Has thanked: 291 times
artur_n wrote: Fri May 09, 2025 6:47 am Panowie macie jakieś źródło tanich głowic TRVZB?
Tutaj kupiłem przed chwilą 5 sztuk ;)
bokk wrote: Fri May 09, 2025 3:23 pm
vajera wrote: Fri May 09, 2025 3:03 pm
bokk wrote: Fri May 09, 2025 2:07 pm Z ta baterią to też dziwna sprawa, wczoraj przy aktualizacji firmware przez bramkę termometra SONOFF SNZB-02D bateria spadła o 35% w ciągu 5 minut aktualizacji.
Jaką masz teraz wersję firmware?
SONOFF ZBBridge-P
SN-NG-ZBP-01
2.5.0
SONOFF TRVZB
SN-MG22-TRVZB-01
1.3.0
SONOFF SNZB-02D
SN-MG22-THMD-01
2.3.0
SONOFF ZBMINIR2
SN-MG21-ZGMR2-01
1.0.4
SONOFF ZBMINIL2
SN-MG22-ZGML2-01
1.0.14
To dla TRVZB powinno Ci teraz działać to:
cluster: "customSonoffTrvzb",
attribute: "tempAccuracy",
entityCategory: "config",
description:
"Temperature control accuracy. " +
"The range is -0.2 ~ -1°C, with an interval of 0.2, and the default is -1. " +
"If the temperature control accuracy is selected as -1°C (default value) and the target temperature is 26 degrees, " +
"then TRVZB will close the valve when the room temperature reaches 26 degrees and open the valve at 25 degrees. " +
"If -0.4°C is chosen as the temperature control accuracy, then the valve will close when the room temperature reaches 26 degrees and open at 25.6 degrees." +
"Note: Only version v1.3.0 or higher is supported.",
valueMin: -1.0,
valueMax: -0.2,
valueStep: 0.2,
unit: "°C",
scale: 100,
Zrób test:
read-attribute nr_kanału_termostatu 0xFC11 0x6011
bokk
Has thanked: 7 times
Been thanked: 25 times
vajera wrote: Fri May 09, 2025 3:26 pm
SONOFF ZBBridge-P
SN-NG-ZBP-01
2.5.0
SONOFF TRVZB
SN-MG22-TRVZB-01
1.3.0
SONOFF SNZB-02D
SN-MG22-THMD-01
2.3.0
SONOFF ZBMINIR2
SN-MG21-ZGMR2-01
1.0.4
SONOFF ZBMINIL2
SN-MG22-ZGML2-01
1.0.14
description:
valueMin: -1.0,
valueMax: -0.2,
valueStep: 0.2,
unit: "°C",
scale: 100,
Zrób test:
Dopiero jutro jak wrócę do domu, a co to ma dodać:)
bokk wrote: Fri May 09, 2025 3:34 pm Dopiero jutro jak wrócę do domu, a co to ma dodać:)
Sterowanie wewnętrzną histerezą głowicy, zgodnie z opisem. A to polecenie to test na odczyt bieżącej wartości.
lukasz06
Has thanked: 46 times
Been thanked: 21 times
A histereza ustawiona w Cloud nie działa? Co to za różnica, bo w sumie nie sprawdzałem 😉
Been thanked: 32 times
vajera wrote: Fri May 09, 2025 3:42 pm
Wygląda dobrze. Szkoda, że akurat teraz nie mam tego modelu. Ciekawe, że tyle czasu im zajęła taka aktualizacja, bo np. w tych HY co mam była możliwość ustawienia histerezy (od 0,2) już w pierwszej wersji softu. A tak z ciekawości ten wyświetlacz na głowicy pokazuje tylko pełne stopnie i połówki, tak? W tym przypadku termostat z Supli będzie pokazywał lepiej (dokładniej)?
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Zrób test:
tak to wygląda na sonnoff trvzb ver.1.3.0 soft głowicy czyli wychodzi że czyta teraz ten parametr ale jak to zmienić write-attribute i co dalej 😉:
>read-attribute 3 0xFC11 0x6011
>Device 59809
>>read-attribute 3 64529 24593
>>Reading attribute successful - data value is 0xff9c, data type is 0x29
LukiSpajder wrote: Fri May 09, 2025 5:16 pm tak to wygląda na sonnoff trvzb ver.1.3.0 soft głowicy czyli wychodzi że czyta teraz ten parametr ale jak to zmienić write-attribute i co dalej 😉:
>Device 59809
0xFF9C (INT16) = -100 /100 = -1 st. C czyli wartość domyślna
jeżeli chcesz to zmienić na np. -0,4 st. C to liczysz tak -0,4 * 100 = -40 = 0xFFD8 (INT16)
write-attribute nr_kanału_termostatu 0xFC11 0x6011 INT16 2 0xFFD8
lukasz06 wrote: Fri May 09, 2025 4:17 pm A histereza ustawiona w Cloud nie działa? Co to za różnica, bo w sumie nie sprawdzałem 😉
Działa, podobnie jak czujnik otwarcia okna ;)
Zasadniczo polecam korzystanie z jak największej liczby funkcji termostatu Supla (histereza, okno), ale ktoś kiedyś pytał o ten parametr, więc napisałem.
LukiSpajder
vajera wrote: Fri May 09, 2025 7:17 pm
>Device 59809
>write-attribute 3 0xFC11 0x6011 INT16 2 0xFFD8
>Device 59809
>>write-attribute 3 0xFC11 0x6011 0x0 0x2
>Write attribute async request sent
write-attribute 3 0xFC11 0x6011 INT16 2 0xFFD8 async
>Device 59809
dodałem async czy dobrze ?
Sprostowanie :
jednak coś nie działa jak to testowałem zmieniałem temperaturę zadaną i wtedy głowica zaczynała grzać ale po podpięciu termometru na kanale 100 obniżenie temperatury o 0.,4 stopnia nie powoduje załaczenia głowicy - może coś źle robię ;)
