Dodał się. Dzięki.
prze_cinek
- Been thanked: 2 times
Chciałbym poprosić o dodanie czujnika temperatury i wilgotności
Sonoff SNZB-02P (w bazie jest już wersja B)
Poniżej logi ze skanera
[16:02:27][ 2281][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x9cef) is open for 180 seconds
[16:02:42][ 16480][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[16:02:42][ 16483][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[16:02:44][ 18499][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[16:02:44][ 18501][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[16:02:44][ 18526][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd15a)
[16:02:44][ 18527][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[16:02:44][ 18527][D][ZigbeeGateway.cpp:475] zbDeviceAnnce(): zbDeviceAnnce short address (0xd15a), ieee_addr (0xd4):(0x48):(0x67):(0xff):(0xfe):(0x4c):(0x4a):(0x96)
[16:02:44][ 18528][D][ZigbeeGateway.cpp:478] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd15a), ieee_addr (0xd4):(0x48):(0x67):(0xff):(0xfe):(0x4c):(0x4a):(0x96)
[16:02:44][ 18529][I][ZigbeeGateway.cpp:502] zbDeviceAnnce(): Tuya magic last hope
[16:02:44][ 18790][I][ZigbeeGateway.cpp:545] printJoinedDevices(): joined devices:
[16:02:44][ 18790][I][ZigbeeGateway.cpp:548] printJoinedDevices(): Device on endpoint 1, short address: 0xd15a
[16:02:44][ 18795][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[16:02:44][ 18796][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[16:02:44][ 18796][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[16:02:44][ 18797][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[16:02:44][ 18797][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 2 size: 21
[16:02:44][ 18797][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18798][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18798][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18798][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x04
[16:02:44][ 18799][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18799][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18800][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18800][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[16:02:44][ 18800][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18801][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18801][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x05
[16:02:44][ 18801][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18802][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18802][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[16:02:44][ 18802][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[16:02:44][ 18803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x86
[16:02:44][ 18803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFE
[16:02:44][ 18803][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[16:02:44][ 18804][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xd15a, 0xd15a, 0x0, 0x0
[16:02:44][ 18804][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[16:02:44][ 19042][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[16:02:44][ 19042][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xd15a), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
[16:02:44][ 19043][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[16:02:44][ 19044][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x2]
[16:02:44][ 19044][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -73
[16:02:44][ 19192][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[16:02:44][ 19296][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[16:02:44][ 19296][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xd15a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[16:02:44][ 19297][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[16:02:44][ 19298][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "eWeLink"
[16:02:45][ 19692][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x2
[16:02:45][ 19692][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[16:02:45][ 19789][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[16:02:45][ 19790][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xd15a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[16:02:45][ 19790][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(8)
[16:02:45][ 19791][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "SNZB-02P"
[16:02:45][ 20193][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x3
[16:02:45][ 20193][I][ZigbeeGateway.cpp:1065] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[16:02:45][ 20291][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[16:02:45][ 20291][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xd15a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[16:02:45][ 20292][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[16:02:46][ 20694][I][ZigbeeGateway.cpp:275] zbPrintDeviceDiscovery(): short_addr_req 53594
[16:02:46][ 20791][I][ZigbeeGateway.cpp:209] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 53594, endpoints count 1
[16:02:46][ 20791][I][ZigbeeGateway.cpp:212] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[16:02:46][ 21056][I][ZigbeeGateway.cpp:228] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 53594, endpoint # 1
[16:02:46][ 21057][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 8, out clusters # 1
[16:02:46][ 21058][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[16:02:46][ 21058][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[16:02:46][ 21058][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[16:02:46][ 21059][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 4, id 32
[16:02:46][ 21059][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 5, id 1026
[16:02:46][ 21060][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 6, id 1029
[16:02:46][ 21060][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 7, id 64599
[16:02:46][ 21061][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 8, id 64529
[16:02:46][ 21061][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[16:02:47][ 21376][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21388][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21406][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21421][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21432][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21443][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21454][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21465][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[16:02:47][ 21808][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK-
- Has thanked: 291 times
- Been thanked: 161 times
+BWNU (0.7.4 - właśnie się buduje)prze_cinek wrote: Sun Mar 23, 2025 3:14 pm Chciałbym poprosić o dodanie czujnika temperatury i wilgotności
Swoją drogą bardzo interesujący czujnik - chyba pierwszy, który ma klaster 0x20 (poll control) - z opisów w sieci wynika, że to może być czujnik w pełni zgodny ze standardem Zigbee czyli dający się odpytać pomimo uśpienia. Zamówiłem 2 do testów
A czy wersja Sonoff SNZB-02D - ta z wyświetlaczem ma takie same parametry, bo zastanawiam się który zamówićvajera wrote: Sun Mar 23, 2025 6:06 pm+BWNU (0.7.4 - właśnie się buduje)prze_cinek wrote: Sun Mar 23, 2025 3:14 pm Chciałbym poprosić o dodanie czujnika temperatury i wilgotności
