Nie mogę dołączyć urządzeń
Domyślnie mysqldump nie robi zrzutu procedur. Musisz je teraz wszystkie ręcznie na nowo utworzyć.
slavo_s2k
Gdzie i w jaki sposób to uzupełnić?
Skąd wziąć listę? To są jakieś standardowe?
-- MySQL dump 10.17  Distrib 10.3.22-MariaDB, for debian-linux-gnu (x86_64)
-- Host: db    Database: supla_test
-- Server version	10.4.12-MariaDB-1:10.4.12+maria~bionic
/*!40103 SET @OLD_TIME_ZONE=@@TIME_ZONE */;
/*!40103 SET TIME_ZONE='+00:00' */;
/*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
/*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
/*!40111 SET @OLD_SQL_NOTES=@@SQL_NOTES, SQL_NOTES=0 */;
-- Dumping routines for database 'supla_test'
/*!50003 SET @saved_cs_client      = @@character_set_client */ ;
/*!50003 SET @saved_cs_results     = @@character_set_results */ ;
/*!50003 SET @saved_col_connection = @@collation_connection */ ;
/*!50003 SET character_set_client  = utf8mb4 */ ;
/*!50003 SET character_set_results = utf8mb4 */ ;
/*!50003 SET collation_connection  = utf8mb4_general_ci */ ;
/*!50003 SET @saved_sql_mode       = @@sql_mode */ ;
/*!50003 SET sql_mode              = 'STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION' */ ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_channel`(IN `_type` INT, IN `_func` INT, IN `_param1` INT, IN `_param2` INT, IN `_param3` INT,
IN `_user_id` INT, IN `_channel_number` INT, IN `_iodevice_id` INT, IN `_flist` INT, IN `_flags` INT)
    NO SQL
BEGIN
INSERT INTO `supla_dev_channel` (`type`, `func`, `param1`, `param2`, `param3`, `user_id`, `channel_number`,
`iodevice_id`, `flist`, `flags`)
VALUES (_type, _func, _param1, _param2, _param3, _user_id, _channel_number, _iodevice_id, _flist, _flags);
END ;;
DELIMITER ;
/*!50003 SET sql_mode              = @saved_sql_mode */ ;
/*!50003 SET character_set_client  = @saved_cs_client */ ;
/*!50003 SET character_set_results = @saved_cs_results */ ;
/*!50003 SET collation_connection  = @saved_col_connection */ ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_client`(IN `_access_id` INT(11), IN `_guid` VARBINARY(16), IN `_name` VARCHAR(100) CHARSET utf8mb4, IN `_reg_ipv4` INT(10) UNSIGNED, IN `_software_version` VARCHAR(20) CHARSET utf8, IN `_protocol_version` INT(11), IN `_user_id` INT(11), IN `_auth_key` VARCHAR(64) CHARSET utf8, OUT `_id` INT(11))
    NO SQL
BEGIN
IF EXISTS(SELECT 1 FROM `supla_user` WHERE `id` = _user_id) THEN
INSERT INTO `supla_client`(`access_id`, `guid`, `name`, `enabled`, `reg_ipv4`, `reg_date`, `last_access_ipv4`,
`last_access_date`,`software_version`, `protocol_version`, `user_id`, `auth_key`)
VALUES (_access_id, _guid, _name, 1, _reg_ipv4, UTC_TIMESTAMP(), _reg_ipv4, UTC_TIMESTAMP(), _software_version, _protocol_version,
    _user_id, _auth_key);
SELECT LAST_INSERT_ID() INTO _id;
END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_em_log_item`(IN `_channel_id` INT(11), IN `_phase1_fae` BIGINT, IN `_phase1_rae` BIGINT,
IN `_phase1_fre` BIGINT, IN `_phase1_rre` BIGINT, IN `_phase2_fae` BIGINT, IN `_phase2_rae` BIGINT, IN `_phase2_fre` BIGINT,
IN `_phase2_rre` BIGINT, IN `_phase3_fae` BIGINT, IN `_phase3_rae` BIGINT, IN `_phase3_fre` BIGINT, IN `_phase3_rre` BIGINT,
IN `_fae_balanced` BIGINT, IN `_rae_balanced` BIGINT)
    NO SQL
BEGIN
INSERT INTO `supla_em_log`(`channel_id`, `date`, `phase1_fae`, `phase1_rae`, `phase1_fre`, `phase1_rre`, `phase2_fae`,
`phase2_rae`, `phase2_fre`, `phase2_rre`, `phase3_fae`, `phase3_rae`, `phase3_fre`, `phase3_rre`, `fae_balanced`, `rae_balanced`)
VALUES (_channel_id, UTC_TIMESTAMP(), _phase1_fae, _phase1_rae, _phase1_fre, _phase1_rre,
