SUPLA Filesensors - wyślij do SUPLI cokolwiek skądkolwiek
PuteR
lesny8 wrote: Sun Feb 16, 2020 11:30 pm A powinieneś dostać wewnętrzny adres. Pokaż
ifconfig eth0
ifconfig wlan0
cat /etc/resolv.conf
pi@raspberrypi:~ $ ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.81 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::17e9:648:f21d:d6d prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:b6:ef:dd txqueuelen 1000 (Ethernet)
RX packets 1726859 bytes 229690634 (219.0 MiB)
RX errors 24 dropped 11186 overruns 0 frame 0
TX packets 1343461 bytes 219173782 (209.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
pi@raspberrypi:~ $ ifconfig wlan0
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:e3:ba:88 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
nameserver 192.168.1.1
pi@raspberrypi:~ $
Been thanked: 9 times
Wyedytuj plik
sudo nano /etc/resolv.conf
zamiast 192.168.1.1 wpisz 192.168.1.81 i zapisz zmiany
ping suplascripts73.noip.pl
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Sun Feb 16, 2020 11:37 pm Wyedytuj plik
teraz jest tak:
pi@raspberrypi:~ $ ping suplascripts73.noip.pl
PING supla.noip.pl (192.168.1.81) 56(84) bytes of data.
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=1 ttl=64 time=0.157 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=2 ttl=64 time=0.175 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=3 ttl=64 time=0.079 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=4 ttl=64 time=0.162 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=5 ttl=64 time=0.112 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=6 ttl=64 time=0.112 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=7 ttl=64 time=0.135 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=8 ttl=64 time=0.115 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=9 ttl=64 time=0.165 ms
64 bytes from 192.168.1.81 (192.168.1.81): icmp_seq=10 ttl=64 time=0.161 ms
Połowa sukcesu, linki z mojej instancji skryptów się już wykonują (lesny8 jak zawsze nie zawodny), niestety wpisane jako komendę w suplafilesensors nie wykonuje się.
To sprawdź czy SUPLA Filesensors działa poprawnie z Twoją instancją tak jak z publiczną
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Sun Feb 16, 2020 11:46 pm To sprawdź czy SUPLA Filesensors działa poprawnie z Twoją instancją tak jak z publiczną
w konsoli linki się wykonują ale juz jak wpiszę w fileasensors i użyję aplikacji to nic się nie dzieje zarówno z moją instancją jak i z publiczną :(
fracz wrote: Sun Feb 16, 2020 10:22 pm Mogę ewentualnie dodać do skryptów możliwość uruchamiania scen komendą z konsoli. Bo rozumiem że skrypty masz na tej samej malinie?
Jeśli nie ma już innych możliwości to może tego spróbować
fracz wrote: Sun Feb 16, 2020 9:42 pm Pierwszy problem: wygląda na to że Twoja malina nie ma dostępu z jakiegoś powodu do Twoich skryptów. Spróbuj wykonać curl na główny adres i porównaj, czy odpowiedź jest taka sama jak z https://supla.fracz.com
Drugi problem: jak działa z konsoli to z configu też musi. Coś źle wklejasz :-)
Pierwszy problem rozwiązany. Nie działało Ci w konsoli z powodu rozwiązywania nazwy przez Funboxa, który to nie wspiera lopbacka, a RPi jest jedynym urządzeniem skonfigurowanym statycznie. O zmnianie DNS swego czasu zapomnieliśmy ;)
Drugi problem to już jak @fracz napisał, że jak z konsoli działa to z configu też musi.
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Mon Feb 17, 2020 12:23 am
Więc czemu nie działa, przecież nie robię nic innego poza kopiuj i wklej?
A czy winny może być sam telefon? Łączę się na nim z siecią wifi poprzez ręcznie wpisany adres IP i adres DNS wskazujący na maline (inaczej z telefonu nie wszedł bym na stronę cloud i skrypty) Czy może to być problemem? Chociaż jak na próbę połączyłem się z inną siecią po dhcp było tak samo.
fracz
Has thanked: 4 times
Been thanked: 6 times
fracz wrote: Sun Feb 16, 2020 10:53 pm A zrób tak żeby nie było tych innych błędów? ;-)
Skup sie na tym. Możliwe że przez wcześniejsze złe wpisy w pliku konfiguracyjnym ten z komendą nie działa.
