Supla 16 X relay -- esp8266 + mcp23017
bulek68
Do I understand correctly that any relay can be set as GATE or TIMER?
If so, is it possible to add a gate opening sensor channel?
elmaya
bulek68 wrote: Mon Feb 10, 2020 4:54 pm Do I understand correctly that any relay can be set as GATE or TIMER?
yes and yes :D
added 3 NO sensors
Gpio14(D5) -- Sensor NO
Gpio12(D6) -- Sensor NO
Gpio13(D7) -- Sensor NO
Supla_16x16_3NO_DOUT_16Mbit.rar
bulek68
sensational!!
bulek68
The system will work if I temporarily connect the 8x relay module?
elmaya
bulek68 wrote: Mon Feb 10, 2020 5:57 pm The system will work if I temporarily connect the 8x relay module?
Could you be more specific in your question?
you mean connect
ESP8266 + 2 x Mcp23017 + 8 x active high relay?
bulek68
I mean when I don't need a 16x relay but for example 8x or 12x.
elmaya
bulek68 wrote: Mon Feb 10, 2020 6:26 pm I mean when I don't need a 16x relay but for example 8x or 12x.
Ok, I think I saw some of yours project in the forum.
while you have connected Esp8266 and the two Mcp23017
It doesn't matter how many channels you use (2-6-8-12), the others you leave disabled in the cloud,
You can also ask me for a specific number of channels. :lol:
bulek68
elmaya wrote: Mon Feb 10, 2020 6:35 pm
Okay, you are right. My questions were theoretical.
Is there one or another possibility.
I'm sorry, I won't take your time anymore.
elmaya
possibility of what?
and I have a lot of time to assist you.
bulek68
In your project you used 4 modules with 4 relays.
I know that in cloud I can run 2,4,8,16 channels.
I asked if I would physically connect 2 modules with 4 relays then this construction would still work.
Return to “Ideas and concepts”