_phase2_fae, _phase2_rae, _phase2_fre, _phase2_rre, _phase3_fae, _phase3_rae, _phase3_fre, _phase3_rre,
_fae_balanced, _rae_balanced);
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_ic_log_item`(IN `_channel_id` INT(11), IN `_counter` BIGINT, IN `_calculated_value` BIGINT)
    NO SQL
BEGIN
INSERT INTO `supla_ic_log`(`channel_id`, `date`, `counter`, `calculated_value`)
VALUES (_channel_id,UTC_TIMESTAMP(),_counter, _calculated_value);
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_iodevice`(IN `_location_id` INT(11), IN `_user_id` INT(11), IN `_guid` VARBINARY(16), IN `_name` VARCHAR(100) CHARSET utf8mb4, IN `_reg_ipv4` INT(10) UNSIGNED, IN `_software_version` VARCHAR(20), IN `_protocol_version` INT(11), IN `_product_id` SMALLINT, IN `_manufacturer_id` SMALLINT, IN `_original_location_id` INT(11), IN `_auth_key` VARCHAR(64), IN `_flags` INT(11), OUT `_id` INT(11))
    NO SQL
BEGIN
SET @mfr_id = _manufacturer_id;
IF _manufacturer_id = 0 THEN
  IF _name LIKE '%sonoff%' THEN SELECT 6 INTO @mfr_id; END IF;
  IF _name LIKE 'NICE %' THEN SELECT  5 INTO @mfr_id; END IF;
  IF _name LIKE 'ZAMEL %' THEN SELECT 4 INTO @mfr_id; END IF;
END IF;
INSERT INTO `supla_iodevice`(`location_id`, `user_id`, `guid`, `name`, `enabled`, `reg_date`, `reg_ipv4`, `last_connected`, `last_ipv4`,
`software_version`, `protocol_version`, `manufacturer_id`, `product_id`, `original_location_id`, `auth_key`, `flags`)
VALUES (_location_id, _user_id, _guid, _name, 1, UTC_TIMESTAMP(), _reg_ipv4, UTC_TIMESTAMP(), _reg_ipv4, _software_version,
    _protocol_version, @mfr_id, _product_id, _original_location_id, _auth_key, _flags);
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_temperature_log_item`(IN `_channel_id` INT(11), IN `_temperature` DECIMAL(8,4))
    NO SQL
BEGIN
INSERT INTO `supla_temperature_log`(`channel_id`, `date`, `temperature`) VALUES (_channel_id,UTC_TIMESTAMP(),_temperature);
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_temphumidity_log_item`(IN `_channel_id` INT(11), IN `_temperature` DECIMAL(8,4),
IN `_humidity` DECIMAL(8,4))
    NO SQL
BEGIN
INSERT INTO `supla_temphumidity_log`(`channel_id`, `date`, `temperature`, `humidity`)
VALUES (_channel_id,UTC_TIMESTAMP(),_temperature, _humidity);
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_add_thermostat_log_item`(IN `_channel_id` INT(11), IN `_measured_temperature` DECIMAL(5,2), IN `_preset_temperature` DECIMAL(5,2), IN `_on` TINYINT)
    NO SQL
BEGIN INSERT INTO `supla_thermostat_log`(`channel_id`, `date`, `measured_temperature`, `preset_temperature`, `on`) VALUES (_channel_id,UTC_TIMESTAMP(),_measured_temperature, _preset_temperature, _on); END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_get_device_firmware_url`(IN `device_id` INT, IN `platform` TINYINT, IN `fparam1` INT, IN `fparam2` INT, IN `fparam3` INT, IN `fparam4` INT, OUT `protocols` TINYINT, OUT `host` VARCHAR(100), OUT `port` INT, OUT `path` VARCHAR(100))
    NO SQL
BEGIN
                SET @protocols = 0;
                SET @host = '';
                SET @port = 0;
                SET @path = '';
                SET @fparam1 = fparam1;
                SET @fparam2 = fparam2;
                SET @platform = platform;
                SET @device_id = device_id;
                INSERT INTO `esp_update_log`(`date`, `device_id`, `platform`, `fparam1`, `fparam2`, `fparam3`, `fparam4`) VALUES (NOW(),device_id,platform,fparam1,fparam2,fparam3,fparam4);
