Przyciski, guziki, kontrolery scen - zgłoszenia, uwagi, pomysły [bramka ZigBee]
- Has thanked: 291 times
- Been thanked: 161 times
Jak w temacie - wszystkie smart buttons/switches/piloty/wyzwalacze scen - zasilane bateryjne.
wojtas567
Poproszę o dodanie takiego przycisku
https://zigbee.blakadder.com/Ikea_E2201.html
17:40:59.726 -> ============ After Setup End =============
17:41:55.501 -> [ 57725][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
17:41:55.501 -> [ 57727][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
17:41:55.501 -> [ 57755][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xfa7f)
17:41:55.501 -> [ 57756][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
17:41:55.501 -> [ 57756][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0xfa7f), ieee_addr (0xc):(0x2a):(0x6f):(0xff):(0xfe):(0x15):(0xd7):(0xfc)
17:41:55.547 -> [ 57757][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xfa7f), ieee_addr (0xc):(0x2a):(0x6f):(0xff):(0xfe):(0x15):(0xd7):(0xfc)
17:41:55.594 -> [ 57813][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
17:41:55.594 -> [ 57813][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0xfa7f
17:41:55.642 -> [ 57867][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
17:41:55.642 -> [ 57868][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa7f), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
17:41:55.642 -> [ 57869][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
17:41:55.759 -> [ 58014][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
17:41:56.259 -> [ 58514][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
17:41:56.513 -> [ 58767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:41:56.513 -> [ 58767][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:41:56.513 -> [ 58768][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(8)
17:41:56.558 -> [ 58768][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "8"
17:41:56.558 -> [ 58770][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
17:41:57.015 -> [ 59270][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
17:41:57.555 -> [ 59767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:41:57.555 -> [ 59767][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:41:57.555 -> [ 59768][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(14)
17:41:57.555 -> [ 59769][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "IKEA of Sweden"
17:41:57.555 -> [ 59770][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
17:41:58.018 -> [ 60273][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
17:41:58.561 -> [ 60780][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:41:58.561 -> [ 60780][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:41:58.561 -> [ 60781][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(8)
17:41:58.561 -> [ 60781][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "8"
17:41:58.561 -> [ 60782][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
17:41:59.029 -> [ 61285][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
17:41:59.535 -> [ 61772][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:41:59.535 -> [ 61773][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:41:59.535 -> [ 61774][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(1)
17:41:59.535 -> [ 61774][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "1"
17:41:59.535 -> [ 61776][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
17:41:59.535 -> [ 61790][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
17:42:00.048 -> [ 62276][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
17:42:00.547 -> [ 62774][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:42:00.547 -> [ 62774][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:42:00.547 -> [ 62775][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(13)
17:42:00.547 -> [ 62776][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "RODRET Dimmer"
17:42:00.547 -> [ 62777][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
17:42:01.061 -> [ 63279][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
17:42:01.497 -> [ 63752][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:42:01.497 -> [ 63752][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:42:01.542 -> [ 63753][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
17:42:01.542 -> [ 63754][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
17:42:01.542 -> [ 63755][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
17:42:02.000 -> [ 64255][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
17:42:02.542 -> [ 64755][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 64127
17:42:02.542 -> [ 64759][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
17:42:02.542 -> [ 64759][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:42:02.542 -> [ 64760][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
17:42:02.542 -> [ 64767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
17:42:02.542 -> [ 64768][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0)
17:42:02.542 -> [ 64768][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
17:42:03.501 -> [ 65756][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 64127, endpoints count 1
17:42:03.501 -> [ 65756][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
17:42:04.463 -> [ 66718][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x4fae) is open for 180 seconds
17:42:04.498 -> [ 66752][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 64127, endpoint # 1
17:42:04.498 -> [ 66752][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 6
17:42:04.498 -> [ 66753][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 32
17:42:04.532 -> [ 66755][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 4096
17:42:04.532 -> [ 66755][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 64636
17:42:04.532 -> [ 66756][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
17:42:04.532 -> [ 66756][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 4
17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 3, id 6
17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 4, id 8
17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 5, id 25
17:42:04.532 -> [ 66758][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 6, id 4096
17:42:04.566 -> [ 66820][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x3, command id: 1
17:42:04.566 -> [ 66821][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:42:04.609 -> [ 66821][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
17:42:04.609 -> [ 66822][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
17:42:04.609 -> [ 66822][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 32 size: 0
17:42:04.609 -> [ 66823][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xfa7f, 0xfa7f, 0x0, 0x0
17:42:04.609 -> [ 66823][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
17:42:05.623 -> [ 67844][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
Witam. Mam w starej instalacji oświetlenie bez przewodu N zamontowane moduły SONOFF ZBMINI Extreme Zigbee Smart Switch (ZBMINI-L2) które z bramkę działają bardzo dobrze. Pytanie czy jest możliwość dołożenia opcji reakcji na przycisk (monostabilny i bistabilny) bo chciałbym wykorzystać przycisk dzwonkowy
mariomar
W cloud w zakładce funkcje ustaw sobie automat schodowy. U mnie też działa jak sparuję switch z Smart life, tam ustawie czas po którym sie ma wyłaczyć, ponownie paruję go do bramki Z2S i pamięta ustawienia.bokk wrote: Mon Feb 24, 2025 3:38 am Witam. Mam w starej instalacji oświetlenie bez przewodu N zamontowane moduły SONOFF ZBMINI Extreme Zigbee Smart Switch (ZBMINI-L2) które z bramkę działają bardzo dobrze. Pytanie czy jest możliwość dołożenia opcji reakcji na przycisk (monostabilny i bistabilny) bo chciałbym wykorzystać przycisk dzwonkowy
Dodany.wojtas567 wrote: Fri Feb 21, 2025 5:07 pm Poproszę o dodanie takiego przycisku