Swoją drogą bardzo interesujący czujnik - chyba pierwszy, który ma klaster 0x20 (poll control) - z opisów w sieci wynika, że to może być czujnik w pełni zgodny ze standardem Zigbee czyli dający się odpytać pomimo uśpienia. Zamówiłem 2 do testów![]()
Według danych z sieci ma te same parametry + wyświetlacz.bokk wrote: Sun Mar 23, 2025 7:39 pmA czy wersja Sonoff SNZB-02D - ta z wyświetlaczem ma takie same parametry, bo zastanawiam się który zamówićvajera wrote: Sun Mar 23, 2025 6:06 pm+BWNU (0.7.4 - właśnie się buduje)prze_cinek wrote: Sun Mar 23, 2025 3:14 pm Chciałbym poprosić o dodanie czujnika temperatury i wilgotności
prze_cinek
Niestety ale czujnik się nie dodaje - wydaje mi się, że manufacturer mu nie pasuje - poniżej log z bramkivajera wrote: Sun Mar 23, 2025 6:06 pm+BWNU (0.7.4 - właśnie się buduje)prze_cinek wrote: Sun Mar 23, 2025 3:14 pm Chciałbym poprosić o dodanie czujnika temperatury i wilgotności
[221570][D][Z2S_Gateway.ino:1054] loop(): Unknown model eWeLink::SNZB-02P, no binding is possible
[223493][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
Fakt, nie zauważyłem, że tam jest inny manuf_id - w 0.7.5 powinno być OK.prze_cinek wrote: Mon Mar 24, 2025 5:48 pm
sebu1
Hej, mam dwa czujniki, jeśli można było by dodać:
1. ONENUO Temp&Humid
i czujnik nr 2,
- LeftSitu Temp&Humid
===== Before Setup End ======
[ 4358][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201051a
[ 4359][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
[ 4360][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[ 4360][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
[ 4440][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
[ 4445][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
[ 4446][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[ 4456][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[ 4457][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
[ 4462][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x30fa) closed, devices joining not allowed.
[ 4464][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[ 4464][I][ZigbeeCore.cpp:294] esp_zb_app_signal_handler(): Device rebooted
[ 4465][I][ZigbeeCore.cpp:298] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[ 4465][D][ZigbeeCore.cpp:539] searchBindings(): Requesting binding table for address 0x0000
[ 4467][D][ZigbeeCore.cpp:479] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[ 4467][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table info: total 0, index 0, count 0
[ 4468][D][ZigbeeCore.cpp:485] bindingTableCb(): No binding table entries found
====== After Setup Start =======
======= After Setup End =======
[ 4933][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x30fa) is open for 180 seconds
[ 9633][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 9636][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
NLME Status Indication, status: 0x9
[ 22403][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 22405][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 26785][I][ZigbeeCore.cpp:403] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xe1e2), rejoin (NO)
[ 30759][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 30761][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 31280][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x5f9a)
[ 31281][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 31281][D][ZigbeeGateway.cpp:475] zbDeviceAnnce(): zbDeviceAnnce short address (0x5f9a), ieee_addr (0xa4):(0xc1):(0x38):(0x45):(0x63):(0xa0):(0x95):(0x1f)
[ 31282][D][ZigbeeGateway.cpp:478] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x5f9a), ieee_addr (0xa4):(0xc1):(0x38):(0x45):(0x63):(0xa0):(0x95):(0x1f)
[ 31283][I][ZigbeeGateway.cpp:502] zbDeviceAnnce(): Tuya magic last hope
[ 31565][I][ZigbeeGateway.cpp:545] printJoinedDevices(): joined devices:
[ 31565][I][ZigbeeGateway.cpp:548] printJoinedDevices(): Device on endpoint 1, short address: 0x5f9a
[ 31609][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 31609][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 31610][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 31611][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_fllyghyj"
[ 31611][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 31612][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): ZCL version id is "3"
[ 31612][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(70)
[ 31613][I][ZigbeeGateway.cpp:365] zbReadBasicCluster(): ZCL application version id is "70"
[ 31613][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 31614][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "TS0201"
[ 31614][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 31615][I][ZigbeeGateway.cpp:371] zbReadBasicCluster(): ZCL power source id is "3"
[ 31616][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[ 31616][I][ZigbeeGateway.cpp:375] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[ 31620][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 31620][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[ 31621][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 31621][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x0]
[ 31622][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -64
[ 31966][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 32278][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 32278][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 32279][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 32280][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_fllyghyj"
[ 32466][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 32466][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 32492][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 32493][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 32494][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 32494][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "TS0201"
[ 32967][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 32967][I][ZigbeeGateway.cpp:1065] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 33323][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 33326][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 33327][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 33327][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[ 33407][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x30fa) is open for 180 seconds
[ 33468][I][ZigbeeGateway.cpp:275] zbPrintDeviceDiscovery(): short_addr_req 24474
[ 33518][I][ZigbeeGateway.cpp:209] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 24474, endpoints count 1
[ 33519][I][ZigbeeGateway.cpp:212] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 33638][I][ZigbeeGateway.cpp:228] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 24474, endpoint # 1
[ 33639][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 5, out clusters # 3
[ 33640][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 1, id 1
[ 33640][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 33641][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 3, id 1026
[ 33641][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 4, id 1029
[ 33641][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 5, id 0
