8 blinds 16 buttons
elmaya
Maniek913 wrote: Sat Mar 28, 2020 12:35 pm I have temporarily changed connections. I didn't ruin anything ....
Effect -Wow :o
The most important changes are:
1. Rapid communication with the module - both in AP mode and with the server.
2.All functions work great, no jams.
3. Channel groups are finally working!
Thank you so much for a good job.
I only lack a thermometer - previously I had it in this place.
controlling 8 blinds we are not going to waste time reading the temperature.
Although the temperature is a classic in Supla DIY, I will not add to this Soft.
Maniek913
I understand.
The system works great.
Can you share the code?
elmaya
there you have the code, now I'm not your friend anymore. :lol:
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define CUSTOMSUPLA_CPP  // 1.6.1 Custom
#include "CustomSupla.h"
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h> //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <Ticker.h>
#include <ESP8266HTTPUpdateServer.h>
extern "C"
#include "user_interface.h"
#define status_led 16 //D0
#define wificonfig_pin 0 // D3
WiFiClient client;
Ticker ticker;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
Adafruit_MCP23017 mcp;
Adafruit_MCP23017 mcp2;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;               // ---------------------- config delay 10 seconds ---------------------------
char Supla_server[40];
char Location_id[15];
char Location_Pass[20];
char Supla_name[51];
char update_username[21];
char update_password[21];
char Supla_status[51];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout;
bool pr_wifi = true;
byte input=0;
byte btnlast_val=0;
unsigned long btnlast_time;
bool Bu_A0;bool Bu_A1;bool Bu_A2;bool Bu_A3;bool Bu_A4;bool Bu_A5;bool Bu_A6;bool Bu_A7;
byte input2=0;
byte btnlast_val2=0;
unsigned long btnlast_time2;
bool Bu_B0;bool Bu_B1;bool Bu_B2;bool Bu_B3;bool Bu_B4;bool Bu_B5;bool Bu_B6;bool Bu_B7;
int s;
unsigned long wifi_checkDelay = 60000;
unsigned long wifimilis;
bool tikOn = false;
int inttmp0 = -1;
bool savers0 = false;
int inttmp1 = -1;
bool savers1 = false;
int inttmp2 = -1;
bool savers2 = false;
int inttmp3 = -1;
bool savers3 = false;
int inttmp4 = -1;
bool savers4 = false;
int inttmp5 = -1;
bool savers5 = false;
int inttmp6 = -1;
bool savers6 = false;
int inttmp7 = -1;
bool savers7 = false;
void supla_rs_SavePosition(int channelNumber, int position) {
   switch(channelNumber){
   case 0:
    if ((!mcp.digitalRead(0))&&(!mcp.digitalRead(8)) || (position <= 100 ) || (position >= 10100)){
      inttmp0 = position;
      savers0 = true;
     } break;
   case 1:
    if ((!mcp.digitalRead(1))&&(!mcp.digitalRead(9)) || (position <= 100 ) || (position >= 10100)){
      inttmp1 = position;
      savers1 = true;
     } break;
  case 2:
    if ((!mcp.digitalRead(2))&&(!mcp.digitalRead(10)) || (position <= 100 ) || (position >= 10100)){
      inttmp2 = position;
      savers2 = true;
     } break;
   case 3:
    if ((!mcp.digitalRead(3))&&(!mcp.digitalRead(11)) || (position <= 100 ) || (position >= 10100)){
      inttmp3 = position;
      savers3 = true;
     } break;
   case 4:
    if ((!mcp.digitalRead(4))&&(!mcp.digitalRead(12)) || (position <= 100 ) || (position >= 10100)){
      inttmp4 = position;
      savers4 = true;
     } break;
   case 5:
    if ((!mcp.digitalRead(5))&&(!mcp.digitalRead(13)) || (position <= 100 ) || (position >= 10100)){
      inttmp5 = position;
      savers5 = true;
     } break;
  case 6:
    if ((!mcp.digitalRead(6))&&(!mcp.digitalRead(14)) || (position <= 100 ) || (position >= 10100)){
      inttmp6 = position;
      savers6 = true;
     } break;
   case 7:
    if ((!mcp.digitalRead(7))&&(!mcp.digitalRead(15)) || (position <= 100 ) || (position >= 10100)){
      inttmp7 = position;
      savers7 = true;
     } break;
void supla_rs_SendPosition(){
  unsigned int R_pos = 0;
         EEPROM.get(1, R_pos);
      CustomSupla.channelRSValueChanged(0, (R_pos-100)/100, 0, 1);
         EEPROM.get(5, R_pos);
