Servo sterowanie Esp8266
Duch__
wt sty 14, 2020 11:10 pm
I get something like this and I don't know why it doesn't connect to WIFI after the reset. I selected my WIFI ssid and writed only password.
*WM: [2] <- HTTP WiFi save
*WM: [3] Method: POST
*WM: [2] Parameters
*WM: [2] --------------------
*WM: [2] server: svrX.supla.org
*WM: [2] email: my@email.pl
*WM: [2] name: Dimmer
*WM: [2] status: SuplaDevice initialized
*WM: [3] Sent wifi save page
*WM: [2] process connect
*WM: [2] Connecting as wifi client...
*WM: [1] STA static IP:
*WM: [2] setSTAConfig static ip not set
*WM: [3] WIFI station disconnect
*WM: [1] CONNECTED:
*WM: [1] Connecting to NEW AP: ssid
*WM: [3] Using Password: password
*WM: [3] WiFi station enable
*WM: [3] enableSTA PERSISTENT ON
*WM: [1] connectTimeout not set, ESP waitForConnectResult...
local IP: 192.168.2.122
subnetMask: 255.255.255.0
gatewayIP: 192.168.2.1
Signal Strength (RSSI): -56 dBm
*WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] Connect to new AP [SUCCESS]
*WM: [1] Got IP Address:
*WM: [1] 192.168.2.122
Should save config
*WM: [2] disconnect configportal
*WM: [2] restoring usermode STA
*WM: [2] wifi status: WL_CONNECTED
*WM: [2] wifi mode: STA
*WM: [1] config portal exiting
connected...yeey :)
saving config
  "Supla_server": "svrX.supla.org",
  "Email": "my@email.pl",
  "Supla_name": "Dimmer"
}config saved
wifi Station disconnected
 ets Jan  8 2013,rst cause:2, boot mode:(3,2)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vac02aff5
~ld
GUID : XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
AUTHKEY : YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
mounted file system
reading config file
opened config file
{"Supla_server":"svrX.supla.org","Email":"my@email.pl","Supla_name":"Dimmer"}
parsed json
Pos: 0
Using protocol version 8
MEW-01, 8x SRW-01, 2x ROW-02, SUPLA TOUCH DL, 16xDS na ESP (GUI), Sonoff S20 CWU, AIRLY
elmaya
wt sty 14, 2020 11:27 pm
for me It looks like this.
GUID : xxxxxxxx
AUTHKEY : xxxxxxxx
mounted file system
reading config file
opened config file
{"Supla_server":"beta-cloud.supla.org","Email":"mail@mail.com","Supla_name":"Servo"}
            parsed json
Pos: 0
in begin
local IP: 192.168.1.106
gatewayIP: 192.168.1.1
Signal Strength (RSSI): -29 dBm
Establishing connection with: beta-cloud.supla.org (port: 2015)
Connected
What Supla library do you use?
have you tried with the compiled version?
elmaya
czw sty 16, 2020 4:57 pm
Duch__ pisze:
*WM: [2] Parameters
*WM: [1] CONNECTED:
Should save config
connected...yeey :)
saving config
}config saved
tail 8
chksum 0x2d
csum 0x2d
vac02aff5
~ld
mounted file system
reading config file
opened config file
parsed json
Pos: 0
Surely you have selected a Flash size without SPIFFS and this is necessary to store credentials.
doing tests I have noticed that if I do not erase the flash of the module it tries to connect with the blank credentials and that effect occurs.
To avoid blocking I have changed these two lines of the code.
char Supla_server[81]=("Unknown server address");   //  it was before     char Supla_server[81];
char Email[81]=("Unknown email address");                 //  it was before      char Email[81];
Duch__
czw sty 16, 2020 4:59 pm
Everything is OK now. I forgot about "v2 Higher Bandwitch". My mistake.
byniom
czw sty 23, 2020 12:15 pm
Czy można jakoś ustawić aby servo pracowało w zakresie od 0 do 50% przy korzystaniu z ustawień on off ?
elmaya
czw sty 23, 2020 12:33 pm
byniom pisze:
edytuj ten wiersz:
int pos = map(_brightness, 0, 100, 0,180);
gdzie 0,180 to pozycja minimalna i maksymalna.
int pos = map(_brightness, 0, 100, 0,90);
dla minimum 0 i maksymalnie 90 (50%)
void set_rgbw() {
    int pos = map(_brightness, 0, 100, 0,90);  // from 0 to 50%
      Serial.print("Pos: "); Serial.println(pos);
      myservo.write(pos);              // tell servo to go to position in variable 'pos'
byniom
czw sty 23, 2020 1:33 pm
Dziekuję :)
Piotr682
wt kwie 21, 2020 9:59 am
Dzień dobry
Soft przydatny, fajnie działa jednak mam drobny problem, mianowicie po skompilowaniu w Arduino IDE i wgraniu softu po kilku godzinach urządzenie rozłącza się i ma problem z ponownym połączeniem (próby połączenie z serwerem widać w terminalu) po resecie łączy się natychmiast jednak bez niego nie nawiązuje połączenia.Prosiłbym o sugestie gdzie popełniam błąd
elmaya
wt kwie 21, 2020 10:09 am
are you using this code?
viewtopic.php?p=58473#p58473
Piotr682
wt kwie 21, 2020 3:21 pm
Tak, tego. Skompilowany (gotowiec) download/file.php?id=9045soft wgrany po skonfigurowaniu pracuje poprawnie regularnie wysyla
natomiast skompilowany w Aduino IDE po konfiguracji wifi łączy się a po jakimś czasie
biblioteki https://github.com/SUPLA/arduino/tree/develop
https://github.com/bblanchon/ArduinoJson/tree/v5.13.2
Wifimanager-development
esp8266TrueRandom
Arduino 1.8.10
Wróć do „Pomysły i koncepcje”
