Wsparcie dla liczników z nakładką wM-Bus
piotrekk
mój licznik IZAR RC868
nie wiem co wpisać w sensor id i w sensor key
w GG w zakładce sensor type jest 2 razy licznik IZAR
17:05:30.240 -> Send: [53 55 50 4C 41 15 09 00 00 00 28 00 00 00 10 00 00 00 19 05 00 00 00 00 00 00 A9 B3 01 00 00 00 00 00 ]
17:05:30.240 -> Send: [53 55 50 4C 41 ]
17:05:30.428 -> Recv: [53 55 50 4C 41 15 09 00 00 00 32 00 00 00 10 00 00 00 4A 34 94 65 00 00 00 00 33 E0 0D 00 00 00 00 00 53 55 50 4C 41 ]
17:05:55.256 -> Send: [53 55 50 4C 41 15 0A 00 00 00 28 00 00 00 10 00 00 00 32 05 00 00 00 00 00 00 EB D2 01 00 00 00 00 00 ]
17:05:55.256 -> Send: [53 55 50 4C 41 ]
17:05:55.397 -> Recv: [53 55 50 4C 41 15 0A 00 00 00 32 00 00 00 10 00 00 00 63 34 94 65 00 00 00 00 04 9F 0D 00 00 00 00 00 53 55 50 4C 41 ]
17:05:59.341 -> wMBus-lib: T1 frame
17:06:07.975 -> wMBus-lib: T1 frame
17:06:07.975 -> wMBus-lib: Processing T1 A frame
17:06:07.975 -> wMBus-lib: packet ok
17:06:07.975 -> wMBus-lib: Found telegram.
17:06:07.975 -> 1944304C2ACC4F41CC01121FA22114401305EA3BF21692004D3B3B5794D8000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
17:06:08.022 -> ----------------
17:06:08.022 -> wMBus-lib: Parsing frame.
17:06:08.022 -> wMBus-lib: Formatting as string.
17:06:08.022 -> wMBus-lib: Removing helping characters.
17:06:08.022 -> wMBus-lib: Getting meter id.
17:06:08.069 -> wMBus-lib: Config for meter: 414FCC2A does not exist.
[email protected]
Has thanked: 18 times
Been thanked: 26 times
piotrekk wrote: Tue Jan 02, 2024 4:08 pm mój licznik IZAR RC868
Jako sensor ID wpisz: 414FCC2A a izar ma albo domyślny klucz albo trzeba go znać
Jesteś pewny że to IZAR? Możesz zrobić zdjęcie? Czego to jest licznik?
https://wmbusmeters.org/analyze/1944304 ... 0000000000
Twierdzi ze nieznany więc tu też nie zadziała
I sprawdzę zaraz czemu jest dwa razy.
Been thanked: 5 times
[email protected] wrote: Fri Dec 29, 2023 2:26 pm
Rozumiem, że już wszystko działa i można zmiany przerzucić na master?
piotrekk
zdjęcie z licznika
polutowałem drugi układ na pająka i też jest ten sam błąd
[email protected]
krycha88 wrote: Tue Jan 02, 2024 5:48 pm
Generalnie działa :D
Daj mi jeszcze ze dwa dni to będę miał obsługę kilku liczników gotową.
[email protected]
piotrekk wrote: Tue Jan 02, 2024 5:50 pm W załączniku zdjęcie z licznika
Dzięki, wygląda na to że jakiś nieznany jeszcze, założę issue na githubie wmbusmeters to może się coś dowiemy, ale może być , że będę potrzebowałem jeszcze jakiegoś info.
Możesz podać jeszcze jaki jest odczyt na ten moment z niego?
piotrekk
[email protected] wrote: Tue Jan 02, 2024 5:56 pm
219m3
[email protected]
https://github.com/krycha88/GUI-Generic/pull/121
piotrekk
piotrekk wrote: Tue Jan 02, 2024 5:50 pm zdjęcie z licznika
udało mi się odczytać coś takiego, niewiem co mam wpisać w sensor id i sensor key
telegram=|1944304C2ACC4F41CC01A2_4114401305A5D947EC56E899E16D58|
Auto driver : izar
Best driver : unknown 00/00
Using driver : izar 00/00
000 : 19 length (25 bytes)
001 : 44 dll-c (from meter SND_NR)
002 : 304c dll-mfct (SAP)
004 : 2acc4f41 dll-id (414fcc2a)
008 : 00 dll-version
009 : 07 dll-type (Water meter)
010 : a2 tpl-ci-field (Mfct specific)
011 C?: 4114401305A5D947EC56E899E16D58 mfct specific
"media":"water",
"meter":"izar",
"name":"",
"id":"414fcc2a",
"last_month_total_m3":218.684,
"remaining_battery_life_y":10,
"total_m3":219.414,
"transmit_period_s":8,
"current_alarms":"underflow",
"last_month_measure_date":"2023-12-31",
"manufacture_year":"2022",
"prefix":"C22SB",
"previous_alarms":"no_alarm",
"serial_number":"006826",
"timestamp":"2024-01-03T08:35:28Z"
[email protected]
piotrekk wrote: Wed Jan 03, 2024 8:51 am
Auto driver : izar
"media":"water",
"meter":"izar",
"name":"",
"id":"414fcc2a",
"total_m3":219.414,
"prefix":"C22SB",
Wygląda na to że licznik wysyła różne ramki.
Jako sensor ID wpisz: 414FCC2A, klucz zostaw pusty.
W zasadzie powinno zadziałać samo z siebie jak nie podasz ID, a podasz typ licznika
Return to “GUI Generic”