      CustomSupla.channelRSValueChanged(1, (R_pos-100)/100, 0, 1);
         EEPROM.get(11, R_pos);
      CustomSupla.channelRSValueChanged(2, (R_pos-100)/100, 0, 1);
         EEPROM.get(15, R_pos);
      CustomSupla.channelRSValueChanged(3, (R_pos-100)/100, 0, 1);
         EEPROM.get(21, R_pos);
      CustomSupla.channelRSValueChanged(4, (R_pos-100)/100, 0, 1);
         EEPROM.get(25, R_pos);
      CustomSupla.channelRSValueChanged(5, (R_pos-100)/100, 0, 1);
         EEPROM.get(31, R_pos);
      CustomSupla.channelRSValueChanged(6, (R_pos-100)/100, 0, 1);
         EEPROM.get(35, R_pos);
      CustomSupla.channelRSValueChanged(7, (R_pos-100)/100, 0, 1);
void supla_rs_LoadPosition(int channelNumber, int *position) {
   case 0:
      *position = R_pos;
      Serial.print("read position 0: ");
      Serial.println(*position);
    break;
    case 1:
      *position = R_pos;
      Serial.print("read position 1: ");
    break;
    case 2:
      *position = R_pos;
      Serial.print("read position 2: ");
    break;
    case 3:
      *position = R_pos;
      Serial.print("read position 3: ");
    break;
    case 4:
      *position = R_pos;
      Serial.print("read position 4: ");
    break;
    case 5:
      *position = R_pos;
      Serial.print("read position 5: ");
    break;
    case 6:
      *position = R_pos;
      Serial.print("read position 6: ");
    break;
    case 7:
      *position = R_pos;
      Serial.print("read position 7: ");
    break;
void supla_rs_SaveSettings(int channelNumber, unsigned int full_opening_time, unsigned int full_closing_time) {
   case 0:
       EEPROM.put(50, full_opening_time);
       Serial.println("R0 full opening time Saved");
       EEPROM.put(55, full_closing_time);
       Serial.println("R0 full closing time Saved");
       EEPROM.commit();
  break;
  case 1:
       EEPROM.put(60, full_opening_time);
       Serial.println("R1 full opening time Saved");
       EEPROM.put(65, full_closing_time);
       Serial.println("R1 full closing time Saved");
       EEPROM.commit();
  break;
  case 2:
       EEPROM.put(70, full_opening_time);
       Serial.println("R2 full opening time Saved");
       EEPROM.put(75, full_closing_time);
       Serial.println("R2 full closing time Saved");
       EEPROM.commit();
  break;
  case 3:
       EEPROM.put(80, full_opening_time);
       Serial.println("R3 full opening time Saved");
       EEPROM.put(85, full_closing_time);
       Serial.println("R3 full closing time Saved");
       EEPROM.commit();
  break;
  case 4:
       EEPROM.put(90, full_opening_time);
       Serial.println("R4 full opening time Saved");
       EEPROM.put(95, full_closing_time);
       Serial.println("R4 full closing time Saved");
       EEPROM.commit();
  break;
  case 5:
       EEPROM.put(100, full_opening_time);
       Serial.println("R5 full opening time Saved");
       EEPROM.put(105, full_closing_time);
       Serial.println("R5 full closing time Saved");
       EEPROM.commit();
  break;
  case 6:
       EEPROM.put(110, full_opening_time);
       Serial.println("R6 full opening time Saved");
       EEPROM.put(115, full_closing_time);
       Serial.println("R6 full closing time Saved");
       EEPROM.commit();
  break;
  case 7:
       EEPROM.put(120, full_opening_time);
       Serial.println("R7 full opening time Saved");
       EEPROM.put(125, full_closing_time);
       Serial.println("R7 full closing time Saved");
       EEPROM.commit();
  break;
void supla_rs_LoadSettings(int channelNumber, unsigned int *full_opening_time, unsigned int *full_closing_time) {
  unsigned int R_opening_time = 0;
  unsigned int R_closing_time = 0;
  case 0:
   EEPROM.get(50, R_opening_time);
    EEPROM.get(55, R_closing_time);
    *full_opening_time = R_opening_time;
    *full_closing_time = R_closing_time;
    Serial.print("read R0--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 1:
   EEPROM.get(60, R_opening_time);
    EEPROM.get(65, R_closing_time);
