Ok, dzięki - całkiem sporo wyszło. Rozumiem, że Twoja wersja ma jeden kanał ściemniacza?[email protected] wrote: Wed Oct 01, 2025 5:23 pmvajera wrote: Wed Oct 01, 2025 3:04 pmDasz radę puścić to przez skaner?[email protected] wrote: Wed Oct 01, 2025 2:07 pm Powitać,
można dodać takie urządzonko?
Zigbee Smart LED Controller
model _TZ3210_i680rtja::TS0501B
typ Single Color
https://pl.aliexpress.com/item/10050074 ... pt=glo2polcoś tam wyszłoCode: Select all
[code][114923][V][ZigbeeCore.cpp:461] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK [114959][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [114959][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0013, asdu_length: 12 APSDE INDICATION - dst_short_addr: 0xfffd, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [114961][I][ZigbeeCore.cpp:365] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xafd0) [114962][V][ZigbeeCore.cpp:369] esp_zb_app_signal_handler(): Device capabilities: 0x8e [114990][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [114990][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8006, asdu_length: 6 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [114992][D][ZigbeeGateway.cpp:259] find_Cb(): BASIC cluster found: short address(0xafd0), endpoint(1) [115064][I][ZigbeeGateway.cpp:691] printJoinedDevices(): joined devices: [115064][I][ZigbeeGateway.cpp:694] printJoinedDevices(): Device on endpoint 1, short address: 0xafd0 [115084][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [115084][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0xef00, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [115086][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 11 [115086][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [115087][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [115087][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [115088][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 12 size: 2 [115088][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x03 [115088][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [115089][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [115089][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [115090][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [115090][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0 [115091][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [115092][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 0, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 255 [115092][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 0, _custom_cmd_last_tsn_flag = 255 [115093][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -1346371584 [115265][I][ZigbeeGateway.cpp:1938] sendCustomClusterCmd(): _custom_cmd_last_tsn = 0 [115465][I][ZigbeeGateway.cpp:1946] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2 [115465][I][ZigbeeGateway.cpp:379] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4 [115485][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [115485][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 24 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [115487][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1 [115487][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [115488][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [115488][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [115489][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 14 size: 21 [115489][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x04 [115489][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [115490][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [115490][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42 [115490][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x10 [115491][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5F [115491][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x54 [115491][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5A [115492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x33 [115492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x32 [115492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x31 [115492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30 [115493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5F [115493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x69 [115493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x36 [115494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x38 [115494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30 [115494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x72 [115495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x74 [115495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x6A [115495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x61 [115496][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [115496][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [115497][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1000) callback [115497][V][ZigbeeHandlers.cpp:255] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xafd0) src endpoint(1) to dst endpoint(1) cluster(0x0) [115498][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16) [115499][I][ZigbeeGateway.cpp:433] zbReadBasicCluster(): Peer Manufacturer is "_TZ3210_i680rtja" [116155][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [116155][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0002, asdu_length: 3 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [116213][I][ZigbeeCore.cpp:443] esp_zb_app_signal_handler(): Device 0xafd0 authorized (status: 0, type: 1) [116235][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [116236][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0036, asdu_length: 3 APSDE INDICATION - dst_short_addr: 0xfffc, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [116238][I][ZigbeeCore.cpp:422] esp_zb_app_signal_handler(): Network(0x02a5) is open for 180 seconds [116338][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [116338][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0xef00, asdu_length: 13 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [116340][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 6 [116340][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [116341][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0 [116341][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [116342][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 20 size: 10 [116342][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [116342][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x01 [116343][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x51 [116343][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x02 [116343][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [116344][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x04 [116344][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xFF [116344][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xFF [116345][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xFF [116345][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xCE [116345][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [116346][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [116347][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1040) callback [116347][I][ZigbeeHandlers.cpp:477] zb_cmd_custom_cluster_req_handler(): Receive custom command: 6 from address 0xafd0 [116348][I][ZigbeeHandlers.cpp:478] zb_cmd_custom_cluster_req_handler(): Frame control 0x0 [116348][I][ZigbeeHandlers.cpp:479] zb_cmd_custom_cluster_req_handler(): Payload size: 10 [116348][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0 [116349][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1 [116349][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x51 [116350][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2 [116350][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0 [116351][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4 [116351][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0xff [116352][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0xff [116352][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0xff [116352][I][ZigbeeHandlers.cpp:481] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xce [116466][I][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): basic tsn 0x1 [116466][I][ZigbeeGateway.cpp:379] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5 [116487][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [116488][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 15 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [116489][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1 [116490][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [116490][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [116491][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [116491][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 3 size: 12 [116492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x05 [116492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [116492][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [116493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42 [116493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x07 [116493][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x54 [116494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x53 [116494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30 [116494][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x35 [116495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30 [116495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x31 [116495][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42 [116496][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [116496][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [116497][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1000) callback [116497][V][ZigbeeHandlers.cpp:255] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xafd0) src endpoint(1) to dst endpoint(1) cluster(0x0) [116498][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7) [116499][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): Peer Model is "TS0501B" [117467][I][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): basic tsn 0x2 [117467][I][ZigbeeGateway.cpp:1533] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13) [117485][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117485][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0000, asdu_length: 4 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117487][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 4 [117487][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117488][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117488][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117488][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 27 size: 1 [117489][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00 [117489][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117490][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117490][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1001) callback [117491][V][ZigbeeHandlers.cpp:297] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xafd0) src endpoint(1) to dst endpoint(1) cluster(0x0) [117492][V][ZigbeeHandlers.cpp:304] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff) [117492][I][ZigbeeGateway.cpp:1062] zbWriteAttrResponse(): tsn = 3, _write_attr_last_tsn = 3, _write_attr_last_tsn_flag = 2 [117493][I][ZigbeeGateway.cpp:1076] zbWriteAttrResponse(): zbWriteAttrResponse async, tsn = 3, _set_config_last_tsn_flag = 2 [117668][I][ZigbeeGateway.cpp:338] zbPrintDeviceDiscovery(): short_addr_req 45008 [117684][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117685][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8005, asdu_length: 7 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [117686][I][ZigbeeGateway.cpp:272] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 45008, endpoints count 2 [117687][I][ZigbeeGateway.cpp:275] Z2S_active_ep_req_cb(): Endpont # 1, id 1 [117688][I][ZigbeeGateway.cpp:275] Z2S_active_ep_req_cb(): Endpont # 2, id 242 [117708][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117709][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x8004, asdu_length: 35 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0 [117711][I][ZigbeeGateway.cpp:291] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 45008, endpoint # 1 [117711][I][ZigbeeGateway.cpp:292] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 2 [117712][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 1, id 3 [117712][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 2, id 4 [117713][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 3, id 5 [117713][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 4, id 6 [117714][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 5, id 4096 [117714][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 6, id 8 [117714][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 7, id 768 [117715][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 8, id 61184 [117715][I][ZigbeeGateway.cpp:296] Z2S_simple_desc_req_cb(): In cluster # 9, id 0 [117716][I][ZigbeeGateway.cpp:311] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25 [117716][I][ZigbeeGateway.cpp:311] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10 [117780][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117780][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0003, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117782][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x3, command id: 11 [117782][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117783][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117783][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117784][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 10 size: 2 [117784][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117785][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117785][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117785][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117786][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117787][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84 [117788][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [117788][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 4, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [117789][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 4, _custom_cmd_last_tsn_flag = 2 [117789][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -792723456 [117794][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117794][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0004, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117796][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x4, command id: 11 [117796][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117797][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117797][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117798][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 7 size: 2 [117798][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117798][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117799][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117799][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117800][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117800][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84 [117801][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [117802][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 5, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [117802][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 5, _custom_cmd_last_tsn_flag = 2 [117803][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -1841299456 [117808][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117809][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0005, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117811][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x5, command id: 11 [117811][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117812][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117812][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117813][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 15 size: 2 [117813][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117813][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117814][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117814][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117815][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117815][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84 [117816][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [117817][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 6, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [117818][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 6, _custom_cmd_last_tsn_flag = 2 [117818][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -1337982976 [117819][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117820][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0006, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117821][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x6, command id: 11 [117822][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117822][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117823][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117823][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 19 size: 2 [117824][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117824][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117824][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117825][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117825][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117826][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84 [117827][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [117827][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 7, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [117828][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 7, _custom_cmd_last_tsn_flag = 2 [117829][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi 0 [117835][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117835][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x1000, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117837][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x1000, command id: 11 [117837][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117838][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117838][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117839][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 20 size: 2 [117839][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117840][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117840][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117840][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117841][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117842][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x1000) for command (0xc) with status 0x84 [117843][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [117843][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 8, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [117844][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 