Servo sterowanie Esp8266
elmaya
the libraries has had many changes.
I have updated the code.
#include <FS.h>       // ---- esp board manager 2.6.3 --- iwip Variant V2
#include <SuplaDevice.h>  //------- https://github.com/SUPLA/arduino/tree/develop
#include <Servo.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <ESP8266TrueRandom.h>
Supla::ESPWifi wifi("", "");  //------ Do not change----wifimanager takes care------
extern "C"
#include "user_interface.h"
char GUID[SUPLA_GUID_SIZE];
char AUTHKEY[SUPLA_AUTHKEY_SIZE];
byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long
Servo myservo;  // create servo object to control a servo
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
WiFiManager wifiManager;
int wificonfig_pin = 0; // D3
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;                      // config delay 10 seconds
char Supla_server[81]=("Unknown server address");
char Email[81]=("Unknown email address");
char Supla_name[51];
char Supla_status[51];;
bool initialConfig = false;
int s = 0;
bool starting = true;
 unsigned char _red = 0;
 unsigned char _green = 255;
 unsigned char _blue = 0;
 unsigned char _color_brightness = 0;
 unsigned char _brightness = 0;
 unsigned char _bright = 0;
void saveConfigCallback () {
  shouldSaveConfig = true;
   WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required");
   WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required");
   WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
   WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly");
   wifiManager.setBreakAfterConfig(true);
   wifiManager.addParameter(&custom_Email);
   wifiManager.addParameter(&custom_Supla_name);
   wifiManager.addParameter(&custom_Supla_status);
   wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
   wifiManager.setMinimumSignalQuality(8);
   //wifiManager.setShowStaticFields(true); // force show static ip fields
   //wifiManager.setShowDnsFields(true);    // force show dns field always
   wifiManager.setConfigPortalTimeout(180);
   if (!wifiManager.startConfigPortal("Servo")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");}
    strcpy(Email, custom_Email.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){
      Serial.println("new guid & authkey.");
      EEPROM.write(300, 0);
      EEPROM.commit();
      ESP.reset();
    WiFi.softAPdisconnect(true);   //  close AP
void status_func(int status, const char *msg) {    //    ------------------------ Status --------------------------
  if (s != status){
    s = status;
      if (s != 10){
        strcpy(Supla_status, msg);
void guid_authkey(void) {
  if (EEPROM.read(300) != 60){
    int eep_gui = 301;
    ESP8266TrueRandom.uuid(uuidNumber);
    String uuidString = "";
    for (int i = 0; i < 16; i++) {
      int topDigit = uuidNumber[i] >> 4;
      int bottomDigit = uuidNumber[i] & 0x0f;
      uuidString += "0123456789abcdef"[topDigit];
      uuidString += "0123456789abcdef"[bottomDigit];
    int length_uuid = uuidString.length();
    for (int i = 0; i < length_uuid; ++i) {
      EEPROM.put(eep_gui + i, uuidString[i]);
    int eep_aut = 341;
    String uuidString2 = "";
      uuidString2 += "0123456789abcdef"[topDigit];
      uuidString2 += "0123456789abcdef"[bottomDigit];
    int length_uuid2 = uuidString2.length();
    for (int i = 0; i < length_uuid2; ++i) {
      EEPROM.put(eep_aut + i, uuidString2[i]);
    EEPROM.write(300, 60);
    EEPROM.commit();
  read_guid();
  read_authkey();
  Serial.print("GUID : ");Serial.println(read_guid());
  Serial.print("AUTHKEY : ");Serial.println(read_authkey());
String read_guid(void) {
  String read_eeprom = "";
  int i, ii = 0;
  int eep_star = 301;
  int end_guid = eep_star + SUPLA_GUID_SIZE;
  String temp_read = "0x";
  for (i = eep_star; i < end_guid + 16;  i = i + 1) {
    temp_read += char(EEPROM.read(i));
    read_eeprom += char(EEPROM.read(i));
    if ( (i % 2) == 0) {
      char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      GUID[ii] = strtoul( _guid, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
