Waga tensometryczna
Dobra to zrobię coś dla nas i naszych 2-gich połówek. Z oled oczywiście. Tak myślę aby schować to w łazience pod terakotą w podłodze a oled w lustrze. Już to ktoś z kolegów zrobił z tym lustrem ale nie pamiętam kto...fajnie wyglądało i prfeska w 100%.
Been thanked: 9 times
Może o tym myślisz?
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
lesny8 wrote: Sun Jun 16, 2019 10:07 pm Może o tym myślisz?
Tak to to. Kolega @Michael zrobił kawał roboty.
Projekt zrealizowany. Poniżej filmik.
https://youtu.be/3bsao7FcjK4
Pod Filmem kod źródłowy - proszę nie mieć za złe - bo to tak na szybko przerobione z stacji pogody i innych. Oparte na kodzie shimano73 z BME280.
KOD do kalibracji wagi (opis kalibracji w kodzie)
 Example using the SparkFun HX711 breakout board with a scale
 By: Nathan Seidle
 SparkFun Electronics
 Date: November 19th, 2014
 License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
 This is the calibration sketch. Use it to determine the calibration_factor that the main example uses. It also
 outputs the zero_factor useful for projects that have a permanent mass on the scale in between power cycles.
 Setup your scale and start the sketch WITHOUT a weight on the scale
 Once readings are displayed place the weight on the scale
 Press +/- or a/z to adjust the calibration_factor until the output readings match the known weight
 Use this calibration_factor on the example sketch
 This example assumes pounds (lbs). If you prefer kilograms, change the Serial.print(" lbs"); line to kg. The
 calibration factor will be significantly different but it will be linearly related to lbs (1 lbs = 0.453592 kg).
 Your calibration factor may be very positive or very negative. It all depends on the setup of your scale system
 and the direction the sensors deflect from zero state
 This example code uses bogde's excellent library: https://github.com/bogde/HX711
 bogde's library is released under a GNU GENERAL PUBLIC LICENSE
 Arduino pin 2 -> HX711 CLK
 3 -> DOUT
 5V -> VCC
 GND -> GND
 Most any pin on the Arduino Uno will be compatible with DOUT/CLK.
 The HX711 board can be powered from 2.7V to 5V so the Arduino 5V power should be fine.
#include "HX711.h"
#define DOUT  3
#define CLK  2
HX711 scale;
float calibration_factor = -7050; //-7050 worked for my 440lb max scale setup
void setup() {
  Serial.begin(9600);
  Serial.println("HX711 calibration sketch");
  Serial.println("Remove all weight from scale");
  Serial.println("After readings begin, place known weight on scale");
  Serial.println("Press + or a to increase calibration factor");
  Serial.println("Press - or z to decrease calibration factor");
  scale.begin(DOUT, CLK);
  scale.set_scale();
  scale.tare(); //Reset the scale to 0
  long zero_factor = scale.read_average(); //Get a baseline reading
  Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
  Serial.println(zero_factor);
void loop() {
