LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Czujnik ruchu TZ-P1 plus sensor natężenia światła
Taki :
https://pl.aliexpress.com/item/10050069 ... pt=glo2pol
      ============ After Setup End =============
                                                  [ 11166][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 11169][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 11687][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x8f46)
[ 11687][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 12193][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x8f46), endpoint(1)
[ 12264][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 12265][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x8f46
[ 12694][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 12695][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 12696][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 12696][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZE200_bh3n6gk8"
[ 12265][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZE200_bh3n6gk8
[ 13199][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 13199][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 13200][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 13201][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0601"
[ 12698][I][Z2S_Device_Scanner.ino:89] loop(): model TS0601
[ 13204][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 36678
[ 13252][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 36678, endpoints count 1
[ 13253][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 13263][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 13698][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 36678, endpoint # 1
[ 13699][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 0
[ 13699][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 13700][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 13700][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 13701][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[ 13900][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x37dc) is open for 180 seconds
[ 13985][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 13985][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 13986][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 13987][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 13987][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 13988][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 13989][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 13990][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 13991][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[ 13992][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[ 13993][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 14007][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 14008][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 14008][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[ 14023][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 14024][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[ 14025][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[ 14025][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[ 14026][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[ 14027][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[ 14028][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[ 14042][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 14043][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 14043][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 14044][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8f46), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 14095][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 14096][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 14968][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 14968][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 14969][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 14970][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 14970][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 14971][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 17547][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 17547][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 17982][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 17982][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[ 22694][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 22694][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 22695][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 22696][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 22696][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 22697][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 23511][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 23512][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[ 28838][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 28838][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 28839][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 28839][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 28840][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 28840][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0xdb23), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 30845][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 30846][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
ostatnie linki to reakcja na naciśniecie przycisku igłą
LukiSpajder
Tak przycisk
https://pl.aliexpress.com/item/10050053 ... pt=glo2pol
Ale tak jakoś nie reaguje dobrze na naciśnięcie połączy się bez problemu , ale potem już nie reaguje;
                                                         [ 20102][I][ZigbeeCore.        cpp:330] esp_zb_app_signal_handler(): Network(0x37dc) is open for 180 seconds
[ 30969][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[ 34975][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 34977][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 35510][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x0649)
[ 35510][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 35627][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x649), endpoint(1)
[ 35705][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 35705][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x649
[ 35744][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35744][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x649) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35745][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 35746][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_yj6k7vfo"
[ 35706][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_yj6k7vfo
[ 35864][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35865][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x649) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35866][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 35866][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0041"
[ 35747][I][Z2S_Device_Scanner.ino:89] loop(): model TS0041
[ 35868][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 1609
[ 35985][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 1609, endpoints count 4
[ 35985][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 35986][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 2, id 2
[ 35986][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 3, id 3
[ 35987][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 4, id 4
[ 36036][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1609, endpoint # 1
[ 36037][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 2
[ 36037][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 1
[ 36038][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 6
[ 36038][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 57344
[ 36039][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[ 36039][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 36040][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[ 36055][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1609, endpoint # 2
[ 36056][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 36057][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 6
[ 36057][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 36057][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 36083][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 1609, endpoint # 4
[ 36083][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 36084][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 6
[ 36084][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 36085][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 36109][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36110][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 36111][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 36111][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 36112][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 36126][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36127][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 36143][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36143][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 36144][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 36145][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 36146][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 36147][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 36148][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 36148][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x6), data type (0x42)
[ 36149][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 36150][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0xffde), data type (0x20)
[ 36151][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 36152][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0xfffe), data type (0x30)
[ 36152][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0xffe2), data type (0x20)
[ 36153][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x0), attribute id (0xffe3), data type (0x48)
[ 36169][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36169][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x0), data type (0xf0)
[ 36170][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x1), data type (0x23)
[ 36171][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x2), data type (0x23)
[ 36172][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x3), data type (0x21)
[ 36173][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x4), data type (0x23)
[ 36173][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x5), data type (0x21)
[ 36174][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x6), data type (0x30)
[ 36175][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x7), data type (0x21)
[ 36176][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x8), data type (0x21)
[ 36177][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0x9), data type (0x21)
[ 36178][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0x19), attribute id (0xfffd), data type (0x21)
[ 36192][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36192][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0xa), attribute id (0xfffd), data type (0x21)
[ 36216][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36216][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 36231][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36231][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 36232][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 36233][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 36234][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 36248][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36248][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x2), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 36272][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36273][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 36287][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36288][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 36288][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 36289][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 36290][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 36294][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 36294][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x4), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 36937][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 37018][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x37dc) is open for 180 seconds
[ 40987][I][ZigbeeGateway.cpp:195] Z2S_simple_desc_req_cb(): Z2S simple desc failed
[ 46535][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 46536][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0xe000), attribute id (0x0), data type (0x10)
[ 46537][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x649), source endpoint (0x1), source cluster (0xe000), attribute id (0x1), data type (0x10)
