LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
oki dzieki Zibi_007 za gotowy wsad ;)
a więc tak bramka odpaliła bez problemu ,dodawane urządzenia parują się szybko , coś czujnik ruchu nie chciał się pojawić ale w końcu się dodał :D
Dalej mam problem z tym termometrem Xiaomi LYWSD03MMC nie raportuje wilgotności tak jakby bramka jej nie odczytuje ,logi:
NLME Status Indication, status: 0x0
Send: [53 55 50 4C 41 17 11 00 00 00 28 00 00 00 10 00 00 00 04 03 00 00 00 00 00 00 A6 16 0D 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 12 00 00 00 32 00 00 00 10 00 00 00 FF 4A 8B 67 00 00 00 00 01 3B 03 00 00 00 00 00 53 55 50 4C 41 ]
[775851][I][Z2S_Gateway.ino:148] loop(): short address before 0xd135
[775851][I][Z2S_Gateway.ino:150] loop(): short address after 0xd135
[780097][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[780097][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x2dc3) src endpoint(1) to dst endpoint(1) cluster(0x402)
[780098][I][Z2S_Devices_Table.cpp:183] Z2S_onTemperatureReceive(): onTemperatureReceive 0xa4:0xc1:0x38:0xc9:0x48:0x6f:0x20:0x60, endpoint 0x1
[780099][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xc9:0x48:0x6f:0x20:0x60, endpoint 0x1, channel type 0xbde
[780100][I][ZigbeeGateway.cpp:372] zbAttributeRead(): zbAttributeRead from (0x2060), endpoint (1), cluster (0x402), attribute id (0x0), attribute data type (0x29)
[782170][I][ZigbeeGateway.cpp:523] sendAttributeRead(): Sending 'read attribute' command
[782172][I][ZigbeeGateway.cpp:523] sendAttributeRead(): Sending 'read attribute' command
Channel(0) value changed to temp(23.80), humi(-1.00)
Send: [53 55 50 4C 41 17 12 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 F7 5C 00 00 18 FC FF FF ]
[785890][I][Z2S_Gateway.ino:148] loop(): short address before 0xd135
[785890][I][Z2S_Gateway.ino:150] loop(): short address after 0xd135
i jeszcze pytanie odnośnie czujnika zalania ma on wbudowany przycisk na górze pewnie do testowania - czy będzie on działa w późniejszym czasie ?
logi z naciśnięcia przycisku :
s (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[997992][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdf:0xe7:0x66:0x27:0xe5, endpoint 0x1, channel type 0x3e8
[998549][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[998549][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x920e) src endpoint(1) to dst endpoint(1) cluster(0x1)
[998550][I][ZigbeeGateway.cpp:358] zbAttributeRead(): zbAttributeRead power config battery percentage remaining 200
[998551][I][ZigbeeGateway.cpp:372] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[998551][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[998552][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0x920e) src endpoint(1) to dst endpoint(1) cluster(0x1)
[998552][I][ZigbeeGateway.cpp:361] zbAttributeRead(): zbAttributeRead power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[998553][I][ZigbeeGateway.cpp:372] zbAttributeRead(): zbAttributeRead from (0x27e5), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
Ogólnie bramka działa bardzo żwawo reakcje na zmiany stanu czajników są raportowane natomiast w aplikacji.
Rewelacja :D
Has thanked: 291 times
LukiSpajder wrote: Sat Jan 18, 2025 6:38 am oki dzieki Zibi_007 za gotowy wsad ;)
Rewelacja :D
Wygląda na to, że czujnik jej nie wysyła - może spróbuj wyjąć/wymienić baterię? Jeżeli to nie pomoże to ogromna prośba - wgraj wersję, która działała i zobacz czy teraz też raportuje wilgotność?
Szybką reakcja w aplikacji to przede wszystkim zasługa rewelacyjnie zaprojektowanego protokołu komunikacji Supla - to jedna z wielu zalet dających Supli przewagę nad konkurencją. Chapeau bas @pzygmunt !
