Masz zmienne IP czy stałe?
Dla tej domeny i adresu IP na który wportysjazuje porty 80 i 443 są zamknięte.
Jeśli kontenery nginx i Supli są uruchomione a na routerze masz przekierowanie to powinny być otwarte.
SOP 2023
SOP 2024
cz->b
+ila
SOP 2024
effendi
Tak jak pisałem wyżej ubiłem sieć, i kontenery przestały startować
./start.sh
Error response from daemon: network with name webproxy already exists
Pulling nginx-web ... done
Pulling nginx-gen ... done
Pulling nginx-letsencrypt ... done
Starting nginx-letsencrypt ... error
Starting nginx-gen ...
Creating nginx-web ...
Starting nginx-gen ... error
ERROR: for nginx-letsencrypt Cannot start service nginx-letsencrypt: network db0d83d81a0a498c22f65ba6f5968d8c47d1d60bfcea2d9da5acc32f416cebec not found
Creating nginx-web ... done
ERROR: for nginx-gen Cannot start service nginx-gen: network db0d83d81a0a498c22f65ba6f5968d8c47d1d60bfcea2d9da5acc32f416cebec not found
ERROR: Encountered errors while bringing up the project.
Pogodynka >>
effendi
Zatrzymałem, usunąłem nginx-web, czy nginx-data również? coś jeszcze?
Pogodynka >>
Najpierw stop, możesz tak, potem usuwasz
docker stop nginx-gen nginx-web nginx-letsencrypt
docker rm nginx-gen nginx-web nginx-letsencrypt
./start.shSOP 2023
SOP 2024
cz->b
+ila
SOP 2024
effendi
nginx-gen
nginx-web
nginx-letsencrypt
pi@SUPLA:~/docker-compose-letsencrypt-nginx-proxy-companion $ docker rm nginx-gen nginx-web nginx-letsencrypt
nginx-gen
nginx-web
nginx-letsencrypt
pi@SUPLA:~/docker-compose-letsencrypt-nginx-proxy-companion $ ./start.sh
Creating nginx-gen ... done
Creating nginx-letsencrypt ... done
pi@SUPLA:~/docker-compose-letsencrypt-nginx-proxy-companion $ cd
pi@SUPLA:~ $ cd supla-docker
pi@SUPLA:~/supla-docker $ ./supla.sh start
Starting SUPLA containers
Starting supla-db ... done
Starting supla-cloud ... error
ERROR: for supla-cloud Cannot start service supla-cloud: network db0d83d81a0a498c22f65ba6f5968d8c47d1d60bfcea2d9da5acc32f416cebec not found
Pogodynka >>
Ok, to teraz usuń kontener z Cloud i wystartuj skrypt
docker stop supla-cloud
docker rm supla-cloud
./supla.sh startSOP 2023
SOP 2024
cz->b
+ila
SOP 2024
klimasstudio
- Been thanked: 1 time
i tutaj mam kolejne błedy... Pewnie wynika to z tego że używam nowszej wersji Raspbiana. Nie myślał nikt aby przygotować gotowy .img z opisem co gdzie w configach poustawiać ? Dodatkowo krótki opis co gdzie jak włączać spr. logi itp ? Dodam że ja używam nowszego raspbiana bo odpalam go z SSH nie mam aktualnie żadnej karty wolnej. Jak wgram starego to malina nie rusza.lesny8 wrote: Sun Nov 14, 2021 7:58 pmklimasstudio wrote: Sun Nov 14, 2021 7:03 pmpi@raspberrypi:~ $ sudo apt install pip3
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package pip3Code: Select all
sudo apt install python3-setuptools sudo pip3 install docker-compose
Z mojej obserwacji wynika że inny Raspbian i już albo czegoś nie ma albo inaczej trzeba kombinować bo już są inne nowsze pakiety i nie współgrają ze sobą.
Więc chodź OSUPLUJE Ci dom
effendi
Extra, dockery ruszyły:
Strona na czerwono
PS.: po usunięci cache - 502
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
a6b5dd48ba13 supla/supla-server:arm32v7 "/usr/bin/server-ent…" About a minute ago Up About a minute 0.0.0.0:2015-2016->2015-2016/tcp supla-server
cac88a39bd8a supla/supla-cloud:arm32v7 "docker-php-entrypoi…" About a minute ago Up About a minute 80/tcp supla-cloud
336f47c19746 lesny8/rpi-docker-gen "/usr/local/bin/dock…" 41 minutes ago Up 41 minutes nginx-gen
c72fa816c8e8 lesny8/rpi-docker-letsencrypt-nginx-proxy-companion "/bin/bash /app/entr…" 41 minutes ago Up 41 minutes nginx-letsencrypt
72f2ad49c8d5 nginx "/docker-entrypoint.…" 41 minutes ago Up 41 minutes 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp nginx-web
8f21f89e3bad hypriot/rpi-mysql:5.5
Pogodynka >>