[ 52555][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 52555][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 55552][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 55552][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[ 65559][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 65560][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 67521][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 67521][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x8f46) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[ 98218][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
i taki zalania
https://pl.aliexpress.com/item/10050074 ... pt=glo2pol
                                                  [ 12720][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 12722][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 13241][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x2189)
[ 13241][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 13746][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x2189), endpoint(1)
[ 13770][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 13771][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x2189
[ 14248][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 14249][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 14249][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 14250][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_k4ej3ww2"
[ 13772][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_k4ej3ww2
[ 14753][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 14753][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 14754][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 14755][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0207"
[ 14252][I][Z2S_Device_Scanner.ino:89] loop(): model TS0207
[ 14757][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 8585
[ 14806][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 8585, endpoints count 1
[ 14807][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 14818][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 15252][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 8585, endpoint # 1
[ 15253][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[ 15253][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 15254][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 15254][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[ 15255][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[ 15255][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[ 15449][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x1816) is open for 180 seconds
[ 15475][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 15475][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 15476][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 15477][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 15478][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 15479][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 15480][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 15480][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 15481][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[ 15482][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[ 15483][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 15500][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 15501][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 15501][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[ 15516][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 15517][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[ 15518][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[ 15519][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[ 15519][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[ 15520][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[ 15521][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[ 15535][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 15536][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 15537][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 15537][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2189), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 15541][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 22761][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 22761][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[ 23505][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 23506][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 24065][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 24066][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 24066][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 24067][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 24068][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 24068][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 27449][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[ 29361][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[ 29362][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[ 29572][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 29573][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 29573][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 29574][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 29574][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x2189) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 29575][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
przed ostanie linie to zalanie a ostanie to naciśniecie przycisku .Chyba że to przesyłać ci osobna z opisem co było zrobione ?
LukiSpajder
cd
tu z tego czujnik próbowałem uzyskać coś przy słabej baterii ale jednoznacznie nie wiem czy coś się pojawia - może ty coś wypatrzysz :
 (0x20)
[179234][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[179248][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[181170][I][ZigbeeCore.cpp:332] esp_zb_app_signal_handler(): Network(0xd350) closed, devices joining not allowed.
[188098][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[188098][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[188099][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[188100][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[188100][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[188101][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[193381][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[193381][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[193940][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[193941][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[193941][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[193942][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[193942][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[193943][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[203491][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[203491][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[203492][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[203493][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[203493][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[203494][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[218556][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[218556][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[219115][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[219116][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[219116][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[219117][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[219117][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[219118][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[219886][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[222654][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[222655][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[223209][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[223209][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[223210][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[223211][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[223211][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[223212][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[223770][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[223771][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[224331][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[224332][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[224332][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[224333][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[224333][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[224334][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[227971][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[227971][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[228531][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[228531][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[228532][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[228532][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[228533][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[228534][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[253525][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[253526][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[254085][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[254085][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[254086][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[254086][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[254087][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[254087][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[265730][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[275318][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[304861][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[304862][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[305421][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[305421][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[305422][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[305423][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[305423][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[305424][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[324420][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[330072][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[330080][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x36da)
[330080][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[330593][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x36da), endpoint(1)
[330690][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[330690][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x36da
[331101][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[331101][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[331102][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[331102][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_k4ej3ww2"
[330691][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_k4ej3ww2
[331617][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[331618][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[331618][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[331619][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0207"
[331104][I][Z2S_Device_Scanner.ino:89] loop(): model TS0207
[331620][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 14042
[332134][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 14042, endpoints count 1
[332134][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[332288][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[332288][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[332289][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[332290][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[332290][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[332291][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[332813][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 14042, endpoint # 1