                SELECT u.`protocols`, u.`host`, u.`port`, u.`path` INTO @protocols, @host, @port, @path FROM supla_iodevice AS d, esp_update AS u WHERE d.id = @device_id AND u.`platform` = @platform AND u.`fparam1` = @fparam1 AND u.`fparam2` = @fparam2 AND u.`device_name` = d.name AND u.`latest_software_version` != d.`software_version` AND ( u.`device_id` = 0 OR u.`device_id` = device_id ) LIMIT 1;
                SET protocols = @protocols;
                SET host = @host;
                SET port = @port;
                SET path = @path;
            END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_oauth_add_client_for_app`(IN `_random_id` VARCHAR(255) CHARSET utf8,
IN `_secret` VARCHAR(255) CHARSET utf8, OUT `_id` INT(11))
    NO SQL
BEGIN
SET @lck = 0;
SET @id_exists = 0;
SELECT GET_LOCK('oauth_add_client', 2) INTO @lck;
IF @lck = 1 THEN
 SELECT id INTO @id_exists FROM `supla_oauth_clients` WHERE `type` = 2 LIMIT 1;
  IF @id_exists <> 0 THEN
     SELECT @id_exists INTO _id;
  ELSE
     INSERT INTO `supla_oauth_clients`(
         `random_id`, `redirect_uris`,
         `secret`, `allowed_grant_types`, `type`) VALUES
     (_random_id, 'a:0:{}', _secret,'a:2:{i:0;s:8:"password";i:1;s:13:"refresh_token";}',2);
     SELECT RELEASE_LOCK('oauth_add_client') INTO @lck;
  END IF;
END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_oauth_add_token_for_app`(IN `_user_id` INT(11), IN `_token` VARCHAR(255) CHARSET utf8,
IN `_expires_at` INT(11), IN `_access_id` INT(11), OUT `_id` INT(11))
    NO SQL
BEGIN
SET @client_id = 0;
SELECT `id` INTO @client_id FROM `supla_oauth_clients` WHERE `type` = 2 LIMIT 1;
IF @client_id <> 0 AND EXISTS(SELECT 1 FROM `supla_accessid` WHERE `user_id` = _user_id AND `id` = _access_id) THEN
  INSERT INTO `supla_oauth_access_tokens`(`client_id`, `user_id`, `token`, `expires_at`, `scope`, `access_id`) VALUES
   (@client_id, _user_id, _token, _expires_at, 'channels_r channels_files', _access_id);
END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_on_channeladded`(IN `_device_id` INT, IN `_channel_id` INT)
    NO SQL
BEGIN
                SET @type = NULL;
                SELECT type INTO @type FROM supla_dev_channel WHERE `func` = 0 AND id = _channel_id;
                IF @type = 3000 THEN
                    UPDATE supla_dev_channel SET `func` = 40 WHERE id = _channel_id;
                END IF;
            END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_on_newclient`(IN `_client_id` INT)
    NO SQL
BEGIN
			END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_on_newdevice`(IN `_device_id` INT)
    MODIFIES SQL DATA
BEGIN
            END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_set_channel_caption`(IN `_user_id` INT, IN `_channel_id` INT, IN `_caption` VARCHAR(100) CHARSET utf8mb4)
    NO SQL
UPDATE supla_dev_channel SET caption = _caption WHERE id = _channel_id AND user_id = _user_id ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_set_channel_function`(IN `_user_id` INT, IN `_channel_id` INT, IN `_func` INT)
    NO SQL
UPDATE supla_dev_channel SET func = _func WHERE id = _channel_id AND user_id = _user_id AND type = 8000 ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_set_registration_enabled`(IN `user_id` INT, IN `iodevice_sec` INT, IN `client_sec` INT)
    NO SQL
BEGIN IF iodevice_sec >= 0 THEN SET @date = NULL; IF iodevice_sec > 0 THEN SET @date = DATE_ADD(UTC_TIMESTAMP, INTERVAL iodevice_sec SECOND); END IF; UPDATE supla_user SET iodevice_reg_enabled = @date WHERE id = user_id; END IF; IF client_sec >= 0 THEN SET @date = NULL; IF client_sec > 0 THEN SET @date = DATE_ADD(UTC_TIMESTAMP, INTERVAL client_sec SECOND); END IF; UPDATE supla_user SET client_reg_enabled = @date WHERE id = user_id; END IF; END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_amazon_alexa`(IN `_access_token` VARCHAR(1024) CHARSET utf8, IN `_refresh_token` VARCHAR(1024) CHARSET utf8, IN `_expires_in` INT, IN `_user_id` INT)
