compiling error wifisocket board x4
Post Reply
emiliakowalski
hello,
i was trying to compile wifisocket_x4. with added 5th relay option but getting compilation error.
below is the error and edited code
----------------------------error-----------------------------------------
error: array subscript is above array bounds
supla_relay_cfg[4].gpio_id= B_RELAY5_PORT
supla_relay_cfg[4].flags= RELAY_FLAT_RESTORE
--------------------------error----------------------------------------------------
-------------------------edited code----------------------------------------------------
#ifdef __BOARD_wifisocket_54
#define B_RELAY1_PORT 5
#define B_CFG_PORT 4
#elif defined(__BOARD_wifisocket_x4)
#define B_RELAY1_PORT 4
#define B_RELAY2_PORT 12
#define B_RELAY3_PORT 13
#define B_RELAY4_PORT 14
#define B_RELAY5_PORT 16
#define B_CFG_PORT 0
#define B_BTN3_PORT 2
#define B_BTN4_PORT 5
#else
#define B_CFG_PORT 5
#endif
#ifdef __BOARD_wifisocket_x4
void supla_esp_board_set_device_name(char *buffer, uint8 buffer_size) {
ets_snprintf(buffer, buffer_size, "SUPLA-SOCKETx4");
#else
void ICACHE_FLASH_ATTR supla_esp_board_set_device_name(char *buffer, uint8 buffer_size) {
ets_snprintf(buffer, buffer_size, "SUPLA-SOCKET");
#endif
void ICACHE_FLASH_ATTR supla_esp_board_gpio_init(void) {
supla_input_cfg[0].type = INPUT_TYPE_BUTTON;
supla_input_cfg[0].gpio_id = B_CFG_PORT;
supla_input_cfg[0].flags = INPUT_FLAG_PULLUP | INPUT_FLAG_CFG_BTN;
supla_input_cfg[0].relay_gpio_id = B_RELAY1_PORT;
supla_input_cfg[0].channel = 0;
supla_input_cfg[1].type = INPUT_TYPE_BUTTON;
supla_input_cfg[1].gpio_id = B_BTN3_PORT;
supla_input_cfg[1].flags = INPUT_FLAG_PULLUP;
supla_input_cfg[1].relay_gpio_id = B_RELAY2_PORT;
supla_input_cfg[1].channel = 1;
supla_input_cfg[2].type = supla_esp_cfg.CfgButtonType == BTN_TYPE_SWITCH ? INPUT_TYPE_SWITCH : INPUT_TYPE_BUTTON;
supla_input_cfg[2].gpio_id = B_BTN3_PORT;
supla_input_cfg[2].relay_gpio_id = B_RELAY3_PORT;
supla_input_cfg[2].channel = 2;
supla_input_cfg[3].type = supla_input_cfg[2].type;
supla_input_cfg[3].gpio_id = B_BTN4_PORT;
supla_input_cfg[3].relay_gpio_id = B_RELAY4_PORT;
supla_input_cfg[3].channel = 3;
supla_input_cfg[4].type = supla_input_cfg[3].type;
supla_input_cfg[4].gpio_id = B_BTN4_PORT;
supla_input_cfg[4].relay_gpio_id = B_RELAY5_PORT;
supla_input_cfg[4].channel = 4;
#else
supla_input_cfg[0].type = supla_esp_cfg.CfgButtonType == BTN_TYPE_SWITCH ? INPUT_TYPE_SWITCH : INPUT_TYPE_BUTTON;
#endif
supla_relay_cfg[0].gpio_id = B_RELAY1_PORT;
supla_relay_cfg[0].flags = RELAY_FLAG_RESTORE_FORCE;
supla_relay_cfg[0].channel = 0;
supla_relay_cfg[1].gpio_id = B_RELAY2_PORT;
supla_relay_cfg[1].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[1].channel = 1;
supla_relay_cfg[2].gpio_id = B_RELAY3_PORT;
supla_relay_cfg[2].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[2].channel = 2;
supla_relay_cfg[3].gpio_id = B_RELAY4_PORT;
supla_relay_cfg[3].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[3].channel = 3;
supla_relay_cfg[4].gpio_id = B_RELAY5_PORT;
supla_relay_cfg[4].flags = RELAY_FLAG_RESTORE;
supla_relay_cfg[4].channel = 4;
#endif
void ICACHE_FLASH_ATTR supla_esp_board_set_channels(TDS_SuplaRegisterDevice_B *srd) {
#if defined(__BOARD_wifisocket_x4)
srd->channel_count = 5;
#else
srd->channel_count = 2;
#endif
srd->channels[0].Number = 0;
srd->channels[0].Type = SUPLA_CHANNELTYPE_RELAY;
srd->channels[0].FuncList = SUPLA_BIT_RELAYFUNC_POWERSWITCH \
| SUPLA_BIT_RELAYFUNC_LIGHTSWITCH;
srd->channels[0].Default = SUPLA_CHANNELFNC_POWERSWITCH;
srd->channels[0].value[0] = supla_esp_gpio_relay_on(B_RELAY1_PORT);
#ifndef __BOARD_wifisocket_x4
srd->channels[1].Number = 1;
srd->channels[1].Type = SUPLA_CHANNELTYPE_THERMOMETERDS18B20;
srd->channels[1].FuncList = 0;
srd->channels[1].Default = 0;
supla_get_temperature(srd->channels[1].value);
#endif
srd->channels[1].Type = srd->channels[0].Type;
srd->channels[1].FuncList = srd->channels[0].FuncList;
srd->channels[1].Default = srd->channels[0].Default;
srd->channels[1].value[0] = supla_esp_gpio_relay_on(B_RELAY2_PORT);
srd->channels[2].Number = 2;
srd->channels[2].Type = srd->channels[0].Type;
srd->channels[2].FuncList = srd->channels[0].FuncList;
srd->channels[2].Default = srd->channels[0].Default;
srd->channels[2].value[0] = supla_esp_gpio_relay_on(B_RELAY3_PORT);
srd->channels[3].Number = 3;
srd->channels[3].Type = srd->channels[0].Type;
srd->channels[3].FuncList = srd->channels[0].FuncList;
srd->channels[3].Default = srd->channels[0].Default;
srd->channels[3].value[0] = supla_esp_gpio_relay_on(B_RELAY4_PORT);
srd->channels[4].Number = 4;
srd->channels[4].Type = srd->channels[0].Type;
srd->channels[4].FuncList = srd->channels[0].FuncList;
srd->channels[4].Default = srd->channels[0].Default;
srd->channels[4].value[0] = supla_esp_gpio_relay_on(B_RELAY5_PORT);
#endif
void ICACHE_FLASH_ATTR supla_esp_board_send_channel_values_with_delay(void *srpc) {
supla_esp_channel_value_changed(0, supla_esp_gpio_relay_on(B_RELAY1_PORT));
supla_esp_channel_value_changed(1, supla_esp_gpio_relay_on(B_RELAY2_PORT));
supla_esp_channel_value_changed(2, supla_esp_gpio_relay_on(B_RELAY3_PORT));
supla_esp_channel_value_changed(3, supla_esp_gpio_relay_on(B_RELAY4_PORT));
supla_esp_channel_value_changed(4, supla_esp_gpio_relay_on(B_RELAY5_PORT));
#endif
Contact:
https://github.com/SUPLA/supla-espressi ... _esp.h#L35
change to
#define RELAY_MAX_COUNT 5
emiliakowalski
solve thankyou
Post Reply
Return to “General discussion”