    Serial.print("read R1--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 2:
   EEPROM.get(70, R_opening_time);
    EEPROM.get(75, R_closing_time);
    Serial.print("read R2--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 3:
   EEPROM.get(80, R_opening_time);
    EEPROM.get(85, R_closing_time);
    Serial.print("read R3--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 4:
   EEPROM.get(90, R_opening_time);
    EEPROM.get(95, R_closing_time);
    Serial.print("read R4--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 5:
   EEPROM.get(100, R_opening_time);
    EEPROM.get(105, R_closing_time);
    Serial.print("read R5--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 6:
   EEPROM.get(110, R_opening_time);
    EEPROM.get(115, R_closing_time);
    Serial.print("read R6--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
  case 7:
   EEPROM.get(120, R_opening_time);
    EEPROM.get(125, R_closing_time);
    Serial.print("read R7--channel: ");Serial.print((channelNumber));Serial.print(" opening_time ");Serial.print((*full_opening_time));Serial.print(" closing_time ");Serial.println((*full_closing_time));
  break;
void tick(){
  int state = digitalRead(status_led);
  digitalWrite(status_led, !state);
void saveConfigCallback () {
  shouldSaveConfig = true;
void ondemandwifiCallback () {
  ticker.attach(0.2, tick);
  CustomSupla.StopTimer();
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 40);
  WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 20);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManagerParameter custom_Supla_status("status", "Supla Last State (readonly)", Supla_status, 51,"readonly");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.addParameter(&custom_Supla_status);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality(5);
  wifiManager.setConfigPortalTimeout(timeout);
  if (!wifiManager.startConfigPortal("Supla 8P")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
    WiFi.softAPdisconnect(true);
    if (shouldSaveConfig) {
    Serial.println("saving config");
    DynamicJsonBuffer jsonBuffer;
    JsonObject& json = jsonBuffer.createObject();
    json["Supla_server"] = Supla_server;
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    File configFile = SPIFFS.open("/configV2.json", "w");
    if (!configFile) {Serial.println("failed to open config file for writing");}
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    ticker.detach();
    digitalWrite(status_led, HIGH);
    ESP.restart();
    delay(5000);
  CustomSupla.StartTimer();
      ticker.detach();
      tikOn = false;
void mcp2_iterate() {
  unsigned long now = millis();
        input = mcp2.readGPIO(0);
        if (input != btnlast_val && now - btnlast_time ) {
           btnlast_val = input;
           btnlast_time = now+100;
    if (input == 255) { Bu_A7 = HIGH;Bu_A6 = HIGH;Bu_A5 = HIGH;Bu_A4 = HIGH;Bu_A3 = HIGH;Bu_A2 = HIGH;Bu_A1 = HIGH;Bu_A0 = HIGH;
    } else {
      Serial.print("Mcp 2A input ");  Serial.println(input);
      delay(75);
      if( (bitRead(input, 0)) != (Bu_A0)){   // in A0
        Bu_A0 = bitRead(input, 0);
       if( !bitRead(input, 0)){
        if ( CustomSupla.rollerShutterMotorIsOn(0) ) {
          Serial.println("0 Stop");
            CustomSupla.rollerShutterStop(0);
        } else {
          Serial.println("0 Shut");
            CustomSupla.rollerShutterShut(0);
      if( (bitRead(input, 1)) != (Bu_A1)){   // in A1
        Bu_A1 = bitRead(input, 1);
       if( !bitRead(input, 1)){
        if ( CustomSupla.rollerShutterMotorIsOn(1) ) {
          Serial.println("1 Stop");
            CustomSupla.rollerShutterStop(1);
        } else {
          Serial.println("1 Shut");
            CustomSupla.rollerShutterShut(1);
      if( (bitRead(input, 2)) != (Bu_A2)){   // in A2
        Bu_A2 = bitRead(input, 2);
       if( !bitRead(input, 2)){
        if ( CustomSupla.rollerShutterMotorIsOn(2) ) {
          Serial.println("2 Stop");
            CustomSupla.rollerShutterStop(2);
        } else {
