Has thanked: 291 times
RomanG wrote: Fri Mar 07, 2025 12:28 pm Mistrzu Łukaszu! :)
Też mam prośbę; napęd zaworu kulowego - czy byłaby szansa na dodanie do Z2S? :)
[ 14667][I][ZigbeeGateway.cpp:342] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_cmcjbqup"
Jak najbardziej, ale potrzebuję jeszcze model name i może jeszcze jakiś link do strony produktu.
RomanG
Has thanked: 26 times
Been thanked: 7 times
vajera wrote: Fri Mar 07, 2025 12:45 pm Jak najbardziej, ale potrzebuję jeszcze model name i może jeszcze jakiś link do strony produktu.
Nie wiem, czy o to chodzi;
[ 19558][D][Z2S_Gateway.ino:655] loop(): Unknown model _TZ3000_cmcjbqup::TS0001, no binding is possible
Na opakowaniu jest napis; ZBDN25B.
Tu kupiony był ten zawór; https://pl.aliexpress.com/item/10050070 ... pt=glo2pol
RomanG wrote: Fri Mar 07, 2025 1:10 pm
+BNWU
endrju_88
Has thanked: 3 times
Been thanked: 4 times
Proszę o dodanie repeatera : TZ3000_n0lphcok - Peer Manufacturer is "TS0001"
https://pl.aliexpress.com/item/10050077 ... 751960!ppc!!!
16:15:49.117 -> ----------------------
16:15:49.117 ->      9 : GPIO
16:15:49.117 ->     12 : USB_DM
16:15:49.117 ->     13 : USB_DP
16:15:49.117 ->     16 : UART_TX[0]
16:15:49.117 ->     17 : UART_RX[0]
16:15:49.117 -> ============ After Setup End =============
16:15:49.117 -> [  2867][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x45c6) is open for 180 seconds
16:15:49.117 -> [ 39844][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
16:15:49.117 -> [ 39846][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
16:15:49.164 -> [ 39908][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x0c05)
16:15:49.164 -> [ 39908][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x8e
16:15:49.164 -> [ 39909][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0xc05), ieee_addr (0x70):(0xb3):(0xd5):(0x2b):(0x60):(0x11):(0xb1):(0x91)
16:15:49.164 -> [ 39909][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xc05), ieee_addr (0x70):(0xb3):(0xd5):(0x2b):(0x60):(0x11):(0xb1):(0x91)
16:15:49.164 -> [ 39926][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
16:15:49.164 -> [ 39926][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0xc05
16:15:49.257 -> [ 39996][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:49.257 -> [ 39997][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
16:15:49.257 -> [ 39997][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:49.398 -> [ 40128][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
16:15:49.398 -> [ 40163][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:49.398 -> [ 40164][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:49.398 -> [ 40165][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
16:15:49.398 -> [ 40165][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
16:15:49.726 -> NLME Status Indication, status: 0x9
16:15:49.726 -> [ 40489][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
16:15:49.820 -> [ 40566][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0x45c6) is open for 180 seconds
16:15:49.867 -> [ 40628][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
16:15:49.867 -> [ 40628][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
16:15:49.914 -> [ 40664][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:49.914 -> [ 40664][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:49.914 -> [ 40665][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
16:15:49.914 -> [ 40666][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_n0lphcok"
16:15:50.289 -> [ 41021][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
16:15:50.289 -> [ 41021][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
16:15:50.289 -> [ 41022][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
16:15:50.289 -> [ 41023][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
16:15:50.289 -> [ 41023][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 2
16:15:50.289 -> [ 41023][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
16:15:50.289 -> [ 41024][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
16:15:50.289 -> [ 41024][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xc05, 0xc05, 0x0, 0x0
16:15:50.289 -> [ 41024][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
16:15:50.382 -> [ 41128][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
16:15:50.382 -> [ 41129][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
16:15:50.429 -> [ 41166][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:50.429 -> [ 41166][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:50.429 -> [ 41167][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
16:15:50.429 -> [ 41168][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
16:15:50.898 -> [ 41630][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
16:15:50.898 -> [ 41631][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
16:15:50.898 -> [ 41666][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:50.898 -> [ 41667][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:50.945 -> [ 41667][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(100)
16:15:50.945 -> [ 41668][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "100"
16:15:51.367 -> [ 42132][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
16:15:51.367 -> [ 42133][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
16:15:51.414 -> [ 42171][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:51.414 -> [ 42171][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:51.414 -> [ 42172][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
16:15:51.414 -> [ 42172][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0001"
16:15:51.882 -> [ 42634][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
16:15:51.882 -> [ 42635][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
16:15:51.929 -> [ 42669][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:51.929 -> [ 42670][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:51.929 -> [ 42671][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
16:15:51.929 -> [ 42671][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "1"