String read_authkey(void) {
  int i, ii = 0;
  int eep_star = 341;
  int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE;
  for (i = eep_star; i < end_authkey + 16;  i = i + 1) {
      char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str());
      AUTHKEY[ii] = strtoul( _authkey, NULL, 16);
      temp_read = "0x";
      ii++;
  return read_eeprom;
void step_pos() {
  if (_brightness > _bright){
    _bright = _bright + 1;
    set_rgbw();
  }else if (_brightness < _bright){
    _bright = _bright - 1;
    set_rgbw();
void get_rgbw_value(int channelNumber, unsigned char *red, unsigned char *green, unsigned char *blue, unsigned char *color_brightness, unsigned char *brightness) {
  *brightness = _brightness;
  *color_brightness= _color_brightness;
  *red = _red;
  *green = _green;
  *blue = _blue;
void set_rgbw() {
    int pos = map(_bright, 0, 100, 0,180);
      Serial.print("Pos: "); Serial.println(pos);
      myservo.write(pos);              // tell servo to go to position in variable 'pos'
void set_rgbw_value(int channelNumber, unsigned char red, unsigned char green, unsigned char blue, unsigned char color_brightness, unsigned char brightness) {
    _brightness = brightness;
    _color_brightness= color_brightness;
    _red = red;
    _green = green;
    _blue = blue;
void setup() {
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  delay(200);
  Serial.println();
  pinMode(wificonfig_pin, INPUT_PULLUP);
  EEPROM.begin(1024);
  myservo.attach(2);  // attaches the servo on GIO2 to the servo object
  if (EEPROM.read(300) != 60){initialConfig = true;}
  guid_authkey();
  if (WiFi.SSID()==""){ initialConfig = true;}
  if (SPIFFS.begin()) {  // ------------------------- wificonfig read -----------------
    Serial.println("mounted file system");
    if (SPIFFS.exists("/servo.json")) {
      Serial.println("reading config file");
       File configFile = SPIFFS.open("/servo.json", "r");
      if (configFile) {
        Serial.println("opened config file");
         DynamicJsonBuffer jsonBuffer;
         json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {Serial.println("\nparsed json");
           if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
           if (json.containsKey("Email")) strcpy(Email, json["Email"]);
           if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
        } else {
          Serial.println("failed to load json config");
        configFile.close();
   } else {
    Serial.println("failed to mount FS");
   wifi_station_set_hostname(Supla_name);
   set_rgbw();
    SuplaDevice.setRGBWCallbacks(&get_rgbw_value, &set_rgbw_value);
    SuplaDevice.addDimmer();
    SuplaDevice.setName(Supla_name);
    SuplaDevice.setStatusFuncImpl(&status_func);
    wifi.enableSSL(false);
    SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY);
void loop() {
   if (initialConfig == true){ondemandwifiCallback();}
   int C_W_read = digitalRead(wificonfig_pin);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        ondemandwifiCallback () ;
   last_C_W_state = C_W_read;
  if (shouldSaveConfig == true) { // ------------------------ wificonfig save --------------
    Serial.println("saving config");
    json["Email"] = Email;
    json["Supla_name"] = Supla_name;
    File configFile = SPIFFS.open("/servo.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing"); }
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    WiFi.mode(WIFI_STA);
    delay(5000);
    ESP.restart();
   SuplaDevice.iterate();
   delay(10);
   step_pos();
    if (starting){
      httpUpdater.setup(&httpServer, "/update", "admin", "pass");
      httpServer.begin();
      starting = false;
    httpServer.handleClient();
Piotr682
Bardzo dziękuję za pomoc i poświęcony czas.
Biorę się za testowanie. :D :D :D
Piotr682
Sprawdzone, wszystko działa dobrze i stabilnie.
Jeszce raz wielkie podziękowania.
Kokszu
Po wielu próbach skompilowania szkicu ostatecznie utknąłem na błędzie którego treść zamieszczam poniżej.
Czy spotkał się już ktoś z tym problemem, udało się to jakoś rozwiązać?
