Been thanked: 10 times
Pokaż plik
cat ~/docker-compose-letsencrypt-nginx-proxy-companion/docker-compose.yml
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
groszek33
version: '3'
services:
<<<<<<< HEAD
  nginx-proxy-automation-web:
    image: nginx:${NGINX_IMAGE_VERSION:-stable-alpine}
  nginx-web:
    image: nginx:1.21.3
>>>>>>> refs/remotes/origin/master
    labels:
      com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy: "true"
    container_name: ${NGINX_WEB_SEVICE_NAME:-nginx-proxy-automation-web}
    restart: always
    ports:
      - "${IPv4:-0.0.0.0}:${DOCKER_HTTP_:-80}:80"
      - "${IPv4:-0.0.0.0}:${DOCKER_HTTPS:-443}:443"
#      - "${IPv6:-::0}:${DOCKER_HTTP_:-80}:80"
#      - "${IPv6:-::0}:${DOCKER_HTTPS:-443}:443"
    environment:
      SSL_POLICY: ${SSL_POLICY:-Mozilla-Intermediate}
#      DEFAULT_HOST: ${DEFAULT_HOST}
#      ENABLE_IPV6: "true"
    volumes:
      - ${NGINX_FILES_PATH:-./data}/conf.d:/etc/nginx/conf.d
      - ${NGINX_FILES_PATH:-./data}/vhost.d:/etc/nginx/vhost.d
      - ${NGINX_FILES_PATH:-./data}/html:/usr/share/nginx/html
      - ${NGINX_FILES_PATH:-./data}/certs:/etc/nginx/certs:ro
      - ${NGINX_FILES_PATH:-./data}/htpasswd:/etc/nginx/htpasswd:ro
    logging:
      driver: ${NGINX_WEB_LOG_DRIVER:-json-file}
      options:
        max-size: ${NGINX_WEB_LOG_MAX_SIZE:-4m}
        max-file: ${NGINX_WEB_LOG_MAX_FILE:-10}
<<<<<<< HEAD
  nginx-proxy-automation-gen:
    image: nginxproxy/docker-gen:${DOCKER_GEN_IMAGE_VERSION:-0.7.7}
    command: -notify-sighup ${NGINX_WEB_SEVICE_NAME:-nginx-proxy-automation-web}        -watch -wait 5s:30s /etc/docker-gen/templates/nginx.tmpl /etc/nginx/conf.d/defa        ult.conf
    container_name: ${DOCKER_GEN_SEVICE_NAME:-nginx-proxy-automation-gen}
  nginx-gen:
    image: lesny8/rpi-docker-gen
    command: -notify-sighup ${NGINX_WEB:-nginx-web} -watch -wait 5s:30s /etc/doc        ker-gen/templates/nginx.tmpl /etc/nginx/conf.d/default.conf
    container_name: ${DOCKER_GEN:-nginx-gen}
    restart: always
    volumes:
      - /var/run/docker.sock:/tmp/docker.sock:ro
      - ./nginx.tmpl:/etc/docker-gen/templates/nginx.tmpl:ro
    logging:
      driver: ${NGINX_GEN_LOG_DRIVER:-json-file}
      options:
        max-size: ${NGINX_GEN_LOG_MAX_SIZE:-2m}
        max-file: ${NGINX_GEN_LOG_MAX_FILE:-10}
<<<<<<< HEAD
  nginx-proxy-automation-letsencrypt:
    image: nginxproxy/acme-companion:${NGINX_PROXY_COMPANION_IMAGE_VERSION:-2.1}
    container_name: ${LETS_ENCRYPT_SEVICE_NAME:-nginx-proxy-automation-letsencry        pt}
  nginx-letsencrypt:
    image: lesny8/rpi-docker-letsencrypt-nginx-proxy-companion
    container_name: ${LETS_ENCRYPT:-nginx-letsencrypt}
    restart: always
    volumes:
      - ${NGINX_FILES_PATH:-./data}/certs:/etc/nginx/certs:rw
      - ${NGINX_FILES_PATH:-./data}/acme.sh:/etc/acme.sh
      - /var/run/docker.sock:/var/run/docker.sock:ro
    environment:
      NGINX_DOCKER_GEN_CONTAINER: ${DOCKER_GEN_SEVICE_NAME:-nginx-proxy-automati        on-gen}
      NGINX_PROXY_CONTAINER: ${NGINX_WEB_SEVICE_NAME:-nginx-proxy-automation-web        }
      DEFAULT_EMAIL: ${DEFAULT_EMAIL:[email protected]}
    logging:
      driver: ${NGINX_LETSENCRYPT_LOG_DRIVER:-json-file}
      options:
        max-size: ${NGINX_LETSENCRYPT_LOG_MAX_SIZE:-2m}
        max-file: ${NGINX_LETSENCRYPT_LOG_MAX_FILE:-10}
networks:
  default:
    external: true
Kto pyta nie błądzi:))
git status
🧩: 🔑cz->b ⛴️+ila
groszek33
pi@raspberrypi:~ $ git status
fatal: Not a git repository (or any of the parent directories): .git
pi@raspberrypi:~ $
Ale wejdź najpierw do katalogu
cd ~/docker-compose-letsencrypt-nginx-proxy-companion/
git status
Zrobiłeś merge i jest konflikt, chce zobaczyć czy tylko ten plik...
🧩: 🔑cz->b ⛴️+ila
groszek33
Oj sorki
On branch master
Your branch and 'origin/master' have diverged,
and have 139 and 3 different commits each, respectively.
(use "git pull" to merge the remote branch into yours)
You have unmerged paths.
(fix conflicts and run "git commit")
(use "git merge --abort" to abort the merge)
Unmerged paths:
(use "git add/rm <file>..." as appropriate to mark resolution)
deleted by us: docker-compose-multiple-networks.yml
both modified: docker-compose.yml
deleted by us: start.sh
Untracked files:
(use "git add <file>..." to include in what will be committed)
nginx-data/
no changes added to commit (use "git add" and/or "git commit -a")
Ok.
Trzeba rozwiązać konflikt w pliku, ale najszybciej będzie jak edytujesz sobie docker-compose.yml i wstawisz tam zawartość stąd .
Potem zrób
git commit
🧩: 🔑cz->b ⛴️+ila
groszek33
U docker-compose-multiple-networks.yml
U docker-compose.yml
U start.sh
error: Committing is not possible because you have unmerged files.
hint: Fix them up in the work tree, and then use 'git add/rm <file>'
hint: as appropriate to mark resolution and make a commit.
fatal: Exiting because of an unresolved conflict.
Przepraszam za ..
Ale...jak widać
Dzięki
Musisz rozwiązać konflikt po połączeniu. Normalnie robi się to uruchamiając
git mergetool
ale nie wiem co tam za narzędzie Ci się uruchomi na malinie.
Bynajmniej usuwasz to co ma wylecieć, zostawiasz to co ma zostać. Pliki mają wyglądać tak jak u mnie na githubie.
Jak masz to zrobione to dodajesz wprowadzone zmiany (nie napisałem tego wcześniej) i zatwierdzasz
git add .
git commit
Jak będziesz miał problem z tym to możesz też cały katalog usunąć lub zmienić mu nazwę i pobrać repo ode mnie z githuba, potem wystartować skrypt.
cd ~
git clone https://github.com/lesny8/docker-compose-letsencrypt-nginx-proxy-companion.git
cd docker-compose-letsencrypt-nginx-proxy-companion
./start.sh
🧩: 🔑cz->b ⛴️+ila
groszek33
lesny8 jesteś wielki.
Dziękuję za wytrzymałość.
Wszystko ruszyło
Zmieniłem nazwę wgrałem i uzupełniłem plik.
Wszystko ruszyło.
Szacun dla Twojej wiedzy
Bardzo dziękuję