[332813][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[332814][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[332814][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[332815][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[332815][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[332816][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[332869][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[332870][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[333397][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[333397][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[333398][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[333399][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[333400][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[333401][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[333401][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[333402][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[333403][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[333404][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[333405][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[333419][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[333420][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[333421][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[333436][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[333436][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[333437][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[333438][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[333439][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[333439][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[333440][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[333455][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[333455][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[333456][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[333457][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[333471][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[342320][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[342320][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[342321][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[342322][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[342322][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[342323][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[352335][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[352336][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[352336][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[352337][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[352338][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[352338][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[358977][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[362351][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[362352][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[362352][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[362353][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[362353][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[362354][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[378356][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[387348][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[387349][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[387908][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[387908][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[387909][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[387910][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[387910][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[387911][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[402267][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[402275][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x36da)
[402276][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[402788][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x36da), endpoint(1)
[402800][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[402800][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x36da
[403296][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[403296][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[403297][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[403298][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_k4ej3ww2"
[402801][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_k4ej3ww2
[403812][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[403813][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[403814][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[403814][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0207"
[403299][I][Z2S_Device_Scanner.ino:89] loop(): model TS0207
[403815][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 14042
[404329][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 14042, endpoints count 1
[404329][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[404483][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[404483][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[404484][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[404485][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[404485][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[404486][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[405009][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 14042, endpoint # 1
[405009][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[405009][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[405010][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[405010][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[405011][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[405011][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[405064][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[405065][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[405592][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[405593][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[405593][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[405594][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[405595][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[405596][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[405597][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[405597][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[405598][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[405599][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[405600][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[405614][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[405615][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[405616][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[405631][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[405631][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[405632][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[405633][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[405634][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[405634][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[405635][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[405650][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[405650][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[405651][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[405652][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[405666][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[408519][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[414517][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[414517][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[414518][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[414518][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[414519][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[414519][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[424534][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[424534][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[424535][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[424535][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[424536][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[424537][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[434461][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[434512][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[434512][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[434513][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[434514][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[434514][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[434515][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[441212][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[441213][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[441773][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[441773][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[441774][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[441774][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[441775][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[441775][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[455552][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[465704][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[471219][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[471228][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x36da)
[471228][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[471740][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x36da), endpoint(1)
[471789][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[471789][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x36da
[472248][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[472249][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[472249][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[472250][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_k4ej3ww2"
[471790][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_k4ej3ww2
[472765][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[472765][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x0)
[472766][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[472767][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0207"
[472251][I][Z2S_Device_Scanner.ino:89] loop(): model TS0207
[472768][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 14042
[473281][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 14042, endpoints count 1
[473282][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[473436][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[473436][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[473437][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[473437][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[473438][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[473438][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[473961][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 14042, endpoint # 1
[473961][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 1
[473962][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[473962][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[473963][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[473963][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[473964][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
[474017][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1031) callback
[474017][V][ZigbeeHandlers.cpp:167] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[474545][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[474545][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[474546][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[474547][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[474547][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[474548][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[474549][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[474550][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[474551][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[474551][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[474552][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[474567][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[474567][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[474568][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[474583][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[474583][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[474584][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[474585][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[474586][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[474587][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[474588][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[474602][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[474603][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[474604][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[474604][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x36da), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[474618][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[483452][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[483453][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[483453][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[483454][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[483454][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[483455][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[492309][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[493459][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[493459][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[493460][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[493460][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[493461][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[493461][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[503474][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[503475][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[503475][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[503476][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[503477][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x36da) src endpoint(1) to dst endpoint(1) cluster(0x1)
[503477][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
lukasz06
Has thanked: 46 times
Been thanked: 21 times
vajera wrote: Wed Jan 15, 2025 3:42 pm
LukiSpajder wrote: Wed Jan 15, 2025 3:32 pm A więc skaner uruchomiony :D
Logi termometru Xiaomi LYWSD03MMC - wgrane alternatywne oprogramowanie zigbeeb tutaj wiecej https://github.com/pvvx/ATC_MiThermometer.
