A da się by wyświetlało inne parametry jak w sofcie wyżej ?bo w tym jest tak
Can other parameters like in the software above be displayed? Because that's how it is
Gniazdko Neo Coolcam z pomiarem energii
Nowy11
elmaya
What device do you have and what did you upload?
Nowy11
gosund sp111
Sprawdzałem też na 100w zarówce
Testowo wygrałem soft BlizWolf_BW-SHP6_15A_LittleFS_DOUT_8Mbit.rar z tego wątku i działa
gosund sp111
I also checked 100w a light bulb
I won soft as a test
gosund sp111
elmaya
currently there are 4 different versions of "gosund sp111" and the 15A version is compatible with "BlizWolf_BW-SHP6_15A"
@elmaya usted ayudará.elmaya wrote: Tue Nov 10, 2020 3:24 pm for Gosund SP111
To access the Wi-Fi configuration, press button for at least 10 seconds, Led winks in wificonfig.Code: Select all
/* Copyright (C) AC SOFTWARE SP. Z O.O. This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program; if not, write to the Free Software Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. */ #include "LittleFS.h" // LittleFS is declared #include <SuplaDevice.h> #include <supla/sensor/one_phase_electricity_meter.h> #include <supla/control/relay.h> #include <WiFiManager.h> #include <ArduinoJson.h> //--------- V6 ------ #include <EEPROM.h> #include <ESP8266WebServer.h> #include <ESP8266HTTPUpdateServer.h> #include <Ticker.h> //for LED status #include <ESP8266TrueRandom.h> #include <HLW8012.h> extern "C" { #include "user_interface.h" } //#define D0 16 //no internal pullup resistor //#define D1 5 //#define D2 4 //#define D3 0 //must not be pulled low during power on/reset, toggles value during boot //#define D4 2 //must not be pulled low during power on/reset, toggles value during boot //#define D5 14 //#define D6 12 //#define D7 13 //#define D8 15 //must not be pulled high during power on/reset #define SEL_PIN 12 #define CF1_PIN 14 #define CF_PIN 5 #define status_led 0 int wificonfig_pin = 13; int relay_pin = 15; int C_W_state = HIGH; int last_C_W_state = HIGH; unsigned long time_last_C_W_change = 0; long C_W_delay = 10000; // config delay 10 seconds int C_W_state2 = HIGH; long C_W_delay2 = 100; unsigned long eep_milis = 10000; bool recover = true; char Supla_server[81]=("Set server address"); char Email[81]=("set email address"); char Supla_name[51]; char Supla_status[51]; char Volt[8]; char Wats[8]; byte mac[6]; bool shouldSaveConfig = false; bool initialConfig = false; int s = 0; bool starting = true; bool Tik = true; unsigned long mem_energy_milis = 3000000; float mem_energy = 0; float _mem_energy = 0; int customFieldLength = 40; WiFiManagerParameter custom_field; // global param ( for non blocking w params ) char GUID[SUPLA_GUID_SIZE]; char AUTHKEY[SUPLA_AUTHKEY_SIZE]; byte uuidNumber[16]; // UUIDs in binary form are 16 bytes long static const char custom_radio_str[] PROGMEM = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>Counter mem</label><input type='radio' name='customfieldid' value='0' checked>keep Storage<input type='radio' name='customfieldid' value='1'>clear Storage</div>"; ESP8266WebServer httpServer(81); ESP8266HTTPUpdateServer httpUpdater; WiFiManager wifiManager; Ticker ticker; #include <supla/network/esp_wifi.h> Supla::ESPWifi wifi("", ""); //------ Do not change----wifimanager takes care------ Supla::Control::Relay *relay1 = nullptr; #define CURRENT_MODE LOW #define HJL01_CURRENT_RATIO 25740 #define HJL01_VOLTAGE_RATIO 313400 #define HJL01_POWER_RATIO 3414290 HLW8012 hjl01; class Hj101 : public Supla::Sensor::OnePhaseElectricityMeter { public: Hj101() { } void onInit() { readValuesFromDevice(); updateChannelValues(); } virtual void readValuesFromDevice() { unsigned int _reactive = 0; double _pf = 0; double _current = hjl01.getCurrent(); unsigned int _voltage = hjl01.getVoltage(); unsigned int _active = hjl01.getActivePower(); unsigned int _apparent = _voltage * _current; if (_apparent > _active) {_reactive = sqrt(_apparent * _apparent - _active * _active); } else {_reactive = 0;} if (_active > _apparent){ _pf = 1;} if (_apparent == 0){ _pf = 0;}else{ _pf = (double) _active / _apparent;} // voltage in 0.01 V setVoltage(0,_voltage * 100); // current in 0.001 A setCurrent(0, _current * 1000); // power in 0.00001 kW setPowerActive(0, _active * 100000); // energy in 0.00001 kWh setFwdActEnergy(0, ((float)hjl01.getEnergy() + mem_energy) / 6 / 6 ); // power in 0.00001 kVA setPowerApparent(0, _apparent * 100000); // power in 0.00001 kvar setPowerReactive(0, _reactive * 100000); // power in 0.001 setPowerFactor(0, _pf * 1000); } }; void tick() { int state = digitalRead(status_led); digitalWrite(status_led, !state); } void ICACHE_RAM_ATTR hjl01_cf1_interrupt() { hjl01.cf1_interrupt(); } void ICACHE_RAM_ATTR hjl01_cf_interrupt() { hjl01.cf_interrupt(); } void calibrate_hj101() { int ex_volt = atoi(Volt); int ex_pow = atoi(Wats); double ex_amps = ((float)ex_pow / (float)ex_volt); Serial.print("volt:"); Serial.println(ex_volt); Serial.print("wats:"); Serial.println(ex_pow); Serial.print("amps:"); Serial.println(ex_amps); digitalWrite(relay_pin,HIGH); Serial.println("Relay On:"); unsigned long timeout1 = millis(); while ((millis() - timeout1) < 10000) { delay(10);} hjl01.expectedActivePower(ex_pow); hjl01.expectedVoltage(ex_volt); hjl01.expectedCurrent(ex_amps); unsigned long timeout2 = millis(); while ((millis() - timeout2) < 2000) {delay(10);} double current_multi = hjl01.getCurrentMultiplier(); double voltage_multi = hjl01.getVoltageMultiplier(); double power_multi = hjl01.getPowerMultiplier(); Serial.print("[HLW] New current multiplier : "); Serial.println(current_multi); Serial.print("[HLW] New voltage multiplier : "); Serial.println(voltage_multi); Serial.print("[HLW] New power multiplier : "); Serial.println(power_multi); EEPROM.put(400, current_multi); EEPROM.put(410, voltage_multi); EEPROM.put(420, power_multi); EEPROM.write(430, 60); EEPROM.commit(); yield(); } void get_hj101_config(){ if (EEPROM.read(430) == 60){ Serial.println("get eep multiplier "); double p_m;double v_m;double c_m; EEPROM.get(400,c_m); EEPROM.get(410,v_m); EEPROM.get(420,p_m); hjl01.setCurrentMultiplier(c_m); hjl01.setVoltageMultiplier(v_m); hjl01.setPowerMultiplier(p_m); } } void saveConfigCallback () { Serial.println("Should save config"); shouldSaveConfig = true; } void ondemandwifiCallback () { ticker.attach(1.5, tick); WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 81,"required"); WiFiManagerParameter custom_Email("email", "Email", Email, 81,"required"); WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required"); WiFiManagerParameter custom_Supla_status("status", "Supla Last State", Supla_status, 51,"readonly"); WiFiManagerParameter custom_Volt("Volt", "expectedVoltage", Volt, 8); WiFiManagerParameter custom_Wats("Wats", "expectedActivePower", Wats, 8); new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input