[ 33642][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[ 33642][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 33643][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 33764][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33764][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x1) for command (0xc) with status 0x84
[ 33765][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33765][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x5[0x0]
[ 33766][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -65
[ 33779][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33780][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 33781][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33781][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x6[0x0]
[ 33782][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -64
[ 33795][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33796][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x402) for command (0xc) with status 0x84
[ 33797][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33797][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x7[0x0]
[ 33798][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -63
[ 33811][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33812][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x405) for command (0xc) with status 0x84
[ 33813][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33813][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x8[0x0]
[ 33814][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -62
[ 33827][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33828][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 33829][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33829][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x9[0x0]
[ 33830][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -61
[ 33843][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33844][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 33845][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33845][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0xa[0x0]
[ 33846][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -60
[ 33859][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 33860][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 33860][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 33861][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 33861][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 17 size: 2
[ 33862][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 33862][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 33862][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x5f9a, 0x5f9a, 0x0, 0x0
[ 33863][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): -----------raw command not processed--------------------------
[ 33866][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 33867][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x5f9a), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 33868][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 33868][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0xc[0x0]
[ 33869][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -56
[ 38431][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38432][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38433][I][ZigbeeGateway.cpp:709] zbAttributeReporting(): zbAttributeReporting from (0x951f), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
[ 38433][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38434][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38434][I][ZigbeeGateway.cpp:709] zbAttributeReporting(): zbAttributeReporting from (0x951f), endpoint (1), cluster (0x0), attribute id (0xffe2), attribute data type (0x20)
[ 38435][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38436][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38436][I][ZigbeeGateway.cpp:709] zbAttributeReporting(): zbAttributeReporting from (0x951f), endpoint (1), cluster (0x0), attribute id (0xffe4), attribute data type (0x20)
[ 38559][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38559][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 38560][I][ZigbeeGateway.cpp:697] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[ 38560][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38561][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 38562][I][ZigbeeGateway.cpp:700] zbAttributeReporting(): zbAttributeReporting power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 38683][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38683][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x402)
[ 38684][I][ZigbeeGateway.cpp:586] zbAttributeReporting(): zbAttributeReporting temperature measurement 27.100000
[ 38806][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38807][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x405)
[ 38808][I][ZigbeeGateway.cpp:595] zbAttributeReporting(): zbAttributeReporting humidity measurement 40.720001
[ 38932][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 38932][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 38933][I][ZigbeeGateway.cpp:709] zbAttributeReporting(): zbAttributeReporting from (0x951f), endpoint (1), cluster (0x0), attribute id (0xffdf), attribute data type (0x42)
[ 39063][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 39063][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 39063][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 39064][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 39064][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 2 size: 2
[ 39065][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[ 39065][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[ 39065][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x5f9a, 0x5f9a, 0x0, 0x0
[ 39066][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): -----------raw command not processed-------
[ 39457][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 39460][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 43469][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 43470][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x402)
[ 43471][I][ZigbeeGateway.cpp:586] zbAttributeReporting(): zbAttributeReporting temperature measurement 27.209999
[ 43594][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 43594][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x405)
[ 43595][I][ZigbeeGateway.cpp:595] zbAttributeReporting(): zbAttributeReporting humidity measurement 40.860001
[ 48474][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 48474][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x5f9a) src endpoint(1) to dst endpoint(1) cluster(0x402)- LeftSitu Temp&Humid
============ Before Setup End ============
[ 282][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4201051a
[ 283][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
[ 284][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[ 284][D][ZigbeeCore.cpp:166] zigbeeInit(): Initialize Zigbee stack
[ 367][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
[ 372][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
[ 372][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[ 388][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[ 389][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
[ 394][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x30fa) closed, devices joining not allowed.
