i dalej nie startuje:
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 11.7 1.7 15124 7792 ? Ss 09:49 0:12 /sbin/init
root 2 0.0 0.0 0 0 ? S 09:49 0:00 [kthreadd]
root 3 1.2 0.0 0 0 ? I 09:49 0:01 [kworker/0:0-events_power_efficient]
root 4 0.0 0.0 0 0 ? I< 09:49 0:00 [kworker/0:0H-kblockd]
root 5 0.0 0.0 0 0 ? I 09:49 0:00 [kworker/u2:0-events_unbound]
root 6 0.0 0.0 0 0 ? I< 09:49 0:00 [mm_percpu_wq]
root 7 0.0 0.0 0 0 ? S 09:49 0:00 [rcu_tasks_rude_]
root 8 0.0 0.0 0 0 ? S 09:49 0:00 [rcu_tasks_trace]
root 9 1.0 0.0 0 0 ? S 09:49 0:01 [ksoftirqd/0]
root 10 0.0 0.0 0 0 ? S 09:49 0:00 [kdevtmpfs]
root 11 0.0 0.0 0 0 ? I< 09:49 0:00 [netns]
root 12 0.0 0.0 0 0 ? I 09:49 0:00 [kworker/0:1-events_long]
root 13 0.0 0.0 0 0 ? S 09:49 0:00 [kauditd]
root 14 0.1 0.0 0 0 ? I 09:49 0:00 [kworker/0:2-events_long]
root 15 0.0 0.0 0 0 ? S 09:49 0:00 [khungtaskd]
root 16 0.0 0.0 0 0 ? S 09:49 0:00 [oom_reaper]
root 17 0.0 0.0 0 0 ? I< 09:49 0:00 [writeback]
root 18 0.0 0.0 0 0 ? S 09:49 0:00 [kcompactd0]
root 33 0.0 0.0 0 0 ? I< 09:49 0:00 [kblockd]
root 34 0.0 0.0 0 0 ? I< 09:49 0:00 [blkcg_punt_bio]
root 35 0.0 0.0 0 0 ? S 09:49 0:00 [watchdogd]
root 36 0.0 0.0 0 0 ? I< 09:49 0:00 [rpciod]
root 37 0.0 0.0 0 0 ? I< 09:49 0:00 [kworker/u3:0]
root 38 0.0 0.0 0 0 ? I< 09:49 0:00 [xprtiod]
root 39 0.0 0.0 0 0 ? S 09:49 0:00 [kswapd0]
root 40 0.0 0.0 0 0 ? I< 09:49 0:00 [nfsiod]
root 41 0.0 0.0 0 0 ? I< 09:49 0:00 [iscsi_eh]
root 42 0.0 0.0 0 0 ? I< 09:49 0:00 [iscsi_destroy]
root 43 0.0 0.0 0 0 ? I< 09:49 0:00 [dwc_otg]
root 44 0.0 0.0 0 0 ? I< 09:49 0:00 [DWC Notificatio]
root 45 0.0 0.0 0 0 ? S< 09:49 0:00 [vchiq-slot/0]
root 46 0.0 0.0 0 0 ? S< 09:49 0:00 [vchiq-recy/0]
root 47 0.0 0.0 0 0 ? S< 09:49 0:00 [vchiq-sync/0]
root 48 0.0 0.0 0 0 ? I< 09:49 0:00 [zswap-shrink]
root 49 0.0 0.0 0 0 ? I 09:49 0:00 [kworker/0:3-events_power_efficient]
root 50 0.0 0.0 0 0 ? I 09:49 0:00 [kworker/0:4-mm_percpu_wq]
root 51 0.3 0.0 0 0 ? D 09:49 0:00 [kworker/0:5+events_freezable]
root 52 0.0 0.0 0 0 ? I< 09:49 0:00 [mmc_complete]
root 53 1.2 0.0 0 0 ? D< 09:49 0:01 [kworker/0:1H+kblockd]
root 54 0.0 0.0 0 0 ? I< 09:49 0:00 [kworker/0:2H-kblockd]
root 55 0.0 0.0 0 0 ? I 09:49 0:00 [kworker/u2:1-events_unbound]
root 57 0.0 0.0 0 0 ? D 09:49 0:00 [jbd2/mmcblk0p2-]
root 58 0.0 0.0 0 0 ? I< 09:49 0:00 [ext4-rsv-conver]
root 59 0.0 0.0 0 0 ? I< 09:49 0:00 [ipv6_addrconf]
root 83 2.0 1.3 15756 6132 ? Ss 09:49 0:01 /lib/systemd/systemd-journald
root 113 1.4 0.8 17944 3704 ? Ss 09:49 0:01 /lib/systemd/systemd-udevd
root 124 0.0 0.0 0 0 ? S 09:49 0:00 [vchiq-keep/0]
root 125 0.0 0.0 0 0 ? S< 09:49 0:00 [SMIO]
