeout_to_interv, line 167
[    5.064711] interv_to_timeout, line 189
[    5.082239] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    5.118553] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    5.154854] calibrat: max_cpufreq 1008Mhz Type 1!
[    5.154881] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    5.191209] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Feb 23 2017 at 19:53:48
[    5.191280] [mmc]: get mmc0's sdc_power is null!
[    5.191340] [mmc]: get mmc1's sdc_power is null!
[    5.191359] [mmc]: get mmc1's 2xmode ok, val = 1
[    5.191379] [mmc]: get mmc1's ddrmode ok, val = 1
[    5.191411] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    5.196095] [mmc]: sdc0 power_supply is null
[    5.198929] no blue_led, ignore it!
[    5.216321] Registered led device: red_led
[    5.216565] Registered led device: green_led
[    5.216600] no led_0, ignore it!
[    5.232924] no led_1, ignore it!
[    5.248874] no led_2, ignore it!
[    5.263792] mmc0: new SDHC card at address 0001
[    5.264827] mmcblk0: mmc0:0001 SD 7.39 GiB
[    5.267844]  mmcblk0: p1
[    5.268950] mmcblk mmc0:0001: Card claimed for testing.
[    5.268976] mmc0:0001: SD 7.39 GiB
[    5.343687] no led_3, ignore it!
[    5.358045] no led_4, ignore it!
[    5.372034] no led_5, ignore it!
[    5.385675] no led_6, ignore it!
[    5.398961] no led_7, ignore it!
[    5.413502] usbcore: registered new interface driver usbhid
[    5.429114] usbhid: USB HID core driver
[    5.450687] asoc: sndcodec <-> sunxi-codec mapping ok
[    5.467834] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    5.496465] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    5.524118] [DAUDIO0] driver not init,just return.
[    5.545606] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    5.563400] oprofile: using arm/armv7-ca7
[    5.576856] u32 classifier
[    5.588181]     Performance counters on
[    5.600628]     input device check on
[    5.612698]     Actions configured
[    5.624724] IPv4 over IPv4 tunneling driver
[    5.638661] TCP: bic registered
[    5.649927] TCP: cubic registered
[    5.661082] TCP: westwood registered
[    5.672261] TCP: highspeed registered
[    5.683261] TCP: hybla registered
[    5.693562] TCP: htcp registered
[    5.703473] TCP: vegas registered
[    5.713427] TCP: veno registered
[    5.723240] TCP: scalable registered
[    5.733544] TCP: lp registered
[    5.743309] TCP: yeah registered
[    5.753196] TCP: illinois registered
[    5.763436] Initializing XFRM netlink socket
[    5.774946] NET: Registered protocol family 10
[    5.788578] NET: Registered protocol family 17
[    5.799780] NET: Registered protocol family 15
[    5.810885] Registering the dns_resolver key type
[    5.823503] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    5.838807] ThumbEE CPU extension supported.
[    5.850379] Registering SWP/SWPB emulation handler
[    5.863882] registered taskstats version 1
[    5.876954] cmdline,disp=
[    5.886981] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE!
[    5.901702] [DISP] bsp_disp_tv_register,line:990:'ptv is null
[    5.915024] tv registered!!
[    5.915102] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr1<-->device1, type=2, mode=11
[    5.939576] ths_fetch_sysconfig_para: type err  device_used = 1.
[    5.955972] CPU Budget:corekeeper enabled
[    5.967570] CPU Budget:Register notifier
[    5.978476] CPU Budget:register Success
[    5.989281] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    6.020458] [rf_pm]: Did not config module_power1 in sys_config
[    6.020488] [rf_pm]: Did not config module_power2 in sys_config
[    6.020510] [rf_pm]: Did not config module_power3 in sys_config
[    6.020532] [rf_pm]: mod has no chip_en gpio
[    6.020550] [rf_pm]: regulator on.
[    6.020585] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 !
[    6.122193] [wifi_pm]: get wifi_sdc_id failed
[    6.123771] [mmc]: sdc1 power_supply is null
[    6.179263] mmc1: new high speed SDIO card at address 0001
[    6.222241] [wifi_pm]: wifi gpio init is OK !!