[ 396][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[ 396][I][ZigbeeCore.cpp:294] esp_zb_app_signal_handler(): Device rebooted
[ 396][I][ZigbeeCore.cpp:298] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[ 397][D][ZigbeeCore.cpp:539] searchBindings(): Requesting binding table for address 0x0000
[ 398][D][ZigbeeCore.cpp:479] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[ 399][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table info: total 0, index 0, count 0
[ 399][D][ZigbeeCore.cpp:485] bindingTableCb(): No binding table entries found
=========== After Setup Start ============
INTERNAL Memory Info:
Total Size : 393308 B ( 384.1 KB)
Free Bytes : 275180 B ( 268.7 KB)
Allocated Bytes : 107688 B ( 105.2 KB)
Minimum Free Bytes: 270656 B ( 264.3 KB)
Largest Free Block: 241652 B ( 236.0 KB)
GPIO Info:
GPIO : BUS_TYPE[bus/unit][chan]
9 : GPIO
12 : USB_DM
13 : USB_DP
16 : UART_TX[0]
17 : UART_RX[0]
============ After Setup End =============
[ 865][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x30fa) is open for 180 seconds
ESP-ROM:esp32c6-20220919
Build:Sep 19 2022
rst:0x15 (USB_UART_HPSYS),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x42084a48
SPIWP:0xee
mode:DIO, clock div:2
load:0x40875720,len:0x1228
load:0x4086c110,len:0xd9c
load:0x4086e610,len:0x2f74
entry 0x4086c110
[ 1][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012d24
[ 12][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012ce8
[ 23][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x42012cac
[ 35][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012c70
[ 46][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RX (2) successfully set to 0x42012d24
[ 57][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_TX (3) successfully set to 0x42012ce8
[ 69][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_CTS (4) successfully set to 0x42012cac
[ 80][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type UART_RTS (5) successfully set to 0x42012c70
[ 91][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DM (38) successfully set to 0x4200e856
[ 103][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type USB_DP (39) successfully set to 0x4200e856
[ 114][V][ZigbeeEP.cpp:21] ZigbeeEP(): Endpoint: 1
[ 128][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type UART_RX (2) with bus 0x4081444c
[ 139][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type UART_TX (3) with bus 0x4081444c
[ 149][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 12 successfully set to type USB_DM (38) with bus 0x40818eec
[ 160][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 13 successfully set to type USB_DP (39) with bus 0x40818eec
=========== Before Setup Start ===========
Chip Info:
Model : ESP32-C6
Package : 0
Revision : 0.01
Cores : 1
CPU Frequency : 160 MHz
XTAL Frequency : 40 MHz
Features Bitfield : 0x00000052
Embedded Flash : No
Embedded PSRAM : No
2.4GHz WiFi : Yes
Classic BT : No
BT Low Energy : Yes
IEEE 802.15.4 : Yes
Free Bytes : 344452 B ( 336.4 KB)
Allocated Bytes : 37216 B ( 36.3 KB)
Minimum Free Bytes: 344452 B ( 336.4 KB)
Largest Free Block: 319476 B ( 312.0 KB)
Flash Info:
Chip Size : 8388608 B (8 MB)
Block Size : 65536 B ( 64.0 KB)
Sector Size : 4096 B ( 4.0 KB)
Page Size : 256 B ( 0.2 KB)
Bus Speed : 40 MHz
Bus Mode : QIO
Partitions Info:
nvs : addr: 0x00009000, size: 20.0 KB, type: DATA, subtype: NVS
otadata : addr: 0x0000E000, size: 8.0 KB, type: DATA, subtype: OTA
app0 : addr: 0x00010000, size: 2560.0 KB, type: APP, subtype: OTA_0
spiffs : addr: 0x00290000, size: 1384.0 KB, type: DATA, subtype: SPIFFS
zb_storage : addr: 0x003EA000, size: 16.0 KB, type: DATA, subtype: FAT
zb_fct : addr: 0x003EE000, size: 4.0 KB, type: DATA, subtype: FAT
rcp_fw : addr: 0x003EF000, size: 4.0 KB, type: DATA, subtype: SPIFFS
coredump : addr: 0x003F0000, size: 64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
Compile Date/Time : Mar 23 2025 18:15:32
Compile Host OS : linux
ESP-IDF Version : v5.3.2-584-g489d7a2b3a-dirty
Arduino Version : 3.1.3
Board Info:
Arduino Board : ESP32C6_DEV
Arduino Variant : esp32c6
Arduino FQBN : esp32:esp32:esp32c6:PartitionScheme=custom,ZigbeeMode=zczr,DebugLevel=verbose,CDCOnBoot=cdc
[ 366][D][ZigbeeCore.cpp:173] zigbeeInit(): Register all Zigbee EPs in list
[ 371][I][ZigbeeCore.cpp:181] zigbeeInit(): List of registered Zigbee EPs:
[ 371][I][ZigbeeCore.cpp:183] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[ 387][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[ 388][I][ZigbeeCore.cpp:275] esp_zb_app_signal_handler(): Zigbee stack initialized
[ 426][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x30fa) closed, devices joining not allowed.
[ 428][I][ZigbeeCore.cpp:281] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[ 428][I][ZigbeeCore.cpp:294] esp_zb_app_signal_handler(): Device rebooted
[ 428][I][ZigbeeCore.cpp:298] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[ 429][D][ZigbeeCore.cpp:539] searchBindings(): Requesting binding table for address 0x0000
[ 430][D][ZigbeeCore.cpp:479] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[ 431][D][ZigbeeCore.cpp:482] bindingTableCb(): Binding table info: total 0, index 0, count 0
[ 431][D][ZigbeeCore.cpp:485] bindingTableCb(): No binding table entries found
[ 897][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x30fa) is open for 180 seconds