          Serial.println("2 Shut");
            CustomSupla.rollerShutterShut(2);
      if( (bitRead(input, 3)) != (Bu_A3)){   // in A3
        Bu_A3 = bitRead(input, 3);
       if( !bitRead(input, 3)){
        if ( CustomSupla.rollerShutterMotorIsOn(3) ) {
          Serial.println("3 Stop");
            CustomSupla.rollerShutterStop(3);
        } else {
          Serial.println("3 Shut");
            CustomSupla.rollerShutterShut(3);
      if( (bitRead(input, 4)) != (Bu_A4)){   // in A4
        Bu_A4 = bitRead(input, 4);
       if( !bitRead(input, 4)){
        if ( CustomSupla.rollerShutterMotorIsOn(4) ) {
          Serial.println("4 Stop");
            CustomSupla.rollerShutterStop(4);
        } else {
          Serial.println("4 Shut");
            CustomSupla.rollerShutterShut(4);
      if( (bitRead(input, 5)) != (Bu_A5)){   // in A5
        Bu_A5 = bitRead(input, 5);
       if( !bitRead(input, 5)){
        if ( CustomSupla.rollerShutterMotorIsOn(5) ) {
          Serial.println("5 Stop");
            CustomSupla.rollerShutterStop(5);
        } else {
          Serial.println("5 Shut");
            CustomSupla.rollerShutterShut(5);
       if( (bitRead(input, 6)) != (Bu_A6)){   // in A6
        Bu_A6 = bitRead(input, 6);
       if( !bitRead(input, 6)){
        if ( CustomSupla.rollerShutterMotorIsOn(6) ) {
          Serial.println("6 Stop");
            CustomSupla.rollerShutterStop(6);
        } else {
          Serial.println("6 Shut");
            CustomSupla.rollerShutterShut(6);
      if( (bitRead(input, 7)) != (Bu_A7)){   // in A7
        Bu_A7 = bitRead(input, 7);
       if( !bitRead(input, 7)){
        if ( CustomSupla.rollerShutterMotorIsOn(7) ) {
          Serial.println("7 Stop");
            CustomSupla.rollerShutterStop(7);
        } else {
          Serial.println("7 Shut");
            CustomSupla.rollerShutterShut(7);
         input2= mcp2.readGPIO(1);
        if (input2 != btnlast_val2 && now - btnlast_time2 ) {
           btnlast_val2 = input2;
           btnlast_time2 = now+100;
    if (input2 == 255) { Bu_B0 = HIGH;Bu_B1 = HIGH;Bu_B2 = HIGH;Bu_B3 = HIGH;Bu_B4 = HIGH;Bu_B5 = HIGH;Bu_B6 = HIGH;Bu_B7 = HIGH;
    } else {
      Serial.print("Mcp 2B input ");  Serial.println(input2);
      delay(75);
       if( (bitRead(input2, 0)) != (Bu_B0)){   // in B0
        Bu_B0 = bitRead(input2, 0);
       if( !bitRead(input2, 0)){
        } else {
          Serial.println("0 Reveal");
            CustomSupla.rollerShutterReveal(0);;
      if( (bitRead(input2, 1)) != (Bu_B1)){   // in B1
        Bu_B1 = bitRead(input2, 1);
       if( !bitRead(input2, 1)){
        } else {
          Serial.println("1 Reveal");
            CustomSupla.rollerShutterReveal(1);
     if( (bitRead(input2, 2)) != (Bu_B2)){   // in B2
        Bu_B2 = bitRead(input2, 2);
      if( !bitRead(input2, 2)){
        } else {
          Serial.println("2 Reveal");
            CustomSupla.rollerShutterReveal(2);
     if( (bitRead(input2, 3)) != (Bu_B3)){   // in B3
        Bu_B3 = bitRead(input2, 3);
       if( !bitRead(input2, 3)){
        } else {
          Serial.println("3 Reveal");
            CustomSupla.rollerShutterReveal(3);
     if( (bitRead(input2, 4)) != (Bu_B4)){   // in B4
        Bu_B4 = bitRead(input2, 4);
      if( !bitRead(input2, 4)){
        } else {
          Serial.println("4 Reveal");
            CustomSupla.rollerShutterReveal(4);
     if( (bitRead(input2, 5)) != (Bu_B5)){   // in B5
        Bu_B5 = bitRead(input2, 5);
      if( !bitRead(input2, 5)){
        } else {
          Serial.println("5 Reveal");
            CustomSupla.rollerShutterReveal(5);
     if( (bitRead(input2, 6)) != (Bu_B6)){   // in B6
        Bu_B6 = bitRead(input2, 6);
      if( !bitRead(input2, 6)){
        } else {
          Serial.println("6 Reveal");
            CustomSupla.rollerShutterReveal(6);
     if( (bitRead(input2, 7)) != (Bu_B7)){   // in B7
        Bu_B7 = bitRead(input2, 7);
      if( !bitRead(input2, 7)){
        } else {
          Serial.println("7 Reveal");