LukiSpajder
vajera wrote: Sat Jan 18, 2025 7:13 am
Rewelacja :D
oto logi z ostatniej działającej wersji - chodzi coś mi się nie chciał połączyć ale to jednorazowy przypadek. Ogólnie testowałem go wcześniej i działał bez problemu pomiary na wykresach były przez cała noc ( oczywiście przednia wersja )
logi :
SSL error: 48, UNKNOWN ERROR CODE (0030)
LAST STATE ADDED: UNKNOWN ERROR CODE (0030)
Connected to Supla Server
Initializing SRPC (proto: 23)
LAST STATE ADDED: Register in progress
Current status: [10] Register in progress
Send: [53 55 50 4C 41 17 01 00 00 00 4B 00 00 00 6B 02 00 00 76 69 74 6F 31 34 37 40 69 6E 74 65 72 69 61 2E 70 6C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B 30 78 30 30 2C 30 78 42 44 2C 30 78 39 46 2C 7B 30 78 30 30 2C 30 78 34 46 2C 30 78 42 45 2C 5A 69 67 62 65 65 20 74 6F 20 53 75 70 6C 61 20 57 45 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
CH[0], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [c8 cd fb ff 18 fc ff ff]
Send: [00 DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 C8 CD FB FF 18 FC FF FF 00 ]
zbInit
[  3255][D][ZigbeeCore.cpp:138] zigbeeInit(): Initialize Zigbee stack
[  3258][D][ZigbeeCore.cpp:145] zigbeeInit(): Register all Zigbee EPs in list
[  3261][I][ZigbeeCore.cpp:153] zigbeeInit(): List of registered Zigbee EPs:
[  3261][I][ZigbeeCore.cpp:155] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[  3265][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[  3265][I][ZigbeeCore.cpp:245] esp_zb_app_signal_handler(): Zigbee stack initialized
[  3268][I][ZigbeeCore.cpp:251] esp_zb_app_signal_handler(): Device started up in  factory-reset mode
[  3268][I][ZigbeeCore.cpp:255] esp_zb_app_signal_handler(): Start network formation
[  5636][I][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Network(0x2ec2) closed, devices joining not allowed.
[  5637][I][ZigbeeCore.cpp:286] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: 40:4c:ca:ff:fe:5f:8d:88, PAN ID: 0x2ec2, Channel:11, Short Address: 0x0000)
[  6105][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0x2ec2) is open for 180 seconds
[  6107][I][ZigbeeCore.cpp:301] esp_zb_app_signal_handler(): Network steering started
Recv: [53 55 50 4C 41 17 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 1A 01 53 55 50 4C 41 ]
Device registered (activity timeout 120 s, server version: 26, server min version: 1)
LAST STATE ADDED: Registered and ready
Current status: [17] Registered and ready
Changing activity timeout to 30 s
Send: [53 55 50 4C 41 17 02 00 00 00 D2 00 00 00 01 00 00 00 1E ]
Recv: [53 55 50 4C 41 17 02 00 00 00 AD 02 00 00 1C 00 00 00 01 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 53 55 50 4C 41 ]
Received new device config
Processing StatusLed config
Sending device config result OK (1)
Send: [53 55 50 4C 41 17 03 00 00 00 B7 02 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 28 00 00 00 00 2D 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Received SetChannelConfig for channel 0, function 45, config type 0, config size 32
Channel[0]: handleChannelConfig, func 45, configtype 0, configsize 32
Channel[0] temperature correction 0.00
Channel[0] humidity correction 0.00
Sending channel config result OK (1)
Send: [53 55 50 4C 41 17 04 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
Recv: [53 55 50 4C 41 17 04 00 00 00 AB 02 00 00 01 00 00 00 00 53 55 50 4C 41 ]
Received ChannelConfigFinished for channel [0]
Recv: [53 55 50 4C 41 17 05 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
Activity timeout set to 30 s
Send: [53 55 50 4C 41 17 05 00 00 00 28 00 00 00 10 00 00 00 A9 03 00 00 00 00 00 00 7A 83 0A 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 06 00 00 00 32 00 00 00 10 00 00 00 AE 6F 8B 67 00 00 00 00 68 92 09 00 00 00 00 00 53 55 50 4C 41 ]
[ 38180][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 38182][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 38711][I][ZigbeeCore.cpp:324] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xaad3)
[ 38711][V][ZigbeeCore.cpp:328] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 39215][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0xaad3), endpoint(1)
[ 39253][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 39253][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0xaad3
[ 39733][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 39733][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 39734][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[ 39735][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "Xiaomi"
[ 39736][I][Z2S_Gateway.ino:638] loop(): manufacturer Xiaomi
[ 40242][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 40243][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 40243][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(12)
[ 40244][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "LYWSD03MMC-z"
[ 40245][I][Z2S_Gateway.ino:640] loop(): model LYWSD03MMC-z