Arduino:1.8.13 (Windows 10), Płytka:"LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Higher Bandwidth, Disabled, None, All Flash Contents, 115200"
C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino: In function 'void setup()':
servoSupla:273:17: error: 'class SuplaDeviceClass' has no member named 'setRGBWCallbacks'
servoSupla:275:17: error: 'class SuplaDeviceClass' has no member named 'addDimmer'
servoSupla:279:17: error: 'class SuplaDeviceClass' has no member named 'setTimerFuncImpl'
SuplaDevice.setTimerFuncImpl(&supla_timer);
exit status 1
Kokszu pisze: wt paź 20, 2020 7:45 pm Po wielu próbach skompilowania szkicu ostatecznie utknąłem na błędzie którego treść zamieszczam poniżej.
Używasz programu napisanego na starą wersję biblioteki SuplaDevice, a bibliotekę masz w nowej wersji.
Jeśli chcesz kompilować "po staremu" tok pobierz bibliotekę z https://github.com/SUPLA/arduino
Kokszu
klew pisze: wt paź 20, 2020 7:50 pm
Dzięki za szybką odpowiedź.
Po skorzystaniu z Twojej rady usunąłem jeszcze implementację esp_wifi.h bo w bibliotece pod linkiem https://github.com/SUPLA/arduino jej nie ma po czym uzyskałem takie błędy:
UWAGA: biblioteka SuplaDevice działa na architekturze(/architekturach) avr i może nie być kompatybilna z obecną płytką która działa na architekturze(/architekturach) esp8266.
In file included from C:\Users\User\Documents\Arduino\libraries\SuplaDevice/SuplaDevice.h:298:0,
from C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino:20:
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla_main_helper._cpp_:68:3: error: 'UNKNOWN' does not name a type
UNKNOWN ETHERNET LIBRARY
servoSupla:29:1: error: 'Supla' does not name a type
servoSupla:281:54: error: no matching function for call to 'SuplaDeviceClass::begin(char [16], char [81], char [81], char [16])'
C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino:281:54: note: candidates are:
In file included from C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino:20:0:
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/SuplaDevice.h:235:9: note: bool SuplaDeviceClass::begin(IPAddress*, char*, uint8_t*, const char*, int, const char*)
bool begin(IPAddress *local_ip, char GUID[SUPLA_GUID_SIZE], uint8_t mac[6], const char *Server,
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/SuplaDevice.h:235:9: note: candidate expects 6 arguments, 4 provided
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/SuplaDevice.h:238:9: note: bool SuplaDeviceClass::begin(char*, uint8_t*, const char*, int, const char*)
bool begin(char GUID[SUPLA_GUID_SIZE], uint8_t mac[6], const char *Server,
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/SuplaDevice.h:238:9: note: candidate expects 5 arguments, 4 provided
exit status 1
więc wpadłem na pomysł by wziąć dwa foldery z tamtej biblioteki żeby załapało wymagane esp_wifi.h lecz otrzymałem błędy:
In file included from C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:25:0,
from C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino:28:
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/network.h:114:30: error: 'TDSC_ChannelState' has not been declared
virtual void fillStateData(TDSC_ChannelState &channelState);
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/network.h:124:3: error: '_supla_int64_t' does not name a type
_supla_int64_t lastSentMs;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/network.h:125:3: error: '_supla_int64_t' does not name a type
_supla_int64_t lastResponseMs;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/network.h:126:3: error: '_supla_int64_t' does not name a type
_supla_int64_t lastPingTimeMs;
In file included from C:\Users\User\Documents\Arduino\servoSupla\servoSupla.ino:28:0:
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:194:22: error: 'TDSC_ChannelState' has not been declared
void fillStateData(TDSC_ChannelState &channelState) {
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h: In member function 'virtual void Supla::ESPWifi::fillStateData(int&)':
