Automatyczny reset - da się?
Dawid84
pt sty 03, 2020 9:36 pm
Elmaya, can you do something about my problem?
Thank you
Dawid
elmaya
pt sty 03, 2020 10:09 pm
Dawid84 pisze:
Thank you
Do you use the same SSID and Password on the router and amplifier?
I see two different IPs:
192.168.8.3 / 255.255.255.0 / 192.168.8.164
192.168.8.177 / 255.255.255.0 / 192.168.8.1
witch is the ip that corresponds to the amplifier?
Here it is connected and reset the counter to 0
Connected
Adres IP:
(RSSI): -56 dBm
Pinging host www.google.com
Success!!
Success!!
What version are you using, I see continuous WiFi disconnections?
Dawid84
sob sty 04, 2020 10:41 pm
In the main router I have the SSID HUAWEI-B525-DOM, and in the HUAWEI-B525-DOM1 amplifier I have a module registered and connected to the HUAWEI-B5B5-DOM1 with the amplifier and it should be reset if there is no internet access from the main router. as I wrote earlier, if on the main router it blocks access of the amplifier to the Internet, there is no reset, but if I remove the amplifier from the socket, it will be reset after a certain time
Dawid
kwiatek67
sob lut 29, 2020 8:47 am
Koledzy który z tych softów będzie najlepszy do Yunshan ?
Gucio2607.
sob lut 29, 2020 9:40 am
A nie można by zrobić tego na sonnof'ie?. Taki przedłużacz który po prostu rozłącza zasilanie routera.
Zainstalowane:
kwiatek67
sob lut 29, 2020 2:31 pm
Gucio2607. pisze:
Mój router zasilany jest z zewnętrznego zasilacza 12 V i to za jego pomocą będę zasilał Yunshana.
elmaya
sob lut 29, 2020 2:40 pm
kwiatek67 pisze:
the one on the first page of the thread,
if you read a little sure you find it :lol:
kwiatek67
ndz mar 01, 2020 3:51 pm
elmaya pisze:
kwiatek67 pisze:
Works, thank you