[    6.222352] [rfkill]: init no bt used in configuration
[    6.222373] ALSA device list:
[    6.232691]   #0: audiocodec
[    6.242809]   #1: sndhdmi
[    6.254315] Freeing init memory: 332K
[    6.348302] systemd-udevd[95]: starting version 215
[    7.493382] Btrfs loaded
[    9.032496] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   10.590632] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[   10.622674] systemd[1]: Detected architecture 'arm'.
[   10.683164] systemd[1]: Set hostname to <orangepizero>.
[   11.616229] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[   11.656804] systemd[1]: Expecting device dev-ttyGS0.device...
[   11.690329] systemd[1]: Expecting device dev-ttyS0.device...
[   11.720273] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[   11.738886] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.757296] systemd[1]: Starting Remote File Systems (Pre).
[   11.790251] systemd[1]: Reached target Remote File Systems (Pre).
[   11.806874] systemd[1]: Starting Encrypted Volumes.
[   11.840232] systemd[1]: Reached target Encrypted Volumes.
[   11.855898] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[   11.875029] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   11.893887] systemd[1]: Starting Paths.
[   11.920237] systemd[1]: Reached target Paths.
[   11.934858] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[   11.990276] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.020292] systemd[1]: Starting Root Slice.
[   12.050246] systemd[1]: Created slice Root Slice.
[   12.065603] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[   12.100247] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   12.117939] systemd[1]: Starting Delayed Shutdown Socket.
[   12.150242] systemd[1]: Listening on Delayed Shutdown Socket.
[   12.166428] systemd[1]: Starting Journal Socket (/dev/log).
[   12.200232] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.216861] systemd[1]: Starting User and Session Slice.
[   12.250237] systemd[1]: Created slice User and Session Slice.
[   12.266730] systemd[1]: Starting udev Control Socket.
[   12.300232] systemd[1]: Listening on udev Control Socket.
[   12.316122] systemd[1]: Starting udev Kernel Socket.
[   12.350237] systemd[1]: Listening on udev Kernel Socket.
[   12.365612] systemd[1]: Starting Journal Socket.
[   12.400235] systemd[1]: Listening on Journal Socket.
[   12.414955] systemd[1]: Starting System Slice.
[   12.450262] systemd[1]: Created slice System Slice.
[   12.464748] systemd[1]: Starting Increase datagram queue length...
[   12.611314] systemd[1]: Starting Restore / save the current clock...
[   12.731955] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   12.861531] systemd[1]: Mounting POSIX Message Queue File System...
[   12.960914] systemd[1]: Starting udev Coldplug all Devices...
[   13.042122] systemd[1]: Mounting Debug File System...
[   13.121253] systemd[1]: Mounted Huge Pages File System.
[   13.140846] systemd[1]: Started Set Up Additional Binary Formats.
[   13.156513] systemd[1]: Starting LSB: Set keymap...
[   13.271013] systemd[1]: Starting system-serial\x2dgetty.slice.
[   13.310324] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   13.325917] systemd[1]: Starting system-getty.slice.
[   13.360269] systemd[1]: Created slice system-getty.slice.
[   13.382539] systemd[1]: Starting Load Kernel Modules...
[   13.471290] systemd[1]: Started File System Check on Root Device.
[   13.486523] systemd[1]: Starting Slices.
[   13.520381] systemd[1]: Reached target Slices.
[   13.550343] systemd[1]: Mounted Debug File System.
[   13.580408] systemd[1]: Mounted POSIX Message Queue File System.
[   13.690400] systemd[1]: Started Increase datagram queue length.
[   13.716361] [XRADIO] Driver Label:L34M.01.08.0002  Feb 23 2017 19:54:01
[   13.731537] [XRADIO] Allocated hw_priv @ d6b5d240
[   13.745014] [SBUS] XRadio Device:sdio clk=50000000
[   13.758224] xradio wlan power on
[   13.769345] gpio wl_reg_on set val 1, act val 1
[   13.819385] gpio wl_reg_on set val 0, act val 0
[   13.821411] gpio wl_reg_on set val 1, act val 1
[   13.921490] [XRADIO] Detect SDIO card 1
[   13.950354] systemd[1]: Started Restore / save the current clock.