=========== Before Setup Start ===========
                                          Chip Info:
                Model             : ESP32-C6
                                              Package           : 0
        Revision        : 0.01
               Cores             : 1
                                      CPU Frequency     : 160 MHz
        XTAL Frequenc        y    : 4-----------------------------------
                                           INTERNAL Memory Info:
                            Total Size        :   446252 B ( 435.8 KB)
        Free Byt        es        :   412280 B ( 402.6 KB)
                                    Allocated Bytes   :    25276 B (  24.7 KB)
        Minimum Free Bytes:   407392 B ( 397.8 KB)
                                            Largest Free Block:   385012 B ( 376        .0 KB)
                                                Flash Info:
                       Chip Size         : 16777216 B (16 MB)
                                                               Block Size        :    65536 B (  64.0 KB)
                           Sector Size       :     4096 B (   4.0 KB)
        Page Size        :      256 B (   0.2 KB)
                                   Bus Speed         : 40 MHz
                                                               Bus Mode        : QIO
                                                Partitions Info:
                                          nvs : addr: 0x00009000, size:    20.0        KB, type: DATA, subtype: NVS
                                        otadata : addr: 0x0000E000, size:     8.        0 KB, type: DATA, subtype: OTA
                                             app0 : addr: 0x00010000, size:  128        0.0 KB, type:  APP, subtype: OTA_0
                                                 app1 : addr: 0x00150000, size:        1280.0 KB, type:  APP, subtype: OTA_1
                                                   spiffs : addr: 0x00290000, si        ze:  1384.0 KB, type: DATA, subtype: SPIFFS
                                                    zb_storage : addr: 0x003EA00        0, size:    16.0 KB, type: DATA, subtype: FAT
                                                          zb_fct : addr: 0x003EE        000, size:     4.0 KB, type: DATA, subtype: FAT
                                                            rcp_fw : addr: 0x003        EF000, size:     4.0 KB, type: DATA, subtype: SPIFFS
                                                               coredump : addr:        0x003F0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
                     Software Info:
        C        ompile Date/Time : Jan 13 2025 12:49:28
                                         Compile Host OS   : windows
        ESP-IDF Ve        rsion   : v5.1.4-972-g632e0c2a9f-dirty
                                        Arduino Version   : 3.0.7
                           Board Info:
        Arduino Board     : ESP32C6_DEV
                                  Arduino Variant   : esp32c6
                                                               Arduino FQBN        : esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80        ,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=verbose,Erase        Flash=all,JTAGAdapter=default,ZigbeeMode=zczr
                                             ============ Before Setup End =====        =======
       [ 20379][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit functi        on for type GPIO (1) successfully set to 0x42004d3c
[ 20379][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set        to type GPIO (1) with bus 0xa
[ 20380][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[ 20380][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
[ 20453][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
[ 20456][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
[ 20456][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoin        t: 1, Device ID: 0x0050
[ 20460][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Con        fig Ready (0x17), status: ESP_FAIL
[ 20461][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initia        lized
[ 20466][I][ZigbeeCore.cpp:332] esp_zb_app_signal_handler(): Network(0x26ef) clo        sed, devices joining not allowed.
[ 20468][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up i        n non factory-reset mode
[ 20468][I][ZigbeeCore.cpp:239] esp_zb_app_signal_handler(): Device rebooted
[ 20468][I][ZigbeeCore.cpp:243] esp_zb_app_signal_handler(): Opening network for        joining for 180 seconds
[ 20469][D][ZigbeeCore.cpp:471] searchBindings(): Requesting binding table for a        ddress 0x0000
[ 20470][D][ZigbeeCore.cpp:410] bindingTableCb(): Binding table callback for add        ress 0x0000 with status 0
[ 20471][D][ZigbeeCore.cpp:413] bindingTableCb(): Binding table info: total 0, i        ndex 0, count 0
[ 20471][D][ZigbeeCore.cpp:416] bindingTableCb(): No binding table entries found
=========== After Setup Start ============
        Free Byte        s        :   383464 B ( 374.5 KB)
                                   Allocated Bytes   :    54100 B (  52.8 KB)
        M        inimum Free Bytes:   383464 B ( 374.5 KB)
                                           Largest Free Block:   360436 B ( 352.        0 KB)
                                               GPIO Info:
                     GPIO : BUS_TYPE[bus/unit][chan]
                   9 : GPIO
                               12 : USB_DM
                                              13 : USB_DP
                                                             16 : UART_TX[0]
        17 : UART_RX[0]
               ============ After Setup End =============
                                                         [ 20937][I][ZigbeeCore.        cpp:330] esp_zb_app_signal_handler(): Network(0x26ef) is open for 180 seconds
[ 46386][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 46388][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 46917][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xccea)
[ 46917][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 47421][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0xccea), endpoint(1)
[ 47466][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 47466][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0xccea
[ 47928][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 47928][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xccea) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 47929][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 47929][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "Xiaomi"
[ 47467][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer Xiaomi
[ 48440][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 48441][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xccea) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 48441][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(12)