[ 6317][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 6320][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 15442][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 15446][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 21226][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 21229][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 21748][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x8d01)
[ 21748][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 21749][D][ZigbeeGateway.cpp:475] zbDeviceAnnce(): zbDeviceAnnce short address (0x8d01), ieee_addr (0xa4):(0xc1):(0x38):(0x12):(0xe9):(0xf3):(0x52):(0x43)
[ 21749][D][ZigbeeGateway.cpp:478] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x8d01), ieee_addr (0xa4):(0xc1):(0x38):(0x12):(0xe9):(0xf3):(0x52):(0x43)
[ 21750][I][ZigbeeGateway.cpp:502] zbDeviceAnnce(): Tuya magic last hope
[ 22007][I][ZigbeeGateway.cpp:545] printJoinedDevices(): joined devices:
[ 22007][I][ZigbeeGateway.cpp:548] printJoinedDevices(): Device on endpoint 1, short address: 0x8d01
[ 22340][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 22341][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 22341][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 22342][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_v1w2k9dd"
[ 22343][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 22343][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): ZCL version id is "3"
[ 22344][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(90)
[ 22344][I][ZigbeeGateway.cpp:365] zbReadBasicCluster(): ZCL application version id is "90"
[ 22345][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 22345][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "TS0201"
[ 22346][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 22346][I][ZigbeeGateway.cpp:371] zbReadBasicCluster(): ZCL power source id is "3"
[ 22347][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[ 22348][I][ZigbeeGateway.cpp:375] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[ 22351][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 22352][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8d01), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x81
[ 22353][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 22353][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x2]
[ 22354][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -71
[ 22408][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 22762][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 22763][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 22763][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 22764][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_v1w2k9dd"
[ 22908][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 22908][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 23409][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 23475][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 23476][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 23476][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 23477][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "TS0201"
[ 23480][I][ZigbeeGateway.cpp:1065] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 23982][I][ZigbeeGateway.cpp:275] zbPrintDeviceDiscovery(): short_addr_req 36097
[ 24052][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 24053][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 24054][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[ 24062][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 24086][I][ZigbeeGateway.cpp:209] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 36097, endpoints count 1
[ 24087][I][ZigbeeGateway.cpp:212] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 24304][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x30fa) is open for 180 seconds
[ 24521][I][ZigbeeGateway.cpp:228] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 36097, endpoint # 1
[ 24522][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 5, out clusters # 3
[ 24522][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 24523][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
[ 24523][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 3, id 1
[ 24524][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 4, id 1026
[ 24524][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 5, id 1029
[ 24525][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
[ 24525][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 24526][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 25042][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25043][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 25044][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 25045][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 25045][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 25046][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 25047][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 25048][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x6), data type (0x42)
[ 25049][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 25049][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0x12), data type (0x10)
[ 25050][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 25051][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0xfffe), data type (0x30)