root 128 0.0 0.0 0 0 ? I< 09:49 0:00 [mmal-vchiq]
root 130 0.0 0.0 0 0 ? I< 09:49 0:00 [mmal-vchiq]
root 133 0.0 0.0 0 0 ? I< 09:49 0:00 [mmal-vchiq]
root 134 0.0 0.0 0 0 ? I< 09:49 0:00 [mmal-vchiq]
root 135 0.0 0.0 0 0 ? I< 09:49 0:00 [mmal-vchiq]
systemd+ 216 1.1 1.2 22364 5476 ? Ssl 09:49 0:00 /lib/systemd/systemd-timesyncd
root 246 0.6 1.3 12992 5736 ? Ss 09:49 0:00 /lib/systemd/systemd-logind
avahi 247 0.6 0.6 5876 2940 ? Ss 09:49 0:00 avahi-daemon: running [rasphome.local]
root 251 0.1 0.4 3672 2004 ? SNs 09:49 0:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
root 258 0.4 0.8 24724 3644 ? Ssl 09:50 0:00 /usr/sbin/rsyslogd -n -iNONE
nobody 259 0.0 0.4 4300 2112 ? Ss 09:50 0:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
root 260 0.0 0.5 7928 2288 ? Ss 09:50 0:00 /usr/sbin/cron -f
message+ 262 1.0 0.7 6528 3384 ? Ss 09:50 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root 267 0.1 1.0 10692 4504 ? Ss 09:50 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 269 0.1 0.3 27636 1368 ? SLsl 09:50 0:00 /usr/sbin/rngd -r /dev/hwrng
avahi 274 0.0 0.3 5748 1500 ? S 09:50 0:00 avahi-daemon: chroot helper
root 289 0.0 0.0 0 0 ? I 09:50 0:00 [kworker/u2:2]
root 303 0.0 0.0 0 0 ? I< 09:50 0:00 [cfg80211]
root 374 0.0 0.4 2812 1912 ? Ss 09:50 0:00 /sbin/dhcpcd -q -w
root 381 4.6 8.0 893660 35660 ? Ssl 09:50 0:02 /usr/bin/containerd
root 382 0.0 0.4 6596 1920 ttyAMA0 Ss+ 09:50 0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyAMA0 vt220
root 383 0.1 0.3 4288 1600 tty1 Ss+ 09:50 0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root 384 0.3 1.2 10664 5604 ? Ss 09:50 0:00 /usr/sbin/sshd -D
root 393 13.2 12.7 932460 55996 ? Ssl 09:50 0:06 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
root 401 1.0 1.3 12176 6164 ? Ss 09:50 0:00 sshd: sxat [priv]
sxat 416 4.6 1.6 14548 7196 ? Ss 09:50 0:01 /lib/systemd/systemd --user
sxat 418 0.0 0.7 16664 3392 ? S 09:50 0:00 (sd-pam)
sxat 467 2.0 0.9 12176 4264 ? S 09:50 0:00 sshd: xxx@pts/0
sxat 471 5.0 0.8 8464 3604 pts/0 Ss 09:50 0:00 -bash
root 537 0.5 0.7 9932 3292 pts/0 S 09:50 0:00 sudo su
root 541 0.6 0.6 9604 2876 pts/0 S 09:50 0:00 su
root 544 0.7 0.6 7912 2992 pts/0 S 09:50 0:00 bash
root 597 0.0 0.5 9768 2596 pts/0 R+ 09:51 0:00 ps -aux
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
docker -v && docker-compose -v
Docker version 23.0.0-rc.3, build e1152b2
docker-compose version 1.21.0, build unknown
cat docker-compose.yml
version: '3.4'
services:
supla-cloud:
image: supla/supla-cloud:arm32v6
supla-db:
image: hypriot/rpi-mysql:5.5
supla-server:
image: supla/supla-server:arm32v6
./supla.sh start
Starting SUPLA containers
Starting supla_supla-cloud_1 ...
