Example of using DimmerBase
elmaya
dim1->setRGBW(-1, -1, -1, -1, 0);
Easiest way is to connect manual button to ESP8266 with Supla and it will send proper command to your dimmer controller.
What are the other external controllers?
RNash2000
X10 technology uses a manually operated light switch that incorporates a receiver that can also except encoded signals over the power line.  Each switch uses a unique code. Different controllers  are used to send the signals. Some switches are able to report their state back over the line, some are not. But I am using the ESP8266 to control a  transmitter that sends the signals  to a RF receiver that sends the signal over the power line. The RF is a one way signal and cannot know the state of a manually operated switch.
Supra allows me to use Alexa voice to control these lights, but it is not sending an off command to a light that was turned on manually.
I am simply using zero "brightness" to equal an off command, anything over zero is on, and dimming level is set by "brightness".
For more info on X10 see:
https://www.smarthome.com/pages/sc-what ... automation
Return to “Help”