    NO SQL
BEGIN UPDATE supla_amazon_alexa SET `access_token` = _access_token, `refresh_token` = _refresh_token, `expires_at` = DATE_ADD(UTC_TIMESTAMP(), INTERVAL _expires_in second) WHERE `user_id` = _user_id; END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_channel_value`(
    IN `_id` INT,
    IN `_user_id` INT,
    IN `_value` VARBINARY(8),
    IN `_validity_time_sec` INT
    NO SQL
BEGIN
    IF _validity_time_sec > 0 THEN
        SET @valid_to = DATE_ADD(UTC_TIMESTAMP(), INTERVAL _validity_time_sec SECOND);
        INSERT INTO `supla_dev_channel_value` (`channel_id`, `user_id`, `update_time`, `valid_to`, `value`)
          VALUES(_id, _user_id, UTC_TIMESTAMP(), @valid_to, _value)
        ON DUPLICATE KEY UPDATE `value` = _value, update_time = UTC_TIMESTAMP(), valid_to = @valid_to;
    ELSE
        DELETE FROM `supla_dev_channel_value` WHERE `channel_id` = _id;
    END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_client`(IN `_access_id` INT(11), IN `_name` VARCHAR(100) CHARSET utf8mb4, IN `_last_ipv4` INT(10) UNSIGNED, IN `_software_version` VARCHAR(20) CHARSET utf8, IN `_protocol_version` INT(11), IN `_auth_key` VARCHAR(64) CHARSET utf8, IN `_id` INT(11))
    NO SQL
BEGIN
UPDATE `supla_client`
SET
`access_id` = _access_id,
`name` = _name,
`last_access_date` = UTC_TIMESTAMP(),
`last_access_ipv4` = _last_ipv4,
`software_version` = _software_version,
`protocol_version` = _protocol_version WHERE `id` = _id;
IF _auth_key IS NOT NULL THEN
  SET `auth_key` = _auth_key WHERE `id` = _id AND `auth_key` IS NULL;
END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_google_home`(IN `_access_token` VARCHAR(255) CHARSET utf8, IN `_user_id` INT)
    NO SQL
BEGIN UPDATE supla_google_home SET `access_token` = _access_token WHERE `user_id` = _user_id; END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_iodevice`(IN `_name` VARCHAR(100) CHARSET utf8mb4, IN `_last_ipv4` INT(10) UNSIGNED, IN `_software_version` VARCHAR(20) CHARSET utf8, IN `_protocol_version` INT(11), IN `_original_location_id` INT(11), IN `_auth_key` VARCHAR(64) CHARSET utf8, IN `_id` INT(11))
    NO SQL
BEGIN
UPDATE `supla_iodevice`
SET
`name` = _name,
`last_connected` = UTC_TIMESTAMP(),
`last_ipv4` = _last_ipv4,
`protocol_version` = _protocol_version,
original_location_id = _original_location_id WHERE `id` = _id;
END IF;
END ;;
DELIMITER ;
DELIMITER ;;
CREATE DEFINER=`supla`@`localhost` PROCEDURE `supla_update_state_webhook`(IN `_access_token` VARCHAR(255) CHARSET utf8, IN `_refresh_token` VARCHAR(255) CHARSET utf8, IN `_expires_in` INT, IN `_user_id` INT)
    NO SQL
BEGIN UPDATE supla_state_webhooks SET `access_token` = _access_token, `refresh_token` = _refresh_token, `expires_at` = DATE_ADD(UTC_TIMESTAMP(), INTERVAL _expires_in second) WHERE `user_id` = _user_id; END ;;
DELIMITER ;
/*!40103 SET TIME_ZONE=@OLD_TIME_ZONE */;
/*!40101 SET SQL_MODE=@OLD_SQL_MODE */;
/*!40014 SET FOREIGN_KEY_CHECKS=@OLD_FOREIGN_KEY_CHECKS */;
/*!40111 SET SQL_NOTES=@OLD_SQL_NOTES */;
-- Dump completed on 2020-12-19 19:28:33
slavo_s2k
No dobrze, tylko jak teraz mam wykorzystać ten kod ?
Wrzuć do pliku i wgraj do bazy tak jakbyś odtwarzał backup.
slavo_s2k
Tylko wtedy zapewne wyczyści mi zawartość urządzeń, które były w bazie?
Jeśli nie zrobić drop-a bazy to nic Ci nie wyczyści.
mysql -u user -p nazwabazy < plik.sql
slavo_s2k
Dobra, poszło!
Wielkie dzięki!
