It‘s configured as reserved IP in my wlan router. I just reconfigured ist to use my internet modems wlan.
I just checked my graphs and found the first problem started on 01.08.2022 with a single drop-out. Than it got worse from week to week…
MEW-01 3-phase monitor connection-lost
worldofmaya
This didn't help too... dropouts since 9:00 in the morning
worldofmaya
I‘ll try to test it somewhere else…
Thanks for your help!
You can try with different AP. I.e. setup Wi-Fi AP on your mobile phone and reconfigure MEW to that network. If connection will be stable, then most probably problem is somewhere in your LAN. If it will still lose connection, then problem is probably with your MEW unit
worldofmaya
Here‘s an update, using my (wired) homeassistant Installation I recorded pings and found some connection outages from time to time. I exchanged my lte router which solved this issue by now.
Thanks for all your help!
