Problem z GUID
Proszę o wyjaśnienie jak lepiej wygenerować GUID bo zobaczcie co się robi (dwa inne WeMos) i nie wiem czy nie będzie to problemem
Kod do generowania prosty - chyba każdy tak robi :
 uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
   char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4],
                                       mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6],mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5],
                                       mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1]};
Sam mac to zbyt mało.
W trywialny sposób tak:
https://github.com/SUPLA/supla-espressi ... cfg.c#L285
elmaya
an example for esp8266:
if it not stored , generate GUID and AUTHKEY and save in eeprom.
if stored, retrieve Guid and Authkey from eeprom
#include <SPI.h>
#include <OneWire.h>
#include <SuplaDevice.h>
#include <EEPROM.h>
#include "ESP8266TrueRandom.h"
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
// ESP8266 based board:
 Supla::ESPWifi wifi("your_wifi_ssid", "your_wifi_password");
 * This example requires Dallas Temperature Control library installed.
 * https://github.com/milesburton/Arduino-Temperature-Control-Library
// Setup a oneWire instance
OneWire oneWire(24); // 24 - Pin number
// Pass oneWire reference to Dallas Temperature
// DS18B20 Sensor read implementation
    double t = -275;
    if ( sensors.getDeviceCount() > 0 )
         sensors.requestTemperatures();
         t = sensors.getTempCByIndex(0);
    return t;
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 321;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
  read_guid();
  read_authkey();
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 321;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  EEPROM.begin(1024);
  Serial.begin(9600);
  // Init DS18B20 library
  sensors.begin();
  // generate or retrieve Guid and Authkey.
  guid_authkey();
  // Set temperature callback
  // CHANNEL0 - RELAY
  SuplaDevice.addRelay(44, true);           // 44 - Pin number where the relay is connected
                                      // Call SuplaDevice.addRelay(44, true) with an extra "true" parameter
                                      // to enable "port value inversion"
                                      // where HIGH == LOW, and LOW == HIGH
  // CHANNEL1 - RELAY
  SuplaDevice.addRelay(45, true);           // 45 - Pin number where the relay is connected
  // CHANNEL3 - TWO RELAYS (Roller shutter operation)
  SuplaDevice.addRollerShutterRelays(46,     // 46 - Pin number where the 1st relay is connected
                                     47, true);    // 47 - Pin number where the 2nd relay is connected
  // CHANNEL4 - Opening sensor (Normal Open)
  SuplaDevice.addSensorNO(5); // 5 - Pin number where the sensor is connected
                               // Call SuplaDevice.addSensorNO(A0, true) with an extra "true" parameter
                               // to enable the internal pull-up resistor
  // CHANNEL5 - Opening sensor (Normal Open)
  SuplaDevice.addSensorNO(6); // 6 - Pin number where the sensor is connected
  // CHANNEL6 - Thermometer DS18B20
   * SuplaDevice Initialization.
                    "svr1.supla.org",  // SUPLA server address
                    "email@address",   // Email address used to login to Supla Cloud
                    AUTHKEY);          // Authorization key
void loop() {
  SuplaDevice.iterate();
elmaya wrote: Sat Dec 21, 2019 4:09 pm an example for esp8266:
#include <SPI.h>
#include <EEPROM.h>
    double t = -275;
    return t;
    int eep_gui = 301;
    int eep_aut = 321;
    EEPROM.commit();
  read_guid();
  read_authkey();
  int i, ii = 0;
  int eep_star = 301;
      temp_read = "0x";
      ii++;
  return read_eeprom;
  int i, ii = 0;
  int eep_star = 321;
      temp_read = "0x";
      ii++;
  return read_eeprom;
void setup() {
  EEPROM.begin(1024);
  Serial.begin(9600);
  sensors.begin();
  guid_authkey();
  // CHANNEL0 - RELAY
  // CHANNEL1 - RELAY
void loop() {
You normally surprise me. But thanks for your commitment, thanks to you I already know a lot when it comes to soft. Thanks for Ota and now for this. You rarely meet such helpful people ...
Temat do zamknięcia