16:15:52.398 -> [ 43136][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
16:15:52.398 -> [ 43137][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
16:15:52.445 -> [ 43172][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
16:15:52.445 -> [ 43172][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:52.445 -> [ 43173][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
16:15:52.445 -> [ 43174][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
16:15:52.914 -> [ 43639][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
16:15:52.961 -> [ 43690][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
16:15:52.961 -> [ 43691][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:52.961 -> [ 43691][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xb191), endpoint (1), cluster (0x0), attribute id (0xfffe), attribute data type (0x30)
16:15:52.961 -> [ 43696][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
16:15:52.961 -> [ 43696][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x0)
16:15:52.961 -> [ 43697][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
16:15:53.382 -> [ 44141][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 3077
16:15:53.429 -> [ 44179][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 3077, endpoints count 1
16:15:53.429 -> [ 44180][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
16:15:53.476 -> [ 44231][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 3077, endpoint # 1
16:15:53.476 -> [ 44232][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 1
16:15:53.476 -> [ 44232][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
16:15:53.476 -> [ 44233][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 6
16:15:53.476 -> [ 44233][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
16:15:53.476 -> [ 44234][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 4
16:15:53.476 -> [ 44234][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 5, id 5
16:15:53.476 -> [ 44234][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 6, id 57345
16:15:53.476 -> [ 44235][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 10
16:15:53.570 -> [ 44332][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:53.570 -> [ 44332][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
16:15:53.570 -> [ 44333][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:53.617 -> NLME Status Indication, status: 0x9
16:15:53.617 -> [ 44359][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:53.617 -> [ 44360][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84
16:15:53.617 -> [ 44361][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:53.664 -> [ 44394][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:53.664 -> [ 44395][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
16:15:53.664 -> [ 44396][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:53.664 -> NLME Status Indication, status: 0x9
16:15:53.664 -> [ 44423][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:53.664 -> [ 44423][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
16:15:53.664 -> [ 44424][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:53.711 -> NLME Status Indication, status: 0x9
16:15:53.711 -> [ 44447][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:53.711 -> [ 44448][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0xe001) for command (0xc) with status 0x84
16:15:53.711 -> [ 44449][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:55.539 -> [ 46275][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
16:15:55.539 -> [ 46276][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0x6)
16:15:55.539 -> [ 46276][I][ZigbeeGateway.cpp:517] zbAttributeReporting(): zbAttributeReporting on/off report ON
16:15:55.539 -> [ 46277][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xb191), endpoint (1), cluster (0x6), attribute id (0x0), attribute data type (0x10)
16:15:55.539 -> [ 46282][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
16:15:55.539 -> [ 46282][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0xe001)
16:15:55.539 -> [ 46283][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xb191), endpoint (1), cluster (0xe001), attribute id (0xd010), attribute data type (0x30)
16:15:55.539 -> [ 46290][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
16:15:55.539 -> [ 46290][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xc05) src endpoint(1) to dst endpoint(1) cluster(0xe001)
16:15:55.539 -> [ 46291][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0xb191), endpoint (1), cluster (0xe001), attribute id (0xd030), attribute data type (0x30)
16:15:56.664 -> [ 47419][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:56.664 -> [ 47419][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
16:15:56.664 -> [ 47420][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:56.710 -> [ 47443][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
16:15:56.710 -> [ 47443][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xc05), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0xc3
16:15:56.710 -> [ 47444][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
16:15:59.664 -> NLME Status Indication, status: 0x0
16:16:23.523 -> [ 74284][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
16:16:23.523 -> [ 74284][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
16:16:23.523 -> [ 74284][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
16:16:23.523 -> [ 74285][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
16:16:23.523 -> [ 74285][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 8 size: 2
16:16:23.523 -> [ 74286][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
16:16:23.523 -> [ 74286][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
16:16:23.523 -> [ 74286][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xc05, 0xc05, 0x0, 0x0
16:16:23.523 -> [ 74287][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
16:18:49.820 -> [220567][I][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Network(0x45c6) closed, devices joining not allowed.