Starting supla_supla-server_1 ...
Starting supla_supla-db_1 ...
ERROR: for supla_supla-cloud_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for supla_supla-server_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for supla_supla-db_1 UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for supla-cloud UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for supla-server UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: for supla-db UnixHTTPConnectionPool(host='localhost', port=None): Read timed out. (read timeout=60)
ERROR: An HTTP request took too long to complete. Retry with --verbose to obtain debug information.
If you encounter this issue regularly because of slow network conditions, consider setting COMPOSE_HTTP_TIMEOUT to a higher value (current value: 60).
mogę wydłużyć czas na 120, wtedy jest niby ok, ale dockery kończą błędem exit(1)
raspberry i supla cloud
karnasw
Ta temperatura z raspberry pi to jakieś virtual device?klimasstudio wrote: Fri Jan 27, 2023 1:47 pmTego nie napisales ze na starszym RPi chceszsxatster wrote: Fri Jan 27, 2023 1:34 pm na tak, tylko że ja to chcę postawić na raspbeery pi 1 B+, a Ty o wersji 4:) a to jest jak porównać rower do odrzutowca
szukałem czegoś co ciągnie mało prądu i się nie grzeje.. i wyglądało że to powinno pociągnąć.. ale ten docker mocno mnie niepokoi..a swoja drogą RPi 4 B 4 czy 8GB juz sie tak nie grzeje. Dodam że mam w szczelnej alu obudowie z cichym wentylatorkiem.
klimasstudio
Tylko tyle mam na tym Rpi 4 8GB
Więc chodź OSUPLUJE Ci dom
sxatster
na dockerze mi to nie pójdzie za słaby sprzęt..
a mocniejszy - szkoda sprzętu.. na suple - zastanawiam się czy nie zmienię sterowników na zigbee
szkoda..
mam problem z instalacją cypress - da się to jakoś pominąć?
921 verbose pkgid [email protected]
922 verbose cwd /var/www/supla-cloud
923 verbose Linux 5.15.84+
924 verbose argv "/usr/bin/node" "/usr/share/nodejs/npm/bin/npm-cli.js" "exec" "--" "cypress" "open"
925 verbose node v12.22.12
926 verbose npm v7.5.2
927 error code 1
928 error path /home/sxat/.npm/_npx/8710cb4bb9bd9866/node_modules/cypress
929 error command failed
930 error command sh -c node index.js --exec install
931 error The Cypress App could not be installed. Your machine does not meet the operating system requirements.
931 error
931 error https://on.cypress.io/guides/getting-st ... quirements
931 error
931 error ----------
931 error
931 error Platform: linux-ia32 (Debian - 11)
931 error Cypress Version: 12.4.1
932 verbose exit 1
927 error code 1
931 error
931 error
931 error
932 verbose exit 1
sxatster
próbuje wykluczyc cypressa z instalacji.. - bo to wygląda ze to jest tylko unit testowy.. ale czy to pomoze nie wiem.. bo mało jest informacji na temat instalacji supla cloud w wersji prod
sxatster
szkoda przerywam tą zabawę... gra nie warta świeczki - a SUPLA.. cóż - jak wszystko co rodem z PL chyba przegra z zigbee .. (jak nie jakością to prądożerczą..
zmieniam automatykę na zigbee i raspbee2 - w cenie prądu zwróci się to max w 2 lata
bo obecny sprzęt zbiera ok 5W, nowe raspberry ok 10W, czyli w ciągu roku to 43 zł, licząc po cenie prądu - a przerost treści nad formą gdzie supla cloud waży jak smok - szkoda może podejdziecie jako projekt do normalnych rozwiązań niewymagających stawiania ciężkich serwerów na tak proste rozwiązania jakim jest "zarządzanie" kilkoma urządzeniami.. ogólnie poddaje się w tym temacie