wifiManager.setBreakAfterConfig(true); wifiManager.setSaveConfigCallback(saveConfigCallback); wifiManager.setSaveParamsCallback(saveParamCallback); wifiManager.addParameter(&custom_Supla_server); wifiManager.addParameter(&custom_Email); wifiManager.addParameter(&custom_Supla_name); wifiManager.addParameter(&custom_Supla_status); wifiManager.addParameter(&custom_Volt); wifiManager.addParameter(&custom_Wats); wifiManager.addParameter(&custom_field); wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>"); wifiManager.setMinimumSignalQuality(8); //wifiManager.setShowStaticFields(true); // force show static ip fields //wifiManager.setShowDnsFields(true); // force show dns field always wifiManager.setConfigPortalTimeout(180); if (!wifiManager.startConfigPortal("Gosund_SP111")) { Serial.println("Not connected to WiFi but continuing anyway.");} else { Serial.println("connected...yeey :)");} strcpy(Supla_server, custom_Supla_server.getValue()); strcpy(Email, custom_Email.getValue()); strcpy(Supla_name, custom_Supla_name.getValue()); strcpy(Volt, custom_Volt.getValue()); strcpy(Wats, custom_Wats.getValue()); if(strcmp(Supla_server, "get_new_guid_and_authkey") == 0){ Serial.println("new guid & authkey."); EEPROM.write(300, 0); EEPROM.commit(); ESP.reset(); } if ((strlen(Volt) != 0) && (strlen(Wats) != 0)){ calibrate_hj101(); } WiFi.softAPdisconnect(true); // close AP } void status_func(int status, const char *msg) { // ------------------------ Status -------------------------- if (s != status){ s = status; if (s != 10){ strcpy(Supla_status, msg); Serial.print("Status: ");Serial.print(s);Serial.print(" ");Serial.println(Supla_status); } } } String getParam(String name){ String value; if(wifiManager.server->hasArg(name)) { value = wifiManager.server->arg(name); if (value == "1"){ float cler = 0.0; EEPROM.put(460, cler); EEPROM.commit(); Serial.println("clearStorage"); } } return value; } void saveParamCallback(){ Serial.println("[CALLBACK] saveParamCallback fired"); Serial.println("PARAM customfieldid = " + getParam("customfieldid")); } void Eeprom_save(){ if (digitalRead(relay_pin)!= EEPROM.read(431)){ _mem_energy = (double)hjl01.getEnergy() + mem_energy; EEPROM.put(460, _mem_energy); EEPROM.write(431,digitalRead(relay_pin)); EEPROM.commit(); Serial.println("mem relay + energy"); } } void guid_authkey(void) { if (EEPROM.read(300) != 60){ int eep_gui = 301; ESP8266TrueRandom.uuid(uuidNumber); String uuidString = ""; for (int i = 0; i < 16; i++) { int topDigit = uuidNumber[i] >> 4; int bottomDigit = uuidNumber[i] & 0x0f; uuidString += "0123456789abcdef"[topDigit]; uuidString += "0123456789abcdef"[bottomDigit]; } int length_uuid = uuidString.length(); for (int i = 0; i < length_uuid; ++i) { EEPROM.put(eep_gui + i, uuidString[i]); } int eep_aut = 341; ESP8266TrueRandom.uuid(uuidNumber); String uuidString2 = ""; for (int i = 0; i < 16; i++) { int topDigit = uuidNumber[i] >> 4; int bottomDigit = uuidNumber[i] & 0x0f; uuidString2 += "0123456789abcdef"[topDigit]; uuidString2 += "0123456789abcdef"[bottomDigit]; } int length_uuid2 = uuidString2.length(); for (int i = 0; i < length_uuid2; ++i) { EEPROM.put(eep_aut + i, uuidString2[i]); } float cler = 0.0; EEPROM.put(460, cler); EEPROM.write(300, 60); EEPROM.commit(); } read_guid(); read_authkey(); Serial.print("GUID : ");Serial.println(read_guid()); Serial.print("AUTHKEY : ");Serial.println(read_authkey()); } String read_guid(void) { String read_eeprom = ""; int i, ii = 0; int eep_star = 301; int end_guid = eep_star + SUPLA_GUID_SIZE; String temp_read = "0x"; for (i = eep_star; i < end_guid + 16; i = i + 1) { temp_read += char(EEPROM.read(i)); read_eeprom += char(EEPROM.read(i)); if ( (i % 2) == 0) { char *_guid = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str()); GUID[ii] = strtoul( _guid, NULL, 16); temp_read = "0x"; ii++; } } return read_eeprom; } String read_authkey(void) { String read_eeprom = ""; int i, ii = 0; int eep_star = 341; int end_authkey = eep_star + SUPLA_AUTHKEY_SIZE; String temp_read = "0x"; for (i = eep_star; i < end_authkey + 16; i = i + 1) { temp_read += char(EEPROM.read(i)); read_eeprom += char(EEPROM.read(i)); if ( (i % 2) == 0) { char *_authkey = strcpy((char*)malloc(temp_read.length() + 1), temp_read.c_str()); AUTHKEY[ii] = strtoul( _authkey, NULL, 16); temp_read = "0x"; ii++; } } return read_eeprom; } void setup() { wifi_set_sleep_type(NONE_SLEEP_T); Serial.begin(115200); Serial.println(); EEPROM.begin(1024); pinMode(wificonfig_pin, INPUT_PULLUP); pinMode(status_led,OUTPUT); digitalWrite(relay_pin, EEPROM.read(431)); guid_authkey(); ticker.attach(0.5, tick); if (WiFi.SSID()==""){ initialConfig = true;} if (LittleFS.begin()) { // ------------------------- wificonfig read ----------------- Serial.println("mounted file system"); if (LittleFS.exists("/config.json")) { Serial.println("reading config file"); File configFile = LittleFS.open("/config.json", "r"); if (configFile) { Serial.println("opened config file"); size_t size = configFile.size(); std::unique_ptr<char[]> buf(new char[size]); configFile.readBytes(buf.get(), size); DynamicJsonDocument json(1024); DeserializationError deserializeError = deserializeJson(json, buf.get()); serializeJsonPretty(json, Serial); if (!deserializeError) {Serial.println("\nparsed json"); if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]); if (json.containsKey("Email")) strcpy(Email, json["Email"]); if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]); } else { Serial.println("failed to load json config"); initialConfig = true; } configFile.close(); } } } else { Serial.println("failed to mount FS"); } wifi_station_set_hostname(Supla_name); hjl01.setCurrentMultiplier(HJL01_CURRENT_RATIO); hjl01.setVoltageMultiplier(HJL01_VOLTAGE_RATIO); hjl01.setPowerMultiplier(HJL01_POWER_RATIO); // void begin(unsigned char cf_pin, unsigned char cf1_pin, unsigned char sel_pin, unsigned char currentWhen = HIGH, bool use_interrupts = false, unsigned long pulse_timeout = PULSE_TIMEOUT); hjl01.begin(CF_PIN, CF1_PIN, SEL_PIN, CURRENT_MODE, true); get_hj101_config(); attachInterrupt(CF1_PIN, hjl01_cf1_interrupt, FALLING); attachInterrupt(CF_PIN, hjl01_cf_interrupt, FALLING); EEPROM.get(460, mem_energy); _mem_energy = mem_energy; Serial.print("mem energy: "); Serial.println(mem_energy); relay1 = new Supla::Control::Relay(relay_pin); new Hj101(); SuplaDevice.setName(Supla_name); SuplaDevice.setStatusFuncImpl(&status_func); wifi.enableSSL(false); SuplaDevice.begin(GUID,Supla_server,Email,AUTHKEY); } char buffer[50]; void loop() { if (initialConfig == true){ondemandwifiCallback();EEPROM.write(431, 0); EEPROM.commit();} int C_W_read = digitalRead(wificonfig_pin);{ if (C_W_read != last_C_W_state) { time_last_C_W_change = millis(); } if ((millis() - time_last_C_W_change) > C_W_delay2) { if (C_W_read != C_W_state2) { C_W_state2 = C_W_read; if (C_W_state2 == LOW) { Serial.println("short press"); if (!relay1->isOn()) { relay1->turnOn(); yield(); Serial.println("relayOn"); Eeprom_save() ; }else{ relay1->turnOff(); yield(); Serial.println("relayOff"); Eeprom_save() ; }}} } if ((millis() - time_last_C_W_change) > C_W_delay) { if (C_W_read != C_W_state) { Serial.println("long press"); C_W_state = C_W_read; if (C_W_state == LOW) { ondemandwifiCallback () ; } } } last_C_W_state = C_W_read; } if (shouldSaveConfig == true) { // ------------------------ wificonfig save -------------- Serial.println(" config..."); DynamicJsonDocument json(1024); json["Supla_server"] = Supla_server; json["Email"] = Email; json["Supla_name"] = Supla_name; File configFile = LittleFS.open("/config.json", "w"); if (!configFile) { Serial.println("failed to open config file for writing"); } serializeJsonPretty(json, Serial); serializeJson(json, configFile); configFile.close(); Serial.println("Config written successfully"); shouldSaveConfig = false; initialConfig = false; WiFi.mode(WIFI_STA); delay(5000); ESP.restart(); } if (s == 17){ if ((Tik == true) && (WiFi.status() == WL_CONNECTED)){ticker.detach();Tik = false;} if(millis() > eep_milis){ Eeprom_save() ; eep_milis = millis() + 3000 ; } if (recover){ Serial.println("ticker off"); if (EEPROM.read(431) == true){ relay1->turnOn(); yield(); Serial.println("relayOn"); eep_milis = millis() + 3000 ; } recover = false; } } if ((s != 17) && (Tik == false)) { ticker.attach(0.5, tick);Tik = true;Serial.println("ticker on no 17"); } //if ((WiFi.status() != WL_CONNECTED) && (Tik == false)){ticker.attach(0.5, tick);Tik = true;Serial.println("ticker on no wifi"); } if (s == 10){recover = true;} SuplaDevice.iterate(); delay(50); if (WiFi.status() == WL_CONNECTED){ if (starting){ httpUpdater.setup(&httpServer, "/update", "admin", "pass"); httpServer.begin(); starting = false; } httpServer.handleClient(); if ((digitalRead(relay_pin) == digitalRead(status_led)) && (s ==17)){ digitalWrite(status_led,!digitalRead(relay_pin)); } } if(millis() > mem_energy_milis){ if ((float(hjl01.getEnergy()) + mem_energy > _mem_energy) && (digitalRead(relay_pin) == HIGH)){ Serial.println("save energy"); _mem_energy = (float)hjl01.getEnergy() + mem_energy; EEPROM.put(460, _mem_energy); EEPROM.commit(); mem_energy_milis = millis() + 600000 ; } } }
in the configuration page enter the data for "suplaServer, Email and Supla Device Name (name with which it will be seen in the cloud and DHCP)"
expectedVoltage = for calibration.
expectedActivePower = for calibration.
clear Storage = reset counter.
calibration process:
connect a resistive load with a known consumption, for example a 60W bulb.
access wificonfig (button pressed 10 seconds)
in the "expectedVoltage" field set the voltage of your line for example 227.
in the "expectedActivePower" field, set the consumption of the connected load, for example 60.
press save.
The procedure takes about 15 seconds, then the device restarts and the readings will be correct.
the calibration is only executed if there are data in both fields "expectedVoltage" and "expectedActivePower"
This allows for example to change the Wi-Fi network without recalibrating.
Gosund_SP111_DOUT_8Mbit.rar
elmaya
Budek
- Has thanked: 1 time
Witaj Elmaya.elmaya wrote: Tue Nov 10, 2020 3:24 pm for Gosund SP111
press save.
Wgralem twój soft do gniazdka.
Czy jest w nim OTA ? i jeżeli tak, to jak się do niego dostać ?
/Budek
elmaya
http: // XX: 81/update where xx = device ip. "for example http : //192.168.1.22:81/update"
user: admin
password: pass
user: admin
password: pass
Funciona.elmaya wrote: Sun Nov 29, 2020 8:25 pm I think it was this.
https://github.com/tzapu/WiFiManager/tree/development
Gracias.
¿Es este código fuente el mismo para:
"BlizWolf_BW-SHP6_15A_LittleFS_DOUT_8Mbit.rar"
En lugar gpio14 - gpio4 ???
Mi ""Gosund sp111 v1.1" es como "BlizWolf_BW-SHP6_15A"