RomanG
Ponowna prośba; ( :) ) myślałem, że urządzenie jest już w bazie, a jednak nie paruje się.
Door/Window Sensor EZ-P4/E. Poprzedni model to - TZ-P4 i ten się paruje bez problemu. Wyglądają identycznie.
Kupiony tu:https://pl.aliexpress.com/item/10050084 ... pt=glo2pol
Peer Manufacturer is "_TZ3000_7d8yme6f"
[186261][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): Peer Model is "TS0203"
Pełny log z parowania i dwukrotnego zbliżenia magnesu do czujnika:
ESP-ROM:esp32c6-20220919
=========== Before Setup Start ===========
                                          Chip Info:
                Model             : ESP32-C6
                                              Package           : 0
        Revision        : 0.01
               Cores             : 1
                                      CPU Frequency     : 160 MHz
        XTAL Frequenc        y    : 4-----------
                   Software Info:
        Com        pile Date/Time : Mar  5 2025 23:00:36
                                       Compile Host OS   : linux
        ESP-IDF Versio        n   : v5.3.2-584-g489d7a2b3a-dirty
                                    Arduino Version   : 3.1.3
                       Board Info:
        Ar        duino Board     : ESP32C6_DEV
                               Arduino Variant   : esp32c6
                                                            Arduino FQBN      :        esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CD        COnBoot=cdc
           ============ Before Setup End ============
                                                     [166756][V][esp32-hal-perim        an.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully        set to 0x42010124
[166757][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set        to type GPIO (1) with bus 0xa
[166758][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[166758][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
[166832][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
[166837][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
[166837][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoin        t: 1, Device ID: 0x0050
[166846][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Con        fig Ready (0x17), status: ESP_FAIL
[166847][I][ZigbeeCore.cpp:274] esp_zb_app_signal_handler(): Zigbee stack initia        lized
[166852][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0xf817) clo        sed, devices joining not allowed.
[166854][I][ZigbeeCore.cpp:280] esp_zb_app_signal_handler(): Device started up i        n non factory-reset mode
[166854][I][ZigbeeCore.cpp:293] esp_zb_app_signal_handler(): Device rebooted
[166855][I][ZigbeeCore.cpp:297] esp_zb_app_signal_handler(): Opening network for        joining for 180 seconds
[166855][D][ZigbeeCore.cpp:527] searchBindings(): Requesting binding table for a        ddress 0x0000
[166857][D][ZigbeeCore.cpp:467] bindingTableCb(): Binding table callback for add        ress 0x0000 with status 0
[166857][D][ZigbeeCore.cpp:470] bindingTableCb(): Binding table info: total 0, i        ndex 0, count 0
[166858][D][ZigbeeCore.cpp:473] bindingTableCb(): No binding table entries found
=========== After Setup Start ============
                                          INTERNAL Memory Info:
                           Total Size        :   394204 B ( 385.0 KB)
        Free Byte        s        :   276084 B ( 269.6 KB)
                                   Allocated Bytes   :   107680 B ( 105.2 KB)
        M        inimum Free Bytes:   271560 B ( 265.2 KB)
                                           Largest Free Block:   245748 B ( 240.        0 KB)
                                               GPIO Info:
                     GPIO : BUS_TYPE[bus/unit][chan]
                   9 : GPIO
                               12 : USB_DM
                                              13 : USB_DP
                                                             16 : UART_TX[0]
        17 : UART_RX[0]
                                                         [167323][I][ZigbeeCore.        cpp:384] esp_zb_app_signal_handler(): Network(0xf817) is open for 180 seconds
[180603][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
[184226][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[184229][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[184747][I][ZigbeeCore.cpp:353] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9f6f)
[184747][V][ZigbeeCore.cpp:357] esp_zb_app_signal_handler(): Device capabilities: 0x80
[184748][D][ZigbeeGateway.cpp:471] zbDeviceAnnce(): zbDeviceAnnce short address (0x9f6f), ieee_addr (0xa4):(0xc1):(0x38):(0x3a):(0xd2):(0xbd):(0xc2):(0x2a)
[184749][D][ZigbeeGateway.cpp:474] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x9f6f), ieee_addr (0xa4):(0xc1):(0x38):(0x3a):(0xd2):(0xbd):(0xc2):(0x2a)
[184749][I][ZigbeeGateway.cpp:508] zbDeviceAnnce(): Tuya magic last hope
[185036][I][ZigbeeGateway.cpp:543] printJoinedDevices(): joined devices:
[185036][I][ZigbeeGateway.cpp:546] printJoinedDevices(): Device on endpoint 1, short address: 0x9f6f
[185261][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x0, command id: 11
[185262][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[185262][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[185263][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[185263][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 15 size: 2
[185263][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x30
[185264][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x82
[185264][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x9f6f, 0x9f6f, 0x0, 0x0
[185264][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[185268][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[185269][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x9f6f), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[185270][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[185270][I][ZigbeeGateway.cpp:1261] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x2]
[185437][I][ZigbeeGateway.cpp:309] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[185760][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[185761][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x0)
[185762][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[185762][I][ZigbeeGateway.cpp:342] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_7d8yme6f"
[185937][I][ZigbeeGateway.cpp:315] zbQueryDeviceBasicCluster(): basic tsn 0x2
[185937][I][ZigbeeGateway.cpp:309] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[186259][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[186259][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x0)