https://zigbee.blakadder.com/Ikea_E2201.htmlCode: Select all
17:40:59.726 -> ============ After Setup End ============= 17:41:55.501 -> [ 57725][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK 17:41:55.501 -> [ 57727][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK 17:41:55.501 -> [ 57755][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xfa7f) 17:41:55.501 -> [ 57756][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80 17:41:55.501 -> [ 57756][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0xfa7f), ieee_addr (0xc):(0x2a):(0x6f):(0xff):(0xfe):(0x15):(0xd7):(0xfc) 17:41:55.547 -> [ 57757][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xfa7f), ieee_addr (0xc):(0x2a):(0x6f):(0xff):(0xfe):(0x15):(0xd7):(0xfc) 17:41:55.594 -> [ 57813][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices: 17:41:55.594 -> [ 57813][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0xfa7f 17:41:55.642 -> [ 57867][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback 17:41:55.642 -> [ 57868][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa7f), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3 17:41:55.642 -> [ 57869][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) 17:41:55.759 -> [ 58014][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0 17:41:56.259 -> [ 58514][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1 17:41:56.513 -> [ 58767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:41:56.513 -> [ 58767][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:41:56.513 -> [ 58768][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(8) 17:41:56.558 -> [ 58768][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "8" 17:41:56.558 -> [ 58770][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4 17:41:57.015 -> [ 59270][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2 17:41:57.555 -> [ 59767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:41:57.555 -> [ 59767][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:41:57.555 -> [ 59768][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(14) 17:41:57.555 -> [ 59769][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "IKEA of Sweden" 17:41:57.555 -> [ 59770][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0 17:41:58.018 -> [ 60273][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3 17:41:58.561 -> [ 60780][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:41:58.561 -> [ 60780][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:41:58.561 -> [ 60781][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(8) 17:41:58.561 -> [ 60781][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "8" 17:41:58.561 -> [ 60782][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1 17:41:59.029 -> [ 61285][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4 17:41:59.535 -> [ 61772][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:41:59.535 -> [ 61773][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:41:59.535 -> [ 61774][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(1) 17:41:59.535 -> [ 61774][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "1" 17:41:59.535 -> [ 61776][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5 17:41:59.535 -> [ 61790][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK 17:42:00.048 -> [ 62276][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5 17:42:00.547 -> [ 62774][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:42:00.547 -> [ 62774][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:42:00.547 -> [ 62775][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(13) 17:42:00.547 -> [ 62776][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "RODRET Dimmer" 17:42:00.547 -> [ 62777][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7 17:42:01.061 -> [ 63279][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6 17:42:01.497 -> [ 63752][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:42:01.497 -> [ 63752][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:42:01.542 -> [ 63753][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3) 17:42:01.542 -> [ 63754][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3" 17:42:01.542 -> [ 63755][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe 17:42:02.000 -> [ 64255][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13) 17:42:02.542 -> [ 64755][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 64127 17:42:02.542 -> [ 64759][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback 17:42:02.542 -> [ 64759][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:42:02.542 -> [ 64760][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0) 17:42:02.542 -> [ 64767][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback 17:42:02.542 -> [ 64768][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xfa7f) src endpoint(1) to dst endpoint(1) cluster(0x0) 17:42:02.542 -> [ 64768][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde) 17:42:03.501 -> [ 65756][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 64127, endpoints count 1 17:42:03.501 -> [ 65756][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1 17:42:04.463 -> [ 66718][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x4fae) is open for 180 seconds 17:42:04.498 -> [ 66752][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 64127, endpoint # 1 17:42:04.498 -> [ 66752][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 6 17:42:04.498 -> [ 66753][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0 17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 1 17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 3 17:42:04.532 -> [ 66754][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 32 17:42:04.532 -> [ 66755][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 4096 17:42:04.532 -> [ 66755][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 64636 17:42:04.532 -> [ 66756][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3 17:42:04.532 -> [ 66756][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 4 17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 3, id 6 17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 4, id 8 17:42:04.532 -> [ 66757][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 5, id 25 17:42:04.532 -> [ 66758][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 6, id 4096 17:42:04.566 -> [ 66820][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x3, command id: 1 17:42:04.566 -> [ 66821][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 17:42:04.609 -> [ 66821][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0 17:42:04.609 -> [ 66822][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0 17:42:04.609 -> [ 66822][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 32 size: 0 17:42:04.609 -> [ 66823][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xfa7f, 0xfa7f, 0x0, 0x0 17:42:04.609 -> [ 66823][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed--------------------------------------------------------------- 17:42:05.623 -> [ 67844][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
wojtas567
Hejka, potwierdzam przyciski IKEA ładnie działają ale mam pytanie może podpiąć pod nie wyzwalacz akcji?
Yepestis
- Has thanked: 19 times
- Been thanked: 3 times
Podpinam się pod prośbę i to dla wszystkich przycisków nie tylko z IKEA. Obecne wykonanie na przełącznikach ma taką wadę że jak jest zanik zasilania na bramce te przełączniki się wyłączają, a mając ustawione reakcje na toggle przełącza to nam światłowojtas567 wrote: Tue Feb 25, 2025 4:42 pm Hejka, potwierdzam przyciski IKEA ładnie działają ale mam pytanie może podpiąć pod nie wyzwalacz akcji?
To pytanie do wszystkich zainteresowanych - ktoś jest przeciwny zmianie tych przycisków z RELAY na ACTIONTRIGGER?
wojtas567
Dla Ciebie mniej roboty
bo po jednym kanale na przycisk no i w ACTIONTRIGGER mamy więcej możliwości.