PuteR
fracz w tej chwili log wygląda tak
pi@raspberrypi:~ $ supervisorctl tail supla-filesensors
NSORS v2.0.0-beta.3
ERR[1581910204.530340] Can't bind ipc socket
INFO[1581910204.531209] SSL version: OpenSSL 1.1.0j  20 Nov 2018
SUPLA-FILESENSORS v2.0.0-beta.3
ERR[1581912004.765662] Can't bind ipc socket
INFO[1581912004.766731] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581913804.444722] Can't bind ipc socket
INFO[1581913804.445598] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581915604.683029] Can't bind ipc socket
INFO[1581915604.683898] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581917404.833592] Can't bind ipc socket
INFO[1581917404.834517] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581919204.948311] Can't bind ipc socket
INFO[1581919204.949172] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581921004.552942] Can't bind ipc socket
INFO[1581921004.553874] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581921378.292492] Can't bind ipc socket
INFO[1581921378.293609] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581922804.657177] Can't bind ipc socket
ERR[1581922804.657542] Can't read file /home/pi/supla-filesensors/var/openwather/wind_speed.txt
INFO[1581922804.658059] SSL version: OpenSSL 1.1.0j  20 Nov 2018
ERR[1581924604.853632] Can't bind ipc socket
ERR[1581924604.854037] Can't read file /home/pi/supla-filesensors/var/openwather/wind_speed.txt
INFO[1581924604.854573] SSL version: OpenSSL 1.1.0j  20 Nov 2018
Nie mam pojęcia z czego mogą brać się te błędy, wszystkie dane o które wołam w aplikacji wyświetlają się prawidłowo.
Mój plik konfiguracyjny wygląda tak, trochę się kanałów już tam namnożyło, ale wszystkie działają poprawnie, po za tymi dwoma REALY
[SERVER]
host=xxxxxxx
[LOCATION]
ID=xxxxxxx
PASSWORD=xxxxxx
[CHANNEL_0] #Alarm otwarty zaobnik UŻYWANY NIEWIDOCZNY
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/piec/alarm_otw_zasob.txt
[CHANNEL_1] #temperatura powrotu UŻYANY NIEWIDOCZNY
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/piec/alarm_zasobnik.txt
[CHANNEL_2] #WYŁĄCZONY
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/pogoda/caqi.txt
[CHANNEL_3] #temperatura wody użytkowej
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/piec/tcwu_value.txt
[CHANNEL_4] #temperatura zewnętrzna
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/piec/tzew_act.txt
[CHANNEL_5] #poziom paliwa w zasobniku
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/piec/fuel_level.txt
[ChANNEL_6] #WYŁĄCZONY
type=TEMPERATURE
file=/home/pi/supla-filesensors/var/pogoda/PM10.txt
[CHANNEL_7] #temperatura kotła i powrotu
type=TEMPERATURE_AND_HUMIDITY
file=/home/pi/supla-filesensors/var/piec/tkot&tpow.txt
[CHANNEL_8] #temperatura podajnika i splain
file=/home/pi/supla-filesensors/var/piec/tpod&tsp.txt
[CHANNEL_9] #temperatura zewnętrzna i wewnętrzna
file=/home/pi/supla-filesensors/var/piec/temp_wew&zew.txt
[CHANNEL_10] #temperatura za zaworem 4d i zadana za zanorem4d
file=/home/pi/supla-filesensors/var/piec/temp_zaw4d.txt
[CHANNEL_11] #prędkośc wiatru Kolno
type=WINDSENSOR
file=/home/pi/supla-filesensors/var/openwather/wind_speed.txt
[CHANNEL_12] #PM1 i CAQI
file=/home/pi/supla-filesensors/var/pogoda/PM1&caqi.txt
[CHANNEL_13] #PM10 i PM25
file=/home/pi/supla-filesensors/var/pogoda/PM10&PM25.txt
[CHANNEL_14] #temperatura i wilgotność
file=/home/pi/supla-filesensors/var/pogoda/temp&wilg.txt
[CHANNEL_15] #cisnienie
type=PRESSURESENSOR
file=/home/pi/supla-filesensors/var/pogoda/cisnienie.txt
[CHANNEL_16]
type=RELAY
command=curl https://suplascripts73.noip.pl/api/scenes/execute/1d098367-a1b4-486e-ba59-1c605b35576a -X GET -m 10000 -H "Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJjbGllbnQiOnsiaWQiOiJmNjVkYjgxZC03NWE5LTQwYjMtYjlkYS1kYWM0MDBkZDgxNDQifSwiaXNzIjoiaHR0cHM6XC9cL3N1cGxhLmZyYWN6LmNvbSIsImlhdCI6MTU4MTg5NjUxNCwibmJmIjoxNTgxODk2NTE0LCJleHAiOjE3Mzk1NzY1MTR9.KCKgd9n8CF3M4IENn2uJqTg6d7vcaRApecrkXlnGunE"
[CHANNEL_17] #temperatura i wilgotność
file=/home/pi/supla-filesensors/var/piec/twew&rh.txt
[CHANNEL_18]
type=RELAY
command= echo puter > /home/pi/supla-filesensors/puter.txt
min_interval_sec=15
# this is a comment
michael
Tak mi się teraz wymyśliło...
może odświeżyć temat głowicy eq-3.
W tej chwili jeżeli możemy pobrać różne dane do plików to i termostat można fajnie rozwinąć :D 8-) :mrgreen:
Przykładowe linki do źródeł gdzie rozpracowana jest ta głowica:
- https://github.com/Heckie75/eQ-3-radiator-thermostat
- https://github.com/zmistrz/eq3-bluetooth
:mrgreen: :mrgreen: :mrgreen:
