As I sad, starting in same way as you described.
1. I push the button until green light is fast flashing.
The slowly blink comes after safe and restart the device.
WiFi Connection Change
Maas
Yes I deactivated the Assistent and used the explorer with 192.168.4.1 to configurated manual without success.
I will try it now with a real wlan Access over a router to make sure that has nothing to do with the phone hot spot….
Switch it to config mode again, connect phone to device's wifi, and open 192.168.4.1 and share print screen from there. There is "last state" field which will tell what's the problem
Maas
Screen shoot
Maas
It’s working now… I made a mistake in the WLAN Name from the IPhone… would be easier if the system would „see“ the wlan name.
Thank you very much for your patience and support.
It’s really a good service !!!
Best Regards
Jörg
Best Regards
Jörg
