Arduino compiling error
Post Reply
jason
Sun Sep 30, 2018 6:49 pm
Compiling any of the examples provided with the arduino library yields the following error:
In file included from /Users/MB/Documents/Arduino/libraries/SuplaDevice/SuplaDevice.h:300:0,
from /Users/MB/Documents/Arduino/libraries/SuplaDevice/examples/SuplaEthernetShield/SuplaEthernetShield.ino:19:
/Users/MB/Documents/Arduino/libraries/SuplaDevice/supla_main_helper.cpp:70:3: error: 'UNKNOWN' does not name a type
UNKNOWN ETHERNET LIBRARY
exit status 1
Both Ethernet and uIP libraries are installed.
Contact:
Sun Sep 30, 2018 6:52 pm
Clean your env or reinstal Arduino IDE
jason
Mon Oct 01, 2018 3:26 pm
Tried both in three separate computers, errors keep coming. Any other suggestion? IDE versions installed: 1.6.9 & 1.8.7
Contact:
Mon Oct 01, 2018 4:03 pm
Install the following libraries:
UIPEthernet
Ethernet
dyrdzik
Fri Oct 12, 2018 8:11 am
Hi!
I had the same problem and the solution is very easy. By default, when you install Arduino IDE, it comes with Ethernet library v 2.0.0. Just go to the libraries manager and change the version to 1.1.2 (the one mentioned by pzygmunt). As soon as you do that, you'll still receive some warnings, but the code will compile and it works on Arduino very well! Love SUPLA :)
M.
selo
Wed Mar 13, 2019 1:11 am
Hi!
M.
Thanks
Post Reply