[186260][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[186438][I][ZigbeeGateway.cpp:315] zbQueryDeviceBasicCluster(): basic tsn 0x3
[186438][I][ZigbeeGateway.cpp:956] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[186757][V][ZigbeeCore.cpp:400] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[186761][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[186761][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x0)
[186762][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[186939][I][ZigbeeGateway.cpp:271] zbPrintDeviceDiscovery(): short_addr_req 40815
[187426][I][ZigbeeCore.cpp:384] esp_zb_app_signal_handler(): Network(0xf817) is open for 180 seconds
[187434][I][ZigbeeGateway.cpp:205] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 40815, endpoints count 1
[187435][I][ZigbeeGateway.cpp:208] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[187954][I][ZigbeeGateway.cpp:224] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 40815, endpoint # 1
[187954][I][ZigbeeGateway.cpp:225] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 0
[187955][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[187955][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[187956][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 3, id 1280
[187956][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 4, id 1
[188454][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[188455][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[188456][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[188457][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[188457][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[188458][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[188459][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[188460][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[188461][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[188461][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0x4000), data type (0x42)
[188462][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[188477][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[188477][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[188478][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[188493][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[188494][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x0), data type (0x30)
[188495][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x1), data type (0x31)
[188496][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x2), data type (0x19)
[188496][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x10), data type (0xf0)
[188497][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x11), data type (0x20)
[188498][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0xf001), data type (0x20)
[188499][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0x13), data type (0x20)
[188500][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x500), attribute id (0xfffd), data type (0x21)
[188503][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[188504][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[188505][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[188506][I][ZigbeeGateway.cpp:718] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x9f6f), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[195651][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[195652][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[195652][I][ZigbeeGateway.cpp:668] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[195653][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[195654][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[195654][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[195655][I][ZigbeeGateway.cpp:671] zbAttributeReporting(): zbAttributeReporting power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[195655][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[195902][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[195902][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[196661][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[196661][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[196662][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[196662][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[196662][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 9 size: 2
[196663][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[196663][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[196663][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x9f6f, 0x9f6f, 0x0, 0x0
[196664][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[200677][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[200677][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[205695][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[205696][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[205697][I][ZigbeeGateway.cpp:668] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[205697][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[205698][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[205698][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[205699][I][ZigbeeGateway.cpp:671] zbAttributeReporting(): zbAttributeReporting power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[205700][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[206040][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[206040][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[210473][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[210474][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[213428][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[213429][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
[214747][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1031) callback
[214748][V][ZigbeeHandlers.cpp:294] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
[215724][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[215724][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[215725][I][ZigbeeGateway.cpp:668] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[215725][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[215726][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[215727][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x9f6f) src endpoint(1) to dst endpoint(1) cluster(0x1)
[215727][I][ZigbeeGateway.cpp:671] zbAttributeReporting(): zbAttributeReporting power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[215728][I][ZigbeeGateway.cpp:680] zbAttributeReporting(): zbAttributeReporting from (0xc22a), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
Z góry dziękuję! ;)
RomanG wrote: Fri Mar 07, 2025 5:01 pm Ponowna prośba; ( :) ) myślałem, że urządzenie jest już w bazie, a jednak nie paruje się.