[ 48442][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "LYWSD03MMC-z"
[ 47931][I][Z2S_Device_Scanner.ino:89] loop(): model LYWSD03MMC-z
[ 48445][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 52458
[ 48931][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 52458, endpoints count 1
[ 48931][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 48947][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 49439][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 52458, endpoint # 1
[ 49440][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 7, out clusters # 1
[ 49440][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 49441][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 49441][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 49442][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 32
[ 49442][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 5, id 516
[ 49443][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 6, id 1026
[ 49443][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 7, id 1029
[ 49443][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 49579][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x26ef) is open for 180 seconds
[ 50129][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50129][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 50130][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 50131][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 50132][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 50132][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 50133][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 50134][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 50135][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[ 50136][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[ 50137][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0x6), data type (0x42)
[ 50137][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 50158][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50158][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 50159][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 50160][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 50179][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50179][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 50180][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[ 50202][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50202][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x0), data type (0x23)
[ 50203][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x1), data type (0x23)
[ 50204][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x2), data type (0x21)
[ 50205][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x3), data type (0x21)
[ 50206][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x4), data type (0x23)
[ 50207][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x5), data type (0x23)
[ 50208][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0x6), data type (0x21)
[ 50208][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x20), attribute id (0xfffd), data type (0x21)
[ 50228][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50228][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x0), data type (0x30)
[ 50229][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x2), data type (0x30)
[ 50230][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x100), data type (0x29)
[ 50231][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x101), data type (0x29)
[ 50232][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x102), data type (0x29)
[ 50233][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x103), data type (0x29)
[ 50234][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x104), data type (0x21)
[ 50234][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x105), data type (0x21)
[ 50235][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x106), data type (0x30)
[ 50236][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0x107), data type (0x20)
[ 50237][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x204), attribute id (0xfffd), data type (0x21)
[ 50253][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50253][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x402), attribute id (0x0), data type (0x29)
[ 50254][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x402), attribute id (0x1), data type (0x29)
[ 50255][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x402), attribute id (0x2), data type (0x29)
[ 50256][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x402), attribute id (0x3), data type (0x21)
[ 50257][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x402), attribute id (0xfffd), data type (0x21)
[ 50261][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50261][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x405), attribute id (0x0), data type (0x21)
[ 50262][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x405), attribute id (0x1), data type (0x21)
[ 50263][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x405), attribute id (0x2), data type (0x21)
[ 50264][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x405), attribute id (0x3), data type (0x21)
[ 50264][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x405), attribute id (0xfffd), data type (0x21)
[ 50275][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 50276][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x0), data type (0xf0)
[ 50277][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x1), data type (0x23)
[ 50277][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x2), data type (0x23)
[ 50278][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x3), data type (0x21)
[ 50279][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x4), data type (0x23)
[ 50280][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x5), data type (0x21)
[ 50281][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x6), data type (0x30)
[ 50282][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x7), data type (0x21)
[ 50282][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x8), data type (0x21)
[ 50283][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0x9), data type (0x21)
[ 50284][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xccea), source endpoint (0x1), source cluster (0x19), attribute id (0xfffd), data type (0x21)
[ 59025][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
dodany
Dziwne, ja też go mam, ale mi się nie pokazał w logach
Been thanked: 32 times
lukasz06 wrote: Wed Jan 15, 2025 5:16 pm [...]
W nich coś chyba było z kilkukrotnym wyjęciem i wsadzeniem baterii, aby zaczął wysyłać sygnał parowania (albo mi się coś już myli). W każdym razie ważne, że komuś się udało odczytać logi i jest dodane :)
Has thanked: 37 times
Been thanked: 27 times
lukasz06 wrote: Wed Jan 15, 2025 5:16 pm Dziwne, ja też go mam, ale mi się nie pokazał w logach
Warunek: wgrane alternatywne oprogramowanie zigbeeb.