            CustomSupla.rollerShutterReveal(7);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
  case 0:
    if (pin == 101) {
    return mcp.digitalRead(0);
    if (pin == 102) {
    return mcp.digitalRead(8);
    } break;
  case 1:
    if (pin == 103) {
    return mcp.digitalRead(1);
    if (pin == 104) {
    return mcp.digitalRead(9);
    } break;
  case 2:
    if (pin == 105) {
    return mcp.digitalRead(2);
    if (pin == 106) {
    return mcp.digitalRead(10);
    } break;
  case 3:
    if (pin == 107) {
    return mcp.digitalRead(3);
    if (pin == 108) {
    return mcp.digitalRead(11);
    } break;
  case 4:
    if (pin == 109) {
    return mcp.digitalRead(4);
    if (pin == 110) {
    return mcp.digitalRead(12);
    } break;
  case 5:
    if (pin == 111) {
    return mcp.digitalRead(5);
    if (pin == 112) {
    return mcp.digitalRead(13);
    } break;
  case 6:
    if (pin == 113) {
    return mcp.digitalRead(6);
    if (pin == 114) {
    return mcp.digitalRead(14);
    } break;
  case 7:
    if (pin == 115) {
    return mcp.digitalRead(7);
    if (pin == 116) {
    return mcp.digitalRead(15);
    } break;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {  //------------------------------------------------  Virtual ----------------------------
  case 0:
     if (pin == 101){
       mcp.digitalWrite(0, val);
       return;
     if (pin == 102){
       mcp.digitalWrite(8, val);
       return;
     } break;
  case 1:
     if (pin == 103){
       mcp.digitalWrite(1, val);
       return;
     if (pin == 104){
       mcp.digitalWrite(9, val);
       return;
     } break;
  case 2:
     if (pin == 105){
       mcp.digitalWrite(2, val);
       return;
     if (pin == 106){
       mcp.digitalWrite(10, val);
       return;
     } break;
  case 3:
     if (pin == 107){
       mcp.digitalWrite(3, val);
       return;
     if (pin == 108){
       mcp.digitalWrite(11, val);
       return;
     } break;
  case 4:
     if (pin == 109){
       mcp.digitalWrite(4, val);
       return;
     if (pin == 110){
       mcp.digitalWrite(12, val);
       return;
     } break;
  case 5:
     if (pin == 111){
       mcp.digitalWrite(5, val);
       return;
     if (pin == 112){
       mcp.digitalWrite(13, val);
       return;
     } break;
  case 6:
     if (pin == 113){
       mcp.digitalWrite(6, val);
       return;
     if (pin == 114){
       mcp.digitalWrite(14, val);
       return;
     } break;
  case 7:
     if (pin == 115){
       mcp.digitalWrite(7, val);
       return;
     if (pin == 116){
       mcp.digitalWrite(15, val);
       return;
     } break;
  return;
void status_func(int status, const char *msg) {
  if (s != status){
     s=status;
     Serial.print("status: ");
     Serial.println(s);
    if (status != 10){
      strcpy(Supla_status, msg);
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  EEPROM.begin(1024);
  pinMode(status_led,OUTPUT);
  ticker.attach(0.8, tick);
  Wire.begin();
  Wire.setClock(400000L);
  mcp.begin(0);      // use address 0
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
  mcp.pinMode(8, OUTPUT);
  mcp.pinMode(9, OUTPUT);
  mcp.pinMode(10, OUTPUT);
  mcp.pinMode(11, OUTPUT);
  mcp.pinMode(12, OUTPUT);
  mcp.pinMode(13, OUTPUT);
  mcp.pinMode(14, OUTPUT);
  mcp.pinMode(15, OUTPUT);
  mcp2.begin(1);      // use address 1
  mcp2.pinMode(0, INPUT);mcp2.pullUp(0, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(1, INPUT);mcp2.pullUp(1, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(2, INPUT);mcp2.pullUp(2, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(3, INPUT);mcp2.pullUp(3, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(4, INPUT);mcp2.pullUp(4, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(5, INPUT);mcp2.pullUp(5, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(6, INPUT);mcp2.pullUp(6, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(7, INPUT);mcp2.pullUp(7, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(8, INPUT);mcp2.pullUp(8, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(9, INPUT);mcp2.pullUp(9, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(10, INPUT);mcp2.pullUp(10, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(11, INPUT);mcp2.pullUp(11, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(12, INPUT);mcp2.pullUp(12, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(13, INPUT);mcp2.pullUp(13, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(14, INPUT);mcp2.pullUp(14, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(15, INPUT);mcp2.pullUp(15, HIGH);  // turn on a 100K pullup internally