8, _custom_cmd_last_tsn_flag = 2 [117844][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -1178599424 [117845][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [117846][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0008, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [117847][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x8, command id: 11 [117848][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [117848][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [117849][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [117849][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 17 size: 2 [117849][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [117850][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [117850][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [117851][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [117851][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [117852][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x8) for command (0xc) with status 0x84 [117853][V][ZigbeeHandlers.cpp:385] zb_cmd_defau_resp_handler(): command id (11), direction (1), is common (1) [118112][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 9, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [118113][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 9, _custom_cmd_last_tsn_flag = 2 [118113][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -1308622848 [118114][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [118115][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0300, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [118116][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x300, command id: 11 [118117][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [118117][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [118118][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [118118][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 3 size: 2 [118118][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [118119][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [118119][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [118120][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [118120][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [118121][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x300) for command (0xc) with status 0x84 [118122][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [118122][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 10, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [118123][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 10, _custom_cmd_last_tsn_flag = 2 [118123][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -754974720 [118124][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [118124][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 0, cluster_id: 0xef00, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [118126][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 11 [118126][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [118127][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [118127][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [118128][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 26 size: 2 [118128][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [118128][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [118129][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [118129][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [118130][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [118131][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0xef00)or command (0xc) with status 0x84 [118397][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [118398][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 11, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [118398][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 11, _custom_cmd_last_tsn_flag = 2 [118399][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi 1027604480 [118400][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [118400][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 178, cluster_id: 0x0000, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [118402][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 11 [118402][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [118403][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [118403][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [118404][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 4 size: 2 [118404][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [118404][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [118405][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [118405][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [118406][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [118406][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84 [118407][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [118408][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 12, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [118408][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 12, _custom_cmd_last_tsn_flag = 2 [118409][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi -2046820352 [120738][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [120738][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x0019, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [120740][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11 [120741][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [120741][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [120742][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [120742][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 6 size: 2 [120742][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [120743][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [120743][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [120743][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [120747][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0 [120747][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255 APSDE INDICATION - src_addr_mode: 208, cluster_id: 0x000a, asdu_length: 5 APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xafd0 APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0 [120749][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0xa, command id: 11 [120750][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1 [120750][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0 [120751][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0 [120751][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 9 size: 2 [120751][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x0C [120752][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x84 [120752][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xafd0, 0xafd0, 0x0, 0x0 [120752][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------ [120753][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1005) callback [120754][V][ZigbeeHandlers.cpp:381] zb_cmd_default_resp_handler(): Received default response: from address(0xafd0), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84 [120754][V][ZigbeeHandlers.cpp:385] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1) [120755][I][ZigbeeGateway.cpp:1884] zbCmdDefaultResponse(): tsn = 14, _custom_cmd_last_tsn = 0, _custom_cmd_last_tsn_flag = 2 [120755][I][ZigbeeGateway.cpp:1899] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 14, _custom_cmd_last_tsn_flag = 2 [120756][I][ZigbeeGateway.cpp:1902] zbCmdDefaultResponse(): custom cmd rssi 2004877312 /code]
- Has thanked: 291 times
- Been thanked: 162 times
[email protected]
- Been thanked: 1 time
tak jedenvajera wrote: Wed Oct 01, 2025 5:28 pmOk, dzięki - całkiem sporo wyszło. Rozumiem, że Twoja wersja ma jeden kanał ściemniacza?[email protected] wrote: Wed Oct 01, 2025 5:23 pmcoś tam wyszłoCode: Select all
- Has thanked: 13 times
- Been thanked: 25 times
Unknown model _TZ3000_ww9i3e0y::TS0207, no binding is possible
Czujnik zalania https://a.aliexpress.com/_EJZX6GA
Oraz przypomina się o wczorajszym
Niespełniony automatyk.
https://pool.lector.top/
MateuszC99
Witam, odpaliłem bramkę supla zigbee i mam problem z dodaniem sterownika rolet Tuya do bramki, otrzymuję komunikat "Unknown model _TZ3210_1ptgp0az::TS130F, no binding is possible" Co mam przygotować abyście mogli dodać ten sterowniczek?
https://botland.com.pl/sterowniki-rolet ... 24356.html
Kolega Marcin podpowiedział żebym napisał tutaj.
+BWNU 0.9.51-02/10/2025Lector wrote: Thu Oct 02, 2025 7:32 am Unknown model _TZ3000_ww9i3e0y::TS0207, no binding is possible
Oraz przypomina się o wczorajszym![]()
+BWNU-0.9.51-02/10/2025 - proszę o informację zwrotną, bo być może trzeba będzie zmienić przypisanie urządzenia.[email protected] wrote: Wed Oct 01, 2025 2:07 pm Powitać,
typ Single Color
+BWNU-0.9.51-02/10/2025 - proszę o informację zwrotną, bo to nowy model.ITContent wrote: Tue Sep 30, 2025 9:53 am Proszę o dodanie urządzenia
Głowica termostatyczna Tuya GTZ02
_TZE200_ps5v5jor::TS0601
Mario78
Uprzejmie proszę kolejny raz o przysługę i dodanie kolejnego przelacznika ściennego. Tym razem to
WS-EUK02 Aqara (bez n)
Bardzo solidnie wykonany. Super miło wciska sie microswitche i ma nawet metalowa podstawę.
https://inteligentnydom.co/bezpieczenst ... -ws-euk02/Unknown model LUMI::lumi.switch.l2aeu1, no binding
Rafimajster
Proszę o dodanie sterownika rolet:
Unknown model _TZ3210_dwytrmda::TS130F
[email protected]
wygląda i działa dobrzevajera wrote: Thu Oct 02, 2025 12:08 pm+BWNU-0.9.51-02/10/2025 - proszę o informację zwrotną, bo być może trzeba będzie zmienić przypisanie urządzenia.[email protected] wrote: Wed Oct 01, 2025 2:07 pm Powitać,
typ Single Color