[ 40247][I][Z2S_Gateway.ino:687] loop(): LIST checking _TZ3000_akqdg6g7::TS0201, entry # 0
[ 40248][I][Z2S_Gateway.ino:649] loop(): LIST matched Xiaomi::LYWSD03MMC-z, entry # 1
[ 40248][I][Z2S_Gateway.ino:652] loop(): DESC matched 0x1000, 4, 0x3, 0x1, 0x402, 0x405, 0x0, 0x0, 0x0, 0x0
[ 40249][D][ZigbeeGateway.cpp:218] bindDeviceCluster(): Request sensor to bind us
[ 40250][D][ZigbeeGateway.cpp:218] bindDeviceCluster(): Request sensor to bind us
[ 40251][D][ZigbeeGateway.cpp:218] bindDeviceCluster(): Request sensor to bind us
[ 40262][V][ZigbeeGateway.cpp:103] bindCb(): Binding success (ZC side)
[ 40263][V][ZigbeeGateway.cpp:103] bindCb(): Binding success (ZC side)
[ 40263][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 1, ieee addr ` oH▒8▒, model_id 0x1000, endpoint 0x1, cluster 0x405, channel 0, channel type 3038
[ 40264][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40265][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40266][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40267][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40268][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40269][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40270][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40271][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40272][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40273][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40274][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40275][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40276][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40277][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40278][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40279][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40280][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40281][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40282][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40283][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40284][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40285][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40286][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40287][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40288][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40289][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40290][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40291][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40292][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40293][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40294][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40295][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40296][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40297][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40307][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40308][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40309][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40310][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40311][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40312][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40313][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40314][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40315][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40316][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40317][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40318][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40319][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40320][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40321][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40322][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40323][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40324][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40325][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40326][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40327][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40328][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40329][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40330][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40331][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40332][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40333][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40334][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40335][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40336][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40337][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40338][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40339][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40340][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40341][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40342][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40343][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40344][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40345][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40346][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40347][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40348][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40349][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40350][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40351][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40352][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40353][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40354][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40355][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40356][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40357][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40358][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40359][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40360][I][Z2S_Gateway.ino:115] Z2S_printDevicesTableSlots(): valid 0, ieee addr , model_id 0x0, endpoint 0x0, cluster 0x0, channel 0, channel type 0
[ 40361][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xffffffff
[ 40362][V][ZigbeeGateway.cpp:103] bindCb(): Binding success (ZC side)
[ 40367][I][Z2S_Gateway.ino:674] loop(): DESC checking 0x2000, 4, 0x3, 0x1, 0x500, 0x6, 0x0, 0x0, 0x0, 0x0
[ 40368][I][Z2S_Gateway.ino:674] loop(): DESC checking 0x4000, 3, 0x3, 0x1, 0x6, 0x0, 0x0, 0x0, 0x0, 0x0
[ 40369][I][Z2S_Gateway.ino:674] loop(): DESC checking 0x4100, 5, 0x3, 0x1, 0x6, 0x702, 0xb04, 0x0, 0x0, 0x0
[ 40369][I][Z2S_Gateway.ino:687] loop(): LIST checking TEST1::TS0202, entry # 2
[ 40370][I][Z2S_Gateway.ino:687] loop(): LIST checking _TZ3000_26fmupbb::TS0203, entry # 3
[ 40370][I][Z2S_Gateway.ino:687] loop(): LIST checking _TZ3000_rcuyhwe3::TS0203, entry # 4
[ 40371][I][Z2S_Gateway.ino:687] loop(): LIST checking TEST1::TS0205, entry # 5
[ 40371][I][Z2S_Gateway.ino:687] loop(): LIST checking _TZ3000_lf56vpxj::TS0202, entry # 6
[ 40372][I][Z2S_Gateway.ino:687] loop(): LIST checking _TZ3000_cehuw1lw::TS011F, entry # 7
[ 40789][V][ZigbeeGateway.cpp:105] bindCb(): Binding success (ED side
[ 40844][V][ZigbeeGateway.cpp:105] bindCb(): Binding success (ED side
[ 40873][V][ZigbeeGateway.cpp:105] bindCb(): Binding success (ED side
[ 40899][V][ZigbeeGateway.cpp:105] bindCb(): Binding success (ED side
[ 40928][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 41267][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0x2ec2) is open for 180 seconds
[ 41661][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 41661][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 41662][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x2060), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 41664][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 41665][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 41666][I][ZigbeeGateway.cpp:339] zbAttributeRead(): zbAttributeRead from (0x2060), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[ 41668][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 41668][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x402)
[ 41669][I][ZigbeeGateway.cpp:286] zbAttributeRead(): zbAttributeRead temperature measurement 26.250000
[ 41670][I][ZigbeeGateway.cpp:287] zbAttributeRead(): zbAttributeRead 164:193:56:201:72:111:32:96, endpoint 0x1
[ 41670][I][Z2S_Gateway.ino:254] Z2S_onTemperatureReceive(): onTemperatureReceive 164:193:56:201:72:111:32:96, endpoint 0x1
[ 41671][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
[ 41674][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 41674][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x405)
[ 41675][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 42.759998
[ 41675][I][Z2S_Gateway.ino:272] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:201:72:111:32:96, endopint 0x1
[ 41676][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(26.25), humi(42.76)
Send: [53 55 50 4C 41 17 06 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 8A 66 00 00 07 A7 00 00 ]
Send: [53 55 50 4C 41 17 07 00 00 00 28 00 00 00 10 00 00 00 C2 03 00 00 00 00 00 00 CA 8C 0D 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 07 00 00 00 32 00 00 00 10 00 00 00 C7 6F 8B 67 00 00 00 00 87 7D 0D 00 00 00 00 00 53 55 50 4C 41 ]
[ 81339][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 81339][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x405)
[ 81340][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 83.550003
[ 81340][I][Z2S_Gateway.ino:272] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:201:72:111:32:96, endopint 0x1
[ 81341][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Send: [53 55 50 4C 41 17 08 00 00 00 28 00 00 00 10 00 00 00 DB 03 00 00 00 00 00 00 7E 92 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 08 00 00 00 32 00 00 00 10 00 00 00 E0 6F 8B 67 00 00 00 00 74 C8 0D 00 00 00 00 00 53 55 50 4C 41 ]
Channel(0) value changed to temp(26.25), humi(83.55)
Send: [53 55 50 4C 41 17 09 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 8A 66 00 00 5E 46 01 00 ]
[ 91358][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 91358][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x402)
[ 91359][I][ZigbeeGateway.cpp:286] zbAttributeRead(): zbAttributeRead temperature measurement 26.549999
[ 91360][I][ZigbeeGateway.cpp:287] zbAttributeRead(): zbAttributeRead 164:193:56:201:72:111:32:96, endpoint 0x1
[ 91360][I][Z2S_Gateway.ino:254] Z2S_onTemperatureReceive(): onTemperatureReceive 164:193:56:201:72:111:32:96, endpoint 0x1
[ 91361][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(26.55), humi(83.55)
Send: [53 55 50 4C 41 17 0A 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 B5 67 00 00 5E 46 01 00 ]
Send: [53 55 50 4C 41 17 0B 00 00 00 28 00 00 00 10 00 00 00 F5 03 00 00 00 00 00 00 61 0F 02 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 09 00 00 00 32 00 00 00 10 00 00 00 FA 6F 8B 67 00 00 00 00 E9 11 01 00 00 00 00 00 53 55 50 4C 41 ]
[111354][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[111354][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x405)
[111355][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 49.349998
[111355][I][Z2S_Gateway.ino:272] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:201:72:111:32:96, endopint 0x1
[111356][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(26.55), humi(49.35)
Send: [53 55 50 4C 41 17 0C 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 B5 67 00 00 C5 C0 00 00 ]
[121371][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[121372][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x402)
[121372][I][ZigbeeGateway.cpp:286] zbAttributeRead(): zbAttributeRead temperature measurement 26.690001
[121373][I][ZigbeeGateway.cpp:287] zbAttributeRead(): zbAttributeRead 164:193:56:201:72:111:32:96, endpoint 0x1
[121373][I][Z2S_Gateway.ino:254] Z2S_onTemperatureReceive(): onTemperatureReceive 164:193:56:201:72:111:32:96, endpoint 0x1
[121374][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(26.69), humi(49.35)
Send: [53 55 50 4C 41 17 0D 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 42 68 00 00 C5 C0 00 00 ]
Send: [53 55 50 4C 41 17 0E 00 00 00 28 00 00 00 10 00 00 00 0E 04 00 00 00 00 00 00 97 C6 04 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0A 00 00 00 32 00 00 00 10 00 00 00 13 70 8B 67 00 00 00 00 E1 B8 03 00 00 00 00 00 53 55 50 4C 41 ]
[141402][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x2000) callback
[141402][V][ZigbeeHandlers.cpp:72] zb_attribute_reporting_handler(): Received report from address(0xaad3) src endpoint(1) to dst endpoint(1) cluster(0x405)
[141403][I][ZigbeeGateway.cpp:297] zbAttributeRead(): zbAttributeRead humidity measurement 45.439999
[141404][I][Z2S_Gateway.ino:272] Z2S_onHumidityReceive(): onHumidityReceive 164:193:56:201:72:111:32:96, endopint 0x1
[141404][I][Z2S_Gateway.ino:130] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 164:193:56:201:72:111:32:96, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(26.69), humi(45.44)
Send: [53 55 50 4C 41 17 0F 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 42 68 00 00 7F B1 00 00 ]
Send: [53 55 50 4C 41 17 10 00 00 00 28 00 00 00 10 00 00 00 27 04 00 00 00 00 00 00 4C 7E 07 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0B 00 00 00 32 00 00 00 10 00 00 00 2D 70 8B 67 00 00 00 00 C5 32 0A 00 00 00 00 00 53 55 50 4C 41 ]
Been thanked: 32 times
l[...]
Rewelacja :D
Cieszę się, że wsad działa. Przycisk na górze oprócz parowania służy do raportowania stanu urządzenia (gotowości). Np. w SmartLive pokazuje w logach komunikat "powodzenie". To nie jest kluczowa funkcja i myślę, że można to zostawić na później. Tam masz chyba dwa piny czujnika od dołu i dwa od góry (jeśli to ten płaski). Łatwo je zewrzeć czymkolwiek (nawet językiem, jak nie masz spinacza pod ręką ;-)) i sprawdzisz, czy działa. Ja bym się skupił w tej chwili na ważniejszych rzeczach. Przyjdzie czas, to na spokojnie się to rozszyfruje i zastanowimy się do czego to przypisać (moja propozycja - może zmieniać stan czujnika - dokładnie, jak alarm). U mnie np. nie działa w gniazdku odczyt parametrów (napięcie, moc, itp.), ale na razie nie zawracam głowy Łukaszowi, bo są ważniejsze rzeczy do zrobienia...
LukiSpajder
Oczywiście masz rację nie jest to priorytet tylko luźne spostrzeżenie. Czujnik od strony zalana dział idealnie info o zalaniu dział natychmiast zwarcie elektrod powoduje zmianę stanu .
lukasz06
Has thanked: 46 times
Been thanked: 21 times
Mam jeszcze poprzednią wersję ale bez websera i pokazuje temp i wilgotność. Jjeszcze nie wgywalem najnowszej, bo mój Xiaomi ma prawie urwany pad gnd i boję się, że go później nie sparuje z nową bramką.