  scale.set_scale(calibration_factor); //Adjust to this calibration factor
  Serial.print("Reading: ");
  Serial.print(scale.get_units(), 1);
  Serial.print(" lbs"); //Change this to kg and re-adjust the calibration factor if you follow SI units like a sane person
  Serial.print(" calibration_factor: ");
  Serial.print(calibration_factor);
  Serial.println();
  if(Serial.available())
    char temp = Serial.read();
    if(temp == '+' || temp == 'a')
      calibration_factor += 10;
    else if(temp == '-' || temp == 'z')
      calibration_factor -= 10;
Natomiast kod pod czujnik wagi i HX711oraz przeróbka pod oled to moje dzieło
   Supla.org NodeMCU WiFi minimal example
   Author: Programistyk - Kamil Kaminski <[email protected]>
   This example shows how to configure SuplaDevice for building for NodeMCU within Arduino IDE
#define LIGHTSENSORPIN A0 //Ambient light sensor reading
#include <BH1750FVI.h>
#include <srpc.h>
#include <log.h>
#include <eh.h>
#include <proto.h>
#include <IEEE754tools.h>
// We define our own ethernet layer
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <lck.h>
#include <WiFiClient.h>
#include <ESP8266WiFiType.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiServer.h>
#include <ESP8266WiFiGeneric.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiSTA.h>
#include <WiFiUdp.h>
#include <Wire.h>
#include <OneWire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define OLED_RESET 0
Adafruit_SSD1306 display(OLED_RESET); // GPIO5 - SCL , GPIO4 -SDA
#include "HX711.h"
#define calibration_factor -24160.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define DOUT  12
#define CLK  14
HX711 scale;
String light;
#define SEALEVELPRESSURE_HPA (1023.0)
Adafruit_BME280 bme; // I2C
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
BH1750FVI LightSensor(BH1750FVI::k_DevModeContLowRes);
#define LOGO32_GLCD_HEIGHT 32
#define LOGO32_GLCD_WIDTH  32
static const unsigned char PROGMEM temp_glcd_bmp[] =
{ // temp_home
  0x00, 0x03, 0xc0, 0x00, 0x00, 0x04, 0x20, 0x00, 0x00, 0x08, 0x10, 0x00, 0x00, 0x08, 0x50, 0x00,
  0x00, 0x08, 0x50, 0x00, 0x00, 0x08, 0x50, 0x00, 0x00, 0x08, 0x10, 0x00, 0x00, 0x09, 0x50, 0x00,
  0x00, 0x08, 0xd0, 0x00, 0x00, 0x0b, 0x10, 0x00, 0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00,
  0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00,
  0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00, 0x00, 0x0b, 0xd0, 0x00, 0x00, 0x17, 0xe8, 0x00,
  0x00, 0x2f, 0xf4, 0x00, 0x00, 0x2f, 0x94, 0x00, 0x00, 0x2f, 0xb4, 0x00, 0x00, 0x2f, 0xf4, 0x00,
  0x00, 0x07, 0xe0, 0x00, 0x00, 0x13, 0xc8, 0x00, 0x00, 0x08, 0x10, 0x00, 0x00, 0x03, 0xc0, 0x00
static const unsigned char PROGMEM pressure_glcd_bmp[] =
  // 'pressure'
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00,
  0x01, 0xc1, 0xc1, 0xf8, 0x03, 0xc3, 0xc1, 0xf8, 0x03, 0x83, 0x81, 0xf8, 0x03, 0x03, 0x00, 0x18,
  0x07, 0x07, 0x00, 0x18, 0x07, 0x07, 0x00, 0xf8, 0x07, 0x07, 0x00, 0xf8, 0x07, 0x07, 0x00, 0xf8,
  0x07, 0x07, 0x00, 0x18, 0x03, 0x03, 0x00, 0x18, 0x03, 0x83, 0x80, 0x18, 0x03, 0x83, 0x81, 0xf8,
  0x03, 0x83, 0x81, 0xf8, 0x03, 0x83, 0x80, 0x18, 0x01, 0x81, 0x80, 0x18, 0x01, 0x81, 0x80, 0x18,
  0x03, 0x83, 0x80, 0xf8, 0x03, 0x83, 0x80, 0xf8, 0x03, 0x83, 0x80, 0xf8, 0x13, 0x93, 0x80, 0x18,
  0x1f, 0x1f, 0x00, 0x18, 0x1f, 0x1f, 0x01, 0xf8, 0x1e, 0x1e, 0x01, 0xf8, 0x1f, 0x1f, 0x01, 0xf8,
  0x1f, 0x9f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
static const unsigned char PROGMEM waga_glcd_bmp[] =
 0x00,0x00,0x80,0x00, // ········▌·······
  0x00,0x01,0xC0,0x00, // ·······▐█·······
  0x3F,0xFF,0xFF,0xFC, // ·██████████████·
  0x3F,0xFF,0xFF,0xFE, // ·██████████████▌
  0x07,0x81,0xC0,0xF0, // ··▐█▌··▐█···██··
  0x07,0x81,0x80,0xF0, // ··▐█▌··▐▌···██··
  0x0F,0xC1,0xC1,0xF8, // ··███··▐█··▐██▌·
  0x1C,0xC1,0xC1,0x98, // ·▐█·█··▐█··▐▌▐▌·
  0x18,0xE1,0xC3,0x8C, // ·▐▌·█▌·▐█··█▌·█·
  0x38,0x61,0xC3,0x0E, // ·█▌·▐▌·▐█··█··█▌
  0x30,0x71,0xC7,0x06, // ·█··▐█·▐█·▐█··▐▌
  0xFF,0xF9,0xCF,0xFF, // ██████▌▐█·██████
  0x7F,0xF9,0xCF,0xFF, // ▐█████▌▐█·██████
  0x3F,0xF1,0xC7,0xFE, // ·█████·▐█·▐████▌
  0x3F,0xE1,0xC3,0xFE, // ·████▌·▐█··████▌
  0x00,0x01,0x80,0x00, // ·······▐▌·······
  0x00,0x1F,0xFC,0x00, // ·····▐█████·····
  0x00,0x3F,0xFE,0x00, // ·····██████▌····
  0x00,0x00,0x00,0x00  // ················
static const unsigned char PROGMEM rain_glcd_bmp[] =
0x00,0x00,0x00,0x00, // ················
  0x00,0xF3,0xE0,0x00, // ····██·██▌······
  0x01,0x8E,0x18,0x00, // ···▐▌·█▌·▐▌·····
  0x03,0x0C,0x08,0x00, // ···█··█···▌·····
  0x04,0x38,0x0F,0x00, // ··▐··█▌···██····
  0x08,0x28,0x11,0x80, // ··▌··▌▌··▐·▐▌···
  0x10,0x40,0x00,0xC0, // ·▐··▐·······█···
  0x10,0x80,0x00,0x40, // ·▐··▌·······▐···
  0x0F,0x00,0x00,0x40, // ··██········▐···
  0x01,0x00,0x00,0x40, // ···▐········▐···
  0x01,0x00,0x00,0x80, // ···▐········▌···
  0x00,0xFF,0xFF,0x00, // ····████████····
  0x00,0x14,0x96,0x00, // ·····▐▐·▌▐▐▌····
  0x00,0x24,0xA4,0x00, // ·····▌▐·▌▌▐·····
  0x00,0x21,0x0C,0x00, // ·····▌·▐··█·····
  0x00,0x40,0x08,0x00, // ····▐·····▌·····
  0x00,0x10,0x80,0x00, // ·····▐··▌·······
static const unsigned char PROGMEM lux_glcd_bmp[] =
  0x00,0xC1,0xC1,0x80, // ····█··▐█··▐▌···
  0x00,0xE1,0xC3,0x80, // ····█▌·▐█··█▌···
  0x00,0x71,0xC7,0x00, // ····▐█·▐█·▐█····
  0x00,0x70,0x87,0x00, // ····▐█··▌·▐█····
  0x00,0x30,0x06,0x00, // ·····█····▐▌····
  0x18,0x07,0xF0,0x0C, // ·▐▌···▐███····█·
  0x3E,0x1F,0xF8,0x3C, // ·██▌·▐████▌··██·
  0x1F,0x3F,0x7E,0x78, // ·▐██·███▐██▌▐█▌·
  0x07,0x78,0x0E,0x70, // ··▐█▐█▌···█▌▐█··
  0x00,0x70,0x07,0x00, // ····▐█····▐█····
  0x00,0xE0,0x03,0x80, // ····█▌·····█▌···
  0x7C,0xC0,0x03,0x9F, // ▐██·█······█▌▐██
  0xFE,0xC0,0x01,0xBF, // ███▌█······▐▌███
  0x7C,0xC0,0x01,0x9F, // ▐██·█······▐▌▐██
  0x07,0x78,0x0F,0x70, // ··▐█▐█▌···██▐█··
  0x0F,0x3E,0x3E,0x78, // ··██·██▌·██▌▐█▌·
  0x1E,0x1F,0xFC,0x3C, // ·▐█▌·▐█████··██·
  0x00,0xC1,0xC3,0x80, // ····█··▐█··█▌···
  0x00,0x01,0xC1,0x00, // ·······▐█··▐····
  0x00,0x00,0x80,0x00  // ········▌·······
static const unsigned char PROGMEM logo32_glcd_bmp[] =
  // 'logo SUPLA'
  0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x03, 0xf8, 0x00, 0x00, 0x07, 0xfc, 0x00, 0x00,
  0x0e, 0x0e, 0x00, 0x00, 0x0c, 0x06, 0x00, 0x00, 0x1c, 0x03, 0x00, 0x00, 0x1c, 0x03, 0x00, 0x00,
  0x1c, 0x03, 0x00, 0x00, 0x0c, 0x07, 0x00, 0x00, 0x0e, 0x0f, 0x80, 0x00, 0x07, 0xfc, 0xe0, 0x00,
  0x03, 0xf8, 0x30, 0x00, 0x00, 0xf0, 0x0d, 0xe0, 0x00, 0x10, 0x07, 0x30, 0x00, 0x18, 0x02, 0x10,
  0x00, 0x18, 0x06, 0x18, 0x00, 0x08, 0x02, 0x10, 0x00, 0x08, 0x03, 0xf0, 0x00, 0x0c, 0x07, 0xc0,
  0x00, 0x04, 0x0c, 0x00, 0x00, 0x04, 0x08, 0x00, 0x00, 0x04, 0x10, 0x00, 0x00, 0x00, 0x20, 0x00,
  0x00, 0x03, 0xc0, 0x00, 0x00, 0x04, 0x40, 0x00, 0x00, 0x0c, 0x20, 0x00, 0x00, 0x0c, 0x20, 0x00,
  0x00, 0x04, 0x40, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
static const unsigned char PROGMEM ASL_glcd_bmp[] =
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00,
  0x00, 0x00, 0x60, 0x00, 0x00, 0x08, 0x21, 0x00, 0x00, 0x0c, 0x03, 0x00, 0x00, 0x00, 0x62, 0x00,
  0x00, 0x1f, 0xf8, 0x00, 0x00, 0x3f, 0x0c, 0x00, 0x00, 0x61, 0x84, 0x00, 0x00, 0xc0, 0xc4, 0xe0,
  0x01, 0xc0, 0xf4, 0x00, 0x03, 0x00, 0x1c, 0x00, 0x06, 0x00, 0x0c, 0x00, 0x06, 0x00, 0x0c, 0x00,
  0x06, 0x10, 0xcd, 0x00, 0x03, 0x10, 0x99, 0x00, 0x01, 0x84, 0x30, 0x00, 0x00, 0x25, 0x00, 0x00,
  0x00, 0x21, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
char* Message[] = {"This is string 1",
                   "Already initialized",
                   "Cb not assigned",
                   "Invalid GUID",
                   "Unknown server address",
                   "Unknow location ID",
                   "Initialized",
                   "Channel limit exceeded",
                   "Rozlaczony",
                   "Rejstracja w toku",
                   "Iterate fail",
                   "Protocol version error",
                   "Bad credentials",
                   "Temporarily unawaliable",
                   "Location conflict",
                   "Channel conflict",
                   "Polaczony i gotowy",
                   "Device is diasbled",
                   "Location is disabled",
                   "Device limit execeeded"
#if (SSD1306_LCDHEIGHT != 64)
//#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
// ***** logowanie WiFi ********************************************************************************
WiFiClient client;
// Setup Supla connection
const char* ssid     = "xxx";
const char* password = "xxxxxx";
char str[10];
char StatCommStr[25];
int StatCommInt;
byte Icon;
byte FiveSek;
//// ******* BME280 Temperatura i wilgotnosc *********************************
void get_temperature_and_humidity (int channelNumber, double *temp, double *humidity){
    *temp = bme.readTemperature();
    Serial.print("Temperature = ");
    Serial.print(bme.readTemperature());
    Serial.println(" *C");
