Suggestion on System requirements for Supla
Post Reply
aruneshdutta
Hello
I wanted to deploy Supla using Linux on VPS,wanted to know the suggestion on system requirements for the same.Thanks
Contact:
https://www.ovh.co.uk/order/vps/#/legacy/vps/options?vps=~(category~'ssd~product~'vps_ssd_model1_2017v3~os~'linux~datacenter~'uk1)
aruneshdutta
Thanks,so is this the ideal requirements as shown in ? was planning to use in Ubuntu 16.04
fracz
If you plan to use Docker installation: viewtopic.php?f=12&p=16088 I would suggest Debian rather than Ubuntu.
aruneshdutta
Thanks I'll go in with debian&docker.What's the minimum hw requirements of the server or any estimates that will help me know same for deployment
LyleSo
aruneshdutta wrote: Fri Jan 26, 2018 6:35 am Thanks I'll give Quick Extender Pro a shot and go in with debian&docker.What's the minimum hw requirements of the server or any estimates that will help me know same for deployment
Does it not work at all on Ubuntu or does it simply work better on Debian? I'm also considering Linux.
fracz
It should work on Ubuntu, too. Just considering debian as more "stable" for server environments. Personal opinion, that's all.
Post Reply
Return to “General discussion”
