[23:54:35]ESP-ROM:esp32c3-api1-20210207
[23:54:35]Build:Feb 7 2021
[23:54:35]rst:0x15 (USB_UART_CHIP_RESET),boot:0xd (SPI_FAST_FLASH_BOOT)
[23:54:35]Saved PC:0x4038548c
[23:54:35]SPIWP:0xee
[23:54:35]mode:DIO, clock div:1
[23:54:35]load:0x3fcd5820,len:0x1144
[23:54:35]load:0x403cc710,len:0xad8
[23:54:35]load:0x403ce710,len:0x2f80
[23:54:35]entry 0x403cc710
[23:54:36][ 416][E][esp32-hal-gpio.c:190] __digitalRead(): IO 0 is not set as GPIO.
[23:54:36][ 430][E][esp32-hal-gpio.c:190] __digitalRead(): IO 3 is not set as GPIO.
[23:54:36][ 479][E][esp32-hal-gpio.c:176] __digitalWrite(): IO 0 is not set as GPIO.
[23:54:36][ 509][E][esp32-hal-gpio.c:176] __digitalWrite(): IO 3 is not set as GPIO.
[23:54:37][ 1654][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:54:37][ 1683][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:54:39][ 3033][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:54:39][ 3041][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:55:39][ 63011][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:55:39][ 63040][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:55:40][ 64461][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:55:40][ 64469][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:56:40][124567][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:56:40][124596][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:56:42][125939][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:56:42][125947][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:57:42][185969][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:57:42][185998][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:57:43][187666][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:57:43][187674][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:58:43][247322][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:58:43][247351][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:58:44][248403][E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():302]: (-32512) SSL - Memory allocation failed
[23:58:44][248413][E][NetworkClientSecure.cpp:159] connect(): start_ssl_client: connect failed: -32512
[23:58:44][248423][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:58:44][248433][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:58:44][248478][E][ssl_client.cpp:36] _handle_error(): [start_ssl_client():302]: (-32512) SSL - Memory allocation failed
[23:58:44][248488][E][NetworkClientSecure.cpp:159] connect(): start_ssl_client: connect failed: -32512
[23:59:44][308696][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:59:44][308726][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:59:45][309351][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:59:46][310028][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
[23:59:46][310037][E][NetworkClient.cpp:323] setSocketOption(): fail on 0, errno: 9, "Bad file number"