  if (WiFi.SSID()==""){initialConfig = true;}
   if (SPIFFS.begin()) {
    Serial.println("mounting Fs...");
    if (SPIFFS.exists("/configV2.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/configV2.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {Serial.println("\nparsed json");
          const char* configSupla_server = json["Supla_server"];if (configSupla_server != nullptr){strcpy(Supla_server, json["Supla_server"]); }else{initialConfig = true;}
          const char* configLocation_id = json["Location_id"];if (configLocation_id != nullptr){strcpy(Location_id, json["Location_id"]); }else{initialConfig = true;}
          const char* configLocation_Pass = json["Location_Pass"];if (configLocation_Pass != nullptr){strcpy(Location_Pass, json["Location_Pass"]); }else{initialConfig = true;}
          const char* configSupla_name = json["Supla_name"];if (configSupla_name != nullptr){strcpy(Supla_name, json["Supla_name"]); }else{initialConfig = true;}
          const char* configupdate_username = json["update_username"];if (configupdate_username != nullptr){strcpy(update_username, json["update_username"]); }else{initialConfig = true;}
          const char* configupdate_password = json["update_password"];if (configupdate_password != nullptr){strcpy(update_password, json["update_password"]); }else{initialConfig = true;}
        } else {
          Serial.println("failed to load json config");
   WiFi.mode(WIFI_STA);
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 0], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 0]};
  CustomSupla.addRollerShutterRelays(101, 102, false);
  CustomSupla.addRollerShutterRelays(103, 104, false);
  CustomSupla.addRollerShutterRelays(105, 106, false);
  CustomSupla.addRollerShutterRelays(107, 108, false);
  CustomSupla.addRollerShutterRelays(109, 110, false);
  CustomSupla.addRollerShutterRelays(111, 112, false);
  CustomSupla.addRollerShutterRelays(113, 114, false);
  CustomSupla.addRollerShutterRelays(115, 116, false);
  CustomSupla.setDigitalReadFuncImpl(&supla_DigitalRead);
  CustomSupla.setDigitalWriteFuncImpl(&suplaDigitalWrite);
  CustomSupla.setStatusFuncImpl(&status_func);
  CustomSupla.setRollerShutterFuncImpl(&supla_rs_SavePosition, &supla_rs_LoadPosition, &supla_rs_SaveSettings, &supla_rs_LoadSettings);
  CustomSupla.setName(Supla_name);
  wifi_station_set_hostname(Supla_name);
  int LocationID = atoi(Location_id);
  CustomSupla.begin(GUID,              // Global Unique Identifier
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
void loop() {
  int C_W_read = Bu_A0;//digitalRead(wificonfig_pin);  // ---------------------let's read the status of the Gpio to start wificonfig ---------------------
   if (C_W_read != last_C_W_state) {  time_last_C_W_change = millis();}
    if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
        if (C_W_state == LOW) {
         mcp.writeGPIOAB(0);
          ondemandwifiCallback ();} } }
           last_C_W_state = C_W_read;
  if (initialConfig){
       EEPROM.put(50, 0);EEPROM.put(55, 0);EEPROM.put(60, 0);EEPROM.put(65, 0);EEPROM.put(70, 0);
       EEPROM.put(75, 0); EEPROM.put(80, 0);EEPROM.put(85, 0); EEPROM.put(90, 0);EEPROM.put(95, 0);
       EEPROM.put(100, 0);EEPROM.put(105, 0); EEPROM.put(110, 0);EEPROM.put(115, 0); EEPROM.put(120, 0);
       EEPROM.put(125, 0);EEPROM.commit();  // CLR EEprom
     ondemandwifiCallback () ;
