Updating WiFi Credentials
Post Reply
bouali
I've freshly flashed my esp with a gate-module-firmware, for the beginning Nothing expected wrong. I configured the module network and works, but when I try to enter the module into his config mode to update the wifi(pass,ssid), it reboots and reconnects again to the same IP.
I respect these configurations:
PORT SETTINGS:
[CHANNEL0] RELAY1 GPIO4
[CHANNEL1] RELAY2 GPIO13
CFG BUTTON GPIO5 // pulled up to 3.3V - RES 10kohm // pressing and hold >5s...
LED
- GREEN GPIO12
- BLUE GPIO14
[CHANNEL2] INPUT_PORT1 GPIO12
[CHANNEL3] IMPUT_PORT2 GPIO14
pls help, thanks in advance.
Contact:
Probably you have wrong flash size.
gate-module-firmware is dedicated for 2MB chip
bouali
Ok, understood. my flash has 4MB size.
Thank you pzygmunt :)
Contact:
bouali wrote: Wed Feb 21, 2018 7:30 pm Ok, understood. my flash has 4MB size.
So, should work. Only you need set 2MB size when flashing.
Contact:
... and don't forget upload esp_init_data_default.bin at 0x1fc000 when you set 2MB flash size
bouali
I've checked the [ESP8266 SDK
Getting Started Guide].
I'll reflash it, and I will get back to you once I have a problem.
esp8266 flash down.PNG (109.3 KiB) Viewed 15273 times
bouali
Good, worked fine now.
Thank you ;)
Post Reply
Return to “Help”