[   14.060299] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   14.280835] [XRADIO_ERR] xradio_load_firmware: can't read config register, err=-110.
[   14.297817] [XRADIO_ERR] xradio_load_firmware failed(-110).
[   14.310406] systemd[1]: Started LSB: Set keymap.
[   14.430306] systemd[1]: Started udev Coldplug all Devices.
[   14.450837] systemd[1]: Time has been changed
[   14.464967] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.571418] systemd[1]: Starting Syslog Socket.
[   14.600510] systemd[1]: Listening on Syslog Socket.
[   14.614593] systemd[1]: Starting Journal Service...
[   14.628995] xradio wlan power off
[   14.640904] gpio wl_reg_on set val 0, act val 0
[   14.690997] [XRADIO] Remove SDIO card 1
[   14.691322] mmc1: card 0001 removed
[   14.691766] [mmc]: sdc1 power_supply is null
[   14.740452] systemd[1]: Started Journal Service.
[   14.801122] ep_matches, wrn: endpoint already claimed, ep(0xc097afbc, 0xd68b3440, ep1in-bulk)
[   14.801165] ep_matches, wrn: endpoint already claimed, ep(0xc097afbc, 0xd68b3440, ep1in-bulk)
[   14.801195] ep_matches, wrn: endpoint already claimed, ep(0xc097b008, 0xd68b3440, ep1out-bulk)
[   14.801218] gadget_is_softwinner_otg is not -int
[   14.801234] gadget_is_softwinner_otg is not -int
[   14.801269] g_serial gadget: Gadget Serial v2.4
[   14.815018] g_serial gadget: g_serial ready
[   14.837878] [XRADIO_ERR] xradio_host_dbg_init failed=2599
[   14.852554] [XRADIO] Driver Label:L34M.01.08.0002  Feb 23 2017 19:54:01
[   14.868799] [XRADIO] Allocated hw_priv @ d6b5d240
[   14.883107] xradio wlan power on
[   14.894312] gpio wl_reg_on set val 1, act val 1
[   14.942709] systemd-udevd[177]: starting version 215
[   14.944369] gpio wl_reg_on set val 0, act val 0
[   14.946389] gpio wl_reg_on set val 1, act val 1
[   15.046492] [XRADIO] Detect SDIO card 1
[   15.048044] [mmc]: sdc1 power_supply is null
[   15.099877] mmc1: new high speed SDIO card at address 0001
[   15.114698] [SBUS] XRadio Device:sdio clk=50000000
[   15.129198] [XRADIO] XRADIO_HW_REV 1.0 detected.
[   15.363240] [XRADIO] Bootloader complete
[   15.545992] [XRADIO] Firmware completed.
[   15.561882] [WSM] Firmware Label:XR_C01.08.0043 Jun  6 2016 20:41:04
[   15.580230] [XRADIO] Firmware Startup Done.
[   15.597537] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   15.686194] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77)
[   15.722089] bmp085: probe of 0-0077 failed with error -70
[   15.743396] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48)
[   15.772182] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48)
[   16.408636] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[   16.829552] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[   18.461961] systemd-journald[176]: Received request to flush runtime journal from PID 1
[   19.259557] gmac0: probed
[   19.272149] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00)
[   21.270374] PHY: gmac0-0:00 - Link is Up - 100/Full
[   25.203180] Registered IR keymap rc-empty
[   25.219150] rc0: sunxi-ir as /devices/virtual/rc/rc0
[   25.733270] IR RC5(x) protocol handler initialized
[   26.234017] rc s_cir0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[   28.110590] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0
[   28.162840] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Re: Arduino - Supla
Posted: Wed Mar 28, 2018 11:43 am
by pzygmunt
I mean logs of supla-server (daemon)
