Problem z modułem MOSFET PWM
elmaya
it will be enough to bridge the led diodes that are in series with the optocouplers so that it works correctly with 3.3v.
the leds are marked as IN1 - IN4.
Has thanked: 3 times
Been thanked: 3 times
elmaya wrote: Sun Mar 06, 2022 6:06 pm it will be enough to bridge the led diodes that are in series with the optocouplers so that it works correctly with 3.3v.
I'm sorry but I don't get it where exactly the bridge is supposed to be. Would You like to draw the bridge on the photo?
elmaya
elmaya wrote: Mon Mar 07, 2022 8:27 am2022030.jpg
Not working. No difference. :(
shimano73
Mi się wydaje że ta dioda która wskazał elmaya jest po stronie tranzystora, ja bym wymienił rezystor o oznaczeniu 471 czyli 470ohm zmień go na 220Ohm
shimano73 wrote: Tue Mar 08, 2022 9:44 am Mi się wydaje że ta dioda która wskazał elmaya jest po stronie tranzystora, ja bym wymienił rezystor o oznaczeniu 471 czyli 470ohm zmień go na 220Ohm
Co szkodzi spróbować. Testowo nie będę wymieniał tylko podłącze równolegle drugi Ok. 400-450ohm
elmaya
equivalent to the input circuit.
By bridging Led 1, the sensitivity of the input increases by at least 1.6Vdc.
the IN are all separate, make sure you have all the GND of the IN interconnected.
elmaya wrote: Tue Mar 08, 2022 11:00 am equivalent to the input circuit.
they are interconnected just right on the PCB, if I understand You well. Besides that I'm looking on the pictures and something seems to be different on Your diagram but ... I will check it afternoon when I have the PCB in my hands
elmaya
what you point out is the ground connection "DC-" for the output of the optocouplers.
check the connection between GND1, GND2, GND3, GND4 and DC- with the multimeter.
elmaya wrote: Tue Mar 08, 2022 2:49 pm what you point out is the ground connection "DC-" for the output of the optocouplers.
You were right. I've made a mistake (it was late at night) and my module has a LED in different place (picture). Something that in my mind was Your mistake was caused that the LED is after the optocoupler (not before) but it doesn't change anything. Bridge on the led solved problem, the dimmer is working but ... there's no connection between GND on input that You were writing about. What is it necessary for? (I've checked the dimmer only using the multimeter, I haven't connected the LED strip yet)