[email protected]
Has thanked: 18 times
@vajera
Pytania i Uwagi do kodu ;) kolejność jak mi się zapisało
1. W logach było by lepiej jak by to jednak było w HEXach
log_i("Z2S_findChannelNumberSlot %d:%d:%d:%d:%d:%d:%d:%d
a tu Ci się formatowanie rozjechało bo chyba dałeś %s dla adresu ;)
 Z2S_onBoundDevice(): No channel found for address �<�З8���p���xV����@xV�� �@`, adding new one
2. Wartość mogła by pochodzić z priv_auth_data
  Zigbee.setRebootOpenNetwork(180);
3. Inny manufacturer do dodania:
  {.manufacturer_name = "_TZ3000_rdhukkmi", .model_name = "TS0201", .z2s_device_desc_id = Z2S_DEVICE_DESC_TEMPHUMIDITY_SENSOR},
4. Co ile odpytywany jest czujnik temperatury? jak nacisnę przycisk reset krótko, lub kiedy bramka jest w trybie parowania to wyśle dane, ale potem cisza.
18:27:05.389 -> [  3311][D][ZigbeeCore.cpp:138] zigbeeInit(): Initialize Zigbee stack
18:27:05.389 -> [  3319][D][ZigbeeCore.cpp:145] zigbeeInit(): Register all Zigbee EPs in list
18:27:05.389 -> [  3328][I][ZigbeeCore.cpp:153] zigbeeInit(): List of registered Zigbee EPs:
18:27:05.389 -> [  3335][I][ZigbeeCore.cpp:155] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
18:27:05.421 -> [  3352][I][ZigbeeCore.cpp:245] esp_zb_app_signal_handler(): Zigbee stack initialized
18:27:05.421 -> [  3366][I][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Network(0xb155) closed, devices joining not allowed.
18:27:05.455 -> [  3378][I][ZigbeeCore.cpp:251] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
18:27:05.455 -> [  3387][I][ZigbeeCore.cpp:264] esp_zb_app_signal_handler(): Device rebooted
18:27:05.455 -> [  3394][I][ZigbeeCore.cpp:268] esp_zb_app_signal_handler(): Opening network for joining for 20 seconds
18:27:05.455 -> [  3403][D][ZigbeeCore.cpp:499] searchBindings(): Requesting binding table for address 0x0000
18:27:05.490 -> [  3413][D][ZigbeeCore.cpp:438] bindingTableCb(): Binding table callback for address 0x0000 with status 0
18:27:05.490 -> [  3422][D][ZigbeeCore.cpp:441] bindingTableCb(): Binding table info: total 4, index 0, count 3
18:27:05.490 -> [  3431][D][ZigbeeCore.cpp:451] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0003, dst_addr_mode 3
18:27:05.490 -> [  3442][I][Z2S_Gateway.ino:342] Z2S_onBTCBoundDevice(): BTC bound device 0xd470 on endpoint 0x1 cluster id 0x3
18:27:05.524 -> [  3452][I][Z2S_Gateway.ino:77] Z2S_printDevicesTableSlots(): valid 1, ieee addr �<�З8��, model_id 0x1000, endpoint 0x1, cluster 0x405, channel 0, channel type 3038
18:27:07.202 -> [  5147][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xffffffff
18:27:07.235 -> [  5160][D][ZigbeeCore.cpp:469] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0xd470, ieee addr: A4:C1:38:97:D0:A9:3C:8D
18:27:07.235 -> [  5174][D][ZigbeeCore.cpp:451] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0001, dst_addr_mode 3
18:27:07.235 -> [  5185][I][Z2S_Gateway.ino:342] Z2S_onBTCBoundDevice(): BTC bound device 0xd470 on endpoint 0x1 cluster id 0x1
18:27:07.272 -> [  5195][I][Z2S_Gateway.ino:354] Z2S_onBTCBoundDevice(): Trying to wake up device 0xd470 on endpoint 0x1 cluster id 0x1
18:27:07.272 -> [  5206][I][Z2S_Gateway.ino:77] Z2S_printDevicesTableSlots(): valid 1, ieee addr �<�З8��, model_id 0x1000, endpoint 0x1, cluster 0x405, channel 0, channel type 3038
18:27:08.953 -> [  6900][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xffffffff
18:27:08.987 -> [  6914][D][ZigbeeCore.cpp:469] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0xd470, ieee addr: A4:C1:38:97:D0:A9:3C:8D
18:27:08.987 -> [  6927][D][ZigbeeCore.cpp:451] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0402, dst_addr_mode 3
18:27:08.987 -> [  6938][I][Z2S_Gateway.ino:342] Z2S_onBTCBoundDevice(): BTC bound device 0xd470 on endpoint 0x1 cluster id 0x402
18:27:09.020 -> [  6948][I][Z2S_Gateway.ino:344] Z2S_onBTCBoundDevice(): Trying to wake up device 0xd470 on endpoint 0x1 cluster id 0x402
18:27:09.020 -> [  6960][I][Z2S_Gateway.ino:77] Z2S_printDevicesTableSlots(): valid 1, ieee addr �<�З8��, model_id 0x1000, endpoint 0x1, cluster 0x405, channel 0, channel type 3038