      if (savers0){Serial.print("write position 0:");Serial.println(inttmp0);EEPROM.put( 1, inttmp0);EEPROM.commit();savers0 = false;}
      if (savers1){Serial.print("write position 1:");Serial.println(inttmp1);EEPROM.put( 5, inttmp1);EEPROM.commit();savers1 = false;}
      if (savers2){Serial.print("write position 2:");Serial.println(inttmp2);EEPROM.put(11, inttmp2);EEPROM.commit();savers2 = false;}
      if (savers3){Serial.print("write position 3:");Serial.println(inttmp3);EEPROM.put(15, inttmp3);EEPROM.commit();savers3 = false;}
      if (savers4){Serial.print("write position 4:");Serial.println(inttmp4);EEPROM.put(21, inttmp4);EEPROM.commit();savers4 = false;}
      if (savers5){Serial.print("write position 5:");Serial.println(inttmp5);EEPROM.put(25, inttmp5);EEPROM.commit();savers5 = false;}
      if (savers6){Serial.print("write position 6:");Serial.println(inttmp6);EEPROM.put(31, inttmp6);EEPROM.commit();savers6 = false;}
      if (savers7){Serial.print("write position 7:");Serial.println(inttmp7);EEPROM.put(35, inttmp7);EEPROM.commit();savers7 = false;}
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
    pr_wifi = true;
    yield();
  else if ((WiFi.status() == WL_CONNECTED)  && (pr_wifi)){
    Serial.println("");
    Serial.println("CONNECTED");
    Serial.print("local IP: ");
    Serial.print("subnetMask: ");
    Serial.print("gatewayIP: ");
    long rssi = WiFi.RSSI();
    Serial.print("Signal Strength (RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
    pr_wifi = false;
    ticker.detach();
    httpUpdater.setup(&httpServer, "/update", update_username, update_password);
    httpServer.begin();
   } else { httpServer.handleClient();
  CustomSupla.iterate();
  delay(25);
  mcp2_iterate();
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
    case 17:      // -----     STATUS_REGISTERED_AND_READY
      if (tikOn){
      ticker.detach();
      supla_rs_SendPosition();
      tikOn = false;}
     break;
    case 9:      // --------------------- DISCONNECTED  ----------------------
     if (!tikOn){
      tikOn = true;
     break;
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
CustomSuplaCallbacks supla_arduino_get_callbacks(void) {
          CustomSuplaCallbacks cb;
          cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
 unsigned long ahora = millis();
  if (ahora >= wifimilis)  {
  Serial.println("CONNECTING WIFI");
  WiFi.begin();
  yield();
  wifimilis = (millis() + wifi_checkDelay) ;
supla_8P_16B_Custom.rar
Gucio2607.
Can someone please confirm if I can use these components for this project?
#Aliexpress £1.06 5%OFF | MCP23017 I2C Interface 16bit I/O Extension Module Pin Board IIC to GIPO Converter 25mA1 Drive Power Supply for Arduino and C51
https://a.aliexpress.com/_BO0y3h
#Aliexpress £0.55 | DC5V 1 2 4 8 Channel Relay Module with Optocoupler. Relay Output 1 2 4 8 way Relay Module for arduino Raspberry Pi
https://a.aliexpress.com/_BOgWvl
Zainstalowane:
elmaya
Mcp23017 is fine.
the relay is not, it is negative trigger and it is not compatible.
use something like this:
https://pl.aliexpress.com/item/32742580 ... b1f7540-12
LukaszH
Very nice software and I'm just testing a bit :)
It is normal that on a server when I set on 5 sec close/open time it is actually 5 sec from the application level but the button works like 2x longer?
I have additional a question is it possible to change the buttons so that the roller blind only works when the button is pressed (I don't know we can say monostable/bistable)? I also would like to control the blind angle and I need the fast response time (0.1-0.4 sec). Now after pressing the button, the shutter operates until the button is pressed again, which practically makes it impossible to set the desired angle.. The perfect will be if from aplication point of view time will be very fast as well ?
elmaya
LukaszH wrote: Sat Apr 11, 2020 2:41 pm Very nice software and I'm just testing a bit :)
that behavior is normal and intentional, with the buttons it works for a longer time.