wojtas567
Cześć
Któraś z wersji kompilacji znajdywała moje urządzenia i dodawała do chmury, teraz już nie dodaje. Patrząc po liście którą dodajecie:
14:17:54.864 -> [ 88316][Z2S_Gateway.ino:208] loop(): model TS011F
14:17:54.864 -> [ 88316][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_akqdg6g7::TS0201, entry # 0
14:17:54.864 -> [ 88316][Z2S_Gateway.ino:272] loop(): LIST checking Xiaomi::LYWSD03MMC-z, entry # 1
14:17:54.864 -> [ 88317][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_rdhukkmi::TS0201, entry # 2
14:17:54.864 -> [ 88318][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_fllyghyj::TS0201, entry # 3
14:17:54.864 -> [ 88318][Z2S_Gateway.ino:272] loop(): LIST checking TEST1::TS0202, entry # 4
14:17:54.864 -> [ 88319][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_26fmupbb::TS0203, entry # 5
14:17:54.864 -> [ 88320][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_rcuyhwe3::TS0203, entry # 6
14:17:54.864 -> [ 88320][Z2S_Gateway.ino:272] loop(): LIST checking _TZE200_bh3n6gk8::TS0601, entry # 7
14:17:54.864 -> [ 88321][Z2S_Gateway.ino:272] loop(): LIST checking __TZ3000_k4ej3ww2::TS0207, entry # 8
14:17:54.864 -> [ 88321][I][Z2S_Gateway.ino:272] loop(): LIST checking TEST1::TS0205, entry # 9
14:17:54.864 -> [ 88322][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_lf56vpxj::TS0202, entry # 10
14:17:54.864 -> [ 88322][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_cehuw1lw::TS011F, entry # 11
14:17:54.864 -> [ 88323][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_5f43h46b::TS011F, entry # 12
14:17:54.864 -> [ 88323][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_wkai4ga5::TS0044, entry # 13
14:17:54.864 -> [ 88324][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_yj6k7vfo::TS0041, entry # 14
14:17:54.864 -> [ 88325][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_4fjiwweb::TS004F, entry # 15
14:17:54.864 -> [ 88325][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_uri7ongn::TS004F, entry # 16
14:17:54.864 -> [ 88326][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_ixla93vd::TS004F, entry # 17
14:17:54.864 -> [ 88326][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_qja6nq5z::TS004F, entry # 18
14:17:54.864 -> [ 88327][I][Z2S_Gateway.ino:272] loop(): LIST checking _TZ3000_abrsvsou::TS004F, entry # 19
to "_abrsvsou" ten człon mam wrażenie że prawie każdy z nas ma inny zależny od partii wersji?
Więc każdy nowy użytkownik po zeskanowaniu swoich wszystkich urządzeń musi podać swoje czujniki i jeżeli ich nie dodacie do listy to nie będzie mógł korzystać z bramki poprawcie mnie jeżeli się mylę?
14:17:54.864 -> [ 88327][D][Z2S_Gateway.ino:274] loop(): Unknown model _TZ3000_w0qqde0g::TS011F, no binding is possible
tu moje gniazdko a tu kilka moich czujników
[Z2S_Gateway.ino:274] loop(): Unknown model _TZ3000_xr3htd96::TS0201
[Z2S_Gateway.ino:274] loop(): Unknown model _TZ3000_2mbfxlzr::TS0203
[Z2S_Gateway.ino:274] loop(): Unknown model _TZ3000_mcxw5ehu::TS0202
_TZ3000_85czd6fy::TS0207
IKEA of Sweden::Remote Control N2
IKEA of Sweden::SYMFONISK Sound Controller
IKEA of Sweden::TRADFRI Driver 10W
zobaczymy czy IKEA zaskoczy :)
wojtas567 wrote: Sat Jan 18, 2025 1:41 pm Cześć
Tak dokładnie jest. Z czasem baza będzie rosła i coraz więcej urządzeń doda się z automatu.
Już teraz @vajera dodaje seriami, jeśli ma taką wiedzę.
Co do czujników - rozpisz, który jest do czego. Łatwiej będzie je dodać.
Jak je rozpiszesz, a ja znajdę chwilę, to w nocy skompiluję nową wersję z webinterfeace.
Uwaga, w gniazdku może nie działać licznik.
@LukiSpajder Czy te logi, które wrzuciłeś dzisiaj o 10:16 to są logi archiwalne czy wgrałeś ponownie starszą wersję i na niej nadal działa raportowanie wilgotności?
wojtas567
to już teraz kumam :)
_TZ3000_w0qqde0g::TS011F                               -    gniazdko z mocą
_TZ3000_2mbfxlzr::TS0203                                 -    czujnik drzwi/okna
_TZ3000_mcxw5ehu::TS0202                              -    czujnik ruchu
_TZ3000_xr3htd96::TS0201                                 -    czujnik temperatura i wilgotność
_TZ3000_85czd6fy::TS0207                                 -    czujnik zalania
_TZ3000_upgcbody::TS0207                                -    czujnik zalania
IKEA of Sweden::Remote Control N2                   -    pilot z czterema przyciskami
IKEA of Sweden::SYMFONISK Sound Controller    -    regulacja audio i przycisk np mute/pauza itp, dwu i trzy klik
IKEA of Sweden::TRADFRI Driver 10W                 -    zasilacz z regulacją jasności