18:27:10.701 -> [  8653][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xffffffff
18:27:10.739 -> [  8667][D][ZigbeeCore.cpp:469] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0xd470, ieee addr: A4:C1:38:97:D0:A9:3C:8D
18:27:10.739 -> [  8684][D][ZigbeeCore.cpp:438] bindingTableCb(): Binding table callback for address 0x0000 with status 0
18:27:10.739 -> [  8693][D][ZigbeeCore.cpp:441] bindingTableCb(): Binding table info: total 4, index 3, count 1
18:27:10.772 -> [  8702][D][ZigbeeCore.cpp:451] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0405, dst_addr_mode 3
18:27:10.772 -> [  8713][I][Z2S_Gateway.ino:342] Z2S_onBTCBoundDevice(): BTC bound device 0xd470 on endpoint 0x1 cluster id 0x405
18:27:10.772 -> [  8723][I][Z2S_Gateway.ino:349] Z2S_onBTCBoundDevice(): Trying to wake up device 0xd470 on endpoint 0x1 cluster id 0x405
18:27:10.806 -> [  8734][I][Z2S_Gateway.ino:77] Z2S_printDevicesTableSlots(): valid 1, ieee addr �<�З8��, model_id 0x1000, endpoint 0x1, cluster 0x405, channel 0, channel type 3038
8:27:12.488 -> [ 10428][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xffffffff
18:27:12.488 -> [ 10442][D][ZigbeeCore.cpp:469] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0xd470, ieee addr: A4:C1:38:97:D0:A9:3C:8D
18:27:12.519 -> [ 10455][D][ZigbeeCore.cpp:490] bindingTableCb(): Filling bounded devices finished
18:27:12.519 -> [ 10469][D][NetworkManager.cpp:83] hostByName(): Clearing DNS cache
18:27:12.636 -> [ 10576][D][NetworkManager.cpp:123] hostByName(): DNS found IPv4 65.109.134.66
18:27:12.920 -> [ 10871][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0xb155) is open for 20 seconds
18:27:18.415 -> NLME Status Indication, status: 0x6
18:27:19.469 -> [ 17408][I][ZigbeeCore.cpp:324] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd470)
18:27:19.469 -> [ 17418][D][ZigbeeCore.cpp:345] esp_zb_app_signal_handler(): Device already bound to endpoint 1
18:27:20.959 -> [ 18910][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0xb155) is open for 180 seconds
18:27:26.044 -> [ 23959][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
18:27:26.044 -> [ 23968][I][ZigbeeGateway.cpp:286] zbAttributeRead(): zbAttributeRead temperature measurement 25.180000
18:27:26.044 -> [ 23977][I][ZigbeeGateway.cpp:287] zbAttributeRead(): zbAttributeRead 164:193:56:151:208:169:60:141, endpoint 0x1
18:27:26.044 -> [ 23987][I][Z2S_Gateway.ino:216] Z2S_onTemperatureReceive(): onTemperatureReceive 164:193:56:151:208:169:60:141, endpoint 0x1
18:27:26.044 -> [ 23999][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xbde
18:27:26.167 -> [ 24089][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
18:27:26.167 -> [ 24098][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 41.580002
18:27:26.167 -> [ 24107][I][Z2S_Gateway.ino:234] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:151:208:169:60:141, endopint 0x1
18:27:26.167 -> [ 24117][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xbde
18:28:27.373 -> [ 85307][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
18:28:27.373 -> [ 85315][I][ZigbeeGateway.cpp:286] zbAttributeRead(): zbAttributeRead temperature measurement 25.280001
18:28:27.373 -> [ 85324][I][ZigbeeGateway.cpp:287] zbAttributeRead(): zbAttributeRead 164:193:56:151:208:169:60:141, endpoint 0x1
18:28:27.417 -> [ 85334][I][Z2S_Gateway.ino:216] Z2S_onTemperatureReceive(): onTemperatureReceive 164:193:56:151:208:169:60:141, endpoint 0x1
18:28:27.417 -> [ 85346][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xbde
18:28:27.492 -> [ 85436][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
18:28:27.492 -> [ 85445][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 41.500000
18:28:27.539 -> [ 85454][I][Z2S_Gateway.ino:234] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:151:208:169:60:141, endopint 0x1
18:28:27.539 -> [ 85464][I][Z2S_Gateway.ino:92] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:151:208:169:60:141, endpoint 0x1, channel type 0xbde
18:30:20.960 -> [198911][I][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Network(0xb155) closed, devices joining not allowed.