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:195:18: error: request for member 'Fields' in 'channelState', which is of non-class type 'int'
channelState.Fields |= SUPLA_CHANNELSTATE_FIELD_IPV4 |
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:195:28: error: 'SUPLA_CHANNELSTATE_FIELD_IPV4' was not declared in this scope
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:196:28: error: 'SUPLA_CHANNELSTATE_FIELD_MAC' was not declared in this scope
SUPLA_CHANNELSTATE_FIELD_MAC |
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:197:28: error: 'SUPLA_CHANNELSTATE_FIELD_WIFIRSSI' was not declared in this scope
SUPLA_CHANNELSTATE_FIELD_WIFIRSSI |
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:198:28: error: 'SUPLA_CHANNELSTATE_FIELD_WIFISIGNALSTRENGTH' was not declared in this scope
SUPLA_CHANNELSTATE_FIELD_WIFISIGNALSTRENGTH;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:199:18: error: request for member 'IPv4' in 'channelState', which is of non-class type 'int'
channelState.IPv4 = WiFi.localIP();
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:200:34: error: request for member 'MAC' in 'channelState', which is of non-class type 'int'
WiFi.macAddress(channelState.MAC);
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:202:18: error: request for member 'WiFiRSSI' in 'channelState', which is of non-class type 'int'
channelState.WiFiRSSI = rssi;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:204:20: error: request for member 'WiFiSignalStrength' in 'channelState', which is of non-class type 'int'
channelState.WiFiSignalStrength = 100;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:206:20: error: request for member 'WiFiSignalStrength' in 'channelState', which is of non-class type 'int'
channelState.WiFiSignalStrength = 0;
C:\Users\User\Documents\Arduino\libraries\SuplaDevice/supla/network/esp_wifi.h:208:20: error: request for member 'WiFiSignalStrength' in 'channelState', which is of non-class type 'int'
channelState.WiFiSignalStrength = 2 * (rssi + 100);
exit status 1
będę wdzięczny za jakiekolwiek rady
Kokszu pisze: wt paź 20, 2020 8:34 pm będę wdzięczny za jakiekolwiek rady
Przyjrzałem się trochę dokładniej i problem jest taki, że ten program opiera się na jakiejś starszej wersji nowej bibliteki SuplaDevice ;).
Spróbuj pobrać biblitekę w tej wersji: https://github.com/SUPLA/arduino/tree/4 ... e18f188cc0
Kokszu
klew pisze: śr paź 21, 2020 8:00 am
pobrałem, podmieniłem i przy kompilacji już inne błędy dotyczące biblioteki timer.h:
Arduino:1.8.13 (Windows 10), Płytka:"LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
C:\Users\User\Documents\Arduino\libraries\SuplaDevice\src\supla\timer.cpp: In function 'void Supla::initTimers()':
C:\Users\User\Documents\Arduino\libraries\SuplaDevice\src\supla\timer.cpp:64:37: error: 'os_timer_func_t' was not declared in this scope
os_timer_setfn(&supla_esp_timer, (os_timer_func_t *)esp_timer_cb, NULL);
C:\Users\User\Documents\Arduino\libraries\SuplaDevice\src\supla\timer.cpp:64:54: error: expected primary-expression before ')' token
C:\Users\User\Documents\Arduino\libraries\SuplaDevice\src\supla\timer.cpp:68:58: error: expected primary-expression before ')' token
os_timer_setfn(&supla_esp_fastTimer, (os_timer_func_t *)esp_fastTimer_cb, NULL);
exit status 1
Błąd kompilacji dla płytki LOLIN(WEMOS) D1 R2 & mini.
EDIT: Udało się po zaktualizowaniu menadżera płytek do wersji 2.6.3. wielkie dzięki za pomoc! :)
Hobo
Mam propozycje na rozszerzenie tego projektu (albo stworzenie nowego w oparciu o ten) o wyznaczanie pozycji słońca w zależności od pozycji geograficznej (jest biblioteka do pythona), ustawienia południa (do określenia max kątów odchylenia na wschód i zachód) i możliwość sterowania drugim urządzeniem jak siłownik do ustawiania nachylenia... jak się już domyślacie panela PV.
Najlepsze moim zdaniem byłoby rozwiązanie jeden sterownik i sterowanie wieloma zestawami (servo/siłownik poziomy i pionowy).
Jeśli nie uważałeś jak robiłeś to rób jak uważasz.
Jeśli uważałeś to bądź pewny tego co zrobiłeś.
Duch__
Do tego stosuje sie proste układy na fotorezystorach.
Wróć do „Pomysły i koncepcje”