[ 25052][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x0), attribute id (0xffde), data type (0x20)
[ 25066][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25067][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 25068][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[ 25082][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25083][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 25083][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 25084][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 25099][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25099][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x402), attribute id (0x0), data type (0x29)
[ 25100][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x402), attribute id (0x1), data type (0x29)
[ 25101][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x402), attribute id (0x2), data type (0x29)
[ 25102][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x402), attribute id (0xfffd), data type (0x21)
[ 25116][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25117][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x405), attribute id (0x0), data type (0x21)
[ 25118][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x405), attribute id (0x1), data type (0x21)
[ 25119][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x405), attribute id (0x2), data type (0x21)
[ 25120][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x405), attribute id (0xfffd), data type (0x21)
[ 25134][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25135][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
[ 25136][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
[ 25151][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25151][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x0), data type (0xf0)
[ 25152][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x1), data type (0x23)
[ 25153][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x2), data type (0x23)
[ 25154][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x3), data type (0x21)
[ 25155][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x4), data type (0x23)
[ 25156][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x5), data type (0x21)
[ 25157][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x6), data type (0x30)
[ 25158][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x7), data type (0x21)
[ 25158][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x8), data type (0x21)
[ 25159][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0x9), data type (0x21)
[ 25160][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0x19), attribute id (0xfffd), data type (0x21)
[ 25164][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 25164][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0xa), attribute id (0x0), data type (0xe2)
[ 25165][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0xa), attribute id (0x1), data type (0x18)
[ 25166][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0xa), attribute id (0x7), data type (0x23)
[ 25167][I][ZigbeeGateway.cpp:752] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x8d01), source endpoint (0x1), source cluster (0xa), attribute id (0xfffd), data type (0x21)
[ 29309][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 29310][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x402)
[ 29310][I][ZigbeeGateway.cpp:586] zbAttributeReporting(): zbAttributeReporting temperature measurement 26.200001
[ 29317][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 29318][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 29318][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 29319][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 29319][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 5 size: 2
[ 29319][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[ 29320][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[ 29320][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x8d01, 0x8d01, 0x0, 0x0
[ 29321][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 29829][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 29829][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x405)
[ 29830][I][ZigbeeGateway.cpp:595] zbAttributeReporting(): zbAttributeReporting humidity measurement 47.000000
[ 30335][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 30336][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 30337][I][ZigbeeGateway.cpp:700] zbAttributeReporting(): zbAttributeReporting power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[ 30844][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 30844][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8d01) src endpoint(1) to dst endpoint(1) cluster(0x1)
[ 30845][I][ZigbeeGateway.cpp:697] zbAttributeReporting(): zbAttributeReporting power config battery percentage remaining 200
[ 35623][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 35626][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
NLME Status Indication, status: 0x9-
Dodałem oba, będą w 0.7.7 (tak za kwadrans).sebu1 wrote: Mon Mar 24, 2025 7:50 pm Hej, mam dwa czujniki, jeśli można było by dodać:
i czujnik nr 2,
sebu1
Niestety obydwa nie działają,
- 1. czujnik w cloud pokazuje się podwójnie (dwa kanały) i wartości są: "Temperatura?°C
Wilgotność-1%"
- 2. czujnik w cloud pokazuje się pojedynczo (czyli prawidłowo) ale wartości tak samo jak wyżej