5. *.ino bardzo spuchło, może to juz pora na jakąś nową klasę która zawiera te callbacki łączace Zigbee z Supla?
6. Nie wiem co jest nie tak z moim ESP ale przez ten kod wpada w bootloop, nawet jak zmienie pin na jakiś inny i nic nie zrobie żeby np. zewrzeć ten pin z masa lub 3.3V, jedynie jak zakomentuje to jest OK
  if (digitalRead(BUTTON_PIN) == LOW) {  // Push button pressed
    // Key debounce handling
    delay(100);
    while (digitalRead(BUTTON_PIN) == LOW) {
      delay(50);
      if ((millis() - startTime) > 5000) {
        // If key pressed for more than 5 secs, factory reset Zigbee and reboot
        Serial.printf("Resetting Zigbee to factory settings, reboot.\n");
        Zigbee.factoryReset();
    Zigbee.openNetwork(180);
  delay(100);
7. metody wypisujące tabele zdecydowanie nie muszą wypisywać wszystkich elementów, tylko te wypelnione ;) straszna ściana tekstu, np. Z2S_printDevicesTableSlots, przez którą ciężko coś skopiować w Arduino IDE
8. chyba binding table puchnie mimo dodawania tego samego urządzenia:
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Musisz zewrzeć z tyłu GND i RESTE ale dłużej tak aby pojawiły się kreski na wyświetlaczu . Ja przylutowałem na test dwa kabelki bo wczoraj się sparował a dziś się męczyłem i nie mogłem tego powtórzyć ale skoro wczoraj się dało 😁 . Jak połączysz piny to po jakimś czasie przeskoczy na Fahrenheita trzymać trzeba jeszcze wyskoczą kreski . Jak się łączy z bramką to znaczek bluetooth zacznie migać jak się połączy to znika .
Oczywiście oprogramowanie zmienione na zigbee
[email protected]
@vajera
potwierdzam natomiast, że urządzenie:
{.manufacturer_name = "_TZ3000_gjrubzje", .model_name = "TS0001", .z2s_device_desc_id = Z2S_DEVICE_DESC_RELAY_ELECTRICITY_METER},
nawet po zamknięciu sieci działa poprawnie i pozwala sterować przekaźnikiem, jeszcze nic do niego nie podłączałem , ale musze skołować jakąś żarówkę :D
Has thanked: 291 times
@[email protected]
Dzięki za audyt kodu, sam próbuję go czyścić w miarę możliwości, ale sporo jeszcze zostało.
Rozbicie *.ino to kwestia najbliższych dni bo już mi samemu trudno cokolwiek odnaleźć ;)
Te wszystkie też logi wymagają reorganizacji, wiele z nich powstało ad hoc żeby coś sprawdzić.
Pytanie o binding table - ta od callbacku (fragment zacytowany przez Ciebie) jest zarządzana przez ZBOSSa i przechowana na oddzielnej partycji. Nie jestem pewny czy do końca rozumiem, co masz na myśli mówiąc, że puchnie?
Czujnik temperatury - ja próbuję je zmusić do raportowania temperatury, ale, np. czujniki Tuya olewają ten rozkaz i wysyłają dane, gdy te ulegną zmianie. Muszę zrobić klasę dziedziczącą po VirtualThermHygroMeter i z niej wysyłać rozkaz odczytu atrybutu w IterateAlways() - może to da efekt?
Prośba do tych, którzy mają kopię kodu na GH - chętnie przyjmę każdy PR.
