I have cloned the master branch and ran ./build.sh gate_module and got following errors:
macmini: src JS$ ./build.sh gate_module
make: *** No rule to make target `clean'. Stop.
./build.sh: line 271: [: : integer expression expected
cp: /hdd2/Espressif/ESP8266_NONOS_SDK154/ld/eagle.app.v6.ld: No such file or directory
Any help would be appreciated.
Build issue
Thanks! It builds fine on the VM. I then flashed the ESP8266-01 with the binaries and powered it up and got this (s. attachment). Shouldn't it be asking for dev id and password as well? Regarding the GPIO configuration: I'd like to drive two relays, one on GPIO2 and one on Rx similarly to the pdf.
Is the following configuration correct?
#define B_CFG_PORT 5
#define B_RELAY1_PORT 3
#define B_RELAY2_PORT 7
Would there be any usable GPIO left, for the two sensor ports?
- Attachments
- IMG-3871.PNG (46.98 KiB) Viewed 12162 times
In the case of configuration, just enter the email and server.
Regarding GPIO ports, you must modify the board source files or create a new one.
https://github.com/SUPLA/supla-espressi ... lude/board
sorry..... email and server
Check LAST STATE
Try to add
#define ESP8266_SUPLA_PROTO_VERSION 7
to the board header file.