I have no intention of changing the operation of the buttons, in real life no shutter is so fast.
use a motor with a gearbox to set the angle, you will have a much more precise adjustment or you can also use a servo controlled as a dimmer to set the angle
viewtopic.php?f=9&t=5925
LukaszH
I don't know proper name for those kind of blinds: https://www.youtube.com/watch?v=cHiUQI5irk4. There is the same motor as in standard blinds and they don't have version with servo drives. In polsih: zamiast rolet chcę użyć żaluzje :)
Here, most of the time, the blinds are lowered position and only "the slat" angle is controlled (full opening is about 1.5 sec - I am talking about only the perpendicular position of the slats). I would like to try to change the code so that the button works only when pressed, but it's probably too difficult for me (too complicated soft). Maybe you can tell which lines from the code are responsible for it if it does not mean rebuilding half of the software?
elmaya
This is the part of the code referring to the buttons:
    } else {
      delay(75);
        if ( SuplaDevice.rollerShutterMotorIsOn(0) ) {
            SuplaDevice.rollerShutterStop(0);
        } else {
            SuplaDevice.rollerShutterShut(0);
        if ( SuplaDevice.rollerShutterMotorIsOn(1) ) {
            SuplaDevice.rollerShutterStop(1);
        } else {
            SuplaDevice.rollerShutterShut(1);
        if ( SuplaDevice.rollerShutterMotorIsOn(2) ) {
            SuplaDevice.rollerShutterStop(2);
        } else {
            SuplaDevice.rollerShutterShut(2);
        if ( SuplaDevice.rollerShutterMotorIsOn(3) ) {
            SuplaDevice.rollerShutterStop(3);
        } else {
            SuplaDevice.rollerShutterShut(3);
        if ( SuplaDevice.rollerShutterMotorIsOn(4) ) {
            SuplaDevice.rollerShutterStop(4);
        } else {
            SuplaDevice.rollerShutterShut(4);
        if ( SuplaDevice.rollerShutterMotorIsOn(5) ) {
            SuplaDevice.rollerShutterStop(5);
        } else {
            SuplaDevice.rollerShutterShut(5);
        if ( SuplaDevice.rollerShutterMotorIsOn(6) ) {
            SuplaDevice.rollerShutterStop(6);
        } else {
            SuplaDevice.rollerShutterShut(6);
        if ( SuplaDevice.rollerShutterMotorIsOn(7) ) {
            SuplaDevice.rollerShutterStop(7);
        } else {
            SuplaDevice.rollerShutterShut(7);
    } else {
      delay(75);
        } else {
            SuplaDevice.rollerShutterReveal(0);;
        } else {
            SuplaDevice.rollerShutterReveal(1);
        } else {
            SuplaDevice.rollerShutterReveal(2);
        } else {
            SuplaDevice.rollerShutterReveal(3);
        } else {
            SuplaDevice.rollerShutterReveal(4);
        } else {
            SuplaDevice.rollerShutterReveal(5);
        } else {
            SuplaDevice.rollerShutterReveal(6);
        } else {
            SuplaDevice.rollerShutterReveal(7);
I anticipate that with a so short duration of movement with this system the precision will be none.
Do you have any documentation about the blinds in English, Spanish or German?
LukaszH
elmaya wrote: Sun Apr 12, 2020 9:53 am This is the part of the code referring to the buttons:
    } else {
      delay(75);
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
    } else {
      delay(75);
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
        } else {
I think I found the correct name: External venetian blind :D
It's a bit hard to find the specification of the control and drive but in Polish I found it to be the same somfy drive like in norml blinds but controlled with relatively short signals (200ms-400ms). Generally Incan by Espablo is ok (from GUI is posible change monostable/bistable - I use bistable) and for buttons is probably only debounce time ~ 200ms from application is around 0,6 sek. but your software is for 8 blinds what is perfect for me :D
However, when it comes to precision, they are still blinds, so it probably does not have to be such an ideal angle setting, so that the position can be changed more or less (trial and error method). Most cases are ajar to 90 degrees and closed.
I will try to figure out these buttons but for now code it looks like an enigme :roll:
link for english description: https://anwis.pl/en/facade-shutters
Return to “Ideas and concepts”