    *humidity = bme.readHumidity();
    Serial.print("Humidity = ");
    Serial.print(bme.readHumidity());               // wyremowane dla BMP280
    Serial.println(" %");
    if ( isnan(*temp) || isnan(*humidity) ) {
      *temp = -275;
      *humidity = -1;
///***********DESZCZ*******************************************************
double get_rain(int channelNumber, double rain) {
 rain = 10;
    Serial.print("Rain = ");
    Serial.print(rain);
    Serial.println(" mm");
   return  rain;
//// ******* Ciśnienie *****************************************************
double get_pressure(int channelNumber, double pressure) {
 pressure = bme.readPressure() / 100.0F;
    Serial.print("Pressure = ");
    Serial.print(bme.readPressure()/100);
    Serial.println(" hPa");
   return  pressure;
////******* Natężenie zrobione obsługą czujnika odległości
double get_distance(int channelNumber, double t) {
 // float lux = analogRead(LIGHTSENSORPIN);             //TEMT6000
   double lux = LightSensor.GetLightIntensity();     //BH1750
    t = abs(lux);
    Serial.print("Natezenie swiatla = ");
    Serial.print(LightSensor.GetLightIntensity());
    delay(1250);
    return t;
double get_weight(int channelNumber, double t) {
   double lux = (scale.get_units()*1000);
    t = abs(lux);
    Serial.print("Twoja waga= ");
    Serial.print(scale.get_units());
    Serial.print(" kg");
    delay(1250);
    return t;
void timer0_ISR (void) {
  FiveSek++;
  if (FiveSek==2) {
    FiveSek=0;
    Icon++;
    if (Icon==3) Icon=1;
  timer0_write(ESP.getCycleCount() + 80000000L); // 80MHz == 1sec
//// ******* Funkcja główna *********************************************************************************
void setup() {
  Serial.begin(9600); //BH1750
  scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
  scale.tare(); //Assuming there is no weight on the scale at start up,
  noInterrupts();
  timer0_isr_init();
  timer0_attachInterrupt(timer0_ISR);
  interrupts();
/*  if (!bme.begin(0x76)) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x64)
  Icon = 0;
  // Clear the buffer.
  display.clearDisplay();
  // text display tests
  display.setTextSize(3);
  display.setTextColor(WHITE);
  display.setRotation(2);
  display.setCursor(30, 25);
  display.print("SUPLA");
  drawbitmap(logo32_glcd_bmp, LOGO32_GLCD_HEIGHT, LOGO32_GLCD_WIDTH);
  display.display();
  // Replace the falowing GUID
char GUID[SUPLA_GUID_SIZE] = {0x8B,0x4A,0x5B,0xB5,0x6B,0x68,0x76,0x5B,0xF5,0xEA,0x9A,0x8C,0x73,0xC6,0x38,0x1D};
  //  GUID that you can retrieve from https://www.supla.org/arduino/get-guid
  // Ethernet MAC address
  uint8_t mac[6] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
     Having your device already registered at cloud.supla.org,
     you want to change CHANNEL sequence or remove any of them,
     then you must also remove the device itself from cloud.supla.org.
     Otherwise you will get "Channel conflict!" error.