                                          Chip Info:
                Model             : ESP32-C6
                                              Package           : 0
        Revision        : 0.01
               Cores             : 1
                   Software Info:
                       Board Info:
                                               GPIO Info:
                   9 : GPIO
                               12 : USB_DM
                                              13 : USB_DP
                                                             16 : UART_TX[0]
        17 : UART_RX[0]
Z góry dziękuję! ;)
+BWNU
rysieks wrote: Fri Mar 07, 2025 11:36 am Czy można prosić o dodanie urządzenia Tuya Zigbee 4 kanałowego z przyciskami fizycznymi
+BWNU
proszę o feedback
rysieks
rysieks pisze: pt mar 07, 2025 12:36 pm
+BWNU
proszę o feedback
Ok. Dzięki za dodanie :D
- urządzenie się zarejestrowało poprawnie,
powtórna parowanie przebiega też prawidłowo.
-- wątpliwość budzi zrejestrowanie pierwszego kanału oraz licznika pomiarowego do niego, raczej to maleństwo nie ma układu pomiarowego
ale głowy za to nie daję - za chwilę to przetestuję.
- poprawnie reaguje na sterowanie 4 kanałów ze strony APki.
- sterowanie ze strony przycisków fizycznych;
--- zachowuje się tak jak podłączenie do przełączników bistabilnych. (zwarcie kanału stan ON, rozwarcie stan Off),
stany prawidłowo przekazywane do Apki.
--- jeżeli przełączymy w Apce kanał na On, a fizycznie przełącznik był rozwarty, jak zwieramy nie przełączamy stanu,
jak rozwieramy kanał idzie na Off. (analogicznie przy przełączniku fizycznym zwartym i Off)
--- naciśnięcie przycisku parowania powoduje przełączenie wszystkich kanałów na Off, powtórne na On itd.
- poprawnie reaguje na wyłączenie zasilania (kanały wracają do stanu sprzed wyłączenia).
- reakcja na wyłączenie urządzenia (syganlizacja OnLine/OffLine) - cały czas OnLine pomimo wyłączenia.
rysieks wrote: Fri Mar 07, 2025 9:53 pm Ok. Dzięki za dodanie :D
Zrobiłem to celowo bo Twoje logi że skanera wykazały obecność klastra Electrical Measurement (V/A/W) i Simple Metering (kWh), ale oczywiście musisz zweryfikować czy pojawią się jakieś dane - najwyżej się to wyrzuci.
Lepsze byłyby monostabilne?
Tego akapitu nie rozumiem?
Przyjrzę się temu.
rysieks
Dotychczasowe testy mówią że tam jednak są same 0, a szkoda... jakby były to nikt by się nie obraził ;)
Nawet wskazane :roll:
Czyli przycisk bistabilny synchronizuje się ze stanem rzeczywistym spowodowanym przez Apkę.
( czyli w przypadku zmiany stanu na przeciwny w Apce - jeżeli bistabilny przechodzi w ten stan - to ta zmiana nie wywołuje przełączenia kanału - ten klik-przełączenie bistabilnym jest synchronizujące jaby martwe, dopiero następny klik-przełaczenie jest aktywne)
p.s. Test 0.5.9
prawidłowa reakcja na wyłączenie urządzenia (po ok 40 sekundach wystawia status OffLine)
przy ponownym podłaczeniu prawie natychmiast wystawia status OnLine.
przy czym trochę się gubi i z czasem zmienia status kanałów 2,3,4 na status OffLine.
następnie status kanału 1 idzie na OffLine.
i tak zostaje ...
jak przyciskiem fizycznym zmienimy stan to status idzie na OnLine danego kanału
potem wszystkich OnLine i po jakichś 80 sekundach idzie wszystko na OffLine. i tak zostaje, chyba że zasteruje się przyciskiem fizycznym.
p.s.2 Test 0.5.8
i nic nie kombinuje ze zmianami po czasie jak w v0.5.9
