Czujnik poczty w skrzynce
Zibi
Panowie jest w ogóle opcja uspac esp?
michael
elmaya
supla esp8266 sensor with deep sleep
esp8266 connects to Supla to send the sensor state and the supply voltage (as temperature) with an interval of 120 seconds.
Pinout:
Gpio 2 // D4 status led ---on when in wificonfig---blinks every 2 minutes in normal operation
Gpio 14 // wificonfig pin ---hold Pressed and restart to access wificonfig ---will enter wificonfig automatically on first start.
Gpio 12 // D6 sensor pin
to make this possible it is necessary to edit SuplaDevice.h.
edit this line:
#define ACTIVITY_TIMEOUT 30 // max 240 -------------------
to this:
#define ACTIVITY_TIMEOUT 240 // max 240 -------------------
Remember to restore to the original state when you finish so as not to affect other compilations!
With this in theory we should be able to do sleep of up to 240 seconds but for some reason with more than 120 seconds it appears as disconnected.
Pinout:
edit this line:
to this:
#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <ESP8266WebServer.h>
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
ADC_MODE(ADC_VCC);
WiFiClient client;
#define status_led 2 // D4 status Led ---on when in wificonfig---blinks every 2 minutes in normal operation
#define sensor 12 // D6 sensor pin
#define config_pin 14 // D5 wificonfig pin ---hold Pressed and restart to access wificonfig ---will enter wificonfig automatically on first start.
#define SLEEP_TIME 120 // sleep seconds
int s;
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout = 120; // seconds to run the wifi config
unsigned long runing;
void saveConfigCallback () { //callback notifying us of the need to save config
Serial.println("Should save config");
shouldSaveConfig = true;
void ondemandwifiCallback () {
digitalWrite(status_led, LOW);
WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManager wifiManager;
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_Supla_server);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality(8);
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("SuplaLP")) {
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
//read updated parameters
strcpy(Supla_server, custom_Supla_server.getValue());
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
WiFi.softAPdisconnect(true); // close AP
double t = -275;
t = (ESP.getVcc()/1024.0);
return t;
void status_func(int status, const char *msg) { // ------------------------ Status --------------------------
s=status; // -- to check if we are registered and ready before restore from memory
void setup() { //------------------------------------------------ Setup ----------------------------------------------
runing = millis();
Serial.begin(115200);
pinMode(config_pin, INPUT_PULLUP);
pinMode(status_led,OUTPUT);
digitalWrite(status_led, HIGH);
if (WiFi.SSID()==""){
initialConfig = true;
WiFi.mode(WIFI_STA);
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial); //print config data to serial on startup
if (json.success()) {
Serial.println("\nparsed json");
strcpy(Supla_server, json["Supla_server"]);
strcpy(Location_id, json["Location_id"]);
strcpy(Location_Pass, json["Location_Pass"]);
strcpy(Supla_name, json["Supla_name"]);
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
if (digitalRead(config_pin) == LOW)ondemandwifiCallback() ;
SuplaDevice.setName(Supla_name);
SuplaDevice.addSensorNO(sensor, true);
SuplaDevice.setStatusFuncImpl(&status_func); // ----------------------------- Status -----------------------------
int LocationID = atoi(Location_id);
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
void loop() {
if (initialConfig)ondemandwifiCallback();
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["Supla_server"] = Supla_server;
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["Supla_name"] = Supla_name;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
Serial.println("config saved");
ESP.restart();
delay(5000);
WiFi.begin();
delay(100);
Serial.print(".");
SuplaDevice.iterate();
switch (s) { // ------------------------------------------------ Status ------------------------------------
case 17: // ----- STATUS_REGISTERED_AND_READY
//SuplaDevice.channelValueChanged(0,digitalRead(sensor));
Serial.print("elapsed: ");
Serial.println(millis() - runing);
ESP.deepSleep(SLEEP_TIME * 1000000, WAKE_RF_DEFAULT);
break;
if ((millis() - runing) > 10000){
Serial.println("conection timeout");
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
SuplaDeviceCallbacks cb;
cb.get_temperature = &get_temperature;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
Zibi
Jak esp jest uspione to jaki prąd pobiera? Wtedy wystarczy jak dostanie impuls np z kontaktronu i się wzbudzi? Ikona w supli też się zmienia jak jest uspiony i wzbudzany bo nie wiem jak to działa.
elmaya
consumption depends on many circumstances but will be less than an average of 15maZibi wrote: Thu Nov 14, 2019 6:06 pm Jak esp jest uspione to jaki prąd pobiera? Wtedy wystarczy jak dostanie impuls np z kontaktronu i się wzbudzi? Ikona w supli też się zmienia jak jest uspiony i wzbudzany bo nie wiem jak to działa.
It will not read impulses while in deepsleep.
Zibi
To super sprawa15mA. To by mnie zadowalało. Wgraniem będę miał problem na tym się nie znam, a biblioteki mam a wyskakuje mi błąd fsh include.
Nie masz pewnie biblioteki fs.h pobierz i wrzuć do library.Zibi wrote: Thu Nov 14, 2019 6:51 pm To super sprawa15mA. To by mnie zadowalało. Wgraniem będę miał problem na tym się nie znam, a biblioteki mam a wyskakuje mi błąd fsh include.
Druga opcja - masz plik bin. Wrzuć programem esp download jak pokazał @elmaya na screenie
elmaya
After some measurements I think 5ma is more realistic.
Fs.h is part of arduino esp board manager, it is not possible to be missing.
you must use esp board manager 2.4.2.
I have 2.5.0 work too.
where is the name of the device entered which is reported in the cloud? reports as a thermostat