          // CHANNEL0
            SuplaDevice.addWeightSensor(); //wagi czujnik
          //  SuplaDevice.addDHT22(); // ten objekt jest tylko po to aby w aplikacji wyświetlic temp i wilgotnosc
	        //  SuplaDevice.addDistanceSensor(); // ten obiekt wyswietla natezenie niestety bez jednostek (LUX)
	       //   SuplaDevice.addPressureSensor();  // cisnienie
  SuplaDevice.setName("R@F_Waga");
  SuplaDevice.setStatusFuncImpl(&status_func);
                    "svrX.supla.org",  // SUPLA server address
                    111,                 // Location ID
                    "77777");               // Location Password
void loop() {
  SuplaDevice.iterate();
  DisplayTemp();
// ****   Obsługa OLED    ****************************************************************************************************
void DisplayTemp() {
   double waga = scale.get_units();
double Light_Intensity = LightSensor.GetLightIntensity();
int rain=0.01;
  display.setCursor(45, 25);
  switch (Icon) {
      case 1:
        display.setTextSize(4);
        display.setCursor(39, 20 );
        display.print(waga, 0);
        display.print("kg" );
        drawbitmap(waga_glcd_bmp, LOGO32_GLCD_HEIGHT, LOGO32_GLCD_WIDTH);
        break;
        case 2:
        break;
  display.setTextSize(1);
  display.setCursor(0, 55);
  display.print(Message[StatCommInt - 1]);
  display.display();
  display.display();
}; //DisplayTemp
void drawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  display.drawBitmap(0, 0, bitmap, w, h, WHITE);
} //drawbitmap
// Supla.org ethernet layer
  if ( size > 0 ) {
  return -1;
  return client.connected();
  client.stop();
  // Serial.println("WiFi init");
  WiFi.begin(ssid, password);
    delay(500);
        Serial.print(".");
 // Serial.print("\nlocalIP: ");
 // Serial.println(WiFi.localIP());
  //Serial.print("subnetMask: ");
 // Serial.println(WiFi.subnetMask());
  //Serial.print("gatewayIP: ");
  //Serial.println(WiFi.gatewayIP());
  SuplaDeviceCallbacks cb;
  cb.get_weight = get_weight;
  cb.get_pressure = NULL;
  cb.get_temperature = NULL;
  cb.get_rgbw_value = NULL;
  cb.set_rgbw_value = NULL;
  cb.get_distance= NULL;
  return cb;
void status_func(int status, const char *msg) {
  Serial.print("Status : ");
  Serial.print(status);
  StatCommInt = status;
  Serial.print(" - ");
  Serial.println(Message[StatCommInt - 1]);
  display.fillRect(0, 55, 128, 65, BLACK);
  display.display();
Tymczasem trwa montaż aby miało ręce i nogi:
Has thanked: 13 times
Been thanked: 25 times
A jakie zasilanie przewidujesz do tej wagi?
https://pool.lector.top/
Lector wrote: Fri Jun 21, 2019 2:26 pm A jakie zasilanie przewidujesz do tej wagi?
No tu jest jeszcze nie ogarnięte . Jakiś reaktor by się przydał. Na razie chyba zrobię z zasilacza.
Szykuje się do remontu i wagę chce ukryć jakoś przy umywalkę, wyświetlacz za lustro, a zasilanie j/W z zasilacza.
Miejsce gdzie będą tensometry też chce wrzucić czujnik zalania. Jak na razie taki plan.
KONIEC PROJEKTU - TESTY DZIAłANIA NA ŻYWYM ORGANIŹMIE :D :lol:
https://youtu.be/RDsYlxqhj90
Fajnie by było, gdyby dane z pomiarów były zapamiętywane w bazie danych. Soft musiałby też wspierać możliwość zmiany użytkowników dokonujących pomiaru, tak aby wynik zapisywał się na właściwym koncie. Można by potem pokusić się o wykres w apce i przeglądać zmiany naszej wagi :)
🧩: 🔑cz->b ⛴️+ila
lesny8 wrote: Sat Jun 22, 2019 12:27 am Fajnie by było, gdyby dane z pomiarów były zapamiętywane w bazie danych. Soft musiałby też wspierać możliwość zmiany użytkowników dokonujących pomiaru, tak aby wynik zapisywał się na właściwym koncie. Można by potem pokusić się o wykres w apce i przeglądać zmiany naszej wagi :)
To nie na moje umiejętności.
Prosiłbym tylko jeszcze @pzygmunt aby zmniejszyć opóźnienie, czy też odświeżanie wartości w apce.
Druga rzecz o czym zawsze zapominam: pod ikonami w Cloud temp i wilgotność mają wyświetlane wartosci a ciśnienie, waga, deszcz nie. Czy można to zrobić jak dla temp i wilgotnosci? Chyba że dużo roboty to nie.
A i trzecia dziwna rzecz - jak waga wskazuje w apce 0 to miano p9trafi zmienić się z gramów na milimetry??
Opóźnienie zależy od urządzenia wykonawczego.
Z tymi mm to muszę sprawdzić.
